Results 1 to 6 of 6
Thread: Kinetis KE1xF
    Junior Member Blake.Volpex's Avatar
    Mar 2019
    Ontario Canada
    3
    Kinetis KE1xF
    I'm looking to port an Arduino project to an arm chip.
    It has bean successfully run on the Teensy 3.5 but 3.3v is not ideal (all the sensors are 5v, so analog read accuracy suffers).
    There are ways around that (5v ADC likely being the best), but there are 5v arm chips avalible.
    Would it be possible to get Bootloader Chips that are compatible with the MKE16F256VLH16 ?
    I can make the Teensy 3.5/3.6 work but as I was planning to make my own custom boards and buy bootlouder chips anyway I figured it was worth asking.
    Thanks.
    20,064
    Nope, that chip isn't supported.
    Mar 2019
    Ontario Canada
    3
    I figured it wasn't supported, I was more looking to see what it would take to add support.
    As I don't know how much work it would take, and how much you'd charge for your time.
    20,064
    Even if it were possible, PJRC would not do this, because we're working on Teensy 4 beta right now!
    But since this chip lacks USB, it's just not possible.
    Mar 2019
    Ontario Canada
    3
    Hmm, I had just figured on an FTDI chip (or similar).
    Okay, I'll look into other options.
    Senior Member xxxajk's Avatar
    Nov 2013
    Buffalo, NY USA
    523
    I program mine using a Teensy 3.x via CAN. it's FAST!!!
