I'm working on part 3-1 and I get this error message when I run Serial Monitor on the IDE.
Board at usb:0/1D0000/0/1/4 is not available
Here is the sketch:
// Advanced Microcontroller-based Audio Workshop
// http://www.pjrc.com/store/audio_tutorial_kit.html
// https://hackaday.io/project/8292-mic...-supercon-2015
// Part 3-1: Peak Detection
// copy the Design Tool code here
#include <SerialFlash.h>
AudioPlaySdWav playSdWav1; //xy=168,123
AudioAnalyzePeak peak1; //xy=343,188
AudioAnalyzePeak peak2; //xy=368,252
AudioOutputI2S i2s1; //xy=500.00000762939453,110.0000057220459
AudioConnection patchCord1(playSdWav1, 0, peak1, 0);
AudioConnection patchCord2(playSdWav1, 0, i2s1, 0);
AudioConnection patchCord3(playSdWav1, 1, peak2, 0);
AudioConnection patchCord4(playSdWav1, 1, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=220,377.0000047683716
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
// Use these with the Teensy 3.5 & 3.6 SD card
//#define SDCARD_CS_PIN BUILTIN_SDCARD
//#define SDCARD_MOSI_PIN 11 // not actually used
//#define SDCARD_SCK_PIN 13 // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN 4
AudioMemory(10);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
// for best effect make your terminal/monitor a minimum of 62 chars wide and as high as you can.
elapsedMillis msecs;
if (playSdWav1.isPlaying() == false) {
Serial.println("Start playing");
//playSdWav1.play("SDTEST1.WAV");
playSdWav1.play("SDTEST2.WAV");
//playSdWav1.play("SDTEST3.WAV");
//playSdWav1.play("SDTEST4.WAV");
delay(10); // wait for library to parse WAV info
if (msecs > 40) {
if (peak1.available() && peak2.available()) {
msecs = 0;
float leftNumber = peak1.read();
float rightNumber = peak2.read();
int leftPeak = leftNumber * 30.0;
int rightPeak = rightNumber * 30.0;
int count;
for (count=0; count < 30-leftPeak; count++) {
Serial.print(" ");
while (count++ < 30) {
Serial.print("<");
Serial.print("||");
for (count=0; count < rightPeak; count++) {
Serial.print(">");
Serial.print(" ");
Serial.print(leftNumber);
Serial.print(", ");
Serial.print(rightNumber);
What have I done wrong, how do I fix it?
