Results 1 to 10 of 10
Thread: Audio Out - amplifier for headphone and speakers?
    Germany NRW
    6,589
    I need a simple headphone/speaker output - Input via SPDIF(best), DACs, or I2S. It should be a small(!), not expensive "breakout"-module or easy to solder (SOIC/DIL) chip, Voltage 5V.
    Best would be 2 channel/stereo.. mono is OK, too.. for speakers perhaps something like 1-3 watts.. (+ loud enough for cheap smartphone headphones)
    Are there any recommendations?
    6,367
    I have played around with some Mono chips on some of my boards that hook up to a DAC, which maybe don't have enough power for your needs. I think this one (LM4862) is something like .8watts
    I think there are others in this class like LM4871 that output up to 3w.
    Germany NRW
    6,589
    Hm.. heaphones have a common ground - can I use this chip for headphones?
    6,367
    Sorry Frank, I have no idea... Hopefully someone who is more of an EE type can give you some better solutions... I was a CS type person whose last EE class was over 35 years ago. I have mainly used these chips on the board with a small speaker also on the board. Something like a: AST-01508MR-R
    Germany NRW
    6,589
    A single-chip solution seems to be a gap in the market...
    TDA1308 is OK for headphones (cheap breakouts on eBay)
    Banned
    Jan 2019
    Australia
    16
    LM4862 is bridge output so not a good candidate for headphones.
    TDA2822, 8-pin Dip useful for headphone driver.
    What about Silicon Labs 16- pin SOIC, Si3000 ?
    Germany NRW
    6,589
    Wow.. the Si3000 looks good 12Khz max - not "HiFi", but OK for my use-case. And it seems it can drive both, a small speaker and headphones. Available in Germany..perfect..Great, thank you!
    Senior Member DD4WH's Avatar
    Oct 2015
    Central Europe
    556
    Hi Frank,
    not quite sure what you want . . .
    Maybe this:
    https://www.maximintegrated.com/en/p...o/MAX9879.html
    The problem with class A/B amps is that you need quite big output caps (in the range of several 100s F), that makes those amps BIG.
    Class D amps do not need this. (But most are in packages not easy to solder by hand).
    The Si3000 is a codec with a built-in amp, but only handles voice/speech (12ksps sample rate restricts your frequency response to < 5kHz, the specs say 300-3400kHz, so this is telephone quality or lower . . .).
    BTW, I recently found this schematic to add headphones to a class D speaker amp, but I have not tried it out!!!
    https://www.edn.com/design/analog/43...ss-D-amplifier
    Maybe a class D speaker amp IC together with that circuit suits your needs of a stereo speaker amp with the possibility to insert standard headphones with common ground?
    All the best,
    Frank DD4WH
    Oct 2015
    Central Europe
    556
    Frank, have a look at the TPA6011 and the schematic on page 16 of the datasheet
    http://www.ti.com/lit/ds/symlink/tpa6011a4.pdf
    Dec 2016
    110
    Hi Frank,
    Maybe this:
    All the best,
    Frank DD4WH
    Any precautions when using a class D mono amp (1-3watt) to drive 1 side off a headphone?
    Alain
