Results 1 to 4 of 4
Thread: Sending MIDI over USB
    Hi all,
    I try to send MIDI over the USB port of a Teensy-3.6. I use the following simple test script:
    #include <MIDI.h>
    #include <midi_UsbTransport.h>
    static const unsigned sUsbTransportBufferSize = 16;
    typedef midi::UsbTransport<sUsbTransportBufferSize> UsbTransport;
    UsbTransport sUsbTransport;
    MIDI_CREATE_INSTANCE(UsbTransport, sUsbTransport, MIDI);
      MIDI.begin();
      Serial.println("Arduino ready.");
      Serial.println("*");
      MIDI.sendNoteOn(68, 100, 1);
      MIDI.sendNoteOff(68, 100, 1);
    On Linux I am searching for the alsa MIDI port like this:
    $ amidi -l
    Dir Device    Name
    IO  hw:1,0,0  Teensy MIDI MIDI 1
    So I have my Teemsy on port hw:1,0,0 and started a simple test to see if there are note-on/note-offs:
    $ amidi -p hw:1,0,0 -d
    But nothing happens... there are no MIDI events.
    Has anybody an idea what I am doing wrong?
    TIA, Holger
    19,929
    Maybe try the examples? In Arduino, click File > Examples > Teensy > USB_MIDI.
    See this page for details.
    https://www.pjrc.com/teensy/td_midi.html
    Do it this way first. Even if you *really* want to use that other MIDI stuff, use the simple known-working way first.
    1,069
    I tried your code on Windows 10 on a T3.6 compiled as type "Serial + MIDI". It doesn't work - MidiOx doesn't see anything.
    Then I removed all of the headers - everything before the setup function and changed MIDI. to usbMIDI. so that I ended up with this:
      while(!Serial);
      usbMIDI.begin();
      Serial.println("Teensy ready.");
      usbMIDI.sendNoteOn(68, 100, 1);
      usbMIDI.sendNoteOff(68, 100, 1);
    Works.
    Pete
    Hi Paul,
    hi Pete,
    Thank you so much for your help. I made a very simple mistake: I didn't use the Teensy example as a template, but one from the MIDI_Library. After I did it the way @Pete described it and looked at the examples from the Teensy area, it worked.
    Thanks again!
    Holger
