I want to use the teensy 3.6 in a high(ish) vibration environment, so I think it would probably be a good idea to disable the programming button. I saw somewhere on the forum that you could remove the button, however I was wondering if I could simply cut the track that seems to go from the button to the pin next to it marked GND?
I don't know if that track is used for anything else.
Or perhaps there is an even easier way?
