Results 1 to 6 of 6
Thread: A simple Keyboard
    Mar 2019
    17
    A simple Keyboard
    Hi Forum, newby here.
    - making a quick prototype of a keyboard with teensy-3.2, Audio-shield, 8 tick-switches that plays 8 different notes. using digi-Inputs 0-7.
    - using waveform >> envelope >> mixer >> I2S
    The code :
    #include <Bounce.h>
    Bounce button1 = Bounce(0, 15);
    Bounce button2 = Bounce(1, 15);
    Bounce button3 = Bounce(2, 15);
    Bounce button4 = Bounce(3, 15);
    Bounce button5 = Bounce(4, 15);
    Bounce button6 = Bounce(5, 15);
    Bounce button7 = Bounce(6, 15);
    Bounce button8 = Bounce(7, 15);
    AudioSynthWaveform waveform1; //xy=64,187
    AudioEffectEnvelope envelope1; //xy=238,176
    AudioMixer4 mixer1; //xy=485,164
    AudioOutputI2S i2s1; //xy=810,169
    AudioConnection patchCord1(waveform1, envelope1);
    AudioConnection patchCord2(envelope1, 0, mixer1, 0);
    AudioConnection patchCord3(mixer1, 0, i2s1, 0);
    AudioConnection patchCord4(mixer1, 0, i2s1, 1);
    AudioControlSGTL5000 sgtl5000_1; //xy=495,480
    AudioMemory(20);
    pinMode(0, INPUT_PULLUP);
    pinMode(1, INPUT_PULLUP);
    pinMode(2, INPUT_PULLUP);
    pinMode(3, INPUT_PULLUP);
    pinMode(4, INPUT_PULLUP);
    pinMode(5, INPUT_PULLUP);
    pinMode(6, INPUT_PULLUP);
    pinMode(7, INPUT_PULLUP);
    mixer1.gain(0, 0.9);
    sgtl5000_1.enable();
    sgtl5000_1.volume(0.32);
    envelope1.attack(0.1);
    envelope1.hold(0);
    envelope1.decay(0.1);
    envelope1.sustain(0.3);
    envelope1.release(2000);
    button1.update();
    button2.update();
    button3.update();
    button4.update();
    button5.update();
    button6.update();
    button7.update();
    button8.update();
    if (button1.risingEdge()){
    Serial.println("C");
    waveform1.begin(0.75,262,WAVEFORM_SAWTOOTH);
    waveform1.pulseWidth(0.15);
    envelope1.noteOn();
    } else if (button1.fallingEdge()){
    envelope1.noteOff();
    if (button7.risingEdge()){
    Serial.println("B");
    waveform1.begin(0.75,493,WAVEFORM_SAWTOOTH);
    envelope1.noteOn();
    } else if (button7.fallingEdge()){
    if (button8.risingEdge()){
    waveform1.begin(0.75,523,WAVEFORM_SAWTOOTH);
    envelope1.noteOn();
    } else if (button8.fallingEdge()){
    What I hear:
    - most of the switches are not triggering anything. the ones that do - are not playing the allocated frequency
    - the audio is not consistent - sometimes it plays some times it doesn't.
    I am sure that I am doing fundamental mistakes both code and wiring. If anyone can shine a light on those mistakes I'd be very happy.
    also - is there a better way to play notes without explicitly writing the frequency? i.e something like C4, D5 etc
    Thank you so much
    21,476
    Looks like the buttons are connected incorrectly. DO NOT wire the buttons to 3.3V power. Connect each button only to GND and to the signal input.
    Also, if you use pin 7, remove that SD card.
    Germany NRW
    6,558
    Mounting the buttons this way is very unreliable, too. Are you sure they have connections?
    Mar 2019
    17
    Works ! Thank you So much!
    two small ones :
    - If i want to make this polyphonic, do I need to give each button its own waveform? is there a more efficient way?
    - is there a way to write notes rather than frequencies?
    Member houtson's Avatar
    Aug 2015
    Scotland
    53
    Have a look at https://www.arduino.cc/en/Tutorial/toneMelody for notes rather than frequencies
    Mar 2019
    17
    Thank you!
    Moving on to make a simple looper - press a button >> play something on the keyboard >> press another button >> play the recording
    trying to work with the "recorder" example:
    1. how do I make my "waveform" object (my synth keyboard above) the input for the recording?
    2. https://www.youtube.com/watch?v=RsCtGyrawKA - a reference to what I'm imagining, unfortunately no documentation for this.
    appreciate it...
