Results 1 to 11 of 11
Thread: Teensy 3.6 ADC - Continuous read giving unexpected results
    Mar 2019
    6
    I am testing out the ADC functionality of my new Teensy 3.6 and have encountered an issue I do not understand. I setup a simple test using the signal generator on my oscilloscope to output a 5 kHz sine wave into pin 17 on the Teensy. The ground connection on the signal generator was made to the Analog Ground pin. Here is the code I used:
    #include <ADC.h>
    #define SAMPLE_NO 1000
    const int readPin = A3;
    int j;
    float buffer[SAMPLE_NO];
    ADC *adc = new ADC();
    	//Read pin is A3 (pin 17) on Teensy 3.6
    	//Oscilloscope signal generator attached to A3 and Analog GND
    	pinMode(readPin, INPUT);
    	delay(6000);
    	Serial.println("Teeny beginning data acquisition...");
    	//Configure ADC_0 for Continuous measurement
    	adc->setAveraging(1);
    	adc->setResolution(16);
    	adc->setSamplingSpeed(ADC_SAMPLING_SPEED::LOW_SPEED);
    	adc->setConversionSpeed(ADC_CONVERSION_SPEED::LOW_SPEED);
    	adc->setReference(ADC_REFERENCE::REF_1V2);
    	adc->startContinuous(readPin, ADC_0);
    	//Start measurement timer
    	elapsedMicros dt;
    	j = 0;
    	uint16_t value;
    	//Fill buffer with ADC_0 output values
    	while (j < SAMPLE_NO) {
    		value = (uint16_t) adc->analogReadContinuous(ADC_0);
    		buffer[j] = value*1.2/adc->getMaxValue(ADC_0);
    		j++;
    	adc->stopContinuous();
    	//Convert buffer to float values and print to Serial
    	Serial.print("Measurement time [us]: ");
    	Serial.println(dt);
    	Serial.println("Buffer Values [V]: ");
    	for (int i = 0; i<SAMPLE_NO; i++) {
    		Serial.println(buffer[i], 5);
    void loop() {}
    And here is the output I got for different ADC speeds:
    I am thoroughly confused by this data. It seems clear that the program is collecting 1000 samples within 487 us for each speed. That gives a sampling speed of roughly 2 Msps! How is this possible? I feel like I am missing something simple. I hope someone can help me out.
    1,366
    I haven't used this but I suspect that you need to wait for the conversion to complete. Add this statement before doing analogReadContinuous:
        while(isConverting(ADC_0));
    Pete
    Mar 2019
    6
    Pete
    I tried that and it didn't work. Just got hung up in the while loop.
    2,534
    try
        if (adc->isComplete(ADC_0)) {
          buffer[j] = value * 1.2 / adc->getMaxValue(ADC_0);
          j++;
    Mar 2019
    6
    try
          j++;
    That worked! Thanks. I'd still like to understand what was happening with my initial code though. It appears that the program was filling up the buffer with 1000 samples as fast as possible, regardless of the state of the ADC. But, if that is the case, why did I get a sine wave at all? It seems like I should have gotten mostly the same values over and over.
    1,366
    You did. That's why the LOW and MED speed output has a "staircase" instead of a smooth sine wave. You didn't wait for the conversion to finish so the function returns the same value as last time until there is a new value.
    Pete
    Mar 2019
    2
    try
          j++;
    Hi
    I want to ask if you can help me understand what you have done in this code and why ??
    thanks in advance
    Dec 2018
    3
    The if statement basically says, "if and only if the conversion is done, the result will be read and j incremented". So after the last conversion result has been read and the current conversion is still going, adc->isComplete(ADC_0) evaluates to false and nothing will be done in the while loop. After the current conversion is done, adc->isComplete(ADC_0) evaluates to true so that the code following if statement is executed. Calling analogReadContinuous(), however, not only reads the result, but also reset the "isComplete" status, so the next time you call adc->isComplete(ADC_0) it evaluates to false. And this goes on and on, until you get all samples you want.
    Is this like "polling" the ADC for new values?
    And would this not occupy the processor fully with the constant polling?
    2,534
    Quote Originally Posted by tschrama View Post
    yep. Using continuous with DMA and interrupt when DMA buffer full would be better. ADC lib probably has DMA examples.
    Thx manituo.
