Results 1 to 4 of 4
Thread: Netflix "Maniac" GRTA Mainframe
    Mar 2019
    8
    Hi all,
    Last fall I built and programmed the mainframe in Netflix's Maniac series using a Teensy 3.2 as the real "mainframe". It was a wild project done in less than 5 weeks. I'd like to thank Paul for a great platform and the rest of the community for all the help and resources that made it possible.
    I ported my Arduino LED animation code to PHP and used a custom serial protocol to send the Teensy frame buffer data. This allowed me to quickly write and update animations to keep up with directorial whims. I then bit-banged the three panel columns' data at a frame rate that matched the camera. It also controlled the analog panel meters and the hard drive activity lights.
    If you haven't seen the show, there are some clips on my website:
    http://www.datax.com/hardware/netflix_maniac/
ID:	16177Click image for larger version.
Name:	panel - 1 (1).jpg
    11,943
    Looks good.
    wow, thats brilliant. Also love the other projects on your site
    Senior Member blackketter's Avatar
    May 2015
    San Francisco
    283
    I was SOOOO impressed by this work when I watched the show to the point of distraction. Just beautiful.
    Thanks for sharing some of the behind the scenes magic.
