#define ENCODER_OPTIMIZE_INTERRUPTS
* In Total there are three programs
* 1 CountDown Timer with hours minutes and seconds Time Stamp
* 2 Intern
#include <stdio.h>
#include <Arduino.h>
#include <U8g2lib.h>
#include <ADC.h>
#include <Encoder.h>
#include <Bounce.h>
#include <CountUpDownTimer.h>
///Function CountDownTimer
int PWMValue=0;
byte menuCount = 1;
byte IntCount= 1;
byte dir = 0;
bool runState = false;
bool runState2 = false;
long oldPosition = -999;
long newPosition;
long oldPWMPosition=-999;
long PWMPosition;
unsigned long Hours=0;
unsigned long Minutes=0;
unsigned int long Seconds=0;
unsigned int long Hours2=0;
unsigned int long Minutes2=0;
unsigned int long Seconds2=0;
int awake;
//Switch Case between states 1 ,2,3
const int ledPin = 13;
const int CountDownPin=21;
const int IntervalPin=22;
const int ExternPin=23;
const int buttonPin = 6;
int StateInput=0; //case switch needs to be global.
boolean OldSwitchState1 = LOW;
boolean OldSwitchState2 = LOW;
boolean OldSwitchState3 = LOW;
boolean newSwitchState1 = LOW;
boolean newSwitchState2 = LOW;
boolean newSwitchState3 = LOW;
//analog PWM control
int Pin_25_OUT_PWM=25; //out
const int Pot_Val_A12=A12; //in
int MapA12=0;
int lastseconds;
unsigned int count = 0; // how many times has it changed to low
unsigned long countAt = 0; // when count changed
unsigned int countPrinted = 0;
unsigned int icount = 0; // how many times has it changed to low
unsigned long icountAt = 0; // when count changed
unsigned int icountPrinted = 0;
//Function Interval Timer
int ON_Time1=0;
int OFFTime1=0;
unsigned long PreviousMillis=0;
int ON_LT3760=LOW;
CountUpDownTimer T(DOWN),T2(DOWN);
Encoder Timer_1(4,3), PWM(2,1);
Bounce clk = Bounce(buttonPin, 10); // 10 ms debounce
ADC *adc = new ADC(); // adc object
U8G2_SSD1327_MIDAS_128X128_F_4W_SW_SPI u8g2(U8G2_R2, 13, 11, 10, 9, 8);// clock= 13, data= 11, cs= 10, dc= 9, reset= 8);
int TimeControlEncoder() //
newPosition = Timer_1.read();
if (newPosition != oldPosition)
oldPosition = newPosition;
return newPosition/4;
Serial.print("TimerEncoder Position ");
Serial.println(newPosition);
int PWMControlEncoder() //
PWMPosition = PWM.read();
if (PWMPosition != oldPWMPosition)
oldPWMPosition = PWMPosition;
return PWMPosition/4;
Serial.print("PWMPosition ");
Serial.println(PWMPosition);
int PWMcontrol()
PWMValue = PWMControlEncoder();
MapA12=map(PWMValue,0,4096,4096,0); //PWM should be kept above 50us 200Hz=5ms 5ms/4096 =1,22us == 1,22x42>50us
analogWrite(25,MapA12); //200 is to be replaced by a analogRead //just a test
int Menu1Check() //Menu Check 1 for CountDown Timer 1 and 2,
Serial.println("in the Menu1Check");
delay(50);
if (clk.update())
Serial.println(" updated ");
if(clk.fallingEdge())
menuCount=menuCount+1; //move statement after pressed
count++;
countAt=millis();
}else
if(count!=countPrinted)
unsigned long nowMillis=millis();
if(nowMillis - countAt>100) //shortened the bounce interval to increase the speed of the button
countPrinted=count;
//do nothing,
// Serial.print("Button not Pressed ");
if (menuCount>10) //limit the menu
{Serial.print("menu larger as 10");
menuCount = 1;
if (menuCount == 1)
TimeControlEncoder();
if(newPosition>0&&newPosition<59)
Hours = newPosition;
// Serial.print(" Hours ");
// Serial.println(Hours);
//out of boundary set to zero.
else Hours=0;
if (menuCount == 2)
{ Serial.print("Menu2");
newPosition=TimeControlEncoder();
Minutes = newPosition;
// Serial.print(" Minutes ");
// Serial.println(Minutes);
}else Minutes=0;
if (menuCount == 3)
{Serial.print("Menu3");
Seconds = newPosition;
// Serial.print(" Seconds ");
// Serial.println(Seconds);
}else Seconds=0;
if(menuCount==4)
Hours2 = newPosition;
else Hours2=0;
if(menuCount==5)
Minutes2 = newPosition;
}else Minutes2=0;
if(menuCount==6)
Seconds2 = newPosition;
// Serial.print(" Seconds2 ");
// Serial.println(Seconds2);
}else Seconds2=0;
if(menuCount==7)
Serial.println("set timer 1");
T.SetTimer(Hours,Minutes,Seconds);
T2.SetTimer(Hours2,Minutes2,Seconds2);
if(menuCount==8)
T.Timer();
//substract Show Stop Time
if(menuCount==9)
ON_LT3760=HIGH;
T2.Timer();
digitalWrite(14,ON_LT3760);//Switch on the Device during T2 State.
PWMcontrol();//allow PWM Control
Serial.println(" Run T2 ");
if(menuCount==10)
//loop Timer 1
Serial.print("condition T2 has ended, Back To Timer 1 which Menu = ");
Serial.print(menuCount);
int Menu2Interval() //Interval Timer
if (clk.update())
Serial.println(" I am in the Menu2interval");
Serial.print(" I ");
Serial.println(IntCount);
IntCount=IntCount+1; //move statement after pressed
icount++;
icountAt=millis();
}else
if(icount!=icountPrinted)
if(nowMillis - icountAt>20) //shortened the bounce interval to increase the speed of the button
icountPrinted=icount;
//do nothing,
if (IntCount>3) //limit the menu
IntCount = 1;
if (IntCount == 1)
OFFTime1=10*TimeControlEncoder();
else OFFTime1=0;
if(IntCount==2)
ON_Time1=10*TimeControlEncoder();
ON_LT3760==HIGH;
else ON_Time1=0; //out of boundary set to zero.
if(IntCount==3)
unsigned long currentMillis=millis();
if((ON_LT3760==HIGH)&&(currentMillis-PreviousMillis>=ON_Time1))
ON_LT3760=LOW;
PreviousMillis=currentMillis;
PWMcontrol();
//some LED for indication or on the display showing Interval 1
else if((ON_LT3760==LOW)&&(currentMillis-PreviousMillis>=OFFTime1))
ON_LT3760=HIGH;
PWMcontrol();
int Menu1Countdown() //Menu 1
/* all graphics commands have to appear within the loop body. */
u8g2.clearBuffer();
u8g2.setFont(u8g2_font_helvB08_tr);
u8g2.setFontMode(0); /* activate transparent font mode */
u8g2.setFontDirection(0);
u8g2.drawStr(0,45,"Set T1");
u8g2.setCursor(0,60);
u8g2.print(Hours,DEC);
u8g2.print(":");
u8g2.print(Minutes,DEC);
u8g2.print(":");
u8g2.print(Seconds,DEC);
u8g2.drawStr(0,80,"Set T2");
u8g2.setCursor(0,95);
u8g2.print(Hours2,DEC);
u8g2.print(":");
u8g2.print(Minutes2,DEC);
u8g2.print(":");
u8g2.print(Seconds2,DEC);
if (menuCount > 7 && menuCount == 8)
if(T.TimeHasChanged())
Serial.println(" R T1 ");
u8g2.drawStr(60,10,"RUN T1");
u8g2.setCursor(60,60);
u8g2.print(T.ShowHours(),DEC);
u8g2.print(":");
u8g2.print(T.ShowMinutes(),DEC);
u8g2.print(":");
u8g2.print(T.ShowSeconds(),DEC);
Serial.print(T.ShowHours());
Serial.print(":");
Serial.print(T.ShowMinutes());
Serial.print(":");
Serial.print(T.ShowSeconds());
u8g2.drawStr(60,10," S T1 ");
menuCount=9;
if(menuCount>8&&menuCount==9)
if(T2.TimeHasChanged())
Serial.println(" R T2 ");
u8g2.drawStr(60,10,"RUN T2");
u8g2.setCursor(60,95);
u8g2.print(T2.ShowHours(),DEC);
u8g2.print(":");
u8g2.print(T2.ShowMinutes(),DEC);
u8g2.print(":");
u8g2.print(T2.ShowSeconds(),DEC);
Serial.print(T2.ShowHours());
Serial.print(":");
Serial.print(T2.ShowMinutes());
Serial.print(":");
Serial.println(T2.ShowSeconds());
u8g2.drawStr(60,10,"S T2");
if(menuCount>9&&menuCount==10)
u8g2.drawStr(60,10,"RESTART COUNTDOWN");
menuCount=1;
u8g2.drawStr(5,10,"M");
u8g2.setCursor(15,10 ); //just a symbol to show where I am in the Menu
u8g2.println(menuCount);
u8g2.display();
u8g2.sendBuffer();
int Menu2IntervalDisplay()
u8g2.clearBuffer();
u8g2.drawStr(0,40,"PWM %");
u8g2.drawRFrame(45,29,90,10,0);// x,y,w,h,_round
int Intensity=PWMControlEncoder();
u8g2.drawBox(45,30,Intensity,8);
u8g2.drawStr(0,50,"OnTime ms");
u8g2.setCursor(60,50);
u8g2.print(": ");
u8g2.print(ON_Time1,DEC);
u8g2.drawStr(0,65,"OFFTime ms ");
u8g2.setCursor(60,65);
u8g2.print(": ");
u8g2.print(OFFTime1,DEC);
if(IntCount>0&&IntCount==1)
u8g2.drawBox(80,50,10,10);
if(IntCount>1&&IntCount==2)
u8g2.drawBox(80,65,10,10);
u8g2.drawStr(5,10,"I");
u8g2.println(IntCount);
u8g2.display();
u8g2.sendBuffer();
//menu 1 for CountDown Timer
T.StartTimer();
T2.StartTimer();
analogWriteFrequency(Pin_25_OUT_PWM,200);
pinMode(CountDownPin, INPUT);
pinMode(IntervalPin, INPUT);
pinMode(ExternPin, INPUT);
pinMode(buttonPin, INPUT_PULLUP);
analogWriteResolution(12);
analogReadResolution(12);
pinMode(20, INPUT);
pinMode(14,OUTPUT); //SHDN Not Pin, switch on the LT3760
analogWriteFrequency(25,200);
u8g2.setBusClock(24000000);
u8g2.begin();
newSwitchState1=digitalRead(CountDownPin);
if(newSwitchState1!=OldSwitchState1)
if(newSwitchState1==HIGH)
StateInput=1;
newSwitchState2=digitalRead(IntervalPin);
if(newSwitchState2!=OldSwitchState2)
if(newSwitchState2==HIGH)
StateInput=2;
newSwitchState3=digitalRead(ExternPin);
if(newSwitchState3!=OldSwitchState3)
if(newSwitchState3==HIGH)
StateInput=3;
switch(StateInput)
case 1:
//Serial.println("CountDown is ON");
Menu2Interval();
Menu2IntervalDisplay();
u8g2.display();
u8g2.sendBuffer();
case 2:
// Serial.println("EXTN is ON");
u8g2.clearBuffer();
u8g2.drawStr(20,0,"PWM CONTROL");
u8g2.drawRFrame(35,29,90,10,0);// x,y,w,h,_round
u8g2.drawStr(0,40,"%"); //x,y,String
u8g2.drawBox(35,30,Intensity,8);
ON_LT3760=HIGH;
PWMcontrol();
case 3:
// Serial.println("Interval is ON");
Menu1Check();
Menu1Countdown();
