Results 1 to 3 of 3
Thread: Sgtl 5000 7-Band programmable EQ
    Germany NRW
    5,659
    Has anyone used the 7-Band parametric EQ inside the SGTL-5000?
    Is there a tool anywhere that can calculate the needed coefficients?
    Senior Member DD4WH's Avatar
    Oct 2015
    Central Europe
    384
    Try the Iowa Hills IIR Filter designer
    http://iowahills.com/8DownloadPage.html
    For each filter stage you need a 2nd order filter and you need to specify the sample rate, cutoff frequency and the filter order. Beware of the order of the coefficients and the sign of the coeffs, they are sometimes swapped in some applications . . .
    I have not yet used the 7-band equalizer, for my purposes the preset 5-band EQ was sufficient.
    All the best,
    Frank DD4WH
    Germany NRW
    5,659
    Thank you Frank!
