roggesound
I'm working on a mouse scroll wheel that I made with an encoder. It works, but I'm trying to get the scrolling to slow down a bit. Mouse.scroll(0.5) won't work. I tried to use a float variable, that also doesn't work for anything less than 1.
My goal here is a smooth scrolling wheel, just like what you'd find in a typical mouse. It's going to be used with a teleprompting software to scroll text on a screen, so smooth and slow is the way to go.
Here's my code, which started from the basic encoder example sketch. I'm using a teensy 2.0 and a 20ppr encoder.
#include <Encoder.h>
float ScPos = 1.5;
float ScNeg = -1.5;
Encoder myEnc(5, 6);
// avoid using pins with LEDs attached
Serial.println("Basic Encoder Test:");
long oldPosition = -999;
long newPosition = myEnc.read();
if (newPosition > oldPosition) {
oldPosition = newPosition;
Mouse.scroll(ScPos);
delay(10);
if (newPosition < oldPosition) {
Mouse.scroll(ScNeg);
delay(10);
