Looper instrument
Ayal
Working on making a looper. for reference - https://www.youtube.com/watch?v=RsCtGyrawKA (unfortunately no documentation).
I am not using samples though - I'm synthesizing audio directly from my 3.2 with a waveform obj.
as a starting point - I am trying to work with the "Recorder" example and simply record my waveform - but no use.
so,
  • first thing - how to record audio from the board (Would have post the code but it's just the "Recorder" example)
  • second - if there's a good reference for a looper code that'l be great.
Thank you Forum
Does this audio system make sense for recording waveform objects?
AudioSynthWaveform waveform1; //xy=303,130
AudioSynthWaveform waveform2; //xy=327,183
AudioMixer4 mixer1; //xy=481,157
AudioPlaySdRaw playRaw1; //xy=507,274
AudioAnalyzePeak peak1; //xy=617,194
AudioRecordQueue queue1; //xy=622,140
AudioOutputI2S i2s1; //xy=740,234
AudioConnection patchCord1(waveform1, 0, mixer1, 0);
AudioConnection patchCord2(waveform2, 0, mixer1, 1);
AudioConnection patchCord3(mixer1, queue1);
AudioConnection patchCord4(mixer1, peak1);
AudioConnection patchCord5(playRaw1, 0, i2s1, 0);
AudioConnection patchCord6(playRaw1, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=535,326
If this make sense - in the Recorder example - what do i put in "myInput" ? :
const int myInput = AUDIO_INPUT_LINEIN ????;
Thank you so much.
Hi Ayal,
Apols for not directly answering your question but...Looking at the video I do think they are recording and looping the sound (i.e. not recording it to SD and playing it back).
It looks as thought they are recording the sequence of triggers then replaying that in a loop to re-trigger the samples.
Interesting, didn't think of that...
do yo think that when it's being played back it's remembers the time-position of each trigger? do you have a thought of how to pseudo-code this?
Thank you so much for the response!
Will do,
Thank you.
I have another basic question -
Let's say i wanna use my 3.2 as a midi device(using capacitive touch), but at the same time also as my synth.
What i mean is - can I use my 3.2 to manage midi and at the same time send the midi data to itself and play synth-audio through the Audio shield?
Sorry if this is a really stupid question.
And thank you so much for the responses.
