Results 1 to 2 of 2
Thread: Teensy 3.6 ADC
    Mar 2019
    2
    Teensy 3.6 ADC
    Hi
    I want to ask if you can help me write a code for the teensy 3.6 ADC that will give me a continuous read from 5kHz till 300kHz , our expected voltage range is from 100mV till 1.5V and at least 4 samples per point ??
    thanks in advance
    Feb 2014
    Colmar, France
    2,381
    Even if you ask friendly, nobody will most probably sit down and write code for you for free. These forums are intended to point people towards the needed resources, so that they get the tools at hand to write their own code. Only when someone has already made the effort to write code and it has a few reproducible problems, others might jump in and help with debugging.
    And here is the first hint: The Teensyduino Software comes with an ADC library which allows to achieve everything you want. Take the time to play with the example sketches until you understand enough to modify them to fit your needs.
