Results 1 to 9 of 9
Thread: RTC hour displays wrong time.
    Mar 2019
    12
    Good Afternoon everyone I have been researching this issue for a little while now about three days and I can't figure out why but the RTC on the Teensy 3.6 displays everything correctly other then the hour time.
    I'm new to programming and I'm having a lot of fun. I normally like to figure things out for myself but i'm having a hard time with this issue
    Current time is 13:37 and the RTC on the teensy 3.6 shows this time below.
    17:37:42: 24/3/2019
    Also here is my github for the project if this helps https://github.com/Dellyjoe/RTC_Light_Timer
    I'm really just using the example code so i'm not sure what is really wrong.
    #include <Arduino.h>
    #include <rtc.h>
    //******************************************Setup*****************************//
    void intrtc()
      // set the Time library to use Teensy 3.0's RTC to keep time
      Serial.begin(115200); // Setting up the Serial Terminal
      while (!Serial)
        ; // Wait for Arduino Serial Monitor to open
      if (timeStatus() != timeSet)
        Serial.println("Unable to sync with the RTC");
        Serial.println("RTC has set the system time");
    //******************************************Main******************************//
    void displaytime()
      intrtc();
      if (Serial.available())
        time_t t = processSyncMessage();
        if (t != 0)
          Teensy3Clock.set(t); // set the RTC
          setTime(t);
      digitalClockDisplay();
      //delay(1000);
    //*****************************************Functions**************************//
    void digitalClockDisplay()
      // digital clock display of the time
      Serial.print(hour());
      Serial.print(":");
      Serial.print(minute());
      Serial.print(":");
      Serial.print(second());
      Serial.print(": ");
      Serial.print(day());
      Serial.print("/");
      Serial.print(month());
      Serial.print("/");
      Serial.print(year());
    time_t getTeensy3Time()
      return Teensy3Clock.get();
    unsigned long processSyncMessage()
      unsigned long pctime = 0L;
      const unsigned long DEFAULT_TIME = 1553130740; // March 20, 2019 9:12:20 PM
      if (Serial.find(TIME_HEADER))
        pctime = Serial.parseInt();
        return pctime;
        if (pctime < DEFAULT_TIME)
        {              // check the value is a valid time (greater than Jan 1 2013)
          pctime = 0L; // return 0 to indicate that the time is not valid
      return pctime;
    } //*****************************************Functions**************************//
    Feb 2014
    Colmar, France
    2,385
    Time zone parameter?
    Mar 2019
    12
    hmm ok
    I'm UTC -5 hours which is 18000 seconds.
    If I use adjustTime(number); which would look like adjustTime(-18000); where in the code would I put this?
    Mar 2019
    12
    Hey everyone, I'm still having a hard time getting the time adjust function to work. Can you not use //adjustTime(offset * SECS_PER_HOUR); when using time_t getTeensy3Time()?
    All I'm trying to do is set the time to EST. Right now it has the right mins and sec but the hours are off. The date works great.
    #include <TimeLib.h>   // Teensy 3.0's RTC
    #include <DS1307RTC.h> // a basic DS1307 library that returns time as a time_t
    time_t getTeensy3Time();
    unsigned long processSyncMessage();
    /*  code to process time sync messages from the serial port   */
    // single character message tags
    #define TIME_HEADER "T"   // Header tag for serial time sync message
    #define FORMAT_HEADER 'F' // Header tag indicating a date format message
    #define FORMAT_SHORT 's'  // short month and day strings
    #define FORMAT_LONG 'l'   // (lower case l) long month and day strings
    #define TIME_REQUEST 7 // ASCII bell character requests a time sync message
    //const int offset = -5;  // Eastern Standard Time (USA)
    const int offset = -4; // Eastern Daylight Time (USA)
    void intrtc();
    void digitalClockDisplay();
    void displaytime();
    void printDigits(int digits);
    #include <rtc.h>
    void intrtc()
    void displaytime()
      intrtc();
        if (t != 0)
          setTime(t);
      //delay(1000);
      //digital clock display of the time
      printDigits(minute());
     printDigits(second());
      Serial.print(": ");
      Serial.print("/");
      Serial.print("/");
    void printDigits(int digits) {
     // utility function for digital clock display: prints preceding colon and leading 0
     Serial.print(":");
     if (digits < 10)
     Serial.print('0');
     Serial.print(digits);
      const unsigned long DEFAULT_TIME = 1357041600; // Jan 1 2013
        return pctime;
      return pctime;
    2,157
    Quote Originally Posted by Dellyjoe View Post
    Why not simply setting RTC time in EST? Or do you have reasons to run RTC in UTC? Also what means "hours are off"? can you not give an example?
    19,929
    Are you actually sending a message to that program running on your Teensy, to properly set the date/time? Or just going with the "default" setting Teensy has?
    If you're going with the default, maybe check your PC's date & time setting? Also make sure you have a coin cell connected to VBAT, if you remove power from your Teensy. The default is based on the time your code was compiled by Arduino, so if your PC's time is incorrect, then you'll get similar error with the default on Teensy. If Teensy loses power, and the coin cell is dead or not connected, when you power up again the time will revert to that default based on when Arduino compiled your code.
    If you are indeed sending that time set message, maybe there's some issue with the way you're creating the message to send? We're pretty good at helping find and solve such problems, but only when we can clearly see what you're really doing (actual code, screenshots, specific steps used, etc). In this case, I can't even tell if you're transmitting the time set message that example expects, or just going with the default time based on when Arduino compiled your program.
    Mar 2019
    12
    Good Evening My PaulStoffregen:
    One I will say I'm really new to programming, so these questions you are asking I might not be able to ask
    Q1/ Are you actually sending a message to that program running on your Teensy, to properly set the date/time? Or just going with the "default" setting Teensy has?
    A1/ Yes I'm using the miniUSB to set the time which I believe is getting it from my computer time but it is off by 4 hours every time
    Q2/If you're going with the default, maybe check your PC's date & time setting?
    A2/ Not sure if i'm using default but i'm using my PC clock time,
    A3/ Yes I understand, right now I'm trying to just get the right time displayed on the Terminal
    Here is the github to the whole project if you would like to look at it, if not let me know I will display all my .cpp/.h/main
    Thank you for your time in advanced !
    Joe
    Mar 2019
    12
    Good Evening WMXZ:
    Not sure If I can set time to EST, b/c the code pulls from my computer time which is 20:48:13 3/4/2019 but the RTC in the terminal displays --> 0:48:13: 3/4/2019
    Dec 2013
    213
    Perhaps this example code will steer you in the right direction?
       TimeRTC.pde
       example code illustrating Time library with Real Time Clock.
    // deprecated API or MS WIN issue?
    // #include <Time.h> // include Arduino Time library
    #include <TimeLib.h> // include Arduino Time library
    // *                            Power Up Init.
    // *                            put your setup code here, to run once:
    void setup()  {
      setSyncProvider(getTeensy3Time); // Set the Arduino Time library to Sync from Teensy 3.x's RTC
      // The default interval for re-syncing the time is 5 minutes but can be changed by calling the setSyncInterval(interval)
      setSyncInterval(60); // 1 minute / Configure how often the getTimeFunction is called in seconds.
      setTime(getTeensy3Time()); // Set Arduino Time library with Teensy 3.x RTC time.
      while (!Serial);  // Wait for Arduino Serial Monitor to open
      if (timeStatus() != timeSet) {
      oneTime_set_option(); //One Time Set Option
    // *                            Main Loop
    // *                            put your main code here, to run repeatedly:
      USBtime_set_option(); //Check for a time message from your computer, USB time set option using your computer's time.
      digitalClockDisplay(); //Display Clock
      delay(1000); //
    // *                            One Time Set Option
    //  my variabls for time
    int myHr, myMin, mySec, myDay, myMonth, myYr;
    boolean oneTime = false; // <---- set me true
    void oneTime_set_option() {
      if (oneTime == true) {
        oneTime = false;
        Serial.println("Setting new time");
        myHr = 14; // 2 pm
        myMin = 1;
        mySec = 1;
        myDay = 3;
        myMonth = 4;
        myYr = 2019;
        // This sets the system time: Arduino Time library (NOT the Teensy RTC Clock)
        // set your seperated date/time variables out as normal and update system time FIRST
        //setTime(hour(), minute(), second(), day(), month(), year())
        setTime(myHr, myMin, mySec, myDay, myMonth, myYr);
        // now lets set the RTC in teensy before exiting.
        // now we can use the system time to update the Teensy's RTC bits
        // This sets the Teensy RTC Clock from Arduino Time library(system time) - epoch stylee, just like it wants :)
        Teensy3Clock.set(now());
    // *                   Display Digital Clock
    void digitalClockDisplay() {
      //isAM();            // Returns true if time now is AM
      //isPM();            // Returns true if time now is PM
      if (isAM() == true) {
        Serial.print(".AM");
      else {
        Serial.print(".PM");
      Serial.print(" "); // space
      switch (weekday()) // Day of the week, Sunday is day 1
        case 1:
          Serial.print("Sunday");
        case 2:
          Serial.print("Monday");
        case 3:
          Serial.print("Tuesday");
        case 4:
          Serial.print("Wednesday");
        case 5:
          Serial.print("Thursday");
        case 6:
          Serial.print("Friday");
        case 7:
          Serial.print("Saturday");
      } //end of switch case
      Serial.println(), Serial.println();
      // Unix epoch
      Serial.print(" Unix ~ Arduino Time library    "); //
      Serial.println(now());
      Serial.print(" Unix ~ Teensy 3.x internal RTC "); //
      Serial.println(Teensy3Clock.get());
    // *  utility function for digital clock display: prints preceding colon and leading 0
      Serial.print(":");
      if (digits < 10)
        Serial.print('0');
    // *  Read Teensy 3.x time from Teensy 3.x internal RTC
    // *              USB time set option using your computer's time.
    // *              TimeSerial listens for a message from your computer.
    // *              This message is sent by a Processing-based program,
    // *              found in Time's examples/Processing folder.
    void USBtime_set_option() {
      if (Serial.available()) {
        if (t != 0) {
          Teensy3Clock.set(t); // set the internal RTC in teensy
          setTime(t); // set the Arduino Time library
    // *  code to process time sync messages from the serial port
    unsigned long processSyncMessage() {
      if (Serial.find(TIME_HEADER)) {
        return pctime;
        if ( pctime < DEFAULT_TIME) { // check the value is a valid time (greater than Jan 1 2013)
      return pctime;
    // Set time using your computer's time and Processing software:
    // The Processing software is free and open source, and runs on the Mac, Windows, and GNU/Linux platforms.
    // Download Processing from https://processing.org/
       SyncArduinoClock.
       portIndex must be set to the port connected to the Arduino
       The current time is sent in response to request message from Arduino
       or by clicking the display window
       The time message is 11 ASCII text characters; a header (the letter 'T')
       followed by the ten digit system time (unix time)
      import processing.serial.*;
      import java.util.Date;
      import java.util.Calendar;
      import java.util.GregorianCalendar;
      public static final short portIndex = 0;  // select the com port, 0 is the first port
      public static final String TIME_HEADER = "T"; //header for arduino serial time message
      public static final char TIME_REQUEST = 7;  // ASCII bell character
      public static final char LF = 10;     // ASCII linefeed
      public static final char CR = 13;     // ASCII linefeed
      Serial myPort;     // Create object from Serial class
      size(200, 200);
      println(Serial.list());
      println(" Connecting to -> " + Serial.list()[portIndex]);
      myPort = new Serial(this,Serial.list()[portIndex], 9600);
      println(getTimeNow());
      void draw()
      textSize(20);
      textAlign(CENTER);
      fill(0);
      text("Click to send\nTime Sync", 0, 75, 200, 175);
      if ( myPort.available() > 0) {  // If data is available,
        char val = char(myPort.read());         // read it and store it in val
        if(val == TIME_REQUEST){
           long t = getTimeNow();
           sendTimeMessage(TIME_HEADER, t);
           if(val == LF)
               ; //igonore
           else if(val == CR)
             println();
             print(val); // echo everying but time request
      void mousePressed() {
      sendTimeMessage( TIME_HEADER, getTimeNow());
      void sendTimeMessage(String header, long time) {
      String timeStr = String.valueOf(time);
      myPort.write(header);  // send header and time to arduino
      myPort.write(timeStr);
      myPort.write('\n');
      long getTimeNow(){
      // java time is in ms, we want secs
      Date d = new Date();
      Calendar cal = new GregorianCalendar();
      long current = d.getTime()/1000;
      long timezone = cal.get(cal.ZONE_OFFSET)/1000;
      long daylight = cal.get(cal.DST_OFFSET)/1000;
      return current + timezone + daylight;
