Results 1 to 4 of 4
Thread: I2C issues in slave mode, sometime stay in I2C_SLAVE_RX state
    Mar 2019
    France
    3
    Hello all,
    I'm need your help.
    I use to write softwares on an MEGA2560 which talk with an I2C bus to other devices base on PCF8574 (write and read) but this is my first time I connect an Teensy.
    So, I added on a such network an Teensy 3.2 with an TXS0102 (for 3.3V to 5V level translator).
    MEGA2560 / I2C 5V (MASTER)
    • TXS0102/ I2C 3.3V + pull-up 4.7k --> Teensy3.2 (SLAVE)
    • PCF8574
    • PCF8574 + pull-up 10k
    After many tests / checks / (flying Teensy ) , I don't understund why Teensy keep sometime the I2C bus in I2C_SLAVE_RX state?
    The master send to the Teensy an message of 2 byte (+ address) each 200ms. Often (one per 5 minutes), Teensy "miss" one message. At this time the I2C state keep "I2C_SLAVE_RX" in the main loop. And some other times (less frenquently) the SCL line stay low, until I reboot the Teensy. Of course, the 2 behaviors introduce heavy disturbtions in the network.
    I realized in writing the post that my issue is not necessary clear. It probablycould be something simple, but I miss it. Many thanks in advanced for your help or support
    Other informations : I used short cables (less than 20cm). Rate : low speed 100kHz
    PS : also many thank for the forum that I used dally.
    // Base on "Basic Slave" i2c_t3
    #include <i2c_t3.h>
    // Function prototypes
    void receiveEvent(size_t count);
    void requestEvent(void);
    // Memory
    #define MEM_LEN 256
    char databuf[MEM_LEN];
    volatile uint8_t received;
    IntervalTimer TimerPrincipal;
    boolean b_FlagTimerCompteur;
    int i_Index;
    void Tache_Timer()
    	b_FlagTimerCompteur = true;
    // Setup
        pinMode(LED_BUILTIN,OUTPUT); // LED
        // Setup for Slave mode, address 0x10, pins 18/19, external pullups, 100kHz
        Wire.begin(I2C_SLAVE, 0x10, I2C_PINS_18_19, I2C_PULLUP_EXT, 100000);
    	Wire.setDefaultTimeout ( 1000 );
        // Data init
        received = 0;
        memset(databuf, 0, sizeof(databuf));
        // register events
        Wire.onReceive(receiveEvent);
        Wire.onRequest(requestEvent);
    	// Start Timer
    	TimerPrincipal.begin(Tache_Timer, 200000);
    	TimerPrincipal.priority(1);					// todo : check value to set
    	if (b_FlagTimerCompteur == true)
    		if(received)							// print received data - this is done in main loop to keep time spent in I2C ISR to minimum
    		{	digitalWrite(LED_BUILTIN,HIGH);
    			/*if (i_Index > 0)
    			{	i_Index = i_Index - 1; }*/
    			Serial.printf("Slave received: '%s' ; char[0] : '%2X' ; char[1] : '%2X' , received : %X, index : %X\n", databuf, databuf[0], databuf[1], received, i_Index);
    			received = 0;
    			digitalWrite(LED_BUILTIN,LOW); }
    		{	i_Index = i_Index + 1;
    			Serial.printf("No I2C message, statut : '%X' , index : %X\n",Wire.status(),i_Index); }
        	b_FlagTimerCompteur = false;
    // handle Rx Event (incoming I2C data)
        Wire.read(databuf, count);  // copy Rx data to databuf
        received = count;           // set received flag to count, this triggers print in main loop
    // handle Tx Event (outgoing I2C data)
        Wire.write(databuf, MEM_LEN); // fill Tx buffer (send full mem)
    Serial Output
    Slave received: 'Q' ; char[0] : '51' ; char[1] : ' 3' , received : 2, index : 5F
    No I2C message, statut : 'C' , index : 60
    Slave received: 'Q' ; char[0] : '51' ; char[1] : ' 3' , received : 2, index : 60
    Feb 2014
    Colmar, France
    2,386
    At 3.3V supply, it is recommended to use 2.2k pull-up resistors on that side.
    Mar 2019
    France
    3
    @Theremingenieur thanks for time and idea.
    I made the change, there are know 2.2k pull-up resistors beetwen level shifter and the Teensy.
    It's the same issue.... it's seem to be worth, issue happens more often.
    Furthermore, Teensy sometime catch only one byte, instead of two.
    Mar 2019
    France
    3
    Slave received: '' ; char[0] : ' 1' ; char[1] : ' 0' , received : 2, index : 75
    No I2C message, statut : 'C' , index : 76
    Slave received: '' ; char[0] : ' 1' ; char[1] : ' 0' , received : 2, index : 76
    No I2C message, statut : 'C' , index : 77
    Slave received: '' ; char[0] : ' 1' ; char[1] : ' 0' , received : 2, index : 77
    Slave received: '' ; char[0] : ' 1' ; char[1] : ' 0' , received : 1, index : 77
