Results 1 to 11 of 11
Thread: bno055 problem code
    bno055 problem code
    This code works in Arduino but gave mistake at teensy 3.5 . Could any on help me?
    #include <Adafruit_Sensor.h>
    #include <Adafruit_BNO055.h>
    #include <utility/imumaths.h>
    #include <EEPROM.h>
    /* This driver uses the Adafruit unified sensor library (Adafruit_Sensor),
       which provides a common 'type' for sensor data and some helper functions.
       To use this driver you will also need to download the Adafruit_Sensor
       library and include it in your libraries folder.
       You should also assign a unique ID to this sensor for use with
       the Adafruit Sensor API so that you can identify this particular
       sensor in any data logs, etc.  To assign a unique ID, simply
       provide an appropriate value in the constructor below (12345
       is used by default in this example).
       Connections
       Connect SCL to analog 5
       Connect SDA to analog 4
       Connect VDD to 3-5V DC
       Connect GROUND to common ground
       History
       2015/MAR/03  - First release (KTOWN)
       2015/AUG/27  - Added calibration and system status helpers
       2015/NOV/13  - Added calibration save and restore
        * Orientation:
        *       front
        *   |   BNO55    |
        *   | Vin        |
        *   | 3Vo    PS0 | <-- This side facing up
        *   | GND    PS1 |
        *   | SDA    IN1 | <-- The positive rotations follow the right hand rule and all the axis are aligned to how you would expect in a 3d coordinate plane
        *   | SCL    ADW |
        *   | DST        |
        *   |   9-Axis   |
        *        back
    bool zero = true;
    bool calibrate = true;
    int zeroTime = 50;
    /* Set the delay between fresh samples */
    #define BNO055_SAMPLERATE_DELAY_MS (100)
    double degToRad = 57.295779513;
    Adafruit_BNO055 bno = Adafruit_BNO055(55);
        Displays some basic information on this sensor from the unified
        sensor API sensor_t type (see Adafruit_Sensor for more information)
    void displaySensorDetails(void)
        sensor_t sensor;
        bno.getSensor(&sensor);
        Serial.println("------------------------------------");
        Serial.print("Sensor:       "); Serial.println(sensor.name);
        Serial.print("Driver Ver:   "); Serial.println(sensor.version);
        Serial.print("Unique ID:    "); Serial.println(sensor.sensor_id);
        Serial.print("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" xxx");
        Serial.print("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" xxx");
        Serial.print("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" xxx");
        Serial.println("");
        Display some basic info about the sensor status
    void displaySensorStatus(void)
        /* Get the system status values (mostly for debugging purposes) */
        uint8_t system_status, self_test_results, system_error;
        system_status = self_test_results = system_error = 0;
        bno.getSystemStatus(&system_status, &self_test_results, &system_error);
        /* Display the results in the Serial Monitor */
        Serial.println("");
        Serial.print("System Status: 0x");
        Serial.println(system_status, HEX);
        Serial.print("Self Test:     0x");
        Serial.println(self_test_results, HEX);
        Serial.print("System Error:  0x");
        Serial.println(system_error, HEX);
        Serial.println("");
        Display sensor calibration status
    void displayCalStatus(void)
        /* Get the four calibration values (0..3) */
        /* Any sensor data reporting 0 should be ignored, */
        /* 3 means 'fully calibrated" */
        uint8_t system, gyro, accel, mag;
        system = gyro = accel = mag = 0;
        bno.getCalibration(&system, &gyro, &accel, &mag);
        /* The data should be ignored until the system calibration is > 0 */
        Serial.print("\t");
        if (!system)
            Serial.print("! ");
        /* Display the individual values */
        Serial.print("Sys:");
        Serial.print(system, DEC);
        Serial.print(" G:");
        Serial.print(gyro, DEC);
        Serial.print(" A:");
        Serial.print(accel, DEC);
        Serial.print(" M:");
        Serial.print(mag, DEC);
        Display the raw calibration offset and radius data
    void displaySensorOffsets(const adafruit_bno055_offsets_t &calibData)
        Serial.print("Accelerometer: ");
        Serial.print(calibData.accel_offset_x); Serial.print(" ");
        Serial.print(calibData.accel_offset_y); Serial.print(" ");
        Serial.print(calibData.accel_offset_z); Serial.print(" ");
        Serial.print("\nGyro: ");
        Serial.print(calibData.gyro_offset_x); Serial.print(" ");
        Serial.print(calibData.gyro_offset_y); Serial.print(" ");
        Serial.print(calibData.gyro_offset_z); Serial.print(" ");
        Serial.print("\nMag: ");
        Serial.print(calibData.mag_offset_x); Serial.print(" ");
        Serial.print(calibData.mag_offset_y); Serial.print(" ");
        Serial.print(calibData.mag_offset_z); Serial.print(" ");
        Serial.print("\nAccel Radius: ");
        Serial.print(calibData.accel_radius);
        Serial.print("\nMag Radius: ");
        Serial.print(calibData.mag_radius);
    void bunnyPrintOrientation(double x, double y, double z) {
      Serial.print(F("Orientation: "));
      Serial.print((float)x);
      Serial.print(F(" "));
      Serial.print((float)y);
      Serial.print((float)z);
      Serial.println(F(""));
    void bunnyPrintCalibration() {
      uint8_t sys, gyro, accel, mag = 0;
      bno.getCalibration(&sys, &gyro, &accel, &mag);
      Serial.print(F("Calibration: "));
      Serial.print(sys, DEC);
        Arduino setup function (automatically called at startup)
    void setup(void)
        Serial.println("Orientation Sensor Test"); Serial.println("");
        /* Initialise the sensor */
        if (!bno.begin())
            /* There was a problem detecting the BNO055 ... check your connections */
            Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
            while (1);
        if(calibrate) {
          int eeAddress = 0;
          long bnoID;
          bool foundCalib = false;
          EEPROM.get(eeAddress, bnoID);
          adafruit_bno055_offsets_t calibrationData;
          sensor_t sensor;
          *  Look for the sensor's unique ID at the beginning oF EEPROM.
          *  This isn't foolproof, but it's better than nothing.
          if (bnoID != sensor.sensor_id)
              Serial.println("\nNo Calibration Data for this sensor exists in EEPROM");
              Serial.println("\nFound Calibration for this sensor in EEPROM.");
              eeAddress += sizeof(long);
              EEPROM.get(eeAddress, calibrationData);
              displaySensorOffsets(calibrationData);
              Serial.println("\n\nRestoring Calibration data to the BNO055...");
              bno.setSensorOffsets(calibrationData);
              Serial.println("\n\nCalibration data loaded into BNO055");
              foundCalib = true;
          /* Display some basic information on this sensor */
          displaySensorDetails();
          /* Optional: Display current status */
          displaySensorStatus();
         //Crystal must be configured AFTER loading calibration data into BNO055.
          bno.setExtCrystalUse(true);
          sensors_event_t event;
          bno.getEvent(&event);
          if (foundCalib){
              Serial.println("Move sensor slightly to calibrate magnetometers");
              while (!bno.isFullyCalibrated())
                  delay(BNO055_SAMPLERATE_DELAY_MS);
              Serial.println("Please Calibrate Sensor: ");
                  imu::Vector<3> euler = bno.getQuat().toEuler();
                  double x = euler.y() * degToRad;
                  double y = euler.z() * degToRad;
                  double z = euler.x() * degToRad;
                  Serial.print("X: ");
                  Serial.print(x, 4);
                  Serial.print(" Y: ");
                  Serial.print(y, 4);
                  Serial.print(" Z: ");
                  Serial.print(z, 4);
                  Serial.print("\t\t");
                  /* Optional: Display calibration status */
                  displayCalStatus();
                  /* New line for the next sample */
                  Serial.println("");
                  /* Wait the specified delay before requesting new data */
          Serial.println("\nFully calibrated!");
          Serial.println("--------------------------------");
          Serial.println("Calibration Results: ");
          adafruit_bno055_offsets_t newCalib;
          bno.getSensorOffsets(newCalib);
          displaySensorOffsets(newCalib);
          Serial.println("\n\nStoring calibration data to EEPROM...");
          eeAddress = 0;
          bnoID = sensor.sensor_id;
          EEPROM.put(eeAddress, bnoID);
          EEPROM.put(eeAddress, newCalib);
          Serial.println("Data stored to EEPROM.");
        else {
        if(zero) {
          Serial.println("Zeroing... Please do not move the device");
        bno.setMode(0X0C);
    int i = 0;
    double totEulerX = 0;
    double totEulerY = 0;
    double totEulerZ = 0;
    double subEulerX = 0;
    double subEulerY = 0;
    double subEulerZ = 0;
        imu::Vector<3> gyro = bno.getVector(Adafruit_BNO055::VECTOR_GYROSCOPE);
        if(zero == false) {
          i = zeroTime + 1;
        if(i < zeroTime) {
          totEulerX += euler.x();
          totEulerY += euler.y();
          totEulerZ += euler.z();
        else if(i == zeroTime) {
          subEulerX = totEulerX / 100;
          subEulerY = totEulerY / 100;
          subEulerZ = totEulerZ / 100;
        else {
          //Display the orientation data
          double x = (euler.y() - subEulerY) * degToRad;
          double y = (euler.z() - subEulerZ) * degToRad;
          double z = (euler.x() - subEulerX) * degToRad;
          Serial.print(x, 4);
          Serial.print(y, 4);
          Serial.print(z, 4);
          //Display the gyro data
          Serial.print(gyro.x());
          Serial.print(gyro.y());
          Serial.print(gyro.z());
          //Optional: Display calibration status
          //displayCalStatus();
          //Optional: Display sensor status (debug only)
          //displaySensorStatus();
          bunnyPrintOrientation(-(z - 90), x, -y);
          bunnyPrintCalibration();
          Serial.println("");
        i += 1;
    static int8_t sgn(int val) {
     if (val < 0) return -1;
     if (val==0) return 0;
     return 1;
    Last edited by defragster; 03-27-2019 at 07:09 AM. Reason: Used toolbar # to add [CODE] formatting
    8,321
    Please give details on the meaning of 'gave mistake '?
    Failed to compile? :: If so please show the verbose console output
    Compiled but failed to function?
    Or functioned but gave bad results?
    Please provide any resulting output that shows how far it got, or what was reported on Serial Monitor.
    Not clear what specific device is in use - if it can be powered by 3.3V that would be proper for Teensy 3.5
    Does the device include pullups? If not they need to be added to function with T_3.5. Diagram here shows use of 4.7K - but 2.2K is more typical for faster lower voltage of Teensy.
    We compiled at arduino but teensy gives mistake .
    ketch_mar27c: In function 'void setup()':
    sketch_mar27c:326: error: invalid conversion from 'int' to 'Adafruit_BNO055::adafruit_bno055_opmode_t' [-fpermissive]
    bno.setMode(0X0C);
    In file included from /Users/kerem/Documents/Arduino/sketch_mar27c/sketch_mar27c.ino:3:0:
    /Users/kerem/Documents/Arduino/libraries/Adafruit_BNO055-master/Adafruit_BNO055.h:287:8: note: initializing argument 1 of 'void Adafruit_BNO055::setMode(Adafruit_BNO055::adafruit _bno055_opmode_t)'
    void setMode(adafruit_bno055_opmode_t mode);
    /Users/kerem/Documents/Arduino/sketch_mar27c/sketch_mar27c.ino: At global scope:
    sketch_mar27c:401: warning: 'int8_t sgn(int)' defined but not used
    8,321
    Not sure if it is a simple as changing this line #326 :: bno.setMode(0X0C);
    to bno.setMode( (adafruit_bno055_opmode_t)0X0C);
    thank . i try
    aa: In function 'void setup()':
    aa:326: error: 'adafruit_bno055_opmode_t' was not declared in this scope
    /Users/kerem/Documents/Arduino/aa/aa.ino: At global scope:
    aa:401: warning: 'int8_t sgn(int)' defined but not used
    8,321
    That seemed too simple.
    The "adafruit_bno055_opmode_t" should be defined in :: /Users/kerem/Documents/Arduino/libraries/Adafruit_BNO055-master/Adafruit_BNO055.h
    It knew what it was in posting the error in post #3.
    Have you included the complete list of errors and warnings?
    In the IDE do a CTRL+T to FORMAT the code. Page down from the top and perhaps there will be broken indentation as an indication of an earlier problem.
    only written belows
    sketch_mar28d: In function 'void setup()':
    sketch_mar28d:326: error: 'adafruit_bno055_opmode_t' was not declared in this scope
    /Users/kerem/Documents/Arduino/sketch_mar28d/sketch_mar28d.ino: At global scope:
    sketch_mar28d:401: warning: 'int8_t sgn(int)' defined but not used
    Senior Member+
    New York
    3,192
    Try using setMode(OPERATION_MODE_NDOF)
    Since you are getting euler angles you shouldn't need to setMode to NDOF
    sketch_mar28i: In function 'void setup()':
    sketch_mar28i:326: error: 'OPERATION_MODE_NDOF' was not declared in this scope
    bno.setMode(OPERATION_MODE_NDOF);
    /Users/kerem/Documents/Arduino/sketch_mar28i/sketch_mar28i.ino: At global scope:
    sketch_mar28i:401: warning: 'int8_t sgn(int)' defined but not used
    it gave mistake , i can not compile to program thanks
    Senior Member+
    New York
    3,192
    Excuse me, my mistake:
        bno.setMode(Adafruit_BNO055::OPERATION_MODE_NDOF);
    This compiles fine for me on a T3.5. I forgot to specify the header correctly.
