This code works in Arduino but gave mistake at teensy 3.5 . Could any on help me?
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
#include <EEPROM.h>
/* This driver uses the Adafruit unified sensor library (Adafruit_Sensor),
which provides a common 'type' for sensor data and some helper functions.
To use this driver you will also need to download the Adafruit_Sensor
library and include it in your libraries folder.
You should also assign a unique ID to this sensor for use with
the Adafruit Sensor API so that you can identify this particular
sensor in any data logs, etc. To assign a unique ID, simply
provide an appropriate value in the constructor below (12345
is used by default in this example).
Connections
Connect SCL to analog 5
Connect SDA to analog 4
Connect VDD to 3-5V DC
Connect GROUND to common ground
History
2015/MAR/03 - First release (KTOWN)
2015/AUG/27 - Added calibration and system status helpers
2015/NOV/13 - Added calibration save and restore
* Orientation:
* front
* | BNO55 |
* | Vin |
* | 3Vo PS0 | <-- This side facing up
* | GND PS1 |
* | SDA IN1 | <-- The positive rotations follow the right hand rule and all the axis are aligned to how you would expect in a 3d coordinate plane
* | SCL ADW |
* | DST |
* | 9-Axis |
* back
bool zero = true;
bool calibrate = true;
int zeroTime = 50;
/* Set the delay between fresh samples */
#define BNO055_SAMPLERATE_DELAY_MS (100)
double degToRad = 57.295779513;
Adafruit_BNO055 bno = Adafruit_BNO055(55);
Displays some basic information on this sensor from the unified
sensor API sensor_t type (see Adafruit_Sensor for more information)
void displaySensorDetails(void)
sensor_t sensor;
bno.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print("Sensor: "); Serial.println(sensor.name);
Serial.print("Driver Ver: "); Serial.println(sensor.version);
Serial.print("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print("Max Value: "); Serial.print(sensor.max_value); Serial.println(" xxx");
Serial.print("Min Value: "); Serial.print(sensor.min_value); Serial.println(" xxx");
Serial.print("Resolution: "); Serial.print(sensor.resolution); Serial.println(" xxx");
Serial.println("");
Display some basic info about the sensor status
void displaySensorStatus(void)
/* Get the system status values (mostly for debugging purposes) */
uint8_t system_status, self_test_results, system_error;
system_status = self_test_results = system_error = 0;
bno.getSystemStatus(&system_status, &self_test_results, &system_error);
/* Display the results in the Serial Monitor */
Serial.println("");
Serial.print("System Status: 0x");
Serial.println(system_status, HEX);
Serial.print("Self Test: 0x");
Serial.println(self_test_results, HEX);
Serial.print("System Error: 0x");
Serial.println(system_error, HEX);
Serial.println("");
Display sensor calibration status
void displayCalStatus(void)
/* Get the four calibration values (0..3) */
/* Any sensor data reporting 0 should be ignored, */
/* 3 means 'fully calibrated" */
uint8_t system, gyro, accel, mag;
system = gyro = accel = mag = 0;
bno.getCalibration(&system, &gyro, &accel, &mag);
/* The data should be ignored until the system calibration is > 0 */
Serial.print("\t");
if (!system)
Serial.print("! ");
/* Display the individual values */
Serial.print("Sys:");
Serial.print(system, DEC);
Serial.print(" G:");
Serial.print(gyro, DEC);
Serial.print(" A:");
Serial.print(accel, DEC);
Serial.print(" M:");
Serial.print(mag, DEC);
Display the raw calibration offset and radius data
void displaySensorOffsets(const adafruit_bno055_offsets_t &calibData)
Serial.print("Accelerometer: ");
Serial.print(calibData.accel_offset_x); Serial.print(" ");
Serial.print(calibData.accel_offset_y); Serial.print(" ");
Serial.print(calibData.accel_offset_z); Serial.print(" ");
Serial.print("\nGyro: ");
Serial.print(calibData.gyro_offset_x); Serial.print(" ");
Serial.print(calibData.gyro_offset_y); Serial.print(" ");
Serial.print(calibData.gyro_offset_z); Serial.print(" ");
Serial.print("\nMag: ");
Serial.print(calibData.mag_offset_x); Serial.print(" ");
Serial.print(calibData.mag_offset_y); Serial.print(" ");
Serial.print(calibData.mag_offset_z); Serial.print(" ");
Serial.print("\nAccel Radius: ");
Serial.print(calibData.accel_radius);
Serial.print("\nMag Radius: ");
Serial.print(calibData.mag_radius);
void bunnyPrintOrientation(double x, double y, double z) {
Serial.print(F("Orientation: "));
Serial.print((float)x);
Serial.print(F(" "));
Serial.print((float)y);
Serial.print((float)z);
Serial.println(F(""));
void bunnyPrintCalibration() {
uint8_t sys, gyro, accel, mag = 0;
bno.getCalibration(&sys, &gyro, &accel, &mag);
Serial.print(F("Calibration: "));
Serial.print(sys, DEC);
Arduino setup function (automatically called at startup)
void setup(void)
Serial.println("Orientation Sensor Test"); Serial.println("");
/* Initialise the sensor */
if (!bno.begin())
/* There was a problem detecting the BNO055 ... check your connections */
Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
while (1);
if(calibrate) {
int eeAddress = 0;
long bnoID;
bool foundCalib = false;
EEPROM.get(eeAddress, bnoID);
adafruit_bno055_offsets_t calibrationData;
sensor_t sensor;
* Look for the sensor's unique ID at the beginning oF EEPROM.
* This isn't foolproof, but it's better than nothing.
if (bnoID != sensor.sensor_id)
Serial.println("\nNo Calibration Data for this sensor exists in EEPROM");
Serial.println("\nFound Calibration for this sensor in EEPROM.");
eeAddress += sizeof(long);
EEPROM.get(eeAddress, calibrationData);
displaySensorOffsets(calibrationData);
Serial.println("\n\nRestoring Calibration data to the BNO055...");
bno.setSensorOffsets(calibrationData);
Serial.println("\n\nCalibration data loaded into BNO055");
foundCalib = true;
/* Display some basic information on this sensor */
displaySensorDetails();
/* Optional: Display current status */
displaySensorStatus();
//Crystal must be configured AFTER loading calibration data into BNO055.
bno.setExtCrystalUse(true);
sensors_event_t event;
bno.getEvent(&event);
if (foundCalib){
Serial.println("Move sensor slightly to calibrate magnetometers");
while (!bno.isFullyCalibrated())
delay(BNO055_SAMPLERATE_DELAY_MS);
Serial.println("Please Calibrate Sensor: ");
imu::Vector<3> euler = bno.getQuat().toEuler();
double x = euler.y() * degToRad;
double y = euler.z() * degToRad;
double z = euler.x() * degToRad;
Serial.print("X: ");
Serial.print(x, 4);
Serial.print(" Y: ");
Serial.print(y, 4);
Serial.print(" Z: ");
Serial.print(z, 4);
Serial.print("\t\t");
/* Optional: Display calibration status */
displayCalStatus();
/* New line for the next sample */
Serial.println("");
/* Wait the specified delay before requesting new data */
Serial.println("\nFully calibrated!");
Serial.println("--------------------------------");
Serial.println("Calibration Results: ");
adafruit_bno055_offsets_t newCalib;
bno.getSensorOffsets(newCalib);
displaySensorOffsets(newCalib);
Serial.println("\n\nStoring calibration data to EEPROM...");
eeAddress = 0;
bnoID = sensor.sensor_id;
EEPROM.put(eeAddress, bnoID);
EEPROM.put(eeAddress, newCalib);
Serial.println("Data stored to EEPROM.");
else {
if(zero) {
Serial.println("Zeroing... Please do not move the device");
bno.setMode(0X0C);
int i = 0;
double totEulerX = 0;
double totEulerY = 0;
double totEulerZ = 0;
double subEulerX = 0;
double subEulerY = 0;
double subEulerZ = 0;
imu::Vector<3> gyro = bno.getVector(Adafruit_BNO055::VECTOR_GYROSCOPE);
if(zero == false) {
i = zeroTime + 1;
if(i < zeroTime) {
totEulerX += euler.x();
totEulerY += euler.y();
totEulerZ += euler.z();
else if(i == zeroTime) {
subEulerX = totEulerX / 100;
subEulerY = totEulerY / 100;
subEulerZ = totEulerZ / 100;
else {
//Display the orientation data
double x = (euler.y() - subEulerY) * degToRad;
double y = (euler.z() - subEulerZ) * degToRad;
double z = (euler.x() - subEulerX) * degToRad;
Serial.print(x, 4);
Serial.print(y, 4);
Serial.print(z, 4);
//Display the gyro data
Serial.print(gyro.x());
Serial.print(gyro.y());
Serial.print(gyro.z());
//Optional: Display calibration status
//displayCalStatus();
//Optional: Display sensor status (debug only)
//displaySensorStatus();
bunnyPrintOrientation(-(z - 90), x, -y);
bunnyPrintCalibration();
Serial.println("");
i += 1;
static int8_t sgn(int val) {
if (val < 0) return -1;
if (val==0) return 0;
return 1;
