Results 1 to 8 of 8
Thread: T3.2 - USB detection?
    Oct 2016
    170
    Hi, it's possible to know if the USB is connected or not to T3.2?
    I hope that it's possible to know for make a specific code if is connected to the USB or by battery.
    Thank u
    Dan
    19,932
    If you edit the low-level USB code, you can detect whether the USB host has assigned an address and a configuration number.
    Jun 2013
    296
    if (usb_configuration) {
    Oct 2016
    170
    Quote Originally Posted by yeahtuna View Post
    Works fine but if i unplug the USB cable "if (usb_configuration)" stay true... it's possible to reset without power off?
    Jun 2013
    296
    I'm not sure it this would work, but couldn't you read the voltage on the USB 5v when an analogRead?
    Oct 2016
    170
    itís perfect but is always true after the first plug of USB (computer, if itís a power supply stay false).
    Itís perfect but canít recognise when is disconnected after the first connection..
    Jun 2013
    296
    You will have to roll your own solution. Another thing I can think of would be to set a timer that periodically sends date to the host. If the function returns 0 bytes sent, you could likely infer that the connection was lost.
    2,952
    Depending on the Teensy, you would might need a voltage divider to bring the voltage down to 0..3.3v. You wouldn't need an analog read, a normal digital read would do.
