Hi All
Apologies for the general nature of this question, but I have only become more confused by what I have read.
There are no problems with the following code (yet), but I was wondering how the following arrays should be null terminated (if it isn't done automatically).
The following array contains 10 constant strings, the longest of which is 24 characters. Is it correct to declare it as [10][25]?
The next array contains 10 variable unsigned char which are filled as the user makes inputs via questions on 10 different pages. There will always be 10 char. Is it necessary to manually add a null terminator as each char is filled? As per below?
Thank you for your help.
const char variableNames[10][25] = {"Survey Mode : ", "Units : ", "Walking Pace (cm/s) : ", "Readings per Unit : ", "Traverses per Metre : ",
"Linear or Return : ", "Grid Length : ", "Grid Width : ", "Start Corner : ", "Start Direction : "};
byte surveyVariables[11];
if (page >= 1) {
surveyVariables[page - 2] = upDown;
[COLOR="#FF0000"] surveyVariables[page - 1] = '\0';[/COLOR]
