jonfarrugia
New member
I'm very new to the teensy line and I'm trying to convert my Canbus arduino code to work on the teensey 3.6.
I'm pretty sure I have most of it figured out except the Mask and Filter settings.
So I'm pretty sure there are 16 Mailboxes to send and recieve Canbus data. I've defiend two of them to be used as transmit. That leaves the first 14 to be used as receive mailboxes.
I would like to apply the same mask to all of them and then I have four filters to use. This is the code I have for Mask and filter settings:
Please let me know if I'm using the mask and filter correctly. I've applied the same extended mask to the begin statement and the first 14 mailboxes. Since I only have four filters i want to use, I used those same four filters across the 14 mailboxes. I am assuming that each mailbox has its own mask and filter and only the messages that are correctly filtered through that mask and filter, end up in that particular mailbox...am I correct on this assumption?
static CAN_filter_t RxFilter[16];
static CAN_filter_t RxMask[16];
long int place[] = {0x01,0x01+0xFF,0x01+0xFFFF,0x01+0xFFFFFF,0x01+0xFFFFFFFF,0x01+0xFFFFFFFFFF,0x01+0xFFFFFFFFFFFF};
//Canbus Module Address
bitWrite(CanAddress, 0, digitalRead(Canpin[0]));
bitWrite(CanAddress, 1, digitalRead(Canpin[1]));
bitWrite(CanAddress, 2, digitalRead(Canpin[2]));
bitWrite(CanAddress, 3, digitalRead(Canpin[3]));
bitWrite(CanAddress, 4, digitalRead(Canpin[4]));
bitWrite(CanAddress, 5, digitalRead(Canpin[5]));
bitWrite(CanAddress, 6, digitalRead(Canpin[6]));
bitWrite(CanAddress, 7, digitalRead(Canpin[7]));
bitWrite(CanAddress, 8, 0);
//Initialize CANbus Filters
RxFilter[0].id=0x00EAFF00;
RxFilter[0].ext=1;
RxFilter[0].rtr=0;
RxFilter[1].id=0x00EA0000 + (CanAddress * place[1]);
RxFilter[1].ext=1;
RxFilter[1].rtr=0;
RxFilter[2].id=0x00EFFF00;
RxFilter[2].ext=1;
RxFilter[2].rtr=0;
RxFilter[3].id=0x00EF0000 + (CanAddress * place[1]);
RxFilter[3].ext=1;
RxFilter[3].rtr=0;
RxFilter[4].id=0x00EAFF00;
RxFilter[4].ext=1;
RxFilter[4].rtr=0;
RxFilter[5].id=0x00EA0000 + (CanAddress * place[1]);
RxFilter[5].ext=1;
RxFilter[5].rtr=0;
RxFilter[6].id=0x00EFFF00;
RxFilter[6].ext=1;
RxFilter[6].rtr=0;
RxFilter[7].id=0x00EF0000 + (CanAddress * place[1]);
RxFilter[7].ext=1;
RxFilter[7].rtr=0;
RxFilter[8].id=0x00EAFF00;
RxFilter[8].ext=1;
RxFilter[8].rtr=0;
RxFilter[9].id=0x00EA0000 + (CanAddress * place[1]);
RxFilter[9].ext=1;
RxFilter[9].rtr=0;
RxFilter[10].id=0x00EFFF00;
RxFilter[10].ext=1;
RxFilter[10].rtr=0;
RxFilter[11].id=0x00EF0000 + (CanAddress * place[1]);
RxFilter[11].ext=1;
RxFilter[11].rtr=0;
RxFilter[12].id=0x00EAFF00;
RxFilter[12].ext=1;
RxFilter[12].rtr=0;
RxFilter[13].id=0x00EA0000 + (CanAddress * place[1]);
RxFilter[13].ext=1;
RxFilter[13].rtr=0;
RxFilter[14].id=0x00EFFF00;
RxFilter[14].ext=1;
RxFilter[14].rtr=0;
Can0.begin(100000,RxMask[16],1,1); //begin(baud, defaultMask, txAlt (29), RxAlt (30))
Can1.begin(100000,RxMask[16],0,0); //begin(baud, defaultMask, txAlt (33), RxAlt (34))
Can0.setNumTXBoxes(2); //2 buffers used for transmissions - buffers 14 & 15
Can1.setNumTXBoxes(2); //2 buffers used for transmissions - buffers 14 & 15
for (int c = 0; c < 14; c++)
Can0.setMask(RxMask[16].id,c);
Can1.setMask(RxMask[16].id,c);
Can0.setFilter(RxFilter[c], c);
Can1.setFilter(RxFilter[c], c);
