I'm making a simple application playing notes from a flash memory to the Dac output.
The flash memory is an 16 Mbit direct add-on to my Teensy 3.2 from Pesky product.
Everything plays as expected apart from a weak tone (a few hundred Hertz) in the background that is not on the file in the memory.
It continues as long as file is read from the memory.
Does anyone have any idea how to get rid of the disturbing sound?
The memory uses pin 13 as SCK which at the same time is the LED-pin. Can that be the problem?
Tomas
Simple example sketch:
Tomas
#include <Bounce.h>
// Create the Audio components. These should be created in the
// order data flows, inputs/sources -> processing -> outputs
AudioPlaySerialflashRaw bas0;
AudioMixer4 mix1;
AudioOutputAnalog dac; // play to on-chip DAC
// Create Audio connections between the components
AudioConnection c1(bas0, 0, mix1, 0);
AudioConnection c3(mix1, 0, dac, 0);
//Using 16Mbit SPI Flash memory add-ons for Teensy from Pesky products
// SPI flash
#define MOSI 11 // kets
#define MISO 12
#define SCK 13
#define CSPIN 10 // kets
// Audio connections require memory to work. For more
AudioMemory(30);
//Set up SPI
SPI.setMOSI(MOSI);
SPI.setMISO(MISO);
SPI.setSCK(SCK);
if (!SerialFlash.begin(CSPIN)) {
while (1) {
Serial.println("Unable to access SPI Flash chip");
// by default the Teensy 3.1 DAC uses 3.3Vp-p output
// if your 3.3V power has noise, switching to the
// internal 1.2V reference can give you a clean signal
//dac.analogReference(INTERNAL);
mix1.gain(0, 0.3);
bas0.play("C1.RAW");
delay(5000);
