Results 1 to 3 of 3
Thread: AudioPlayMemory limits
    Mar 2019
    17
    Hi people,
    Trying to work with many samples, and did the "wav2sketch" process. For prototyping I have only 8 samples that each ".cpp" file is about 364KB and the ".h" files are 101KB
    When I work with only 2 samples everything's fine. but when I add a third AudioSample I get this:
    (disregard all the other errors, and look at the "FLASH OVERFLOW" error)
    Arduino: 1.8.8 (Mac OS X), TD: 1.45, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz (overclock), Faster, US English"
    In file included from /Users/ayalrosenberg/Documents/Arduino/Thesis/Looper_Rec_sampleTest_piano/Looper_Rec_sampleTest_piano.ino:19:0:
    /Users/ayalrosenberg/Documents/Arduino/libraries/FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.002.006
     #    pragma message "FastLED version 3.002.006"
    Looper_Rec_sampleTest_piano: In function 'void loop()':
    Looper_Rec_sampleTest_piano:416: warning: comparison between signed and unsigned integer expressions
     if(blinkTime > millisBPM/4 ){
    /Applications/Arduino.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: /var/folders/3r/yp404b7s4hs9h93s9dk4r7400000gn/T/arduino_build_907650/Looper_Rec_sampleTest_piano.ino.elf section `.text' will not fit in region `FLASH'
    /Applications/Arduino.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: region `FLASH' overflowed by 102420 bytes
    collect2: error: ld returned 1 exit status
    Multiple libraries were found for "FastLED.h"
     Used: /Users/ayalrosenberg/Documents/Arduino/libraries/FastLED
     Not used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED
     Used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
     Not used: /Applications/Arduino.app/Contents/Java/libraries/SD
    Error compiling for board Teensy 3.2 / 3.1.
    So I'm trying to wrap my head around how many FLASH files can I include in a sketch (or how big)?
    Maybe that's not the problem?
    Help !
    Here's the full Code :
    // WAV files converted to code by wav2sketch
    //#include "AudioSampleSnare.h"        // http://www.freesound.org/people/KEVOY/sounds/82583/
    //#include "AudioSampleTomtom.h"       // http://www.freesound.org/people/zgump/sounds/86334/
    //#include "AudioSampleHihat.h"        // http://www.freesound.org/people/mhc/sounds/102790/
    //#include "AudioSampleKick.h"         // http://www.freesound.org/people/DWSD/sounds/171104/
    //#include "AudioSampleGong.h"         // http://www.freesound.org/people/juskiddink/sounds/86773/
    #include "AudioSampleC4.h" // http://www.freesound.org/people/kiddpark/sounds/201159/
    //#include "AudioSampleD4.h"
    //#include "AudioSampleE4.h"
    //#include "AudioSampleF4.h"
    #include "AudioSampleG4.h"
    #include "AudioSampleA4.h"
    //#include "AudioSampleB4.h"
    //#include "AudioSampleC5.h"
    /////LED//////
    #include <FastLED.h>
    #define LED_PIN     12
    #define NUM_LEDS    4
    CRGB leds[NUM_LEDS];
    #include <Bounce.h>
    #include "pitches.h"
    const unsigned int* notes[] = {
      AudioSampleC4, AudioSampleA4, AudioSampleG4, AudioSampleA4, AudioSampleC4, AudioSampleA4, AudioSampleC4, AudioSampleA4
    const unsigned int* melody1[64] = {};
    const unsigned int* melody2[64] = {};
    const unsigned int* melody3[64] = {};
    const unsigned int* melody4[64] = {};
    const unsigned int* melody1Play[64] = {};
    const unsigned int* melody2Play[64] = {};
    const unsigned int* melody3Play[64] = {};
    const unsigned int* melody4Play[64] = {};
    bool arrToggle12 = false;
    bool arrToggle34 = false;
    bool channelToggle = false;
    int play1MemMode = 0;
    int play2MemMode = 0;
    ///////CAP TOUCH///////////////////
    #include "Adafruit_MPR121.h"
    #ifndef _BV
    #define _BV(bit) (1 << (bit))
    #include <SerialFlash.h>
    AudioPlayMemory          playMem7;       //xy=81,253
    AudioPlayMemory          playMem3;       //xy=82,88
    AudioPlayMemory          playMem4;       //xy=82,121
    AudioPlayMemory          playMem8;       //xy=82,293
    AudioPlayMemory          playMem5;       //xy=83,166
    AudioPlayMemory          playMem6;       //xy=83,213
    AudioPlayMemory          playMem2;       //xy=84,53
    AudioPlayMemory          playMem1;       //xy=85,20
    AudioPlayMemory          playMem9; //xy=85,349
    AudioPlayMemory          playMem12; //xy=85,464
    AudioPlayMemory          playMem11; //xy=86,424
    AudioPlayMemory          playMem10; //xy=89,381
    AudioPlayMemory          playMem16; //xy=106,644
    AudioPlayMemory          playMem13; //xy=108,535
    AudioPlayMemory          playMem14; //xy=109,568
    AudioPlayMemory          playMem15; //xy=109,611
    AudioMixer4              mixer5; //xy=347,589
    AudioMixer4              mixer4; //xy=348,474
    AudioMixer4              mixer2;         //xy=355,322
    AudioMixer4              mixer1;         //xy=356,207
    AudioMixer4              mixer3;         //xy=568,260
    AudioOutputI2S           i2s1;           //xy=834,218
    AudioConnection          patchCord1(playMem7, 0, mixer2, 2);
    AudioConnection          patchCord2(playMem3, 0, mixer1, 2);
    AudioConnection          patchCord3(playMem4, 0, mixer1, 3);
    AudioConnection          patchCord4(playMem8, 0, mixer2, 3);
    AudioConnection          patchCord5(playMem5, 0, mixer2, 0);
    AudioConnection          patchCord6(playMem6, 0, mixer2, 1);
    AudioConnection          patchCord7(playMem2, 0, mixer1, 1);
    AudioConnection          patchCord8(playMem1, 0, mixer1, 0);
    AudioConnection          patchCord9(playMem9, 0, mixer4, 0);
    AudioConnection          patchCord10(playMem12, 0, mixer4, 3);
    AudioConnection          patchCord11(playMem11, 0, mixer4, 2);
    AudioConnection          patchCord12(playMem10, 0, mixer4, 1);
    AudioConnection          patchCord13(playMem16, 0, mixer5, 3);
    AudioConnection          patchCord14(playMem13, 0, mixer5, 0);
    AudioConnection          patchCord15(playMem14, 0, mixer5, 1);
    AudioConnection          patchCord16(playMem15, 0, mixer5, 2);
    AudioConnection          patchCord17(mixer5, 0, mixer3, 3);
    AudioConnection          patchCord18(mixer4, 0, mixer3, 2);
    AudioConnection          patchCord19(mixer2, 0, mixer3, 1);
    AudioConnection          patchCord20(mixer1, 0, mixer3, 0);
    AudioConnection          patchCord21(mixer3, 0, i2s1, 0);
    AudioConnection          patchCord22(mixer3, 0, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=643,692
    //CAP TOUCH Vars//
    Adafruit_MPR121 cap = Adafruit_MPR121();
    uint16_t lasttouched = 0;
    uint16_t currtouched = 0;
    // Bounce objects to read pushbuttons
    Bounce rec1Button = Bounce(0, 15);
    Bounce play1Button = Bounce(1, 15);
    Bounce rec2Button = Bounce(2, 15);
    Bounce play2Button = Bounce(3, 15);
    //Bounce button5 = Bounce(4, 15);
    //Bounce button6 = Bounce(5, 15);
    //Bounce button7 = Bounce(6, 15);
    //Bounce button8 = Bounce(8, 15);
    //TEMPO Vars//
    elapsedMillis blinkTime;
    elapsedMillis loopTime;
    int tempoPin = A0;
    int millisBPM = 0;
    int bars;
    int bpm;
    int tempoCounter = 0;
    int barsCounter = 0;
    bool didPlay = false;
    bool didBarPlay = false;
    //int timing[];
    ////////LED Vars//////
    FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
        while (!Serial) { // needed to keep leonardo/micro from starting too fast!
        delay(10);
    //  Serial.println("Adafruit MPR121 Capacitive Touch sensor test");
      // Default address is 0x5A, if tied to 3.3V its 0x5B
      // If tied to SDA its 0x5C and if SCL then 0x5D
      if (!cap.begin(0x5A)) {
    //    Serial.println("MPR121 not found, check wiring?");
        while (1);
    //  Serial.println("MPR121 found!");
      pinMode(0, INPUT_PULLUP);
      pinMode(1, INPUT_PULLUP);
      pinMode(2, INPUT_PULLUP);
      pinMode(3, INPUT_PULLUP);
    //  pinMode(4, INPUT_PULLUP);
    //  pinMode(5, INPUT_PULLUP);
    //  pinMode(6, INPUT_PULLUP);
    //  pinMode(8, INPUT_PULLUP);
      AudioMemory(10);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.5);
      ///////////MIXERS IN///////////////////
      mixer1.gain(0, 0.4);
      mixer1.gain(1, 0.4);
      mixer1.gain(2, 0.4);
      mixer1.gain(3, 0.4);
      mixer2.gain(0, 0.4);
      mixer2.gain(1, 0.4);
      mixer2.gain(2, 0.4);
      mixer2.gain(3, 0.4);
      mixer4.gain(0, 0.4);
      mixer4.gain(1, 0.4);
      mixer4.gain(2, 0.4);
      mixer4.gain(3, 0.4);
      mixer5.gain(0, 0.4);
      mixer5.gain(1, 0.4);
      mixer5.gain(2, 0.4);
      mixer5.gain(3, 0.4);
      ////////////////MIXER OUT////////////
      mixer3.gain(0, 0.4);
      mixer3.gain(1, 0.4);
      mixer3.gain(2, 0.4);
      mixer3.gain(3, 0.4);
    // //Envelope///
    //  envelope1.attack(0.3);
    //  envelope1.hold(0);
    //  envelope1.decay(0.1);
    //  envelope1.sustain(0.3);
    //  envelope1.release(1000);
    //  envelope2.attack(0.3);
    //  envelope2.hold(0);
    //  envelope2.decay(0.1);
    //  envelope2.sustain(0.3);
    //  envelope2.release(1000);
    bool preCount = false;
    bool isRec1 = false;
    bool isPlay1 = false;
    bool isRec2 = false;
    bool isPlay2 = false;
    bool rec1Mode = false;//////TOGGLE REC1 AND STOP
    bool rec2Mode = false;//////TOGGLE REC2 AND STOP
    bool play1Mode = false;//////TOGGLE PLAY1 AND STOP
    bool play2Mode = false;//////TOGGLE PLAY2 AND STOP
    ////////////MAKE LEDS BLACK////////////
    if (!isPlay1 && !isRec1 && !isPlay2 && !isRec2){
      for (int i = 0; i < NUM_LEDS; i++){
        leds[i] = CRGB::Black;
        FastLED.show();
    /////////////////BPM///////////////////////
    bpm = map(analogRead(tempoPin),0,1023,60,140);
    millisBPM = 60000/bpm;
    bars = millisBPM/4;
    ///////////BUTTON CHECK////////////
    rec1Button.update();
    if (rec1Button.fallingEdge()){
      if (rec1Mode == false){
      preCount = true;
      barsCounter = 0;
     ///////////////CLEAR THE RECORD AND PLAY ARRAYS//////////////////
      memset(melody1, 0, sizeof(melody1));
      memset(melody2, 0, sizeof(melody2));
      memset(melody1Play, 0, sizeof(melody1Play));
      memset(melody2Play, 0, sizeof(melody2Play));
      Serial.println("record12");
      isRec1 = true;
      //////STOP IF PLAY 1 IS PLAYING//////////////
      isPlay1 = false;
      isRec2 = false;
        barsCounter = 0;
    //    envelope1.noteOff();
        for (int i = 0; i < 64; i++){
          melody1Play[i] = melody1[i];
          melody2Play[i] = melody2[i];
         isRec1 = false;
        Serial.println("stopRecording1");
     rec1Mode = !rec1Mode;
    play1Button.update();
    if (play1Button.fallingEdge()){
      if (!play1Mode){
      ////////DONT REC WHILE PLAY/////////////
      isRec1 = false;
      barsCounter = 0;
      isPlay1 = true;
        Serial.println("play1");
        barsCounter = 0;
        Serial.println("stopPlaying1");
        isPlay1 = false;
        FastLED.show();
      play1Mode = !play1Mode;
    rec2Button.update();
    if (rec2Button.fallingEdge()){
      if (rec2Mode == false){
      preCount = true;
      barsCounter = 0;
      memset(melody3, 0, sizeof(melody3));
      memset(melody4, 0, sizeof(melody4));
      memset(melody3Play, 0, sizeof(melody3Play));
      memset(melody4Play, 0, sizeof(melody4Play));
      Serial.println("record34");
      isPlay2 = false;
      isRec2 = true;
      isRec1 = false;
        barsCounter = 0;
    //    envelope2.noteOff();
          melody3Play[i] = melody3[i];
          melody4Play[i] = melody4[i];
        isRec2 = false;
        channelToggle = true;
        Serial.println("stopRecording2");
       rec2Mode = !rec2Mode;
    play2Button.update();
    if (play2Button.fallingEdge()){
       if (!play2Mode){
      isRec2 = false;
      barsCounter = 0;
      isPlay2 = true;
        Serial.println("play2");
        barsCounter = 0;
        Serial.println("stopPlaying2");
        isPlay2 = false;
        FastLED.show();
      play2Mode = !play2Mode;
    //recButton.update();
    //if (recButton.fallingEdge()){
    //  preCount = true;
    //  barsCounter = 0;
    //  memset(melody1, 0, sizeof(melody1));
    //  memset(melody2, 0, sizeof(melody2));
    //    Serial.println("record");
    //  arrToggle = false;
    //playButton.update();
    //if (playButton.fallingEdge()){
    //  barsCounter = 0;
    //  isPlay = true;
    //    Serial.println("play");
    //stopButton.update();
    //if (stopButton.fallingEdge()){
    //  isPlay = false;
    //  isRec = false;
    //  tempoCounter = 0;
    //  barsCounter = 0;
    //  for (int i = 0; i < 64; i++){
    //    melody1Play[i] = melody1[i];
    //    melody2Play[i] = melody2[i];
    //    Serial.println("stop");
    //channelButton.update();
    //if(channelButton.fallingEdge()){
    //    channelToggle = !channelToggle;
    ////////////PRECOUNT/////////////////////
    if (preCount){
    //     playMem1.play(AudioSampleTomtom);
       leds[0] = CRGB::Red;
          FastLED.show();
       delay(millisBPM);
    //   playMem1.play(AudioSampleSnare);
       leds[0] = CRGB::Green;
          FastLED.show();
       delay(millisBPM);
          FastLED.show();
       delay(millisBPM);
          FastLED.show();
       delay(millisBPM);
          FastLED.show();
       delay(millisBPM);
          FastLED.show();
       delay(millisBPM);
          FastLED.show();
       delay(millisBPM);
          FastLED.show();
       delay(millisBPM);
      preCount = false;
    ///////////////////SEQUENCE////////////////////
    if(isRec1 || isPlay1 || isRec2 || isPlay2){
    //////////////////Couner of bars///////////
          barsCounter ++;
          didPlay = false;
          didBarPlay = false;
          blinkTime = 0;
          Serial.println(barsCounter);
    ///////////////////CLICK////////////////////
      if (barsCounter == 4 && !didPlay){
        leds[3] = CRGB::Black;
    //    Serial.println('!');
    //    Serial.println(bpm);
        didPlay = true;
        FastLED.show();
      } else if (barsCounter == 8 && !didPlay){
        leds[0] = CRGB::Black;
    //    Serial.println('/');
        didPlay = true;
        leds[1] = CRGB::Green;
        FastLED.show();
      } else if (barsCounter == 12 && !didPlay){
        leds[1] = CRGB::Black;
        didPlay = true;
        leds[2] = CRGB::Green;
        FastLED.show();
      } else if (barsCounter == 16 && !didPlay){
        leds[2] = CRGB::Black;
        didPlay = true;
        leds[3] = CRGB::Green;
        FastLED.show();
      } else if(barsCounter == 20 && !didPlay){
        didPlay = true;
        FastLED.show();
      } else if (barsCounter == 24 && !didPlay){
        didPlay = true;
        FastLED.show();
      } else if (barsCounter == 28 && !didPlay){
        didPlay = true;
        FastLED.show();
      } else if (barsCounter == 32 && !didPlay){
        didPlay = true;
        FastLED.show();
      }else if(barsCounter == 36 && !didPlay){
        didPlay = true;
        FastLED.show();
      } else if (barsCounter == 40 && !didPlay){
        didPlay = true;
        FastLED.show();
      } else if (barsCounter == 44 && !didPlay){
        didPlay = true;
        FastLED.show();
      } else if (barsCounter == 48 && !didPlay){
        didPlay = true;
        FastLED.show();
      }else if(barsCounter == 52 && !didPlay){
        didPlay = true;
        FastLED.show();
      } else if (barsCounter == 56 && !didPlay){
        didPlay = true;
        FastLED.show();
      } else if (barsCounter == 60 && !didPlay){
        didPlay = true;
        FastLED.show();
      } else if (barsCounter == 64 && !didPlay){
        didPlay = true;
        FastLED.show();
    ///////////////////PLAY THE LOOP//////////////////
    if (isPlay1){
      if(didBarPlay == false){
        if(arrToggle12 == true){
          if(melody1Play[barsCounter]!= NULL){
           if (play1MemMode == 0){
            playMem1.play(melody1Play[barsCounter]);
            } else if (play1MemMode == 1){
              playMem2.play(melody1Play[barsCounter]);
             } else if (play1MemMode == 2){
              playMem3.play(melody1Play[barsCounter]);
              } else if (play1MemMode == 3){
              playMem4.play(melody1Play[barsCounter]);
              } else if (play1MemMode == 4){
              playMem5.play(melody1Play[barsCounter]);
             } else if (play1MemMode == 5){
              playMem6.play(melody1Play[barsCounter]);
              } else if (play1MemMode == 6){
              playMem7.play(melody1Play[barsCounter]);
              }else if (play1MemMode == 7){
              playMem8.play(melody1Play[barsCounter]);
            play1MemMode ++;
       }else if(arrToggle12 == false){
        if(melody2Play[barsCounter]!= NULL){
            playMem1.play(melody2Play[barsCounter]);
              playMem2.play(melody2Play[barsCounter]);
              playMem3.play(melody2Play[barsCounter]);
              playMem4.play(melody2Play[barsCounter]);
              playMem5.play(melody2Play[barsCounter]);
              playMem6.play(melody2Play[barsCounter]);
              playMem7.play(melody2Play[barsCounter]);
              playMem8.play(melody2Play[barsCounter]);
            play1MemMode ++;
      if (isPlay2){
        if(arrToggle34 == true){
          if(melody3Play[barsCounter]!= NULL){
           if (play2MemMode == 0){
            playMem9.play(melody3Play[barsCounter]);
            } else if (play2MemMode == 1){
              playMem10.play(melody3Play[barsCounter]);
             } else if (play2MemMode == 2){
              playMem11.play(melody3Play[barsCounter]);
              } else if (play2MemMode == 3){
              playMem12.play(melody3Play[barsCounter]);
              } else if (play2MemMode == 4){
              playMem13.play(melody3Play[barsCounter]);
             } else if (play2MemMode == 5){
              playMem14.play(melody3Play[barsCounter]);
              } else if (play2MemMode == 6){
              playMem15.play(melody3Play[barsCounter]);
              }else if (play2MemMode == 7){
              playMem16.play(melody3Play[barsCounter]);
            play2MemMode ++;
       }else if(arrToggle34 == false){
        if(melody4Play[barsCounter]!= NULL){
            playMem9.play(melody4Play[barsCounter]);
              playMem10.play(melody4Play[barsCounter]);
              playMem11.play(melody4Play[barsCounter]);
              playMem12.play(melody4Play[barsCounter]);
              playMem13.play(melody4Play[barsCounter]);
              playMem14.play(melody4Play[barsCounter]);
              playMem15.play(melody4Play[barsCounter]);
              playMem16.play(melody4Play[barsCounter]);
            play2MemMode ++;
      didBarPlay = true;
    ////////////////Counter reset/////////////////
        if (barsCounter >= 64){
          barsCounter = 0;
          if (isPlay1){
            if (arrToggle12){
            Serial.println("playing array 1");
    //      for(int i = 0; i < sizeof(melody1); i++){
    //        Serial.println(melody1[i]);
              Serial.println("playing array 2");
            if (isPlay2){
              if (arrToggle34){
            Serial.println("playing array 3");
              Serial.println("playing array 4");
          if (isRec1){
            arrToggle12 = !arrToggle12;
            if (arrToggle12){
              }else {
            if (isRec2){
            arrToggle34 = !arrToggle34;
            if (arrToggle34){
              }else {
    //////////////KEYBOARD////////////////////
    currtouched = cap.touched();
     for (uint8_t i=0; i<12; i++) {
      //////////////////KEYBOARD PLAY////////////////////////
        if ((currtouched & _BV(i)) && !(lasttouched & _BV(i)) ) {
         if(isPlay1){
            playMem9.play(notes[i]);
              playMem10.play(notes[i]);
              playMem11.play(notes[i]);
              playMem12.play(notes[i]);
              playMem13.play(notes[i]);
              playMem14.play(notes[i]);
              playMem15.play(notes[i]);
              playMem16.play(notes[i]);
            play2MemMode ++;
        }else if (isPlay2){
            playMem1.play(notes[i]);
              playMem2.play(notes[i]);
              playMem3.play(notes[i]);
              playMem4.play(notes[i]);
              playMem5.play(notes[i]);
              playMem6.play(notes[i]);
              playMem7.play(notes[i]);
              playMem8.play(notes[i]);
            play1MemMode ++;
    //    if (play1MemMode > 7){
    //      play1MemMode = 0;
        else {
            play1MemMode ++;
    ////////////////////////KEYBOARD RECORD////////////////////////
          if (isRec2){
            if (!arrToggle34){
              melody3[barsCounter] = notes[i];
             }else{
              melody4[barsCounter] = notes[i];
            } else if (isRec1){
              if (!arrToggle12){
              melody1[barsCounter] = notes[i];
              }else{
              melody2[barsCounter] = notes[i];
          ////////////////BURNING THE SAMPLES TO THE ARRAYS/////////////////
    //    if(isRec1){
    //       if((currtouched & _BV(i))){
    //          if (!arrToggle12){
    //          melody1[barsCounter] = notes[i];
    //         }else{
    //          melody2[barsCounter] = notes[i];
    //      if (isRec2){
    //          if (!arrToggle34){
    //          melody3[barsCounter] = notes[i];
    //         }else{
    //          melody4[barsCounter] = notes[i];
          play1MemMode = 0;
        if (play2MemMode > 7){
          play2MemMode = 0;
      // reset our state
      lasttouched = currtouched;
    Mar 2019
    17
    Correction - the .h files are 101bytes and not KB
    1,915
    you need to look at the size of the array in the audio sample .h file. for example, in AudioSampleSnare.h
    extern const unsigned int AudioSampleSnare[2817];
    So that array consumes 11268 bytes of FLASH. (if 8-bit mono encoding @44.1khz, that's about quarter a second of audio.)
    The audio lib and teensy core consumes about 27KB of FLASH (out of 256KB for T3.2), leaving 235KB of flash for in-memory audio data (about 5.3 seconds of audio).
