Results 1 to 8 of 8
Thread: One Midi Device not working with the USBHost_t36 library
    I am building a device that should be able to connect to several Roland devices. So far I am quite successful, as three of the four devices are working, but one is not. Here is a short video of the current progress on this project:
    https://youtu.be/a3bDT5Viceo
    The device that is not working seems to be transmitting data, but seems to be receiving bogus data. It does send and receive MIDI PC messages, but it does not seem to respond to sysex data.
    Here is how I invoke the library:
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    MIDIDevice_BigBuffer usbhMIDI(myusb);
    In the library I made the following changes:
    In USBHost_t36.h I increased the RX_QUEUE_SIZE - this seemed to be the solution for one of my devices:
    class MIDIDevice_BigBuffer : public MIDIDeviceBase {
    public:
    	MIDIDevice_BigBuffer(USBHost &host) :
    		MIDIDeviceBase(host, rx, tx1, tx2, MAX_PACKET_SIZE, queue, RX_QUEUE_SIZE) {};
    	// MIDIDevice(USBHost *host) : ....
    private:
    	enum { MAX_PACKET_SIZE = 512 };
    	enum { RX_QUEUE_SIZE = 1600 }; // must be more than MAX_PACKET_SIZE/4
    	uint32_t rx[MAX_PACKET_SIZE/4];
    	uint32_t tx1[MAX_PACKET_SIZE/4];
    	uint32_t tx2[MAX_PACKET_SIZE/4];
    	uint32_t queue[RX_QUEUE_SIZE];
    But I am still at a loss with my Boss GP-10 to which sysex data requests are sent, but no sysex data is coming back.
    The unit should respond to the universal identity request message (it does when I test it with other USB hosts). This message contains the following bytes: 0xF0, 0x7E, 0x7F, 0x06, 0x01, 0xF7.
    I enabled debugging and here is the output:
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
     reset waited 5
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 1FFF9000
    periodictable = 1FFF9000
    port change: 10001803
        connect
      begin reset
    port change: 18001205
      port enabled
      end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 FF 00 FF 40 82 05 85 01 00 00 01 02 00 01
        VendorID = 0582, ProductID = 0185, Version = 0000
        Class/Subclass/Protocol = 255 / 0 / 255
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: BOSS
    enumeration:
    Product: GP-10
    enumeration:
    Config data length = 176
    enumeration:
    Configuration Descriptor:
      09 02 B0 00 04 01 00 C0 00
        NumInterfaces = 4
        ConfigurationValue = 1
      09 04 00 00 00 FF FF 00 00
        Interface = 0
        Number of endpoints = 0
        Class/Subclass/Protocol = 255 / 255 / 0
      09 04 01 00 00 FF 02 02 00
        Interface = 1
        Class/Subclass/Protocol = 255 / 2 / 2
      06 24 F1 01 00 00
      09 04 01 01 01 FF 02 02 00
        Interface = 1
        Number of endpoints = 1
      07 24 01 01 00 01 00
      0B 24 02 01 08 04 18 01 44 AC 00
      07 05 0D 05 00 01 01
        Endpoint = 13 OUT
        Type = Isochronous
        Max Size = 256
        Polling Interval = 1
      07 25 01 00 00 00 00
      09 04 02 00 00 FF 02 01 00
        Interface = 2
        Class/Subclass/Protocol = 255 / 2 / 1
      09 04 02 01 01 FF 02 01 00
        Interface = 2
      07 24 01 07 00 01 00
      07 05 8E 25 00 01 01
        Endpoint = 14 IN
        Type = Isochronous
        Max Size = 256
      09 04 03 00 02 FF 03 00 00
        Interface = 3
        Number of endpoints = 2
        Class/Subclass/Protocol = 255 / 3 / 0
      06 24 F1 02 02 02
      07 05 03 02 00 02 01
        Endpoint = 3 OUT
        Type = Bulk
        Max Size = 512
      07 05 84 02 00 02 00
        Endpoint = 4 IN
        Type = Bulk
        Max Size = 512
        Polling Interval = 0
      09 04 03 01 02 FF 03 00 00
        Interface = 3
        Endpoint = 3 OUT
        Type = Bulk
        Max Size = 512
      07 05 85 03 00 02 01
        Endpoint = 5 IN
        Type = Interrupt
        Max Size = 512
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=1FFF49E0
    USBHub claim_device this=1FFF2E20
    Descriptor 4 = INTERFACE
    MIDIDevice claim this=1FFF5C40
    len = 167
      Interface is unknown (might be Yahama)
    type: 4, len: 9
    This interface is not MIDI
    len = 158
    type: 36, len: 6
        Unknown MIDI CS_INTERFACE descriptor!
    Descriptor 36 =  ???
    len = 143
    type: 36, len: 7
        MIDI Header (ignored)
    type: 36, len: 11
        MIDI IN Jack (ignored)
    type: 5, len: 7
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 5 = ENDPOINT
    Descriptor 37 =  ???
    len = 102
    type: 4, len: 9
    len = 93
    type: 36, len: 7
    type: 36, len: 11
    type: 5, len: 7
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 37 =  ???
    len = 52
    type: 36, len: 6
        Roland vendor-specific (ignored)
    type: 5, len: 7
        MIDI Endpoint: 3
          tx_size = 512
    type: 5, len: 7
        MIDI Endpoint: 84
          rx_size = 512
    type: 4, len: 9
    new_Pipe
    new_Pipe
    Descriptor 36 =  ???
    MIDIDevice Receive
      MIDI Data: 0B B0 65 00 1B B0 65 00 0B B0 64 00 1B B0 64 00 0B B0 06 18 1B B0 06 18 0B B0 26 00 1B B0 26 00 0B B0 65 7F 1B B0 65 7F 0B B0 64 7F 1B B0 64 7F 0B B1 65 00 1B B1 65 00 0B B1 64 00 1B B1 64 00 0B B1 06 18 1B B1 06 18 0B B1 26 00 1B B1 26 00 0B B1 65 7F 1B B1 65 7F 0B B1 64 7F 1B B1 64 7F 0B B2 65 00 1B B2 65 00 0B B2 64 00 1B B2 64 00 0B B2 06 18 1B B2 06 18 0B B2 26 00 1B B2 26 00 0B B2 65 7F 1B B2 65 7F 0B B2 64 7F 1B B2 64 7F 0B B3 65 00 1B B3 65 00 0B B3 64 00 1B B3 64 00 0B B3 06 18 1B B3 06 18 0B B3 26 00 1B B3 26 00 0B B3 65 7F 1B B3 65 7F 0B B3 64 7F 1B B3 64 7F 0B B4 65 00 1B B4 65 00 0B B4 64 00 1B B4 64 00 0B B4 06 18 1B B4 06 18 0B B4 26 00 1B B4 26 00 0B B4 65 7F 1B B4 65 7F 0B B4 64 7F 1B B4 64 7F 0B B5 65 00 1B B5 65 00 0B B5 64 00 1B B5 64 00 0B B5 06 18 1B B5 06 18 0B B5 26 00 1B B5 26 00 0B B5 65 7F 1B B5 65 7F 0B B5 64 7F 1B B5 64 7F 0B B0 65 00 1B B0 65 00 0B B0 64 01 1B B0 64 01 0B B0 06 40 1B B0 06 40 0B B0 26 00 1B B0 26 00 0B B0 65 7F 1B B0 65 7F 0B B0 64 7F 1B B0 64 7F 0B B1 65 00 1B B1 65 00 0B B1 64 01 1B B1 64 01 0B B1 06 40 1B B1 06 40 0B B1 26 00 1B B1 26 00 0B B1 65 7F 1B B1 65 7F 0B B1 64 7F 1B B1 64 7F 0B B2 65 00 1B B2 65 00 0B B2 64 01 1B B2 64 01 0B B2 06 40 1B B2 06 40 0B B2 26 00 1B B2 26 00 0B B2 65 7F 1B B2 65 7F 0B B2 64 7F 1B B2 64 7F 0B B3 65 00 1B B3 65 00 0B B3 64 01 1B B3 64 01 0B B3 06 40 1B B3 06 40 0B B3 26 00 1B B3 26 00 0B B3 65 7F 1B B3 65 7F 0B B3 64 7F 1B B3 64 7F 0B B4 65 00 1B B4 65 00 0B B4 64 01 1B B4 64 01 0B B4 06 40 1B B4 06 40 0B B4 26 00 1B B4 26 00
    avail = 1471
    queue another receive packet
    read: 65B00B
    read: 65B01B
    read: 64B00B
    reaMIDIDevice Receive
      MIDI Data: 0B B4 65 7F 1B B4 65 7F 0B B4 64 7F 1B B4 64 7F 0B B5 65 00 1B B5 65 00 0B B5 64 01 1B B5 64 01 0B B5 06 40 1B B5 06 40 0B B5 26 00 1B B5 26 00 0B B5 65 7F 1B B5 65 7F 0B B5 64 7F 1B B5 64 7F
    avail = 1459
    queue another rd: 64B01B
    read: 1806B00B
    read: 1806B01B
    read: 26B00B
    read: 26B01B
    read: 7F65B00B
    read: 7F65B01B
    read: 7F64B00B
    read: 7F64B01B
    read: 65B10B
    read: 65B11B
    read: 64B10B
    read: 64B11B
    read: 1806B10B
    read: 1806B11B
    read: 26B10B
    read: 26B11B
    read: 7F65B10B
    read: 7F65B11B
    read: 7F64B10B
    read: 7F64B11B
    read: 65B20B
    read: 65B21B
    read: 64B20B
    read: 64B21B
    read: 1806B20B
    read: 1806B21B
    read: 26B20B
    read: 26B21B
    read: 7F65B20B
    read: 7F65B21B
    read: 7F64B20B
    read: 7F64B21B
    read: 65B30B
    read: 65B31B
    read: 64B30B
    read: 64B31B
    read: 1806B30B
    read: 1806B31B
    read: 26B30B
    read: 26B31B
    read: 7F65B30B
    read: 7F65B31B
    read: 7F64B30B
    read: 7F64B31B
    read: 65B40B
    read: 65B41B
    read: 64B40B
    read: 64B41B
    read: 1806B40B
    read: 1806B41B
    read: 26B40B
    read: 26B41B
    read: 7F65B40B
    read: 7F65B41B
    read: 7F64B40B
    read: 7F64B41B
    read: 65B50B
    read: 65B51B
    read: 64B50B
    read: 64B51B
    read: 1806B50B
    read: 1806B51B
    read: 26B50B
    read: 26B51B
    read: 7F65B50B
    read: 7F65B51B
    read: 7F64B50B
    read: 7F64B51B
    read: 65B00B
    read: 65B01B
    read: 164B00B
    read: 164B01B
    read: 4006B00B
    read: 4006B01B
    read: 26B00B
    read: 26B01B
    read: 7F65B00B
    read: 7F65B01B
    read: 7F64B00B
    read: 7F64B01B
    read: 65B10B
    read: 65B11B
    read: 164B10B
    read: 164B11B
    read: 4006B10B
    read: 4006B11B
    read: 26B10B
    read: 26B11B
    read: 7F65B10B
    read: 7F65B11B
    read: 7F64B10B
    read: 7F64B11B
    read: 65B20B
    read: 65B21B
    read: 164B20B
    read: 164B21B
    read: 4006B20B
    read: 4006B21B
    read: 26B20B
    read: 26B21B
    read: 7F65B20B
    read: 7F65B21B
    read: 7F64B20B
    read: 7F64B21B
    read: 65B30B
    read: 65B31B
    read: 164B30B
    read: 164B31B
    read: 4006B30B
    read: 4006B31B
    read: 26B30B
    read: 26B31B
    read: 7F65B30B
    read: 7F65B31B
    read: 7F64B30B
    read: 7F64B31B
    read: 65B40B
    read: 65B41B
    read: 164B40B
    read: 164B41B
    read: 4006B40B
    read: 4006B41B
    read: 26B40B
    read: 26B41B
    read: 7F65B40B
    read: 7F65B41B
    read: 7F64B40B
    read: 7F64B41B
    read: 65B50B
    read: 65B51B
    read: 164B50B
    read: 164B51B
    read: 4006B50B
    read: 4006B51B
    read: 26B50B
    read: 26B51B
    read: 7F65B50B
    read: 7F65B51B
    read: 7F64B50B
    read: 7F64B51B
    MIDIDevice transmit complete
      MIDI Data: 04 F0 7E 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      MIDI Data: 07 06 01 F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    I would welcome any suggestions of things I can check.
    Here is the output from one of the devices that is working (Boss Katana 100):
    sizeof Device = 36
    sizeof Pipe = 96
    power up USBHS PHY
     reset waited 5
    port change: 10001003
        connect
    port change: 1C001002
        disconnect
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 FF 00 FF 40 82 05 D8 01 00 00 01 02 00 01
        VendorID = 0582, ProductID = 01D8, Version = 0000
    enumeration:
    enumeration:
    Manufacturer: BOSS
    enumeration:
    Product: KATANA
    enumeration:
    Config data length = 188
    enumeration:
      09 02 BC 00 04 01 00 C0 00
        NumInterfaces = 4
        Interface = 0
        Interface = 1
      06 24 F1 01 00 00
        Interface = 1
      0B 24 02 01 04 04 18 01 44 AC 00
      06 24 F1 04 16 00
      07 05 0D 05 70 00 01
        Endpoint = 13 OUT
        Type = Isochronous
        Max Size = 112
        Interface = 2
        Interface = 2
      06 24 F1 04 16 00
      07 05 8E 25 70 00 01
        Endpoint = 14 IN
        Type = Isochronous
        Max Size = 112
        Interface = 3
      06 24 F1 02 03 03
        Endpoint = 3 OUT
        Type = Bulk
        Max Size = 512
        Endpoint = 4 IN
        Type = Bulk
        Max Size = 512
        Interface = 3
      07 05 03 03 00 02 04
        Endpoint = 3 OUT
        Type = Interrupt
        Max Size = 512
        Polling Interval = 4
      07 05 85 03 00 02 04
        Endpoint = 5 IN
        Type = Interrupt
        Max Size = 512
    enumeration:
    len = 179
    type: 4, len: 9
    len = 170
    type: 36, len: 6
    Descriptor 36 =  ???
    len = 155
    type: 36, len: 7
    type: 36, len: 11
    type: 36, len: 6
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 37 =  ???
    len = 108
    type: 4, len: 9
    len = 99
    type: 36, len: 7
    type: 36, len: 11
    type: 36, len: 6
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 37 =  ???
    len = 52
    type: 36, len: 6
    type: 5, len: 7
        MIDI Endpoint: 3
          tx_size = 512
    type: 5, len: 7
        MIDI Endpoint: 84
          rx_size = 512
    type: 4, len: 9
    new_Pipe
    new_Pipe
    Descriptor 36 =  ???
    MIDIDevice Receive
      MIDI Data: 04 F0 7E 00 04 06 02 41 04 33 03 00 04 00 01 01 07 00 00 F7
    avail = 1594
    read: 7EF004
    read: 41020604
    read: 33304
    read: 1010004
    read: F7000007
      MIDI Data: 04 F0 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      MIDI Data: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      MIDI Data: 04 33 12 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      MIDI Data: 04 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      MIDI Data: 07 01 7F F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      MIDI Data: 04 33 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      MIDI Data: 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      MIDI Data: 07 02 7D F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    MIDIDevice Receive
      MIDI Data: 04 F0 41 00 04 00 00 00 04 33 12 00 04 01 00 00 04 00 00 7F 05 F7 00 00
    avail = 1593
      MIDI Data: 04 33 11 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    I have looked at this issue for many hours now, and I cannot get my head around it. Though I would reply to my own post to bump it and hope somebody will give me some new ideas or clues.
    A few things I noticed:
    - The Boss GP-10 responds very sluggishly to MIDI PC messages using the host port of the Teensy 3.6. When I connect via my Mac with MIDI forwarding, the GP-10 responds very quickly to PC messages and everything works including sysex.
    - The burst of MIDI CC-messages only happens once using the host port of the Teensy after connection. Using other ports these messages never appear. Am I connection to the correct port.
    Here is my basic test sketch:
    #include <USBHost_t36.h>
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    uint32_t timer = 0;
    const uint32_t TIME = 1000; // 1 sec between identity request messages
      myusb.begin();
      usbhMIDI.setHandleSysEx(OnSysEx);
      myusb.Task();
      usbhMIDI.read();
      if (millis() > timer) {
        SendIdentityRequest();
        timer = millis() + TIME;
    void OnSysEx(const unsigned char* sxdata, short unsigned int sxlength, bool sx_comp)
      Serial.print("Receiving " + String(sxlength) + " bytes: ");
      for (uint8_t i = 0; i < sxlength; i++) {
        if (sxdata[i] < 0x10) Serial.print("0" + String(sxdata[i], HEX) + " ");
        else Serial.print(String(sxdata[i], HEX) + " ");
    #define Anybody_out_there {0xF0, 0x7E, 0x7F, 0x06, 0x01, 0xF7}  // Ask all MIDI devices to respond with their Manufacturing ID, Device ID and version number
    void SendIdentityRequest() {
      uint8_t sxdata[6] = Anybody_out_there;
      usbhMIDI.sendSysEx(6, sxdata, true);
      Serial.println("Sending identity request");
    Anybody have any ideas?
    Apr 2019
    12
    Hello, this is probably of no use to you but the Boss GP-10 is not MIDI Class compliant:
    https://www.soundonsound.com/reviews/boss-gp-10
    Quote Originally Posted by UHF View Post
    Most non compliant Boss/Roland can be fixed by adding a quirk to the usb host library. The USBHost_t36 library has this quirk and it works for the Boss Katana, the Roland GR55 and VG99 which all are not class compliant. It is just the GP-10 that is not working.
    20,169
    Oh, looks like another not-quite-compliant MIDI device!
    Just to set your expectations... after T4 is released (sorry, can't do much until then), if you're willing to run lots of tests, we probably can figure out what's wrong. It's a slow and frustrating process, but eventually we did get those Yamaha guitar effects boxes to work. This will probably end up being similar.
    Usually the best place to look for info is the Linux "quirks" files. If there are quirks mode definitions for this device, looks at what the Linux kernel does is usually the shortest path.
    Thanks for replying Paul. I will revive thuis thread once T4 is out and the issue had not been solved some other way.
    Today I finally solved this issue. It turns out the Boss GP-10 only supports sysex messages via cable 1. The default is cable 0. So the example above will work by changing one line:
    usbhMIDI.sendSysEx(6, sxdata, true, 1);
