Good Evening everyone, I have been looking at this issue for a long time. I feel it is something simple but I can't seem to figure this one out.
my goal here is to use a interrupt to clear my OLED screen. It will be a switch in the long run and when the switch is high I would like to clear the display and use a pot to set the current time and make a timer.
I got this to work with just one function OLEDflag. Which had the code that clocktimerset has now.
I was told you want to keep the interrupt code short and simple. THis is why i'm just making a if statement to change the state which will feed info another loop to run the code.
The error I have is a warring, Multiple definitions of 'OLEDclockset' not sure how to fix this.
i'm now here so go easy on me
Let me know if you need more info !!
Thank you ,
Joe
Following code show main.cpp
Thank you ,
Joe
#include <U8g2lib.h> // OLED
#ifdef U8X8_HAVE_HW_I2C
class OLED
private:
public:
void intdisplay();
void OLEDdraw(int potvalue, int currenttimer, String RelayString);
}; // end class OLED
int OLEDclockset;
void OLEDflag(); //Not in a class Because this is used for an interrupt function it needs to be global
int clocktimerset();
#include <OLED.h>
#include <Arduino.h>
#include <wire.h>
//******************************************Declare*****************************//
U8G2_SH1106_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/U8X8_PIN_NONE);
//******************************************Setup*****************************//
void OLED::intdisplay()
u8g2.begin(); // Start the Library code for the OLED
} // end void OLED
//*****************************************Functions**************************//
void OLED::OLEDdraw(int potvalue, int currenttimer, String RelayString)
u8g2.clearBuffer(); // clear the internal memory
u8g2.setFlipMode(1); // Flips display 180 (1) = True
u8g2.setFont(u8g2_font_koleeko_tr); // choose a suitable font
u8g2.drawStr(0, 10, "Pot Value:");
u8g2.setCursor(70, 10); // set cursor location
u8g2.print(potvalue); // print at current cursor location
u8g2.drawStr(85, 10, " % ");
u8g2.drawStr(0, 25, "Relay State:");
u8g2.setCursor(85, 25); // set cursor location
u8g2.print(RelayString);
u8g2.drawStr(0, 50, "Runing Timer(s):");
u8g2.setCursor(0, 60); // set cursor location
u8g2.print(currenttimer); // print at current cursor location
u8g2.sendBuffer(); // transfer internal memory to the display
} // end void OLED
void OLEDflag()
if (HIGH)
OLEDclockset = 1;
OLEDclockset = 0;
} // end void OLEDflag
int clocktimerset()
while (OLEDclockset == 1)
u8g2.clearBuffer(); // clears current display
u8g2.drawStr(0, 10, "Set Clock:");
u8g2.drawStr(0, 25, "Set Timer");
u8g2.sendBuffer();
delay(500); // Needs to change, I can't have my timer get deplayed because I want to change the time... Think about?
return (0);
} //end clocktimerset
// Start Date: 03/15/19
// Completion Date: n/A
// Discription: This project will be able to display current time, set relay on/off
// time, the use of pots and buttons to navigate around the OLED display and set
// time to use for a timer.
#include <potentiometer.h>
#include <OLED.h>
#include <rtc.h>
#include <timer.h>
#include <wire.h> // i/O pins
#include <avr/io.h> // interrupt
#include <avr/interrupt.h> // interrupt
Timer12hour Timer12hour0; // Setting Object 0 for Timer12hour0
OLED OLED0; // Setting Object 0 for OLED
Timer12hour0.setuptimer();
OLED0.intdisplay();
intrtc(); // get current time, set Serial
pinMode(0, INPUT);
attachInterrupt(digitalPinToInterrupt(0), OLEDflag, HIGH); // Setting interrupt pin D0
} //end setup
//******************************************Main******************************//
displaytime();
Timer12hour0.timer();
Potentiometer Potentiometer0; // Updated Pot Value
OLED0.OLEDdraw(Potentiometer0.getpot(), Timer12hour0.timer(), Timer12hour0.getRelayString());
} // end void loop
