I'm working with a wonderful MIDI-to-CV converter designed by little-scale, and have spent the morning adding a 5-pin DIN input. Accessing the clock messages works brilliantly when using usbMIDI.setHandleRealTimeSystem (code pasted below), but isn't so clear when using DIN MIDI where setHandleRealTimeSystem isn't available
ex: When sending MIDI clock from an electron machinedrum, a clock message 0xf8 occurs 24 times per quarter note. Anyone know of a way to access the clock ticks in a similar manner as is done with usbMIDI.setHandleRealTimeSystem?
Arduino: 1.8.7 (Mac OS X), TD: 1.45, Board: "Teensy LC, Serial + MIDI, 48 MHz, Smallest Code, US English"
'class midi::MidiInterface<HardwareSerial>' has no member named 'setHandleRealTimeSystem'
#include <MIDI.h> //--------------------
const int pitchbend_value_positive = 1200;
const int pitchbend_value_negative = -1200;
const float offset_pitch = 60;
const int LED = 13;
int cs_pin = 21;
int gate_pin = 7;
int pitchbend_value[8];
int pitch_values[8];
int cs9 = 2;
byte shadow_gate;
byte clock_tick;
byte clock_value;
byte play_flag;
byte play_tick;
float voltage_range = 4.024 * 1200;
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
SPI.begin();
pinMode(cs9, OUTPUT);
for (int i = 0; i < 8; i ++) {
pinMode(cs_pin - i, OUTPUT);
digitalWriteFast(cs_pin - i, HIGH);
writeGate(i, HIGH);
delay(50);
for (int i = 0; i < 4; i ++) {
pinMode(gate_pin + i, OUTPUT);
digitalWrite(gate_pin + i, HIGH);
delay(50);
writeGate(i, LOW);
digitalWrite(gate_pin + i, LOW);
usbMIDI.setHandleNoteOn(OnNoteOn);
usbMIDI.setHandleNoteOff(OnNoteOff);
usbMIDI.setHandlePitchChange(OnPitchChange);
usbMIDI.setHandleRealTimeSystem(OnClock);
Serial1.setRX(3); // 5-pin DIN MIDI IN
MIDI.begin(MIDI_CHANNEL_OMNI);
MIDI.setHandlePitchBend(OnPitchChange);
//MIDI.setHandleRealTimeSystem(OnClock); // setHandleRealTimeSystem is not a member of the MidiInterface class
Serial.begin(57600);
usbMIDI.read();
MIDI.read();
void OnNoteOn(byte channel, byte pitch, byte velocity) {
if (channel < 9) {
pitch_values[channel - 1] = pitch;
writeDAC(cs_pin - channel + 1, 1, constrain(map((pitch - offset_pitch) * 100.0 + pitchbend_value[channel - 1], 0.0, voltage_range, 0.0, 4095.0), 0.0, 4095.0));
writeDAC(cs_pin - channel + 1, 0, map(velocity, 0, 127, 0, 4095));
if (velocity > 0) {
writeGate(channel - 1, HIGH);
else {
writeGate(channel - 1, LOW);
else if (channel == 9) {
if (velocity > 0) {
digitalWriteFast(gate_pin + (3 - (pitch % 4)), HIGH);
else {
digitalWriteFast(gate_pin + (3 - (pitch % 4)), LOW);
void OnNoteOff(byte channel, byte pitch, byte velocity) {
if (channel < 9) {
else {
void OnPitchChange (byte channel, int pitch_change) {
if (channel < 9) {
pitchbend_value[channel - 1] = map(pitch_change, 0, 16383, pitchbend_value_negative, pitchbend_value_positive);
writeDAC(cs_pin - channel + 1, 1, constrain(map((pitch_values[channel - 1] - offset_pitch) * 100.0 + pitchbend_value[channel - 1], 0.0, voltage_range, 0.0, 4095.0), 0.0, 4095.0));
void writeDAC (int cs, int dac, int val) {
digitalWriteFast(cs, LOW);
dac = dac & 1;
val = val & 4095;
SPI.transfer(dac << 7 | 0 << 5 | 1 << 4 | val >> 8);
SPI.transfer(val & 255);
digitalWriteFast(cs, HIGH);
void writeGate(byte bit_number, byte bit_value) {
bitWrite(shadow_gate, bit_number, bit_value);
digitalWriteFast(cs9, LOW);
SPI.transfer(shadow_gate);
digitalWriteFast(cs9, HIGH);
void OnClock(byte clockbyte) {
if (clockbyte == 0xf8 && play_flag == 1) {
digitalWriteFast(9, 1 - bitRead(clock_tick, 0)); // 12 ppqn
digitalWriteFast(8, 1 - bitRead(clock_tick / 3, 0)); // sixteenths
digitalWriteFast(7, 1 - bitRead(clock_tick / 6, 0)); // eights
digitalWriteFast(LED, 1 - bitRead(clock_tick / 12, 0)); // quarter note LED flash
clock_tick ++;
if (clock_tick == 24) {
clock_tick = 0;
if (clock_tick == 6 && play_tick == 1) {
play_tick = 0;
digitalWriteFast(10, LOW);
if (clockbyte == 0xfa || clockbyte == 0xfb) { // start or continue bytes
play_flag = 1;
play_tick = 1;
clock_value = 0;
clock_tick = 0;
digitalWriteFast(10, HIGH);
if (clockbyte == 0xfc) { // stop byte
digitalWriteFast(9, LOW);
digitalWriteFast(8, LOW);
digitalWriteFast(7, LOW);
digitalWriteFast(LED, LOW);
play_flag = 0;
