Results 1 to 7 of 7
Thread: T3.6 USB Host - New USB Keyboard
    The USB HOST support in Teensyduino 3.6 has been fantastic, testing has gone well with a few MIDI devices and keyboards so far.
    I picked up a new USB 48-key Mechanical Keyboard (https://www.amazon.com/Koolertron-Si.../dp/B076LRJ528), it's connecting but fails after the first Key Press with ERROR Followup no matter which initial key is pressed.
    Teensyduino 3.6 (180 Mhz)/Loader 1.45
    Arduino 1.88
    USBHost_t36/blob/master/examples/Test/Test.ino
    I've enabled USBHOST_PRINT_DEBUG in USBHost_t36.h and captured connecting, keypress and disconnect. I'm hoping the log picks what the problem could be, happy to make any code changes to get this keyboard working.
    USB Host Testing
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
    port change: 10001803
        connect
      begin reset
    port change: 10001805
      port enabled
      end recovery
    new_Device: 12 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 00 00 00 08 B4 04 18 08 10 60 01 02 03 01
        VendorID = 04B4, ProductID = 0818, Version = 6010
        Class/Subclass/Protocol = 0 / 0 / 0
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: LingYao ShangHai
    enumeration:
    Product: Thumb Keyboard
    enumeration:
    Serial Number: 000000000000
    enumeration:
    Config data length = 59
    enumeration:
    Configuration Descriptor:
      09 02 3B 00 02 01 00 80 32
        NumInterfaces = 2
        ConfigurationValue = 1
      09 04 00 00 01 03 01 01 04
        Interface = 0
        Number of endpoints = 1
        Class/Subclass/Protocol = 3(HID) / 1(Boot) / 1(Keyboard)
      09 21 11 01 21 01 22 3F 00
        HID, 1 report descriptor
      07 05 81 03 12 00 0A
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 18
        Polling Interval = 10
      09 04 01 00 01 03 01 02 05
        Interface = 1
        Class/Subclass/Protocol = 3(HID) / 1(Boot) / 2(Mouse)
      09 21 11 01 21 01 22 32 00
      07 05 82 03 08 00 02
        Endpoint = 2 IN
        Type = Interrupt
        Max Size = 8
        Polling Interval = 2
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=1FFF8700
    KeyboardController claim this=1FFFA540
    KeyboardController claim this=1FFFA7C0
    KeyboardController claim this=1FFFAA40
    Descriptor 4 = INTERFACE
    ep = 81
    packet size = 18
    polling interval = 10
    new_Pipe
    allocate_interrupt_pipe_bandwidth
     best_bandwidth = 3, at offset = 0, shift= 0
    Descriptor 33 = HID
    Descriptor 5 = ENDPOINT
    MIDIDevice claim this=1FFF94C0
    len = 25
    Descriptor 33 = HID
    control callback (keyboard)
      mesg = B21
    KeyboardController Callback (member)
      KB Data: 00 00 00 5C 00 00 00 00
      press, key=92
      unicode = 216
    key '⸮'  216
    key ⸮
    ERROR Followup
    port change: 1C00100A
        disconnect
    disconnect_Device:
    USBDriver (available_drivers) list: 1FFF8700 -> 1FFFA7C0 -> 1FFFAA40 -> 1FFF94C0
    USBDriver (dev->drivers) list: 1FFFA540
    disconnect driver 1FFFA540
    USBDriver (available_drivers) list: 1FFFA540 -> 1FFF8700 -> 1FFFA7C0 -> 1FFFAA40 -> 1FFF94C0
    delete_Pipe 1FFF9920
      Free transfers
        * 536855680 * remove * defer free until QH
      Free transfers attached to QH
        * 536855680
        * 536844992
    * Delete Pipe completed
    delete_Pipe 1FFFC400
      shut down async schedule
      Free transfers
        * 536855744
    removed Device_t from devlist
      disable
    11,929
    There is an updated Beta for T_3.6 on this thread that might give different results :: T3-6-USB-Host-Bluetooth
    It is generally Bluetooth - but it seems other things for host have been done
    7,090
    My Gut tells me, this one might be problematic and maybe requires someone who has it to debug it...
    When you look at the product page, it shows that it requires Windows 7, 8, 10. And if you are going to try to use it with Linux or MAC, you first must configure it with a Windows machine...
    Also wondering how the code is handling the mapping of raw input to unicode...
    Ok thanks, I tried the T3-6-USB-Host-Bluetooth fork with similar results. I did however enable a bit more debugging, seems to exit at stat & USBHS_USBSTS_UEI error check in ehci.cpp. I'm a bit new to HID programming, so it's unclear what next steps might be.
    The programmer that comes with the SMKD72-A 48-Key runs on Windows and allows customization and persistent writing to the MCU. I've loaded a Default config, and it runs on my Mac as well as Windows without issues. I think the idea is the USB keyboard is intended (and should work) with any USB Host but the programmer is available on Windows.
    The manufacturer provides a helpful public link to manuals, HID guide, and software in a RAR file here: https://amazonfiles.s3.amazonaws.com/smkd72.rar
    There is quite a bit to configuration beyond key assignments, like Key Rate (1-100ms), Mouse Rate (2-100ms), etc. I've been experimenting with bouncing between Default and custom configurations to see if it helps get USB Keyboard working.
    ISR: 408C
     Port Change
        connect
    ISR: 1004088
     Timer0
      begin reset
    ISR: 408C
     Port Change
      port enabled
    ISR: 1004080
     Timer0
      end recovery
    new_Pipe
    ISR: 4E081
     USB Async
    Async Followup
    Transfer Followup List 1FFF2620 to 1FFF44C0
        forward:
        1FFF2620 SETUP
        1FFF4480 IN 0
        1FFF44C0 OUT 0
        backward:
        1FFF44C0 OUT 0
        1FFF4480 IN 0
        1FFF2620 SETUP
    enumeration:
    ISR: 4E081
     USB Async
    Async Followup
    Transfer Followup List 1FFF4540 to 1FFF2620
        forward:
        1FFF4540 SETUP
        1FFF2620 IN 0
        backward:
        1FFF2620 IN 0
        1FFF4540 SETUP
    enumeration:
    ISR: 4E081
     USB Async
    Async Followup
    Transfer Followup List 1FFF4480 to 1FFF44C0
        forward:
        1FFF4480 SETUP
        1FFF2660 IN 0
        1FFF44C0 OUT 0
        backward:
        1FFF44C0 OUT 0
        1FFF2660 IN 0
        1FFF4480 SETUP
    enumeration:
    Device Descriptor:
    ISR: 4E081
     USB Async
    Async Followup
    Transfer Followup List 1FFF4540 to 1FFF4480
        forward:
        1FFF4540 SETUP
        1FFF2620 IN 504
        1FFF4480 OUT 0
        backward:
        1FFF4480 OUT 0
        1FFF2620 IN 504
        1FFF4540 SETUP
    enumeration:
    ISR: 4E081
     USB Async
    Async Followup
    Transfer Followup List 1FFF2660 to 1FFF4540
        forward:
        1FFF2660 SETUP
        1FFF44C0 IN 474
        1FFF4540 OUT 0
        backward:
        1FFF4540 OUT 0
        1FFF44C0 IN 474
        1FFF2660 SETUP
    enumeration:
    ISR: 4E081
     USB Async
    Async Followup
    Transfer Followup List 1FFF2620 to 1FFF2660
        forward:
        1FFF2620 SETUP
        1FFF4480 IN 478
        1FFF2660 OUT 0
        backward:
        1FFF2660 OUT 0
        1FFF4480 IN 478
        1FFF2620 SETUP
    enumeration:
    ISR: 4E081
     USB Async
    Async Followup
    Transfer Followup List 1FFF44C0 to 1FFF2620
        forward:
        1FFF44C0 SETUP
        1FFF4540 IN 482
        1FFF2620 OUT 0
        backward:
        1FFF2620 OUT 0
        1FFF4540 IN 482
        1FFF44C0 SETUP
    enumeration:
    Serial Number: 081820131130
    ISR: 4E081
     USB Async
    Async Followup
        forward:
        1FFF4480 SETUP
        1FFF2660 IN 0
        1FFF44C0 OUT 0
        backward:
        1FFF44C0 OUT 0
        1FFF2660 IN 0
        1FFF4480 SETUP
    enumeration:
    ISR: 4E081
     USB Async
    Async Followup
        forward:
        1FFF4540 SETUP
        1FFF2620 IN 0
        1FFF4480 OUT 0
        backward:
        1FFF4480 OUT 0
        1FFF2620 IN 0
        1FFF4540 SETUP
    enumeration:
        NumInterfaces = 2
        Interface = 0
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 18
        Interface = 1
        Endpoint = 2 IN
        Type = Interrupt
        Max Size = 8
    ISR: 4E081
     USB Async
    Async Followup
        forward:
        1FFF2660 SETUP
        1FFF4540 IN 0
        backward:
        1FFF4540 IN 0
        1FFF2660 SETUP
    enumeration:
    KeyboardController claim this=1FFF26E0
    USBHub claim_device this=1FFF2960
    USBHub claim_device this=1FFF2D20
    USBHub claim_device this=1FFF30E0
    09 04 00 00 01 03 01 01 04 09 21 11 01 21 01 22 3F 00 07 05 81 03 12 00 0A 09 04 01 00 01 03 01 02 05 09 21 11 01 21 01 22 32 00 07 05 82 03 08 00 02
    ep = 81
    packet size = 18
    new_Pipe
    Descriptor 33 = HID
    MIDIDevice claim this=1FFF2020
    len = 25
    Descriptor 33 = HID
      mesg = A21
    ISR: 4E081
     USB Async
    Async Followup
    Transfer Followup List 0 to 0
        forward:
        backward:
    ISR: 8E08B
     USB Error
     USB Periodic
    Periodic Followup
      KB Data: 00 00 00 16 00 00 00 00
      release, key=20
      press, key=22
      unicode = 115
    key 's'  115
    ERROR Followup
    ERROR Followup End
    A follow-up, also tried the SMKD72-A keyboard with Raspberry Pi 3 B+ without issue (as above, also works on macos and Win10).
    Any tips for USB debugging & T3-6-USB-Host-Bluetooth?
    Forgot to add the raspberrypi lsusb output, which appears to treat the device as a USB keyboard HID and a mouse HID:
    pi@raspberrypi:~ $ lsusb -v -d  04b4:0818
    Bus 001 Device 005: ID 04b4:0818 Cypress Semiconductor Corp.
    Couldn't open device, some information will be missing
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            0 (Defined at Interface level)
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0         8
      idVendor           0x04b4 Cypress Semiconductor Corp.
      idProduct          0x0818
      bcdDevice           60.10
      iManufacturer           1
      iProduct                2
      iSerial                 3
      bNumConfigurations      1
        bLength                 9
        bDescriptorType         2
        wTotalLength           59
        bNumInterfaces          2
        bConfigurationValue     1
        iConfiguration          0
        bmAttributes         0x80
          (Bus Powered)
        MaxPower              100mA
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceClass         3 Human Interface Device
          bInterfaceSubClass      1 Boot Interface Subclass
          bInterfaceProtocol      1 Keyboard
          iInterface              4
            HID Device Descriptor:
              bLength                 9
              bDescriptorType        33
              bcdHID               1.11
              bCountryCode           33 US
              bNumDescriptors         1
              bDescriptorType        34 Report
              wDescriptorLength      63
             Report Descriptors:
               ** UNAVAILABLE **
          Endpoint Descriptor:
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x81  EP 1 IN
            bmAttributes            3
              Transfer Type            Interrupt
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0012  1x 18 bytes
            bInterval              10
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceProtocol      2 Mouse
          iInterface              5
              bLength                 9
              bDescriptorType        33
              bcdHID               1.11
              bCountryCode           33 US
              bNumDescriptors         1
              wDescriptorLength      50
             Report Descriptors:
               ** UNAVAILABLE **
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x82  EP 2 IN
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0008  1x 8 bytes
            bInterval               2
    pi@raspberrypi:~ $
    7,090
    Probably without one of these, the next thing I would try, is to see if it trying to force keyboard to use boot mode would help.
    I did not look at your data close enough, but look in keyboard.cpp there is a force boot table with one entry. Try adding your vid and see if it makes a difference
