Teensy 3.6 can not write to EEPROM memory when running faster than 120 MHz
Can some body confirm if Teensy 3.6 can read/write EEPROM at speed > 120Mhz?
The situation is exactly as that page documents:
Teensy 3.6 can not write to EEPROM memory when running faster than 120 MHz. The EEPROM library will automatically reduce the processor's speed during the time EEPROM data is written. If using Serial1 or Serial2, communication may be disrupted due to baud rate changes. Other serial ports are not affected by the temporary speed change during EEPROM writing.
If you are running at 180 MHz and attempt to write to EEPROM, Teensy 3.6 will briefly drop to a slower speed while performing the EEPROM write.
So the answer to your question really depends on the context. If you're asking about whether you can use the EEPROM library to write to the EEPROM memory, then yes, you can. But it does have a minor side effect which usually is only observable if using fast baud rates on Serial1 or Serial2. For most practical purposes, writing to EEPROM works fine when running at 180 or 240 MHz.
If you're asking about the actual underlying hardware capability, then no, writing to non-volatile memory is impossible when in HSRUN mode (which is used for speeds over 120 MHz).
Thanks Paul,
If my Serial 1 and 2 are running at 115200 baud rate (fast baud rate?), would the writing to EEPROM affect the communication? Also, if I drop the Teensy 3.6 speed to 120Mhz, then there will be no more issues to the Serial1/2 during writing to the EEPROM, right?
Correct - if compiled at 120 MHz (or lower)- there will be no need to change the clock speed for EEPROM write and system operation continues at speed with no clock changes.
If Serial 1 or 2 Rx or Tx happen during the clock change when dropped down to 120 MHz for EEPROM write that may affect those bytes.
