Hey guys, I've been using the FlexCAN library for some time now, but never used hardware filters. Trying to implement them now, but am having some issues.
EDIT:
My testing method is that I have a CAN2.0 device sending out a frame every 50ms with ID 0x720. I seem to always be getting these frames no matter how I set up my filter and mask.
I have also tried editing the FlexCAN.cpp. When I run the Can0.begin, it initializes with a defaultFilter of 0,0,0 for ext, rtr, and id respectively, as well as setting each mask to 0.
I changed this to:
Still no luck.
If anyone has any advice I would greatly appreciate it! I looked to Paul's github, but it seems to be an older version of the FlexCAN library.
Thanks,
- Tool: Teensy 3.6
- FlexCAN version: the one included in the most recent Teensyduino
EDIT:
CAN_filter_t hs_filter;
hs_filter.ext = 0;
hs_filter.rtr = 0;
hs_filter.id = 0x5FF;
Can0.begin(500000);
for (int c = 0; c < 14; c++) // 14 is from NUM_MAILBOXES - numTxMailboxes
Can0.setMask(0xFFFF, c); // setMask takes uint32_t mask variable. 0xFFFF should only accept the one ID.
Can0.setFilter(hs_filter, c);
CAN_filter_t defaultFilter;
defaultFilter.ext = 0;
defaultFilter.rtr = 0;
defaultFilter.id = 0;
for (int c = 0; c < NUM_MAILBOXES - numTxMailboxes; c++)
setMask(0, c);
setFilter(defaultFilter, c);
I changed this to:
defaultFilter.id = 0x5FF;
setMask(0xFFFF, c);
Still no luck.
Thanks,
