SoftwareSerial.cpp (formerly NewSoftSerial.cpp) -
Multi-instance software serial library for Arduino/Wiring
-- Interrupt-driven receive and other improvements by ladyada
(http://ladyada.net)
-- Tuning, circular buffer, derivation from class Print/Stream,
multi-instance support, porting to 8MHz processors,
various optimizations, PROGMEM delay tables, inverse logic and
direct port writing by Mikal Hart (http://www.arduiniana.org)
-- Pin change interrupt macros by Paul Stoffregen (http://www.pjrc.com)
-- 20MHz processor support by Garrett Mace (http://www.macetech.com)
-- ATmega1280/2560 support by Brett Hagman (http://www.roguerobotics.com/)
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
The latest version of this library can always be found at
http://arduiniana.org.
// When set, _DEBUG co-opts pins 11 and 13 for debugging with an
// oscilloscope or logic analyzer. Beware: it also slightly modifies
// the bit times, so don't rely on it too much at high baud rates
#define _DEBUG 0
#define _DEBUG_PIN1 11
#define _DEBUG_PIN2 13
// Includes
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#include <Arduino.h>
#include <SoftwareSerial.h>
#if defined(__MK20DX128__) || defined(__MK20DX256__) || defined(__MKL26Z64__) || defined(__MK64FX512__) || defined(__MK66FX1M0__)
SoftwareSerial::SoftwareSerial(uint8_t rxPin, uint8_t txPin, bool inverse_logic /* = false */)
buffer_overflow = false;
if (rxPin == 0 && txPin == 1) {
port = &Serial1;
return;
} else if (rxPin == 9 && txPin == 10) {
port = &Serial2;
return;
} else if (rxPin == 7 && txPin == 8) {
port = &Serial3;
return;
port = NULL;
pinMode(txPin, OUTPUT);
pinMode(rxPin, INPUT_PULLUP);
txpin = txPin;
rxpin = rxPin;
txreg = portOutputRegister(digitalPinToPort(txPin));
rxreg = portInputRegister(digitalPinToPort(rxPin));
cycles_per_bit = 0;
void SoftwareSerial::begin(unsigned long speed)
if (port) {
port->begin(speed);
cycles_per_bit = (uint32_t)(F_CPU + speed / 2) / speed;
ARM_DEMCR |= ARM_DEMCR_TRCENA;
ARM_DWT_CTRL |= ARM_DWT_CTRL_CYCCNTENA;
void SoftwareSerial::end()
if (port) {
port->end();
port = NULL;
pinMode(txpin, INPUT);
pinMode(rxpin, INPUT);
cycles_per_bit = 0;
// The worst case expected length of any interrupt routines. If an
// interrupt runs longer than this number of cycles, it can disrupt
// the transmit waveform. Increasing this number causes SoftwareSerial
// to hog the CPU longer, delaying all interrupt response for other
// libraries, so this should be made as small as possible but still
// ensure accurate transmit waveforms.
#define WORST_INTERRUPT_CYCLES 360
static void wait_for_target(uint32_t begin, uint32_t target)
if (target - (ARM_DWT_CYCCNT - begin) > WORST_INTERRUPT_CYCLES+20) {
uint32_t pretarget = target - WORST_INTERRUPT_CYCLES;
//digitalWriteFast(12, HIGH);
interrupts();
while (ARM_DWT_CYCCNT - begin < pretarget) ; // wait
noInterrupts();
//digitalWriteFast(12, LOW);
while (ARM_DWT_CYCCNT - begin < target) ; // wait
size_t SoftwareSerial::write(uint8_t b)
elapsedMicros elapsed;
uint32_t target;
uint8_t mask;
uint32_t begin_cycle;
// use hardware serial, if possible
if (port) return port->write(b);
if (cycles_per_bit == 0) return 0;
// start bit
target = cycles_per_bit;
noInterrupts();
begin_cycle = ARM_DWT_CYCCNT;
*txreg = 0;
wait_for_target(begin_cycle, target);
// 8 data bits
for (mask = 1; mask; mask <<= 1) {
*txreg = (b & mask) ? 1 : 0;
target += cycles_per_bit;
// stop bit
*txreg = 1;
interrupts();
while (ARM_DWT_CYCCNT - begin_cycle < target) ; // wait
return 1;
void SoftwareSerial::flush()
if (port) port->flush();
// TODO implement reception using pin change DMA capturing
// ARM_DWT_CYCCNT and the bitband mapped GPIO_PDIR register
// to a circular buffer (8 bytes per event... memory intensive)
int SoftwareSerial::available()
if (port) return port->available();
return 0;
int SoftwareSerial::peek()
if (port) return port->peek();
return -1;
int SoftwareSerial::read()
if (port) return port->read();
return -1;
#else
// Lookup table
typedef struct _DELAY_TABLE
long baud;
unsigned short rx_delay_centering;
unsigned short rx_delay_intrabit;
unsigned short rx_delay_stopbit;
unsigned short tx_delay;
} DELAY_TABLE;
#if F_CPU == 16000000
static const DELAY_TABLE PROGMEM table[] =
// baud rxcenter rxintra rxstop tx
{ 115200, 1, 17, 17, 12, },
{ 57600, 10, 37, 37, 33, },
{ 38400, 25, 57, 57, 54, },
{ 31250, 31, 70, 70, 68, },
{ 28800, 34, 77, 77, 74, },
{ 19200, 54, 117, 117, 114, },
{ 14400, 74, 156, 156, 153, },
{ 9600, 114, 236, 236, 233, },
{ 4800, 233, 474, 474, 471, },
{ 2400, 471, 950, 950, 947, },
{ 1200, 947, 1902, 1902, 1899, },
{ 600, 1902, 3804, 3804, 3800, },
{ 300, 3804, 7617, 7617, 7614, },
const int XMIT_START_ADJUSTMENT = 5;
#elif F_CPU == 8000000
static const DELAY_TABLE table[] PROGMEM =
{ 115200, 1, 5, 5, 3, },
{ 57600, 1, 15, 15, 13, },
{ 38400, 2, 25, 26, 23, },
{ 31250, 7, 32, 33, 29, },
{ 28800, 11, 35, 35, 32, },
{ 19200, 20, 55, 55, 52, },
{ 14400, 30, 75, 75, 72, },
{ 9600, 50, 114, 114, 112, },
{ 4800, 110, 233, 233, 230, },
{ 2400, 229, 472, 472, 469, },
{ 1200, 467, 948, 948, 945, },
{ 600, 948, 1895, 1895, 1890, },
{ 300, 1895, 3805, 3805, 3802, },
const int XMIT_START_ADJUSTMENT = 4;
#elif F_CPU == 20000000
// 20MHz support courtesy of the good people at macegr.com.
// Thanks, Garrett!
{ 115200, 3, 21, 21, 18, },
{ 57600, 20, 43, 43, 41, },
{ 38400, 37, 73, 73, 70, },
{ 31250, 45, 89, 89, 88, },
{ 28800, 46, 98, 98, 95, },
{ 19200, 71, 148, 148, 145, },
{ 14400, 96, 197, 197, 194, },
{ 9600, 146, 297, 297, 294, },
{ 4800, 296, 595, 595, 592, },
{ 2400, 592, 1189, 1189, 1186, },
{ 1200, 1187, 2379, 2379, 2376, },
{ 600, 2379, 4759, 4759, 4755, },
{ 300, 4759, 9523, 9523, 9520, },
const int XMIT_START_ADJUSTMENT = 6;
#else
#error This version of SoftwareSerial supports only 20, 16 and 8MHz processors
// Statics
SoftwareSerial *SoftwareSerial::active_object = 0;
char SoftwareSerial::_receive_buffer[_SS_MAX_RX_BUFF];
volatile uint8_t SoftwareSerial::_receive_buffer_tail = 0;
volatile uint8_t SoftwareSerial::_receive_buffer_head = 0;
// Debugging
// This function generates a brief pulse
// for debugging or measuring on an oscilloscope.
inline void DebugPulse(uint8_t pin, uint8_t count)
#if _DEBUG
volatile uint8_t *pport = portOutputRegister(digitalPinToPort(pin));
uint8_t val = *pport;
while (count--)
*pport = val | digitalPinToBitMask(pin);
*pport = val;
// Private methods
/* static */
inline void SoftwareSerial::tunedDelay(uint16_t delay) {
uint8_t tmp=0;
asm volatile("sbiw %0, 0x01 \n\t"
"ldi %1, 0xFF \n\t"
"cpi %A0, 0xFF \n\t"
"cpc %B0, %1 \n\t"
"brne .-10 \n\t"
: "+r" (delay), "+a" (tmp)
: "0" (delay)
// This function sets the current object as the "listening"
// one and returns true if it replaces another
bool SoftwareSerial::listen()
if (active_object != this)
_buffer_overflow = false;
uint8_t oldSREG = SREG;
cli();
_receive_buffer_head = _receive_buffer_tail = 0;
active_object = this;
SREG = oldSREG;
return true;
return false;
// The receive routine called by the interrupt handler
void SoftwareSerial::recv()
return; // added by SEB to remove RX delays
#if GCC_VERSION < 40302
// Work-around for avr-gcc 4.3.0 OSX version bug
// Preserve the registers that the compiler misses
// (courtesy of Arduino forum user *etracer*)
asm volatile(
"push r18 \n\t"
"push r19 \n\t"
"push r20 \n\t"
"push r21 \n\t"
"push r22 \n\t"
"push r23 \n\t"
"push r26 \n\t"
"push r27 \n\t"
uint8_t d = 0;
// If RX line is high, then we don't see any start bit
// so interrupt is probably not for us
if (_inverse_logic ? rx_pin_read() : !rx_pin_read())
// Wait approximately 1/2 of a bit width to "center" the sample
tunedDelay(_rx_delay_centering);
DebugPulse(_DEBUG_PIN2, 1);
// Read each of the 8 bits
for (uint8_t i=0x1; i; i <<= 1)
tunedDelay(_rx_delay_intrabit);
uint8_t noti = ~i;
if (rx_pin_read())
d |= i;
else // else clause added to ensure function timing is ~balanced
d &= noti;
// skip the stop bit
tunedDelay(_rx_delay_stopbit);
if (_inverse_logic)
d = ~d;
// if buffer full, set the overflow flag and return
if ((_receive_buffer_tail + 1) % _SS_MAX_RX_BUFF != _receive_buffer_head)
// save new data in buffer: tail points to where byte goes
_receive_buffer[_receive_buffer_tail] = d; // save new byte
_receive_buffer_tail = (_receive_buffer_tail + 1) % _SS_MAX_RX_BUFF;
#if _DEBUG // for scope: pulse pin as overflow indictator
DebugPulse(_DEBUG_PIN1, 1);
_buffer_overflow = true;
// Restore the registers that the compiler misses
asm volatile(
"pop r27 \n\t"
"pop r26 \n\t"
"pop r23 \n\t"
"pop r22 \n\t"
"pop r21 \n\t"
"pop r20 \n\t"
"pop r19 \n\t"
"pop r18 \n\t"
void SoftwareSerial::tx_pin_write(uint8_t pin_state)
if (pin_state == LOW)
*_transmitPortRegister &= ~_transmitBitMask;
*_transmitPortRegister |= _transmitBitMask;
uint8_t SoftwareSerial::rx_pin_read()
return *_receivePortRegister & _receiveBitMask;
// Interrupt handling
/* static */
inline void SoftwareSerial::handle_interrupt()
if (active_object)
// active_object->recv();
#if defined(PCINT0_vect)
ISR(PCINT0_vect)
// SoftwareSerial::handle_interrupt(); // added by SEB to remove RX delays
#if defined(PCINT1_vect)
ISR(PCINT1_vect)
#if defined(PCINT2_vect)
ISR(PCINT2_vect)
#if defined(PCINT3_vect)
ISR(PCINT3_vect)
// Constructor
SoftwareSerial::SoftwareSerial(uint8_t receivePin, uint8_t transmitPin, bool inverse_logic /* = false */) :
_rx_delay_centering(0),
_rx_delay_intrabit(0),
_rx_delay_stopbit(0),
_tx_delay(0),
_buffer_overflow(false),
_inverse_logic(inverse_logic)
setTX(transmitPin);
setRX(receivePin);
// Destructor
SoftwareSerial::~SoftwareSerial()
end();
void SoftwareSerial::setTX(uint8_t tx)
pinMode(tx, OUTPUT);
digitalWrite(tx, HIGH);
_transmitBitMask = digitalPinToBitMask(tx);
uint8_t port = digitalPinToPort(tx);
_transmitPortRegister = portOutputRegister(port);
void SoftwareSerial::setRX(uint8_t rx)
pinMode(rx, INPUT);
if (!_inverse_logic)
digitalWrite(rx, HIGH); // pullup for normal logic!
_receivePin = rx;
_receiveBitMask = digitalPinToBitMask(rx);
uint8_t port = digitalPinToPort(rx);
_receivePortRegister = portInputRegister(port);
// Public methods
void SoftwareSerial::begin(long speed)
_rx_delay_centering = _rx_delay_intrabit = _rx_delay_stopbit = _tx_delay = 0;
for (unsigned i=0; i<sizeof(table)/sizeof(table[0]); ++i)
long baud = pgm_read_dword(&table[i].baud);
if (baud == speed)
_rx_delay_centering = pgm_read_word(&table[i].rx_delay_centering);
_rx_delay_intrabit = pgm_read_word(&table[i].rx_delay_intrabit);
_rx_delay_stopbit = pgm_read_word(&table[i].rx_delay_stopbit);
_tx_delay = pgm_read_word(&table[i].tx_delay);
// Set up RX interrupts, but only if we have a valid RX baud rate
/* // added by SEB to remove RX delays
if (_rx_delay_stopbit)
if (digitalPinToPCICR(_receivePin))
*digitalPinToPCICR(_receivePin) |= _BV(digitalPinToPCICRbit(_receivePin));
*digitalPinToPCMSK(_receivePin) |= _BV(digitalPinToPCMSKbit(_receivePin));
tunedDelay(_tx_delay); // if we were low this establishes the end
#if _DEBUG
pinMode(_DEBUG_PIN1, OUTPUT);
pinMode(_DEBUG_PIN2, OUTPUT);
listen();
if (digitalPinToPCMSK(_receivePin))
*digitalPinToPCMSK(_receivePin) &= ~_BV(digitalPinToPCMSKbit(_receivePin));
// Read data from buffer
return -1; // added by SEB to remove RX delays
if (!isListening())
return -1;
// Empty buffer?
if (_receive_buffer_head == _receive_buffer_tail)
return -1;
// Read from "head"
uint8_t d = _receive_buffer[_receive_buffer_head]; // grab next byte
_receive_buffer_head = (_receive_buffer_head + 1) % _SS_MAX_RX_BUFF;
return d;
return 0; // added by SEB to remove RX delays
if (!isListening())
return 0;
return (_receive_buffer_tail + _SS_MAX_RX_BUFF - _receive_buffer_head) % _SS_MAX_RX_BUFF;
if (_tx_delay == 0) {
setWriteError();
return 0;
cli(); // turn off interrupts for a clean txmit
// Write the start bit
tx_pin_write(_inverse_logic ? HIGH : LOW);
tunedDelay(_tx_delay + XMIT_START_ADJUSTMENT);
// Write each of the 8 bits
if (_inverse_logic)
for (byte mask = 0x01; mask; mask <<= 1)
if (b & mask) // choose bit
tx_pin_write(LOW); // send 1
tx_pin_write(HIGH); // send 0
tx_pin_write(LOW); // restore pin to natural state
tx_pin_write(HIGH); // send 1
tx_pin_write(LOW); // send 0
tx_pin_write(HIGH); // restore pin to natural state
SREG = oldSREG; // turn interrupts back on
return 1;
return // added by SEB to remove RX delays
if (!isListening())
return;
cli();
SREG = oldSREG;
if (!isListening())
return -1;
// Empty buffer?
return -1;
// Read from "head"
return _receive_buffer[_receive_buffer_head];
