Page 1 of 2 1 2 LastLast
Results 1 to 25 of 43
Thread: Tx only needed oSoftserial lib for MIDI on T3.6 -
    May 2018
    Portland, OR USA
    27
    Tx only needed in Softserial lib for MIDI on T3.6 -
    If I missed this info in another thread feel free to point to it, I’ve been browsing and reading for several hours today and haven’t come across these answers. But learned a ton of other stuff in the search! :-)
    I’m working on a MIDI router device that bridges several “5-pin DINs” (via serial UARTs) to the “USB device port” and the “USB host ports via 4 port hub”.
    I was hoping to get some feedback on optimizing the softserial library when only MIDI messages are needed to be transmitted (Tx’ed). I edited the Softserial library removing as much RX code as possible, but still leaving return values as if the input buffer is empty. The program creates 8 softserial objects using the same Input pin and they seem to be working fine. FYI There are a total of 14 MIDI outputs, the first 6 of which are using UART serial ports.
    Question: does each instantiated object create its own interrupt timer to manage the outbound pulse train? At what cost w.r.t. starving other interrupt threads? Maybe I’m even asking the wrong question... can somebody describe the theory of operation for the soft serial transmit, and what the pitfalls might be for running eight of them. The warnings are strong but a bit vague on the PJRC website on this matter.
    Thanks in advance!
    Steve
    May 2018
    Portland, OR USA
    27
    Here's the SoftwareSerial.cpp that I modified... all locations where code was commented out or added has the comment... "// added by SEB to remove RX delays"
    SoftwareSerial.cpp (formerly NewSoftSerial.cpp) -
    Multi-instance software serial library for Arduino/Wiring
    -- Interrupt-driven receive and other improvements by ladyada
       (http://ladyada.net)
    -- Tuning, circular buffer, derivation from class Print/Stream,
       multi-instance support, porting to 8MHz processors,
       various optimizations, PROGMEM delay tables, inverse logic and
       direct port writing by Mikal Hart (http://www.arduiniana.org)
    -- Pin change interrupt macros by Paul Stoffregen (http://www.pjrc.com)
    -- 20MHz processor support by Garrett Mace (http://www.macetech.com)
    -- ATmega1280/2560 support by Brett Hagman (http://www.roguerobotics.com/)
    This library is free software; you can redistribute it and/or
    modify it under the terms of the GNU Lesser General Public
    License as published by the Free Software Foundation; either
    version 2.1 of the License, or (at your option) any later version.
    This library is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
    Lesser General Public License for more details.
    You should have received a copy of the GNU Lesser General Public
    License along with this library; if not, write to the Free Software
    Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
    The latest version of this library can always be found at
    http://arduiniana.org.
    // When set, _DEBUG co-opts pins 11 and 13 for debugging with an
    // oscilloscope or logic analyzer.  Beware: it also slightly modifies
    // the bit times, so don't rely on it too much at high baud rates
    #define _DEBUG 0
    #define _DEBUG_PIN1 11
    #define _DEBUG_PIN2 13
    // Includes
    #include <avr/interrupt.h>
    #include <avr/pgmspace.h>
    #include <Arduino.h>
    #include <SoftwareSerial.h>
    #if defined(__MK20DX128__) || defined(__MK20DX256__) || defined(__MKL26Z64__) || defined(__MK64FX512__) || defined(__MK66FX1M0__)
    SoftwareSerial::SoftwareSerial(uint8_t rxPin, uint8_t txPin, bool inverse_logic /* = false */)
    	buffer_overflow = false;
    	if (rxPin == 0 && txPin == 1) {
    		port = &Serial1;
    		return;
    	} else if (rxPin == 9 && txPin == 10) {
    		port = &Serial2;
    		return;
    	} else if (rxPin == 7 && txPin == 8) {
    		port = &Serial3;
    		return;
    	port = NULL;
    	pinMode(txPin, OUTPUT);
    	pinMode(rxPin, INPUT_PULLUP);
    	txpin = txPin;
    	rxpin = rxPin;
    	txreg = portOutputRegister(digitalPinToPort(txPin));
    	rxreg = portInputRegister(digitalPinToPort(rxPin));
    	cycles_per_bit = 0;
    void SoftwareSerial::begin(unsigned long speed)
    	if (port) {
    		port->begin(speed);
    		cycles_per_bit = (uint32_t)(F_CPU + speed / 2) / speed;
    		ARM_DEMCR |= ARM_DEMCR_TRCENA;
    		ARM_DWT_CTRL |= ARM_DWT_CTRL_CYCCNTENA;
    void SoftwareSerial::end()
    	if (port) {
    		port->end();
    		port = NULL;
    		pinMode(txpin, INPUT);
    		pinMode(rxpin, INPUT);
    	cycles_per_bit = 0;
    // The worst case expected length of any interrupt routines.  If an
    // interrupt runs longer than this number of cycles, it can disrupt
    // the transmit waveform.  Increasing this number causes SoftwareSerial
    // to hog the CPU longer, delaying all interrupt response for other
    // libraries, so this should be made as small as possible but still
    // ensure accurate transmit waveforms.
    #define WORST_INTERRUPT_CYCLES 360
    static void wait_for_target(uint32_t begin, uint32_t target)
    	if (target - (ARM_DWT_CYCCNT - begin) > WORST_INTERRUPT_CYCLES+20) {
    		uint32_t pretarget = target - WORST_INTERRUPT_CYCLES;
    		//digitalWriteFast(12, HIGH);
    		interrupts();
    		while (ARM_DWT_CYCCNT - begin < pretarget) ; // wait
    		noInterrupts();
    		//digitalWriteFast(12, LOW);
    	while (ARM_DWT_CYCCNT - begin < target) ; // wait
    size_t SoftwareSerial::write(uint8_t b)
    	elapsedMicros elapsed;
    	uint32_t target;
    	uint8_t mask;
    	uint32_t begin_cycle;
    	// use hardware serial, if possible
    	if (port) return port->write(b);
    	if (cycles_per_bit == 0) return 0;
    	// start bit
    	target = cycles_per_bit;
    	noInterrupts();
    	begin_cycle = ARM_DWT_CYCCNT;
    	*txreg = 0;
    	wait_for_target(begin_cycle, target);
    	// 8 data bits
    	for (mask = 1; mask; mask <<= 1) {
    		*txreg = (b & mask) ? 1 : 0;
    		target += cycles_per_bit;
    	// stop bit
    	*txreg = 1;
    	interrupts();
    	while (ARM_DWT_CYCCNT - begin_cycle < target) ; // wait
    	return 1;
    void SoftwareSerial::flush()
    	if (port) port->flush();
    // TODO implement reception using pin change DMA capturing
    // ARM_DWT_CYCCNT and the bitband mapped GPIO_PDIR register
    // to a circular buffer (8 bytes per event... memory intensive)
    int SoftwareSerial::available()
    	if (port) return port->available();
    	return 0;
    int SoftwareSerial::peek()
    	if (port) return port->peek();
    	return -1;
    int SoftwareSerial::read()
    	if (port) return port->read();
    	return -1;
    #else
    // Lookup table
    typedef struct _DELAY_TABLE
      long baud;
      unsigned short rx_delay_centering;
      unsigned short rx_delay_intrabit;
      unsigned short rx_delay_stopbit;
      unsigned short tx_delay;
    } DELAY_TABLE;
    #if F_CPU == 16000000
    static const DELAY_TABLE PROGMEM table[] =
      //  baud    rxcenter   rxintra    rxstop    tx
      { 115200,   1,         17,        17,       12,    },
      { 57600,    10,        37,        37,       33,    },
      { 38400,    25,        57,        57,       54,    },
      { 31250,    31,        70,        70,       68,    },
      { 28800,    34,        77,        77,       74,    },
      { 19200,    54,        117,       117,      114,   },
      { 14400,    74,        156,       156,      153,   },
      { 9600,     114,       236,       236,      233,   },
      { 4800,     233,       474,       474,      471,   },
      { 2400,     471,       950,       950,      947,   },
      { 1200,     947,       1902,      1902,     1899,  },
      { 600,      1902,      3804,      3804,     3800,  },
      { 300,      3804,      7617,      7617,     7614,  },
    const int XMIT_START_ADJUSTMENT = 5;
    #elif F_CPU == 8000000
    static const DELAY_TABLE table[] PROGMEM =
      { 115200,   1,          5,         5,      3,      },
      { 57600,    1,          15,        15,     13,     },
      { 38400,    2,          25,        26,     23,     },
      { 31250,    7,          32,        33,     29,     },
      { 28800,    11,         35,        35,     32,     },
      { 19200,    20,         55,        55,     52,     },
      { 14400,    30,         75,        75,     72,     },
      { 9600,     50,         114,       114,    112,    },
      { 4800,     110,        233,       233,    230,    },
      { 2400,     229,        472,       472,    469,    },
      { 1200,     467,        948,       948,    945,    },
      { 600,      948,        1895,      1895,   1890,   },
      { 300,      1895,       3805,      3805,   3802,   },
    const int XMIT_START_ADJUSTMENT = 4;
    #elif F_CPU == 20000000
    // 20MHz support courtesy of the good people at macegr.com.
    // Thanks, Garrett!
      { 115200,   3,          21,        21,     18,     },
      { 57600,    20,         43,        43,     41,     },
      { 38400,    37,         73,        73,     70,     },
      { 31250,    45,         89,        89,     88,     },
      { 28800,    46,         98,        98,     95,     },
      { 19200,    71,         148,       148,    145,    },
      { 14400,    96,         197,       197,    194,    },
      { 9600,     146,        297,       297,    294,    },
      { 4800,     296,        595,       595,    592,    },
      { 2400,     592,        1189,      1189,   1186,   },
      { 1200,     1187,       2379,      2379,   2376,   },
      { 600,      2379,       4759,      4759,   4755,   },
      { 300,      4759,       9523,      9523,   9520,   },
    const int XMIT_START_ADJUSTMENT = 6;
    #else
    #error This version of SoftwareSerial supports only 20, 16 and 8MHz processors
    // Statics
    SoftwareSerial *SoftwareSerial::active_object = 0;
    char SoftwareSerial::_receive_buffer[_SS_MAX_RX_BUFF];
    volatile uint8_t SoftwareSerial::_receive_buffer_tail = 0;
    volatile uint8_t SoftwareSerial::_receive_buffer_head = 0;
    // Debugging
    // This function generates a brief pulse
    // for debugging or measuring on an oscilloscope.
    inline void DebugPulse(uint8_t pin, uint8_t count)
    #if _DEBUG
      volatile uint8_t *pport = portOutputRegister(digitalPinToPort(pin));
      uint8_t val = *pport;
      while (count--)
        *pport = val | digitalPinToBitMask(pin);
        *pport = val;
    // Private methods
    /* static */
    inline void SoftwareSerial::tunedDelay(uint16_t delay) {
      uint8_t tmp=0;
      asm volatile("sbiw    %0, 0x01 \n\t"
        "ldi %1, 0xFF \n\t"
        "cpi %A0, 0xFF \n\t"
        "cpc %B0, %1 \n\t"
        "brne .-10 \n\t"
        : "+r" (delay), "+a" (tmp)
        : "0" (delay)
    // This function sets the current object as the "listening"
    // one and returns true if it replaces another
    bool SoftwareSerial::listen()
      if (active_object != this)
        _buffer_overflow = false;
        uint8_t oldSREG = SREG;
        cli();
        _receive_buffer_head = _receive_buffer_tail = 0;
        active_object = this;
        SREG = oldSREG;
        return true;
      return false;
    // The receive routine called by the interrupt handler
    void SoftwareSerial::recv()
          return;  // added by SEB to remove RX delays
    #if GCC_VERSION < 40302
    // Work-around for avr-gcc 4.3.0 OSX version bug
    // Preserve the registers that the compiler misses
    // (courtesy of Arduino forum user *etracer*)
      asm volatile(
        "push r18 \n\t"
        "push r19 \n\t"
        "push r20 \n\t"
        "push r21 \n\t"
        "push r22 \n\t"
        "push r23 \n\t"
        "push r26 \n\t"
        "push r27 \n\t"
      uint8_t d = 0;
      // If RX line is high, then we don't see any start bit
      // so interrupt is probably not for us
      if (_inverse_logic ? rx_pin_read() : !rx_pin_read())
        // Wait approximately 1/2 of a bit width to "center" the sample
        tunedDelay(_rx_delay_centering);
        DebugPulse(_DEBUG_PIN2, 1);
        // Read each of the 8 bits
        for (uint8_t i=0x1; i; i <<= 1)
          tunedDelay(_rx_delay_intrabit);
          uint8_t noti = ~i;
          if (rx_pin_read())
            d |= i;
          else // else clause added to ensure function timing is ~balanced
            d &= noti;
        // skip the stop bit
        tunedDelay(_rx_delay_stopbit);
        if (_inverse_logic)
          d = ~d;
        // if buffer full, set the overflow flag and return
        if ((_receive_buffer_tail + 1) % _SS_MAX_RX_BUFF != _receive_buffer_head)
          // save new data in buffer: tail points to where byte goes
          _receive_buffer[_receive_buffer_tail] = d; // save new byte
          _receive_buffer_tail = (_receive_buffer_tail + 1) % _SS_MAX_RX_BUFF;
    #if _DEBUG // for scope: pulse pin as overflow indictator
          DebugPulse(_DEBUG_PIN1, 1);
          _buffer_overflow = true;
    // Restore the registers that the compiler misses
      asm volatile(
        "pop r27 \n\t"
        "pop r26 \n\t"
        "pop r23 \n\t"
        "pop r22 \n\t"
        "pop r21 \n\t"
        "pop r20 \n\t"
        "pop r19 \n\t"
        "pop r18 \n\t"
    void SoftwareSerial::tx_pin_write(uint8_t pin_state)
      if (pin_state == LOW)
        *_transmitPortRegister &= ~_transmitBitMask;
        *_transmitPortRegister |= _transmitBitMask;
    uint8_t SoftwareSerial::rx_pin_read()
      return *_receivePortRegister & _receiveBitMask;
    // Interrupt handling
    /* static */
    inline void SoftwareSerial::handle_interrupt()
      if (active_object)
        // active_object->recv();
    #if defined(PCINT0_vect)
    ISR(PCINT0_vect)
      // SoftwareSerial::handle_interrupt();  // added by SEB to remove RX delays
    #if defined(PCINT1_vect)
    ISR(PCINT1_vect)
    #if defined(PCINT2_vect)
    ISR(PCINT2_vect)
    #if defined(PCINT3_vect)
    ISR(PCINT3_vect)
    // Constructor
    SoftwareSerial::SoftwareSerial(uint8_t receivePin, uint8_t transmitPin, bool inverse_logic /* = false */) :
      _rx_delay_centering(0),
      _rx_delay_intrabit(0),
      _rx_delay_stopbit(0),
      _tx_delay(0),
      _buffer_overflow(false),
      _inverse_logic(inverse_logic)
      setTX(transmitPin);
      setRX(receivePin);
    // Destructor
    SoftwareSerial::~SoftwareSerial()
      end();
    void SoftwareSerial::setTX(uint8_t tx)
      pinMode(tx, OUTPUT);
      digitalWrite(tx, HIGH);
      _transmitBitMask = digitalPinToBitMask(tx);
      uint8_t port = digitalPinToPort(tx);
      _transmitPortRegister = portOutputRegister(port);
    void SoftwareSerial::setRX(uint8_t rx)
      pinMode(rx, INPUT);
      if (!_inverse_logic)
        digitalWrite(rx, HIGH);  // pullup for normal logic!
      _receivePin = rx;
      _receiveBitMask = digitalPinToBitMask(rx);
      uint8_t port = digitalPinToPort(rx);
      _receivePortRegister = portInputRegister(port);
    // Public methods
    void SoftwareSerial::begin(long speed)
      _rx_delay_centering = _rx_delay_intrabit = _rx_delay_stopbit = _tx_delay = 0;
      for (unsigned i=0; i<sizeof(table)/sizeof(table[0]); ++i)
        long baud = pgm_read_dword(&table[i].baud);
        if (baud == speed)
          _rx_delay_centering = pgm_read_word(&table[i].rx_delay_centering);
          _rx_delay_intrabit = pgm_read_word(&table[i].rx_delay_intrabit);
          _rx_delay_stopbit = pgm_read_word(&table[i].rx_delay_stopbit);
          _tx_delay = pgm_read_word(&table[i].tx_delay);
      // Set up RX interrupts, but only if we have a valid RX baud rate
      /* // added by SEB to remove RX delays
      if (_rx_delay_stopbit)
        if (digitalPinToPCICR(_receivePin))
          *digitalPinToPCICR(_receivePin) |= _BV(digitalPinToPCICRbit(_receivePin));
          *digitalPinToPCMSK(_receivePin) |= _BV(digitalPinToPCMSKbit(_receivePin));
        tunedDelay(_tx_delay); // if we were low this establishes the end
    #if _DEBUG
      pinMode(_DEBUG_PIN1, OUTPUT);
      pinMode(_DEBUG_PIN2, OUTPUT);
      listen();
      if (digitalPinToPCMSK(_receivePin))
        *digitalPinToPCMSK(_receivePin) &= ~_BV(digitalPinToPCMSKbit(_receivePin));
    // Read data from buffer
      return -1;  // added by SEB to remove RX delays
      if (!isListening())
        return -1;
      // Empty buffer?
      if (_receive_buffer_head == _receive_buffer_tail)
        return -1;
      // Read from "head"
      uint8_t d = _receive_buffer[_receive_buffer_head]; // grab next byte
      _receive_buffer_head = (_receive_buffer_head + 1) % _SS_MAX_RX_BUFF;
      return d;
      return 0; // added by SEB to remove RX delays
      if (!isListening())
        return 0;
      return (_receive_buffer_tail + _SS_MAX_RX_BUFF - _receive_buffer_head) % _SS_MAX_RX_BUFF;
      if (_tx_delay == 0) {
        setWriteError();
        return 0;
      cli();  // turn off interrupts for a clean txmit
      // Write the start bit
      tx_pin_write(_inverse_logic ? HIGH : LOW);
      tunedDelay(_tx_delay + XMIT_START_ADJUSTMENT);
      // Write each of the 8 bits
      if (_inverse_logic)
        for (byte mask = 0x01; mask; mask <<= 1)
          if (b & mask) // choose bit
            tx_pin_write(LOW); // send 1
            tx_pin_write(HIGH); // send 0
        tx_pin_write(LOW); // restore pin to natural state
            tx_pin_write(HIGH); // send 1
            tx_pin_write(LOW); // send 0
        tx_pin_write(HIGH); // restore pin to natural state
      SREG = oldSREG; // turn interrupts back on
      return 1;
      return // added by SEB to remove RX delays
      if (!isListening())
        return;
      cli();
      SREG = oldSREG;
      if (!isListening())
        return -1;
      // Empty buffer?
        return -1;
      // Read from "head"
      return _receive_buffer[_receive_buffer_head];
    May 2018
    Portland, OR USA
    27
    For instance functions "tx_pin_write" & "tunedDelay" are called bracketed by toggling all interrupts. Could "tunedDelay" be achieved by setting a high priority micro-sec timer to the pulse width needed and use the timer tick to return? Thus not blocking other code from running while clocking out pulses.
    Steve
    May 2018
    Portland, OR USA
    27
    Quote Originally Posted by SteveBar View Post
    Steve
    BTW given its MIDI at 31250 baud its fixed at a 32usec pulse
    Feb 2014
    Colmar, France
    2,386
    Can’t understand your over-complicated approach. The Teensy 3.6 has 6 hardware UARTs. Each of these might serve for a 5pin Midi port. No need to waste cpu cycles and ram for bit banging with a soft serial emulation.
    May 2018
    Portland, OR USA
    27
    Canít understand your over-complicated approach. The Teensy 3.6 has 6 hardware UARTs. Each of these might serve for a 5pin Midi port. No need to waste cpu cycles and ram for bit banging with a soft serial emulation.
    I need more than 6 outputs.
    Steve
    Feb 2014
    Colmar, France
    2,386
    Sorry, didn‘t see that. Can hardly imagine a use case with the need of 14 Midi ports especially since midi allows theoretically daisy-chaining devices, concentrating or adding up several streams on one port.
    I’m now very interested to read more about your project!
    May 2018
    Portland, OR USA
    27
    MIDI can be daisy-chained from device to device... but that can add latency especially with older devices. And tedious when re-configuring equipment. So spitting the MIDI and running cables in parallel is common.
    Steve
Name:	MRTR Black Top Mount v5.jpg
    ...preliminary UI design
    19,943
    Pretty sure you're going to be very unhappy with the performance of software emulated serial. While you can transmit 1 MIDI port quite well that way, the problem is the interrupt disable behavior interferes with everything else, including all 6 hardware serial ports. It can also add significant latency on the USB communication too. When any of those 8 extra emulated ports is active, and especially if 2 or more are transmitting bytes, you're going to find the whole system suffers terribly.
    To get 14 MIDI OUT ports, you really should use two more Teensy 3.6 boards. Connect a hub on the USB host port on your main Teensy 3.6, and then plug in both of those boards. When you want to send a message beyond the 6th port, transmit it on the USB host port to one of those 2 other Teensy 3.6 boards, and let them take care of actually sending it as serial. The USBHost_t36 library has an example that shows how to forward MIDI messages, which should give you most of the code you'll need.
    Make sure you get a Multi-TT type hub. Those are more efficient than Single-TT types.
    You may believe that extra USB communication sounds like a lot of overhead, but I'm confident you will find it performs *much* better than disabling interrupts when more than 1 of those 14 ports is active. The serial bit times are lengthy compared to moving data around with USB. Even just 1 MIDI message at 31250 takes the entire time for a full USB frame (8 micro-frames between the host port and hub) which can convey a tremendous number of USB messages. Structuring the project this way, with 3 Teensy 3.6 boards and an extra step of USB communication will add much less latency than what you'll suffer from even one of those 8 emulated serial channels blocking interrupts when you really need the system to be responsive for the other 13 channels.
    May 2018
    Portland, OR USA
    27
    Could the "tunedDelay" function in the Softwareserial lib be achieved by using a high priority 32 micro-sec interrupt timer, and not turning off interrupts?
    Guess Iím asking for someoneís help... I know the theory a bit, but Iím not a low level skilled coder.
    A Software Serial, TX only, for MIDI (31250 baud only) that bit bangs using a interrupt timer that supports multiple object instantiation. Could this work?
    Steve
    Germany NRW
    5,567
    I doubt that this works for that number of parallel sending TXs. Then, the core disables interrupts, too, at various places.
    Paul is right, the best, *reliable*, way is to use more Teensys.
    Germany NRW
    5,567
    Hm, on the other hand, If only 8x TX is needed you can write code to do it in sync- means toggle 8 TX pins instead of only one in your Softwareserial. In the T4 Beta thread there is an example for a efficient minimal code softwareserail ( don't have the link at hand) - that can be easily expanded to 8x digitalWriteFast. Might be worth a try.
    Germany NRW
    5,567
    https://github.com/FrankBoesing/snip...ptimized.h#L70
    Please note it disables to interrupts, too for a reliable timing. you can try to use a high-priority timer instead.
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,072
    Excuse if this is way off base... but if you're not processing the MIDI messages in any way that alters them; what about controlling a MUX with at Teensy to physically route signals?
    Does anyone really have this many physical MIDI devices that need to be routed independantly?
    19,943
    Are all 14 incoming MIDI message streams arriving on a single 31250 baud input? Or are they coming in over 12 Mbit USB? Somehow I assumed USB was used, but now I'm not so sure. Much is a bit unclear here...
    May 2018
    Portland, OR USA
    27
    Hi Paul/All,
    Here are some more details... I have a prototype of this already built and running and about 60% of the code written. Below is the current input/output definitions of the MIDI router. Often MIDI routers have the same in number of inputs and outputs, this one does not. The front panel image is a few posts back.
    Any input can be routed to one or more outputs. MIDI message filtering is also part of the feature set.
    11 MIDI INPUTS ( 6x Serial (via UART), 4x USB Host, 1x USB device (w/16 Cables) )
    19 MIDI OUTPUTS ( 6x Serial (via UART), 8x Soft-Serial, 4x USB Host, 1x USB device (w/16 Cables) )
    Steve
    May 2018
    Portland, OR USA
    27
    Hi Frank,
    Thanks for your feedback. In addition to using an interrupt timer I was planning to do all 8 outputs simultaneously in the same interrupt handler, as you mentioned. This will require only one 32 micro second timer for all eight outputs. Essentially doing all eight outputs in parallel and greatly reducing the number of timer interrupts for as many outputs.
    Steve
    19,943
    Maybe that can work, if you're able to keep you ISR well under 30 microseconds.
    May 2018
    Portland, OR USA
    27
    If I did the calc right, a clock tic @240MHz ~4.2nano sec. so 30us = ~7200 ticks!
    I think the ISR would need to inc a counter, test for empty buffer, test 8 on/off states and set 8 pin states to match.
    Simple matter of programming... I’m sure I’m forgetting like 10 steps! :-)
    steve
    Banned
    Jan 2019
    Australia
    16
    Quote Originally Posted by oddson View Post
    ...Does anyone really have this many physical MIDI devices that need to be routed independantly?
    Absolutely Yes.
    19,943
    Use FASTRUN on the function, so it's located in RAM with zero wait states. A function running that often would probably remain in the cache, but the cache on Teensy 3.6 is only 8K. Best to have such a speed critical ISR in RAM.
    Of course, also make sure its interrupt priority is higher than all other interrupts. You can still disrupt your waveforms with any activity which temporarily disables interrupts (and many things do), but at least the nested interrupt priorities will give it the best chance of synthesizing those waveforms was well as possible.
    The approach using 3 Teensy 3.6 boards would avoid those issues and likely perform better, so please keep that in mind if you run into trouble with the emulating serial ports.
    May 2017
    203
    Hi Frank,
    Steve
    I suggest you just write the low level code for this approach and forget about modifying softwareserial. The problem with softwareserial is that it is coded to send bytes, meaning that it blocks until the entire byte has been sent. With that approach, just one busy serial stream will consume all the processing power available.
    You need to think in terms of sending one bit ( or 8 in parallel ) and returning from the interrupt. You can add 8 tx fifo's to make the higher level interface to your software serial simple and non-blocking.
    May 2018
    Portland, OR USA
    27
    MIDI Bit-Bang via 32usec Interrupt timer on T3.6
    Here's my stab at writing the code. I love any feedback, suggestions, comments...
    Theory of operation:
    1. setup 32usec interrupt timer at high priority to callback bit-bang function once per "tic"
    2. convert an inbound MIDI msg stream into a bit stream with start/stop bits etc... (manually done for this example)
    3. on int "tic" set digital pin based on buffer position
    This version bit-bangs 1 output (Digital Pin 36) with a pre-configured MIDI message: Note On, Ch1, Note C4, Vel 127.
    A 64 bit buffer is used, the message takes 30 bits, the remainder of the buffer are padded with zeros.
    The buffer is sent repeatedly.
    The interrupt timer is set to 32usec. this is the calc'ed & confirmed* pulse width per bit @ 31250 BAUD (10bits/byte) *MIDI association web site
    I tried a small range of pulse width timings ~27-40 usec, with no better (but different message) result.
    The interrupt priority 35 is used, below is a list of the other libs and their associated priorities that I put together from various post on this forum.
    I tried it at priority 10 with no change observed.
    Teensy Libs Timer Priorities...
    TEENSY USB MIDI Driver XXXTimer.priority(112);
    TEENSY Serial Driver XXXTimer.priority(64);
    MIDI-BIT-BANG XXXTimer.priority(35); <----
    TEENSY 'Sys Tick' Driver XXXTimer.priority(32);
    I don't have a scope, but will have access to one in the next day or two.
    Below is the MIDI-Ox input, does not match the sent message. In fact it's not reporting a 3 byte message being received
    MIDI-OX input...
    TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT
    000B88FE 4- -- D8 7B -- 9 --- Channel Aft
    Raw BIN = 0 1101 1000 1 0 0111 1011 1 = 0D81 07B1
    Out vs In (bit order reversed) - NO MATCH at any position
    RAW OUTPUT: 11111111001001111000100001001000000000000000000000 00000000000000
    MIDI-OX IN: 11101111001000110110
    // ==================== Soft MIDI Tx ======================
        #define MAX_BITS 64
        #define TX_PIN   36
        volatile uint8_t gTxReadHead = 0;   // location of head to "bang-out" a bit from ring buffer
        // NoteOn(0x90) + Ch1(0x00), Note C4(0x3C), Vel127(0x7F) => 0 1001 0000 1 - 0 0011 1100 1 - 0 0111 1111 1;
        uint64_t msgNoteOn = 0b1111111100100111100010000100100000000000000000000000000000000000;  // reverse order, padded w/ 0's
        // Setup bit-bang 32usec timer tic (31250 BAUD)
        IntervalTimer sMIDITx_Timer;
    void BitBangPin() {   // called from interrupt timer
          boolean theBit;
          gTxReadHead = (gTxReadHead+1) % MAX_BITS;      // inc the "Read Head" of the buffer with wrapping
          theBit = !(1 & (msgNoteOn >> gTxReadHead));    //
          digitalWriteFast(TX_PIN, theBit);              // write the bit to the pin from the buff location of the "read head"
          //Serial.println(String(theBit) + " <-" + gTxReadHead);  // make timer val 32000 to slow debug output
    } // end fcn _SetPins
       pinMode(TX_PIN, OUTPUT);
       //setup up Interrupt Timer
       sMIDITx_Timer.priority(35);                // 35 = very high priority
       // make timer val 32000 for debug output
       sMIDITx_Timer.begin(BitBangPin, 32);       // 32 usec == 31250 BAUD for MIDI
       Serial.println("MIDI Bit Bang running...");
      // nothing in loop - fcn BitBangPins called from timer
  24. #24
    19,943
    I ran your code on a Teensy 3.6. Here's what my oscilloscope sees.
    Here's a zoom in to just 1 frame of the data, with a custom time scale of 128 us/div so each bit is exactly 1/4th of a division on the screen.
  25. #25
    May 2018
    Portland, OR USA
    27
    Thanks Paul...
    I modified the image and super imposed the 0/1 stream... looks like the right bits are getting thru. I'll double check my "format" of the MIDI bit stream.
