Results 1 to 6 of 6
Thread: Newbie Question Regarding Pin Assignments
    Mar 2019
    17
    When I look at the pin assignments for my Teensy 3.5, I see that many pins have multiple "alternate" functions, and some of them have the same alternate functions. Is it correct to say there is no problem, or chance of conflict, by using pins with the same alternate functions for different things? For example, am I correct in saying that I can set Pin 21 to a PWM output and Pin 27 to LOW even though they both have the same alternate RX1 functionality? I'm chasing down a bug and trying to eliminate as many possible causes for it.
    Dec 2016
    Montreal, Canada
    3,002
    as long as it’s operation is not of the same peripheral port access yes. one pwm and 1 gpio is 2 different things, but dont expect 2x Serial1 TX pins to work together. It’s basically a multiplexer.
    Mar 2019
    17
    as long as itís operation is not of the same peripheral port access yes. one pwm and 1 gpio is 2 different things, but dont expect 2x Serial1 TX pins to work together. Itís basically a multiplexer.
    Thanks.. I'm seeing strange PWM behavior on pin 21 and was wondering if there could be an issue because I'm doing GPIO on pin 27 (they both happen to be capable as functioning as RX1, even though I haven't set them up as such). My concern was whether the multiplexer can introduce such issue.
    Feb 2014
    Colmar, France
    2,385
    It can‘t. As long as you do not willingly mux one peripheral to two different pins, the mux is quite fool proof.
    Feb 2017
    279
    The multiplexing is on a per-pin basis. There should be absolutely not problem using Pin 21 for PWM and Pin 27 for GPIO. If you're "seeing strange PWM behavior", it's due to some other reason.
    Mar 2019
    17
    Thanks all, I just wanted to scratch that off the list.. I think it's time to break out the oscilloscope.
