Results 1 to 7 of 7
Thread: XRAD: Need help, code not working on T 3.6, works on 3.2
    Junior Member XRAD's Avatar
    Aug 2018
    18
    I have this code which runs great on 3.2:
    #include <UTFT_Geometry.h>
    #include <UTFT.h>
    #define width 310// minus a bit from 320 so that edges not lost
    #define height 230//minus a bit from 240 so that edges not lost
    #define radius 10  // drawCircle radius
    UTFT myGLCD(ILI9341_S5P, 12,  13,  10,   8,   9); // (ILI9341_S5P, MISO, SCK, CS, RST,DC)
    UTFT_Geometry geo(&myGLCD);
    // initial position of the point is the middle of the screen
    int xPos = width / 2;
    int yPos = height / 2;
    // direction and speed
    int xDir = 20;//1-20 works well
    int yDir = 20;
    // variables to keep track of the point's location
    int xPrev = xPos;
    int yPrev = yPos;
      myGLCD.InitLCD();
      myGLCD.InitLCD(LANDSCAPE);
      myGLCD.fillScr(VGA_BLACK);
      myGLCD.setColor(200, 0, 0);
      // update the location of the dot
      xPos = xPos + xDir;
      yPos = yPos + yDir;
      // check if the current location is different than the previous
      if (xPos != xPrev || yPos != yPrev) {
        myGLCD.setColor(0, 0, 0); // set the 'draw' color to black
        myGLCD.drawCircle(xPrev, yPrev, radius); // color in the previous point(s)
      // draw a point in the current location
      myGLCD.setColor(255, 255, 255);
      myGLCD.drawCircle(xPos, yPos, radius);
      // if the x or x position is at the screen edges, reverse direction
      if (xPos >= width - 15 || xPos <= 20) { //screen borders minus (diameter +/- a bit) to avod wrap
        xDir = xDir * -1;
      if (yPos >= height - 15 || yPos <= 20) {
        yDir = yDir * -1;
      // update the point's previous location
      xPrev = xPos;
      yPrev = yPos;
      // a 33ms delay means the screen updates 30 times a second
      delay(33);
    But will not compile for 3.6. I have newest teensy loader 1.45 and newest UTFT.h and Geo.h.
    Arduino IDE
    Any help much appreciated!
    error message verbose:
    Arduino: 1.8.8 (Windows 10), TD: 1.45, Board: "Teensy 3.6, Serial, 180 MHz, Faster, US English"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\FGM\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\FGM\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\FGM\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10808 -build-path C:\Users\FGM\AppData\Local\Temp\arduino_build_738043 -warnings=none -build-cache C:\Users\FGM\AppData\Local\Temp\arduino_cache_294423 -verbose C:\Users\FGM\Desktop\LIDAR_MOVEMENT_ACROSS_SCREEN\LIDAR_MOVEMENT_ACROSS_SCREEN.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\FGM\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\FGM\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\FGM\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10808 -build-path C:\Users\FGM\AppData\Local\Temp\arduino_build_738043 -warnings=none -build-cache C:\Users\FGM\AppData\Local\Temp\arduino_cache_294423 -verbose C:\Users\FGM\Desktop\LIDAR_MOVEMENT_ACROSS_SCREEN\LIDAR_MOVEMENT_ACROSS_SCREEN.ino
    Using board 'teensy36' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Detecting libraries used...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o nul
    Using cached library dependencies for file: C:\Users\FGM\Documents\Arduino\libraries\UTFT_Geometry\UTFT_Geometry.cpp
    Using cached library dependencies for file: C:\Users\FGM\Documents\Arduino\libraries\UTFT\DefaultFonts.c
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT\\UTFT.cpp" -o nul
    Error while detecting libraries included by C:\Users\FGM\Documents\Arduino\libraries\UTFT\UTFT.cpp
    Generating function prototypes...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043/pch/Arduino.h" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043/pch/Arduino.h.gch"
    Using previously compiled file: C:\Users\FGM\AppData\Local\Temp\arduino_build_738043\pch\Arduino.h.gch
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp.o"
    In file included from C:\Users\FGM\Documents\Arduino\libraries\UTFT/UTFT.h:167:0,
                     from C:\Users\FGM\Documents\Arduino\libraries\UTFT_Geometry/UTFT_Geometry.h:28,
                     from C:\Users\FGM\Desktop\LIDAR_MOVEMENT_ACROSS_SCREEN\LIDAR_MOVEMENT_ACROSS_SCREEN.ino:2:
    C:\Users\FGM\Documents\Arduino\libraries\UTFT/hardware/arm/HW_ARM_defines.h:35:0: warning: "pgm_read_word" redefined
     #define pgm_read_word(data) *data
    In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/WProgram.h:41:0,
                     from C:\Users\FGM\AppData\Local\Temp\arduino_build_738043\pch\Arduino.h:6:
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/avr/pgmspace.h:101:0: note: this is the location of the previous definition
     #define pgm_read_word(addr) ({ \
    C:\Users\FGM\Documents\Arduino\libraries\UTFT/hardware/arm/HW_ARM_defines.h:36:0: warning: "pgm_read_byte" redefined
     #define pgm_read_byte(data) *data
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/avr/pgmspace.h:95:0: note: this is the location of the previous definition
     #define pgm_read_byte(addr) (*(const unsigned char *)(addr))
    Compiling libraries...
    Compiling library "UTFT_Geometry"
    Using previously compiled file: C:\Users\FGM\AppData\Local\Temp\arduino_build_738043\libraries\UTFT_Geometry\UTFT_Geometry.cpp.o
    Compiling library "UTFT"
    Using previously compiled file: C:\Users\FGM\AppData\Local\Temp\arduino_build_738043\libraries\UTFT\DefaultFonts.c.o
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT\\UTFT.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_738043\\libraries\\UTFT\\UTFT.cpp.o"
    In file included from C:\Users\FGM\Documents\Arduino\libraries\UTFT\UTFT.h:167:0,
                     from C:\Users\FGM\Documents\Arduino\libraries\UTFT\UTFT.cpp:40:
    C:\Users\FGM\Documents\Arduino\libraries\UTFT\hardware/arm/HW_ARM_defines.h:35:0: warning: "pgm_read_word" redefined
                     from C:\Users\FGM\AppData\Local\Temp\arduino_build_738043/pch/Arduino.h:6,
                     from C:\Users\FGM\Documents\Arduino\libraries\UTFT\UTFT.h:166,
    C:\Users\FGM\Documents\Arduino\libraries\UTFT\hardware/arm/HW_ARM_defines.h:36:0: warning: "pgm_read_byte" redefined
    C:\Users\FGM\Documents\Arduino\libraries\UTFT\UTFT.cpp:85:4: error: #error "Unsupported ARM MCU!"
    C:\Users\FGM\Documents\Arduino\libraries\UTFT\UTFT.cpp: In member function 'void UTFT::printNumF(double, byte, int, int, char, int, char)':
    C:\Users\FGM\Documents\Arduino\libraries\UTFT\UTFT.cpp:1095:18: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       for (int i=0; i<sizeof(st); i++)
    C:\Users\FGM\Documents\Arduino\libraries\UTFT\UTFT.cpp:1105:19: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        for (int i=1; i<sizeof(st); i++)
    C:\Users\FGM\Documents\Arduino\libraries\UTFT\UTFT.cpp:1111:19: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
    Using library UTFT_Geometry in folder: C:\Users\FGM\Documents\Arduino\libraries\UTFT_Geometry (legacy)
    Using library UTFT in folder: C:\Users\FGM\Documents\Arduino\libraries\UTFT (legacy)
    Error compiling for board Teensy 3.6.
    1,069
    It compiles for me after I remove the UTFT_Geometry.h dependency which I can't find.
    Try installing the most recent Teensyduino which is 1.46 beta 10. That might fix the problem.
    Pete
    Aug 2018
    18
    Hi Pete, THX for reply.
    I will try your suggestions.
    I use geo for drawing the arcs in the sketch:
    http://www.rinkydinkelectronics.com/library.php?id=60
    1,069
    Yup, it compiles with the most recent Teensyduino.
    Pete
    Aug 2018
    18
    Hi Pete,
    Downloaded and installed and using 1.46-beta10
    using same code in post #1....
    Compiles fine for T3.2
    Not compiling for T3.6
    3.2 verbose
    No errors
    3.6 verbose
    Arduino: 1.8.8 (Windows 10), TD: 1.46-beta10, Board: "Teensy 3.6, Serial, 180 MHz, Faster, US English"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\FGM\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\FGM\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\FGM\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -ide-version=10808 -build-path C:\Users\FGM\AppData\Local\Temp\arduino_build_646137 -warnings=none -build-cache C:\Users\FGM\AppData\Local\Temp\arduino_cache_948672 -verbose C:\Users\FGM\Desktop\LIDAR_V3__version_5_draw_erase\LIDAR_V3__version_5_draw_erase.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\FGM\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\FGM\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\FGM\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -ide-version=10808 -build-path C:\Users\FGM\AppData\Local\Temp\arduino_build_646137 -warnings=none -build-cache C:\Users\FGM\AppData\Local\Temp\arduino_cache_948672 -verbose C:\Users\FGM\Desktop\LIDAR_V3__version_5_draw_erase\LIDAR_V3__version_5_draw_erase.ino
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137\\sketch\\LIDAR_V3__version_5_draw_erase.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137\\sketch\\LIDAR_V3__version_5_draw_erase.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137\\sketch\\LIDAR_V3__version_5_draw_erase.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "C:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT\\UTFT.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "C:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry\\UTFT_Geometry.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137\\sketch\\LIDAR_V3__version_5_draw_erase.ino.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137/pch/Arduino.h" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137/pch/Arduino.h.gch"
    Using previously compiled file: C:\Users\FGM\AppData\Local\Temp\arduino_build_646137\pch\Arduino.h.gch
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137\\sketch\\LIDAR_V3__version_5_draw_erase.ino.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137\\sketch\\LIDAR_V3__version_5_draw_erase.ino.cpp.o"
                     from C:\Users\FGM\Desktop\LIDAR_V3__version_5_draw_erase\LIDAR_V3__version_5_draw_erase.ino:1:
                     from C:\Users\FGM\AppData\Local\Temp\arduino_build_646137\pch\Arduino.h:6:
    Using previously compiled file: C:\Users\FGM\AppData\Local\Temp\arduino_build_646137\libraries\UTFT\DefaultFonts.c.o
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "C:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT\\UTFT.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_646137\\libraries\\UTFT\\UTFT.cpp.o"
                     from C:\Users\FGM\AppData\Local\Temp\arduino_build_646137/pch/Arduino.h:6,
    Multiple libraries were found for "UTFT.h"
     Used: C:\Users\FGM\Documents\Arduino\libraries\UTFT
     Not used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\UTFT
    Tried this code which works fine on 3.2:
    #include <UTFT.h>
    UTFT myGLCD(ILI9341_S5P, 12,  13,  10,   8,   9); // (ILI9341_S5P, MOSI, SCK, CS, RST,DC)
    int yDir = 20;
    int xPrev = xPos;
    int yPrev = yPos;
      myGLCD.InitLCD();
      xPos = xPos + xDir;
      yPos = yPos + yDir;
        xDir = xDir * -1;
        yDir = yDir * -1;
      xPrev = xPos;
      yPrev = yPos;
      delay(33);
    does not compile for 3.6
    verbose:
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\FGM\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\FGM\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\FGM\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10808 -build-path C:\Users\FGM\AppData\Local\Temp\arduino_build_364373 -warnings=none -build-cache C:\Users\FGM\AppData\Local\Temp\arduino_cache_948672 -verbose C:\Users\FGM\Desktop\LIDAR_MOVEMENT_ACROSS_SCREEN\LIDAR_MOVEMENT_ACROSS_SCREEN.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\FGM\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\FGM\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\FGM\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10808 -build-path C:\Users\FGM\AppData\Local\Temp\arduino_build_364373 -warnings=none -build-cache C:\Users\FGM\AppData\Local\Temp\arduino_cache_948672 -verbose C:\Users\FGM\Desktop\LIDAR_MOVEMENT_ACROSS_SCREEN\LIDAR_MOVEMENT_ACROSS_SCREEN.ino
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT\\UTFT.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373/pch/Arduino.h" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373/pch/Arduino.h.gch"
    Using previously compiled file: C:\Users\FGM\AppData\Local\Temp\arduino_build_364373\pch\Arduino.h.gch
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp.o"
                     from C:\Users\FGM\AppData\Local\Temp\arduino_build_364373\pch\Arduino.h:6:
    Using previously compiled file: C:\Users\FGM\AppData\Local\Temp\arduino_build_364373\libraries\UTFT_Geometry\UTFT_Geometry.cpp.o
    Using previously compiled file: C:\Users\FGM\AppData\Local\Temp\arduino_build_364373\libraries\UTFT\DefaultFonts.c.o
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT\\UTFT.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_364373\\libraries\\UTFT\\UTFT.cpp.o"
                     from C:\Users\FGM\AppData\Local\Temp\arduino_build_364373/pch/Arduino.h:6,
    not sure why you can compile and I have errors. I can get neopixels to display from the 3.6 without issue so my assumption is that the hardware is OK...
    1,069
    You have two versions of the UTFT library. The IDE is using the one for Arduino and ignoring the one for Teensy. Temporarily move the Arduino UTFT library out of the libraries directory and try again.
    Pete
    Aug 2018
    18
    Thx for reply. I did see that, and a few weeks back, I had to delete all arduino files using revo uninstaller. I had a few duplicates of UTFT, but these functioned OK with T3.2.
    So I deleted every UTFT lib file I could find and reinstalled it using the arduino add zip lib (same w/Geo).
    Zero problems compiling for 3.2...still will not compile for 3.6......not sure if it is something in the UTFT lib...I might have to go through it....
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\FGM\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\FGM\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\FGM\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10808 -build-path C:\Users\FGM\AppData\Local\Temp\arduino_build_32596 -warnings=none -build-cache C:\Users\FGM\AppData\Local\Temp\arduino_cache_451974 -verbose C:\Users\FGM\Desktop\LIDAR_MOVEMENT_ACROSS_SCREEN\LIDAR_MOVEMENT_ACROSS_SCREEN.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\FGM\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\FGM\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\FGM\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10808 -build-path C:\Users\FGM\AppData\Local\Temp\arduino_build_32596 -warnings=none -build-cache C:\Users\FGM\AppData\Local\Temp\arduino_cache_451974 -verbose C:\Users\FGM\Desktop\LIDAR_MOVEMENT_ACROSS_SCREEN\LIDAR_MOVEMENT_ACROSS_SCREEN.ino
    Build options changed, rebuilding all
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry\\UTFT_Geometry.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT\\DefaultFonts.c" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596/pch/Arduino.h" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596/pch/Arduino.h.gch"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596\\sketch\\LIDAR_MOVEMENT_ACROSS_SCREEN.ino.cpp.o"
                     from C:\Users\FGM\AppData\Local\Temp\arduino_build_32596\pch\Arduino.h:6:
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry\\UTFT_Geometry.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596\\libraries\\UTFT_Geometry\\UTFT_Geometry.cpp.o"
                     from C:\Users\FGM\Documents\Arduino\libraries\UTFT_Geometry\UTFT_Geometry.h:28,
                     from C:\Users\FGM\Documents\Arduino\libraries\UTFT_Geometry\UTFT_Geometry.cpp:23:
                     from C:\Users\FGM\AppData\Local\Temp\arduino_build_32596/pch/Arduino.h:6,
                     from C:\Users\FGM\Documents\Arduino\libraries\UTFT/UTFT.h:166,
    C:\Users\FGM\Documents\Arduino\libraries\UTFT_Geometry\UTFT_Geometry.cpp:26:0: warning: "swap" redefined
     #define swap(a, b) { int16_t t = a; a = b; b = t; }
    C:\Users\FGM\Documents\Arduino\libraries\UTFT/hardware/arm/HW_ARM_defines.h:31:0: note: this is the location of the previous definition
     #define swap(type, i, j) {type t = i; i = j; j = t;}
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT\\DefaultFonts.c" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596\\libraries\\UTFT\\DefaultFonts.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=146 -DARDUINO=10808 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT_Geometry" "-IC:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT" "C:\\Users\\FGM\\Documents\\Arduino\\libraries\\UTFT\\UTFT.cpp" -o "C:\\Users\\FGM\\AppData\\Local\\Temp\\arduino_build_32596\\libraries\\UTFT\\UTFT.cpp.o"
