Page 22 of 25 FirstFirst ... 12 20 21 22 23 24 ... LastLast
Results 526 to 550 of 606
Thread: USBHost_t36 USB Mass Storage Driver Experiments
  1. #526
    15,278
    Looks right for FAT32. Fat16 was big enough for MS-DOS as HDD's grew - much more so accounting for var sized clusters with compression factor of 16:1. Even Win95 with FAT32 couldn't fit FAT in single alloc limit of 1MB.
    512B/sec and 4B/fat entry is 128 fat entries per sector
    4,092,416 B in the 7993 sectors of the FAT!
    So read was 0.694 MB/sec ? ... with parsing? { 4MB in 5.9 seconds } - should read faster than that.
    PRIOR NOTE p#613: Yes having just a VolumeName.ino would be nice - like i2c scanner just to show finding the attached devices.
    Then perhaps read/write testing - the @mjs513 speedBench() for ref?
  2. #527
    New York
    7,702
    Just messed up my sdfat lib as well just for a another data point for you.:
    This is for a SD Card with 2 FAT32 and 1 exfat:
    msc # Partition Table
    	part,boot,bgnCHS[3],type,endCHS[3],start,length
    FAT32:	1,80,0x0,0x1,0x10,0xC,0x3,0xE0,0xFF,2048,524288
    FAT32:	2,0,0xC2,0x23,0x20,0xC,0xFE,0xFF,0xFF,526336,16564224
    exFAT:	3,0,0xFE,0xFF,0xFF,0x7,0xFE,0xFF,0xFF,17092608,232642560
    pt_#0:	4,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
    USB Fat Type: Fat32
    Volume Name: system-boot
    2021-01-01 00:00     128890 bench0.txt
    2021-01-01 00:00     128890 bench1.txt
    2021-01-01 00:00     200000 bench2.txt
    2021-01-01 00:00     200000 bench3.txt
    2021-01-01 00:00     149000 bench4.txt
    2021-01-01 00:00     149000 bench5.txt
    ###FatPartition::freeClusterCount: FT:32 start:2080 todo:516192
        m_sectorsPerCluster:1
        m_clusterSectorMask:0
        m_sectorsPerClusterShift:0
        m_fatType:32
        m_rootDirEntryCount:0
        m_allocSearchStart:1
        m_sectorsPerFat:4033
        m_dataStartSector:10146
        m_fatStartSector:2080
        m_lastCluster:516191
        m_rootDirStart:2
        m_bytesPerSector:512
    FAT16 Partition Total Size:264289280 Used:961024 time us: 2122125
    Try calling getUSBPartitionVolumeLabel
    FAT32:	>> Volume name:(system-boot)
    USB Fat Type: Fat32
    Volume Name: NEW VOLUME1
    ###FatPartition::freeClusterCount: FT:32 start:526814 todo:2066434
        m_sectorsPerCluster:8
        m_clusterSectorMask:7
        m_sectorsPerClusterShift:3
        m_fatType:32
        m_sectorsPerFat:16145
        m_dataStartSector:559104
        m_fatStartSector:526814
        m_lastCluster:2066433
        m_rootDirStart:2
    FAT16 Partition Total Size:8464105472 Used:983040 time us: 8072750
    FAT32:	>> Volume name:(NEW VOLUME1)
    USB Fat Type: ExFat
    Volume Name: New Volume2
    2021-01-27 05:36       429216 CommandStation-EX-Arch-v1-0.pdf
    2020-12-27 14:47      5725283 VSLAM_and_Navigation_System_of_Unmanned_Ground_Vehicle_Based_on_RGB-D_Camera.pdf
    ExFat Partition Total Size:119107747840 Used:7077888 time us: 111003
  3. #528
    9,774
    Thanks @mjs513 will probably look more in the morning.
    Today I also hacked up that function some more that printed that data, and used digital Write high/low with pin 0 for the whole duration and pin 1 around each call to the cached read...
    And the capture of data also confirmed it:
    Which shows the two getting free counts for the two FAT partitions.
    A close up of the start of the first one shows that the majority of time it is waiting for the sectors to be read:
    One of the interesting things with the new Logic 2 software, is you can use things like shift mouse select over a set of data and it will do things like count how many pulses happened in that region, which helps confirm some of the calculated data.
  4. #529
    15,278
    Was there a change I missed for improved SD card reading? I have four partitions on mine and it is only giving this:
    Initialize SD card...SD card is present.
    SD Fat Type: Fat32
    Volume Name: SD1_8GB_AD
    done...
    Swapped in other simple FAT32 SD and no DIR print??
    Pulled down the Yesterday change to KurtE/MTP_t4/tree/MEM_send_object_large
  5. #530
    Senior Member wwatson's Avatar
    Aug 2017
    599
    Quick note: I am thinking it might make sense to add the VolumeName.ino as an example sketch to maybe MscFS.h project. That way we can all keep track of it?
    Make sense?
    Yes it does. Just trying to figure out which version I should add to UsbMSCFat. I am thinking p#506 as a base sketch, but not sure.
  6. #531
    15,278
    Quote Originally Posted by wwatson View Post
    I'm using p#522 here - just minor tweaks for cleaner output and a KurtE Edit that works between 506 and 507.
  7. #532
    Aug 2017
    599
    @All,
    I added 'volumeName.ino' example from post#522 to the examples in USbMSCFat.
  8. #533
    9,774
    @wwatson - Sounds great.
    @all as I mentioned over in the MTP thread (https://forum.pjrc.com/threads/43050...l=1#post271721)
    I am playing around with seeing about the SDFat/Fslib working with volumes. So I started hacking up a fsPartition.h file which I have it compiling within my version of the volumeName sketch.
    But still not far enough to make work...
    Mainly now because of the class structures...
    That is:
    for Fat we have: class FatVolume : public FatPartition {
    for ExFat we have: class ExFatVolume : public ExFatPartition {
    but Fs we have: class FsVolume {
    Which knows nothing about partition...
    But let me see if I can hack around it......
    Wonder if @Paul and/or @Bill would mind if the FsVolume::begin took optional parameter for part... WIll try that out.
  9. #534
    Oct 2015
    Roma (IT, EU)
    360
    was wondering, what is the current status of USBHost_t36 vs. reading mass storage devices?
    In particular, I would like to read a "raw" SD card inserted into a USB card reader (which I would connect to the USB Host port of the T3.6).
    "Raw" as in "no filesystem": would read it the raw sectors (long story).
  10. #535
    Ok here is the fix for extFat:
    Waiting up to 5 seconds for USB drive
    Initialize USB drive...USB drive 1 is present.
    msc1 Partition Table
    Fat Type: Fat32
    Fat Type: Fat32
    Fat Type: ExFat
    No or Not Supported Partition
    Initialize SD card...initialization failed.
    Fat Type: ExFAT
    Failed to get volume label
    done...
    Press any key to run again
    //  VolumeName.ino
    //  An example of how to retrieve Fat32 and ExFat volume names using SdFat.
    //  Works with SD cards and USB mass storage drives.
    #include "Arduino.h"
    #include "mscFS.h"
    // Setup USBHost_t36 and as many HUB ports as needed.
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    USBHub hub3(myusb);
    USBHub hub4(myusb);
    // Setup MSC for the number of USB Drives you are using. (Two for this example)
    // Mutiple  USB drives can be used. Hot plugging is supported. There is a slight
    // delay after a USB MSC device is plugged in. This is waiting for initialization
    // but after it is initialized ther should be no delay.
    msController msDrive1(myusb);
    msController msDrive2(myusb);
    #define sdDrive 1
    #define msDrive 2
    #define SD_CONFIG SdioConfig(FIFO_SDIO)
    // set up variables using the mscFS utility library functions:
    UsbFs msc1;
    SdFs sd;
    //FatVolume partVol;
    //create holding array for partions
    uint8_t partitionTable[4];
    int32_t dataStart[4];
    // Get ExFat volume name.
    bool getExFatVolumeLabel(uint8_t  drvType, uint8_t part) {
      uint8_t buf[32];
      UsbExFat volName;
      SdExFat volName1;
      ExFatFile root;
      msController *mscDrive;
      DirLabel_t *dir;
      ExFatVolume expartVol;
      if (drvType == msDrive) {
        mscDrive = &msDrive1;
        //if (!volName.begin(&msDrive1)) {
       //   Serial.println("EXFat volName.begin failed");
       //   return false;
        expartVol.begin(msc1.usbDrive(), true, part);
        expartVol.chvol();
        if (!root.openRoot(&expartVol)) {
          Serial.println("openRoot failed");
          return false;
      if (drvType == sdDrive) {
        if (!volName1.begin(SD_CONFIG)) {
          return false;
        if (!root.openRoot(&volName1)) {
          return false;
      root.read(buf, 32);
      dir = reinterpret_cast<DirLabel_t*>(buf);
      Serial.print(F("Volume Name: "));
      for (size_t i = 0; i < dir->labelLength; i++) {
        Serial.write(dir->unicode[2 * i]);
      expartVol.ls(LS_SIZE | LS_DATE | LS_R);
      return true;
    // Get Fat32 volume name.
    bool getFat32VolumeLabel(uint8_t  drvType, uint8_t part) {
      FatVolume partVol;
      uint8_t buf[512];
      partVol.chvol();
        msc1.usbDrive()->readSector(partVol.dataStartSector(), buf);
        sd.card()->readSector(sd.dataStartSector(), buf);
      for (size_t i = 0; i < 11; i++) {
        Serial.write(buf[i]);
      return true;
    // Get Fat16 volume name.
    bool getFat16VolumeLabel(uint8_t  drvType, uint8_t part) {
      FatVolume partVol;
      MbrSector_t mbr;
      uint8_t buf[512];
      partVol.chvol();
        msc1.usbDrive()->readSector(partVol.rootDirStart(), buf);
    //    print_hexbytes(buf, 512);
      return true;
    bool mbrDmp() {
      MbrSector_t mbr;
      bool valid = true;
      if (!msc1.usbDrive()->readSector(0, (uint8_t*)&mbr)) {
        Serial.print("\nread MBR failed.\n");
        //errorPrint();
        return false;
      Serial.print("\nmsc1 Partition Table\n");
      Serial.print("part,boot,bgnCHS[3],type,endCHS[3],start,length\n");
      for (uint8_t ip = 1; ip < 5; ip++) {
        MbrPart_t *pt = &mbr.part[ip - 1];
        //    if ((pt->boot != 0 && pt->boot != 0X80) ||
        //        getLe32(pt->relativeSectors) > sdCardCapacity(&m_csd)) {
        //      valid = false;
        switch (pt->type) {
          case 4:
          case 6:
          case 0xe:
            Serial.print("FAT16: ");
          case 11:
          case 12:
            Serial.print("FAT32: ");
          case 7:
            Serial.print("exFAT: ");
        partitionTable[ip - 1] = pt->type;
        dataStart[ip - 1] = getLe32(pt->relativeSectors);
        Serial.print( int(ip)); Serial.print( ',');
        Serial.print(int(pt->boot), HEX); Serial.print( ',');
        for (int i = 0; i < 3; i++ ) {
          Serial.print("0x"); Serial.print(int(pt->beginCHS[i]), HEX); Serial.print( ',');
        Serial.print("0x"); Serial.print(int(pt->type), HEX); Serial.print( ',');
          Serial.print("0x"); Serial.print(int(pt->endCHS[i]), HEX); Serial.print( ',');
        Serial.print(getLe32(pt->relativeSectors), DEC); Serial.print(',');
        Serial.println(getLe32(pt->totalSectors));
      return true;
      while (!Serial) {
        SysCall::yield(); // wait for serial port to connect.
      // Start USBHost_t36, HUB(s) and USB devices.
      myusb.begin();
    void loop(void) {
      myusb.Task();
      if (!msDrive1) {
        Serial.println("Waiting up to 5 seconds for USB drive");
        elapsedMillis em = 0;
        while (!msDrive1 && (em < 5000) )  myusb.Task();
      if (msDrive1) {
        Serial.printf("Initialize USB drive...");
        if (!msc1.begin(&msDrive1)) {
          msc1.errorPrint(&Serial);
          Serial.println("initialization failed.\n");
          Serial.println("USB drive 1 is present.\n");
        mbrDmp();
          if(msc1.fatType() == 32) {
            Serial.printf("Fat Type: Fat32\n");
            if(!getFat32VolumeLabel(msDrive))
              Serial.printf("Failed to get volume label\n");
            Serial.printf("Fat Type: ExFat\n");
          if(!getExFatVolumeLabel(msDrive,1))
          msc1.ls(LS_SIZE | LS_DATE | LS_R);
        for (uint8_t i = 1; i < 5; i++) {
          switch (partitionTable[i - 1]) {
            case 11:
            case 12:
              Serial.printf("\nFat Type: Fat32\n");
              if (!getFat32VolumeLabel(msDrive, i))
            case 4:
            case 6:
            case 0xe:
              Serial.printf("\nFat Type: Fat16\n");
              if (!getFat16VolumeLabel(msDrive, i))
            case 7:
              Serial.printf("\nFat Type: ExFat\n");
              if (!getExFatVolumeLabel(msDrive, i))
            default:
              Serial.println("No or Not Supported Partition");
      Serial.printf("\nInitialize SD card...");
      if (!sd.begin(SD_CONFIG)) {
        Serial.println("SD card is present.\n");
      if (sd.fatType() == 32) {
        if (!getFat32VolumeLabel(sdDrive, 1))
        Serial.printf("Fat Type: ExFAT\n");
        if (!getExFatVolumeLabel(sdDrive, 1)) {
      //sd.ls(LS_SIZE | LS_DATE | LS_R);
      Serial.println("done...");
      Serial.println("Press any key to run again");
      while (Serial.read() == -1);
      while (Serial.read() != -1);
    void print_hexbytes(const void *ptr, int len)
      if (ptr == NULL || len <= 0) return;
      const uint8_t *p = (const uint8_t *)ptr;
      while (len) {
        for (uint8_t i = 0; i < 32; i++) {
          if (i > len) break;
          Serial.printf("%02X ", p[i]);
        Serial.print(":");
          if (i > len) break;
          Serial.printf("%c", ((p[i] >= ' ') && (p[i] <= '~')) ? p[i] : '.');
        p += 32;
        len -= 32;
    Thank you very much MJS
  11. #536
    Aug 2017
    599
    Quote Originally Posted by XFer View Post
    MSC is now part of Teensyduino as of TD1.54B6. It sounds like you are wanting to do direct sector reads. To do this you can use the 'msReadBlocks()' function.
    Here is an example sketch that does a direct sector read of sector 0 an does a hexdump of it.
    #include "USBHost_t36.h"
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    USBHub hub3(myusb);
    USBHub hub4(myusb);
    msController usbSDCard(myusb);
    //msController msDrive2(myusb);
    // A small hex dump function
    void hexDump(const void *ptr, uint32_t len)
      uint32_t  i = 0, j = 0;
      uint8_t   c = 0;
      Serial.printf("BYTE      00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F\n");
      Serial.printf("---------------------------------------------------------\n");
      for(i = 0; i <= (len-1); i+=16) {
       Serial.printf("%4.4x      ",i);
       for(j = 0; j < 16; j++) {
          c = p[i+j];
          Serial.printf("%2.2x ",c);
        Serial.printf("  ");
          c = p[i+j];
          if(c > 31 && c < 127)
            Serial.printf("%c",c);
            Serial.printf(".");
        Serial.printf("\n");
    static uint8_t mscError = 0;
    uint8_t rdBuf[512];
       while (!Serial) {
      myusb.begin();
      Serial.printf("Initialize USB drive...\n");
      if(mscError = usbSDCard.mscInit())
    	Serial.printf(F("usbSDCard not connected: Code: %d\n\n"),  mscError);
    	Serial.printf(F("usbSDCard connected\n"));
      // Read sector 0 of SD card.
      usbSDCard.msReadBlocks(0, 1, 512, rdBuf);
      // Hex dump rdBuf[].
      hexDump(rdBuf, 512);
    void loop(void) {
    I tested it with a USB SD card reader I have. One thing you may have to change is in 'USBHost_t36/utility/msc.h'. The timeout for waiting for a USB drive to become ready is to small. It is set at 1000ms and should be at least 3000ms. It is around line number 75. I was getting an timeout error with one of my SD cards so I bumped the timeout to 3000ms which took care of the problem.
    I need to do a PR on it.
    Hopefully this is what you are looking for
  12. #537
    Oct 2015
    Roma (IT, EU)
    360
    Thank you, that's great!
  13. #538
    Oct 2015
    Roma (IT, EU)
    360
    By the way: does it work with Teensy 4.1 as well? Maybe a silly question, but... just to be sure.
  14. #539
    Aug 2017
    599
    Yes, T3.6, T4.0, T4.1.
    Glad it's working for you
  15. #540
    Apr 2019
    174
    Hello, is it possible to get a T4.1 to enter mass storage device mode on the USB client port? I'm running it as a Serial + MIDI + Audio port, so I suspect it would have to reboot in some way to enter this mode and reboot to get out of it. Thanks.
  16. #541
    Apr 2019
    174
    ... sorry, to make this clear - I want to access the SD card on the T4.1 as a mass storage device.
  17. #542
    3,340
    Quote Originally Posted by UHF View Post
    AFAIK, this thread addresses the use of Teensy as a host to a mass storage device, and not the teensy or its microSD card as a mass storage device.
    I have not seen that someone implemented a mass storage device driver on Teensy 3.x or 4.x.
    We have MTP implemented, but that is not what you asked for.
  18. #543
  19. #544
    Apr 2019
    174
    Thanks very much.
  20. #545
    Dec 2015
    LA
    230
    Since I played with this and setting type 'USB MTP...' on my T3.6 now whenever I plug the T3.6 into my mac the photo application opens. Not sure how to break the association on the mac. If I change the type to 'No USB' the photo app no longer opens but the serial is gone. Returning type to 'serial' makes the photos open again.
    None of many other Teensy's have this problem. What can I change on this T3.6 to make it good again. This is with 1.54 beta 7 with any program.
  21. #546
    15,278
    Not sure of the ways of on mac? How it associates and can change that ...
    > Plug it in holding button, perhaps on a different USB port - then upload the Serial only sketch?
    > Do that with a second T_3.6 (if there is one at hand) and do the above?
    > Program it with Dual Serial for something else different?
    > Maybe do a 15s Restore? Press program Button a timed 15 seconds, then release and wait for Blink to start.
  22. #547
    Dec 2015
    LA
    230
    thanks defragster
    Tried messing with two 3.6s. Then both have the issue!
    then
    For some reason loading the example 'AnalogReadSerial.ino' and switching between type serial and MTP serial and trying Teensy ports and regular port with two T3.6 attached one of them finally showed up as a device in the photo app! Toggled a 'load photos checkbox' that appeared in the app on then off and closed photos. That seemed to return everything back to normal... computers.... cheezz
  23. #548
    15,278
    Glad to hear you found a solution.
  24. #549
    Aug 2021
    6
    Hi, I am trying to copy a file from the SD card of the Teensy to a Mass storage device connected to the USB Host port of the Teensy. Haven't got any luck. I am thinking of using the MSC2, but getting compilation error, while compiling the example:
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\USBHos t_t36/USBHost_t36.h:2045:2: error: 'msSCSICapacity_t' does not name a type
    msSCSICapacity_t msCapacity;
    Any help will be highly appreciated.
  25. #550
    Aug 2017
    599
    Quote Originally Posted by sharafat View Post
    I am sorry that I have been so slow at updating the MSC library. MSC is pretty much outdated and not functional with the latest versions of Teensyduino starting with version 1.53 and up. The MSC driver is now included with Teensyduino starting with version 1.53 and up. In an effort to standardize SD which was the original file system for Teensy and Arduino and create a level of abstraction for the various mass storage devices being used with the Teensy Paul at PJRC created FS.h which allowed using SdFat and LittleFS with the SD API. Both SD and SdFat API's can be mixed. I took that and created a library that is compatible with MSC, SD and SdFat.
    Here:
    https://github.com/wwatson4506/UsbMscFat
    And @KurtE and @mjs513 developed it further adding a lot more functionality. The latest being:
    https://github.com/wwatson4506/UsbMs...scFat-FS_DATES
    This added the time an date functionality. Some of the added ability is using Fat32 and EXFat partitions, partition labels, creating and formatting both Fat32 and EXFat partitions.
    Check out the examples in the UsbMscFat library. It has a lot of examples in both versions of the library including copying files between USB thumb drives and SD cards.
    I noticed that I do not have an example of copying a file from SD to MSC using non-SdFat methods and using file access abstraction. TODO
    Actually will do
