Page 23 of 25 FirstFirst ... 13 21 22 23 24 25 LastLast
Results 551 to 575 of 606
Thread: USBHost_t36 USB Mass Storage Driver Experiments
  1. #551
    Aug 2021
    6
    Quote Originally Posted by wwatson View Post
    I am sorry that I have been so slow at updating the MSC library. MSC is pretty much outdated and not functional with the latest versions of Teensyduino starting with version 1.53 and up. The MSC driver is now included with Teensyduino starting with version 1.53 and up. In an effort to standardize SD which was the original file system for Teensy and Arduino and create a level of abstraction for the various mass storage devices being used with the Teensy Paul at PJRC created FS.h which allowed using SdFat and LittleFS with the SD API. Both SD and SdFat API's can be mixed. I took that and created a library that is compatible with MSC, SD and SdFat.
    Here:
    https://github.com/wwatson4506/UsbMscFat
    And @KurtE and @mjs513 developed it further adding a lot more functionality. The latest being:
    https://github.com/wwatson4506/UsbMs...scFat-FS_DATES
    This added the time an date functionality. Some of the added ability is using Fat32 and EXFat partitions, partition labels, creating and formatting both Fat32 and EXFat partitions.
    Check out the examples in the UsbMscFat library. It has a lot of examples in both versions of the library including copying files between USB thumb drives and SD cards.
    I noticed that I do not have an example of copying a file from SD to MSC using non-SdFat methods and using file access abstraction. TODO
    Actually will do
    Thanks a lot for that.
    I am trying to use the UsbMscFat library. I was trying the ReadWriteUSB example. It can initialize the USB but gets stuck writing:
    Initializing USB MSC drive...initialization done.
    Writing to test.txt..
    I am using a Sandisk USB drive with 16gb storage size. Tried formatting to both Fat32 and ExFat. Same results for both format type.
  2. #552
    Senior Member wwatson's Avatar
    Aug 2017
    574
    @sharafat - What version of Arduino and Teensyduino are you using? I just tried it here and I get this:
    Writing to test.txt...done.
    test.txt:
    testing 1, 2, 3.
    done.
    This is with Arduino 1.8.15 and Teensyduino 1.54.
    Another issue we have had is USB hubs. Did you use a USB hub? If you did then try the sketch without the hub. I have not tried a Sandisk USB thumb drive yet.
    As a last resort we can turn on debug in USBHost_t36.h. This is located in ~/arduino-1.8.15/hardware/teensy/avr/lbiraries/UABHoat_t36/USBHost_t36.h at about line 62.
    Just un-comment that line and rerun the sketch. You should see a huge dump of info about your particular USB device.
    Something like this:
    USB2 PLL running
     reset waited 6
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 20005000
    periodictable = 20005000
    Initializing USB MSC drive...port change: 10001803
        connect
      begin reset
    port change: 18001205
      port enabled
      end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 10 02 00 00 00 40 51 09 66 16 01 00 01 02 03 01
        VendorID = 0951, ProductID = 1666, Version = 0001
        Class/Subclass/Protocol = 0 / 0 / 0
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: Kingston
    enumeration:
    Product: DataTraveler 3.0
    enumeration:
    Serial Number: 00E04C819241F2C188BE0F0D
    enumeration:
    Config data length = 32
    enumeration:
    Configuration Descriptor:
      09 02 20 00 01 01 00 80 96
        NumInterfaces = 1
        ConfigurationValue = 1
      09 04 00 00 02 08 06 50 00
        Interface = 0
        Number of endpoints = 2
        Class/Subclass/Protocol = 8(Mass Storage) / 6(SCSI) / 80(Bulk Only)
      07 05 81 02 00 02 FF
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
        Polling Interval = 255
      07 05 02 02 00 02 FF
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=20002BA0
    USBHub claim_device this=20002F60
    USBHub claim_device this=20003320
    USBHub claim_device this=200027E0
    msController claim this=20001EE0
    msController claim this=20003700
    Descriptor 4 = INTERFACE
    09 04 00 00 02 08 06 50 00 07 05 81 02 00 02 FF 07 05 02 02 00 02 FF
    numendpoint=2
    endpointIn=81
    endpointOut=2
    packet size in (msController) = 512
    packet size out (msController) = 512
    polling intervalIn = 255
    polling intervalOut = 255
    new_Pipe
    new_Pipe
    Descriptor 5 = ENDPOINT
    control CallbackIn (msController)
    00 00 00 00 00 00 00 00
    msController CallbackOut (static)
    transfer->qtd.token = 0
    msController dataOut (static)31
    55 53 42 43 01 00 00 00 00 00 00 00 80 00 06 1B 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00
    msController CallbackIn (static)
    msController dataIn (static): 13
    55 53 42 53 01 00 00 00 00 00 00 00 00
    55 53 42 43 02 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 02 00 00 00 00 00 00 00 00
    55 53 42 43 03 00 00 00 24 00 00 00 80 00 06 12 00 00 00 24 00 00 00 00 00 00 00 00 00 00 00
    msController dataIn (static): 36
    00 80 06 02 F8 00 00 00 4B 69 6E 67 73 74 6F 6E 44 61 74 61 54 72 61 76 65 6C 65 72 20 33 2E 30
    55 53 42 53 03 00 00 00 00 00 00 00 00
    55 53 42 43 04 00 00 00 08 00 00 00 80 00 0A 25 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    msController dataIn (static): 8
    03 9A 33 F3 00 00 02 00
    55 53 42 53 04 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 05 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
    msController dataIn (static): 512
    FA B8 00 10 8E D0 BC 00 B0 B8 00 00 8E D8 8E C0 FB BE 00 7C BF 00 06 B9 00 02 F3 A4 EA 21 06 00
    55 53 42 53 05 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 06 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 08 00 00 00 01 00 00 00 00 00 00 00
    EB 58 90 6D 6B 66 73 2E 66 61 74 00 02 20 20 00 02 00 00 00 00 F8 00 00 20 00 40 00 00 08 00 00
    55 53 42 53 06 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 07 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 07 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 08 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 08 00 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 08 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 09 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 7B 60 00 00 01 00 00 00 00 00 00 00
    33 32 47 46 41 54 33 32 20 20 20 08 00 00 79 94 CE 52 CE 52 00 00 79 94 CE 52 00 00 00 00 00 00
    55 53 42 53 09 00 00 00 00 00 00 00 00
    Writing to test.txt...msReadBlocks()
    55 53 42 43 0A 00 00 00 00 02 00 00 80 00 0A 28 00 00 0C 7A 20 00 00 01 00 00 00 00 00 00 00
    74 65 73 74 69 6E 67 20 31 2C 20 32 2C 20 33 2E 0D 0A CE 52 00 00 79 94 CE 52 00 00 00 00 00 00
    55 53 42 53 0A 00 00 00 00 00 00 00 00
    55 53 42 43 0B 00 00 00 00 02 00 00 00 00 0A 2A 00 00 0C 7A 20 00 00 01 00 00 00 00 00 00 00
    msController dataOut (static)512
    74 65 73 74 69 6E 67 20 31 2C 20 32 2C 20 33 2E 0D 0A 74 65 73 74 69 6E 67 20 31 2C 20 32 2C 20
    55 53 42 53 0B 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 0C 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 7B 60 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 0C 00 00 00 00 00 00 00 00
    55 53 42 43 0D 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 7B 60 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 0D 00 00 00 00 00 00 00 00
    done.
    test.txt:
    msReadBlocks()
    55 53 42 43 0E 00 00 00 00 02 00 00 80 00 0A 28 00 00 0C 7A 20 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 0E 00 00 00 00 00 00 00 00
    testing 1, 2, 3.
    testing 1, 2, 3.
    Your results will probably be different. But may give a clue to what is going wrong.
  3. #553
    Aug 2021
    6
    Thanks. I was using an older Arduino version. Currently updates to 1.8.15 and 1.54. However, still stuck. Getting the following message with verbose:
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
     reset waited 4
    USBHS_PERIODICLISTBASE = 1FFF4000
    periodictable = 1FFF4000
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 10 02 00 00 00 40 81 07 99 55 00 01 01 02 03 01
        VendorID = 0781, ProductID = 5599, Version = 0100
    enumeration:
    enumeration:
    Manufacturer: SanDisk
    enumeration:
    Product: Cruzer Dial
    enumeration:
    Serial Number: 4C530000190309122541
    enumeration:
    enumeration:
      09 02 20 00 01 01 00 80 70
        NumInterfaces = 1
        Interface = 0
      07 05 81 02 00 02 00
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
        Polling Interval = 0
      07 05 02 02 00 02 00
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
    enumeration:
    msController claim this=1FFF2020
    msController claim this=1FFF2920
    09 04 00 00 02 08 06 50 00 07 05 81 02 00 02 00 07 05 02 02 00 02 00
    numendpoint=2
    endpointIn=81
    endpointOut=2
    polling intervalIn = 0
    polling intervalOut = 0
    new_Pipe
    new_Pipe
    00 80 06 12 43 00 00 00 53 61 6E 44 69 73 6B 00 43 72 75 7A 65 72 20 44 69 61 6C 00 00 00 00 00
    01 D2 FF FF 00 00 02 00
    msReadBlocks()
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 06 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 20 00 00 01 00 00 00 00 00 00 00
    EB 58 90 4D 53 44 4F 53 35 2E 30 00 02 10 60 0B 02 00 00 00 00 F8 00 00 3F 00 FF 00 20 00 00 00
    msReadBlocks()
    msReadBlocks()
    55 53 42 43 08 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 20 00 00 01 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 09 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 80 20 00 00 01 00 00 00 00 00 00 00
    42 20 00 49 00 6E 00 66 00 6F 00 0F 00 72 72 00 6D 00 61 00 74 00 69 00 6F 00 00 00 6E 00 00 00
    55 53 42 43 0A 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 80 20 00 00 01 00 00 00 00 00 00 00
    transfer->qtd.token = 64
    msController dataIn (static): 0
    ERROR Followup
    CSW Tag Error: 253
    CSW Tag Error: 253
    msController dataOut (static)0
    ERROR Followup
  4. #554
    Aug 2017
    574
    @sharafat - I think I might know what is happening here. At this point a guess. I had an 8GB Sandisk Cruzer and have a 16GB PNY thumb stick that magically write protected them selves. What I am seeing is about the time the sketch opens the file for a write operation it fails with code 253 which is a tag error. In other words every read and write to the drive is followed by a status read which gives info about the last OP. Success or failure. In this case a tag error #253 which means the status read did not return the same tag number that was sent with the last command. Several things can cause this and when the error occurs we need to read the sense codes and decode them to find out why the error happened.
    A simple way to test this is to use your PC to copy a file to the thumb drive and see if it completes successfully. That will let me know if the integrity of the drive is good. Otherwise it might be magically write protected
    If it is working properly with the PC then I need to write a sketch you can use to check the sense codes. Reading an decoding sense codes is available in UsbMscFat. It will probably be this weekend before I can pursue the further. If you have another thumb drive or SD card reader try that out as well. This is exactly what I was looking for testing MSC.
    Edit: SSD's as well.
  5. #555
    15,260
    Given a clean TD 1.54 install - and a branch of UsbMscFat,
    what edits and other libs are needed to test 'the current code' at hand
  6. #556
    Aug 2017
    574
    @defragster - All that is really needed is TD 1.54 and this version of UsbMscFat:
    This is the most up to date version that was worked on by @Kurte and @mjs513.
    Plus I have a PR for timeouts in msc.h in the USBHOST_t36 library. They need to be longer timeouts for USB SD card readers and maybe other slower USB drives.
    I want to be able to test retrieving sense codes upon failures of access to MSC drives. I have UsbMscFat setup to do that and decode the failures. I have not played with it for a while and this weekend with @sharafat's issue I am going to setup a sketch for testing this specifically. The framework is there but not utilized yet. As I stated above I had a PNY thumb stick that somehow write protected it's self and was able to decode that sense code.
    EDIT: Hopefully this will isolate hardware failure from software problems.
  7. #557
    15,260
    Thanks - I got that - but no joy? Will double check github delivered the right branch.
    I see MTP experimental in the boards.txt - but not MTP_Serial using the edited usb_desc.h? Any other changes?
  8. #558
    Aug 2017
    574
    I have not been involved with MTP myself so I cannot answer that
  9. #559
    15,260
    Opps - okay confused including MTP then.
    Not sure the missing piece for a UsbMsc example to run ... and show on PC?
  10. #560
    Aug 2017
    574
    Sorry, It is ReadWriteUSB.ino in UsbMscFat-FS_DATES.
  11. #561
    15,260
    Thanks. Nothing shows on PC?
    64GB AData in on startup - removed then 128GB AData Flash on USB Host:
    USB2 PLL running
    reset waited 6
    Initializing USB MSC drive...initialization failed!
    connect
    begin reset
    port enabled
    end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    12 01 10 02 00 00 00 40 5F 12 8A DB 75 10 01 02 03 01
    VendorID = 125F, ProductID = DB8A, Version = 1075
    enumeration:
    enumeration:
    Manufacturer: ADATA
    enumeration:
    Product: ADATA USB Flash Drive
    enumeration:
    Serial Number: 1510710162080035
    enumeration:
    enumeration:
    09 02 20 00 01 01 00 80 64
    NumInterfaces = 1
    Interface = 0
    Endpoint = 2 OUT
    Type = Bulk
    Max Size = 512
    Endpoint = 1 IN
    Type = Bulk
    Max Size = 512
    enumeration:
    09 04 00 00 02 08 06 50 00 07 05 02 02 00 02 00 07 05 81 02 00 02 00
    numendpoint=2
    endpointIn=81
    endpointOut=2
    new_Pipe
    new_Pipe
    port change: 1C00100A
    disconnect
    disconnect_Device:
    USBDriver (available_drivers) list: 20002BA0 -> 20002F60 -> 20003320 -> 200027E0 -> 20003700
    USBDriver (dev->drivers) list: 20001EE0
    disconnect driver 20001EE0
    Device Disconnected...
    USBDriver (available_drivers) list: 20001EE0 -> 20002BA0 -> 20002F60 -> 20003320 -> 200027E0 -> 20003700
    delete_Pipe 20003940
    remove QH from async schedule
    Free transfers
    Free transfers attached to QH
    * 536886048
    * Delete Pipe completed
    delete_Pipe 200038E0
    Free transfers
    * 536892544
    delete_Pipe 20005400
    shut down async schedule
    Free transfers
    * 536892736
    removed Device_t from devlist
    disable
    connect
    begin reset
    port enabled
    end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    12 01 10 02 00 00 00 40 5F 12 2B 31 00 11 01 02 03 01
    VendorID = 125F, ProductID = 312B, Version = 1100
    enumeration:
    enumeration:
    Manufacturer: ADATA
    enumeration:
    enumeration:
    Serial Number: 2032803290010002
    enumeration:
    enumeration:
    NumInterfaces = 1
    Interface = 0
    07 05 01 02 00 02 00
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 512
    07 05 82 02 00 02 00
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 512
    enumeration:
    09 04 00 00 02 08 06 50 00 07 05 01 02 00 02 00 07 05 82 02 00 02 00
    numendpoint=2
    endpointIn=82
    endpointOut=1
    new_Pipe
    new_Pipe
  12. #562
    Aug 2017
    574
    @defragster - In your case the initallization failed at the software level. UsbFat could not find a formatted volume to mount. MSC is finding and initializing the drive at the hardware level ok.
    In ReadWriteUSB.ino you can insert this:
      // Check Sense Codes
      MSC.mscfs.printMscError(&Serial);
    To line #53.
    This will return any hardware errors and sense codes if the problem is at the hardware level, otherwise it will suggest that the drive might not be formatted properly.
    In my case with the PNY 64Gig drive I get this output:
    Check USB drive format.
    Next in the MSCFormatter.ino sketch we can add this:
      msc[drive_index].printMscError(&Serial);
    To line #217.
    After it it has loaded and shows the prompt:
    done...
    Enter command:
    You can enter this on the command line:
    R 0 1
    This will try to format the USB drive to FAT32.
    On my PNY drive I had this output:
    Cards up to 2 GiB (GiB = 2^30 bytes) will be formated FAT16.
    Cards larger than 2 GiB and up to 32 GiB will be formatted
    FAT32. Cards larger than 32 GiB will be formatted exFAT.
    Commands:
      f <partition> [16|32|ex] - to format
      v <partition> <label> - to change volume label
      d <partition> - to dump first sectors
      p <partition> - print Partition info
      l <partition> - to do ls command on that partition
      c -  toggle on/off format show changed data
      *** Danger Zone ***
      N <USB Device> start_addr <length> - Add a new partition to a disk
      R <USB Device> - Setup initial MBR and format disk *sledgehammer*
      X <partition> [d <usb device> - Delete a partition
    Waiting up to 5 seconds for a USB drive
    Initialize USB drive...
    initialization drive 0 failed.
    Read Capacity: status: 0 Blocks: 120922111 block Size: 512
    From object: Blocks: 120922111 Size: 512
    Initialize SDIO SD card...initialization failed.
    Initialize SPI SD card...initialization failed.
    ***** Partition List *****
    done...
    Enter command:
     **** Try Sledgehammer on USB Drive 0 ****
    sectorCount = 120922111, FatType: 10
    TODO createPartition on ExFat
    PFsFatFormatter::addPartitionToMbr: 2048 0 120922111
    00 20 21 00 83 FE FF FF 00 08 00 00 00 18 35 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 :. !...........5.................
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 :................................
        p 3: 0 0 0:  - empty slot
        p 2: 0 0 0:  - empty slot
        p 1: 0 0 0:  - empty slot
        p 0: 131 2048 120920064: - exited copy down
        Adjust sector count: 120920063 = 120922111 - 2048 CAP: 59043
        Return partion num: 1
    After Add Partition
        m_relativeSectors: 2048
        m_totalSectors: 120922111
    VS: 27
    sectorsPerClusterShift: 8,
     sectorsPerCluster: 256,
     fatLength 16384
    fatOffset: 16384,
     partitionOffset: 2048
    clusterHeapOffset: 32768,
     clusterCount: 472095,
     volumeLength 120922111
    cluster 2 bitmap: 34816
    Up case table: 35072
        m_relativeSectors:2048
        m_totalSectors:120922111
    Format failed
    USB drive error: 0x1,0x0 --> Type: DATA_PROTECT Cause: WRITE PROTECTED
    Press any key to run again
    The lines in red are output from printMSCerror() in UsbFat.h.
    Very curious to see your results
    @sharafat - Your problem is at the hardware level causing a tag error. Possibly A timing issue with MSC and your thumb drive. Still working on that.
  13. #563
    Aug 2017
    574
    @sharafat - An update. I now know why your particular device failed writing to it:
    ERROR Followup
    CSW Tag Error: 253
    CSW Tag Error: 253
    ERROR Followup
    The qtd.token = 64 indicates that the host device (your thumb drive) halted the pipe/endpoint. qtd.token bit 6 (64) indicates this error:
    Halted. Set to a 1 by the Host Controller during status updates to indicate that
    a serious error has occurred at the device/endpoint addressed by this qTD.
    This can be caused by babble, the error counter counting down to zero, or
    reception of the STALL handshake from the device during a transaction. Any
    time that a transaction results in the Halted bit being set to a one, the Active bit
    is also set to 0
    Active bit is bit 7.
    At this point I am not sure how to recover from this type of error. Possibly by resending the request.
    If you have another USB thumb drive you might want to try that and see if the problem persists.
  14. #564
    15,260
    To line #53.
    DOH! - Both those flash drives were made MultiPartition in last testing.
    Removed dual partitions and formated all 64GB Flash as ExFat.
    Only made one edit in ReadWriteUSB.ino.
    SerMon shows this - no device showing 'Teensy' in Windows?:
    USB2 PLL running
     reset waited 6
    USBHS_PERIODICLISTBASE = 2000B000
    periodictable = 2000B000
    No USB drive detected, plugged in?
    USB drive error: 0x28,0x0 --> Type: NO_SENSE Cause: NO ADDITIONAL SENSE INFORMATION
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    enumeration:
    enumeration:
    Manufacturer: ADATA
    enumeration:
    enumeration:
    enumeration:
    enumeration:
        NumInterfaces = 1
        Interface = 0
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
    enumeration:
    USBHub claim_device this=20009440
    USBHub claim_device this=20009800
    USBHub claim_device this=20009BC0
    USBHub claim_device this=20009080
    msController claim this=20008780
    msController claim this=20009FA0
    numendpoint=2
    endpointIn=81
    endpointOut=2
    new_Pipe
    new_Pipe
  15. #565
    Aug 2017
    574
    USB2 PLL running
     reset waited 6
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    enumeration:
    enumeration:
    Manufacturer: ADATA
    enumeration:
    enumeration:
    enumeration:
    enumeration:
        NumInterfaces = 1
        Interface = 0
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
    enumeration:
    numendpoint=2
    endpointIn=81
    endpointOut=2
    new_Pipe
    new_Pipe
    In USBHost_t36/utility/msc.h there are two timeout settings to check. These start at line #73.
    If they look like this:
    // These two defines are timeouts for detecting a connected drive
    // and waiting for it to be operational.
    #define MEDIA_READY_TIMEOUT	3000
    #define MSC_CONNECT_TIMEOUT       3000
    Then increase them to this:
    #define MEDIA_READY_TIMEOUT	5000
    #define MSC_CONNECT_TIMEOUT       5000
    And try it.
    I have a PR in for USBHost_t36 about these timeouts being to small for some USB drives. There have been a few issues with these timeouts. I have seen some drives take up to 30 seconds to become ready. That is what code 0x28 means. (MS_NO_MEDIA_ERR).
    It seems strange that in post #561 that code 0x28 did not happen and after formatting to EXFAT it did. Anyway, try changing the timeouts.
  16. #566
    15,260
    And try it.
    again ... doh ... there was an April usbHost_t36 in my libraries.
    Removed and went to TD1.54 in libs and edit what was 1000 and 4000 to 5000 for both:
    Using library UsbMscFat at version 1.0.0 in folder: T:\tCode\libraries\UsbMscFat
    Using library USBHost_t36 at version 0.1 in folder: T:\arduino-1.8.15\hardware\teensy\avr\libraries\USBHost_t36
    Using library SdFat at version 2.0.5-beta.1 in folder: T:\arduino-1.8.15\hardware\teensy\avr\libraries\SdFat
    Using library SPI at version 1.0 in folder: T:\arduino-1.8.15\hardware\teensy\avr\libraries\SPI
    Recopied the github UsbMscFat and got this with UsbHost debug on:
    USB2 PLL running
     reset waited 6
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    enumeration:
    enumeration:
    Manufacturer: ADATA
    enumeration:
    enumeration:
    enumeration:
    enumeration:
        NumInterfaces = 1
        Interface = 0
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
    enumeration:
    numendpoint=2
    endpointIn=81
    endpointOut=2
    new_Pipe
    new_Pipe
    transfer->qtd.token = 1
    00 80 06 02 5B 00 00 00 41 44 41 54 41 20 20 20 55 53 42 20 46 6C 61 73 68 20 44 72 69 76 65 20
    07 39 FF FF 00 00 02 00
    msReadBlocks()
    33 C0 8E D0 BC 00 7C 8E C0 8E D8 BE 00 7C BF 00 06 B9 00 02 FC F3 A4 50 68 1C 06 CB FB B9 04 00
    msReadBlocks()
    EB 76 90 45 58 46 41 54 20 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 07 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 20 00 00 00 01 00 00 00 00 00 00 00
    FF FF FF FF FF FF FF FF 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 08 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 22 00 00 00 01 00 00 00 00 00 00 00
    83 04 41 00 44 00 36 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 09 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 22 01 00 00 01 00 00 00 00 00 00 00
    C1 00 4C 00 49 00 43 00 45 00 4E 00 53 00 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 43 0A 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 22 01 00 00 01 00 00 00 00 00 00 00
    Writing to test.txt...msController CallbackOut (static)
    55 53 42 43 0B 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 67 00 00 00 01 00 00 00 00 00 00 00
    74 65 73 74 69 6E 67 20 31 2C 20 32 2C 20 33 2E 0D 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 0C 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 22 01 00 00 01 00 00 00 00 00 00 00
    55 53 42 43 0D 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 20 00 00 00 01 00 00 00 00 00 00 00
    FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 43 0E 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 22 01 00 00 01 00 00 00 00 00 00 00
    done.
    msReadBlocks()
    55 53 42 43 0F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 22 00 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 0F 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 10 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 22 01 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 10 00 00 00 00 00 00 00 00
    test.txt:
    msReadBlocks()
    55 53 42 43 11 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 67 00 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 11 00 00 00 00 00 00 00 00
    testing 1, 2, 3.
    Then I turned of the UsbHost DEBUG and got this before turning it back on and failing again?
    USB2 PLL running
     reset waited 6
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    enumeration:
    enumeration:
    Manufacturer: ADATA
    enumeration:
    enumeration:
    enumeration:
    enumeration:
        NumInterfaces = 1
        Interface = 0
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
    enumeration:
    numendpoint=2
    endpointIn=81
    endpointOut=2
    new_Pipe
    new_Pipe
    Did a CLEAN build with debug on and it worked again - then DEBUG off and clean build fails ...
  17. #567
    Aug 2017
    574
    Looks like we are getting somewhere now
    I appreciate you testing this. As a radical move try increasing the timeouts to 10000 or even 30000. After that try powering down and then powering up without uploading the sketch. I have seen this as a problem before. Not sure why.
    Have to sign off for tonight. Gotta feed the family
  18. #568
    15,260
    Plugged 64GB flash into powered Hub with 30K and 30K - power off and on to Button bootloader:
    test.txt:
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    Edited setup to show current millis() and did upload ( forgot to remove 'ln' from print ):
    Initializing USB MSC drive...13622
     ms >> initialization done.
    test.txt:
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
  19. #569
    15,260
    Again with Flash on Hub - then flash moved to direct connect:
    Initializing USB MSC drive...14015 ms >> initialization done.  // ON HUB
    test.txt:
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    Initializing USB MSC drive...5477 ms >> initialization done.  // Direct connect - No HUB
    test.txt:
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    Immediate fail on 128GB Flash with two partitions:
  20. #570
    Aug 2017
    574
    Awesome It's a sketchy world with these USB devices. Something that @Paul talked about was these USB devices do not always work the same. Possibly need to to have a data base of device PID's and VID's with known parameters that can be used for initializing, reading and writing to that particular device. But that is a major undertaking and probably not something that is going to happen any time soon
  21. #571
    Aug 2017
    574
    Post #569 - ReadWrite.ino does not work with with multiple partitions. Only SdFat and USbFat at this time FS.h is not setup for that. I am working on that right now but am not finished yet
  22. #572
    15,260
    Good it works - odd it takes long time. And longer with Hub - hoped that might have the drive ready sooner.
    Dual Partitions .... Not a problem - just leftover form last testing with 'others' months back.
    Here's the start of setup() to the millis() print:
       while (!Serial) {
        ; // wait for serial port to connect.
      // Start USBHost_t36, HUB(s) and USB devices.
      myusb.begin();
      Serial.print("\nInitializing USB MSC drive...");
      if (!MSC.begin(&msDrive1)) {
        Serial.println("initialization failed!");
        return;
      Serial.print( millis() );
      Serial.println(" ms >> initialization done.");
      // open the file.
      myFile = MSC.open("test.txt", FILE_WRITE);
  23. #573
    15,260
    @wwatson: I have a powered hub with internal HDD.
    Plugged it in and restarted - and a couple resets all working.
    > Also have the same 64GB Flash plugged into the HUB it is found ...
    In the spew you'll find the same :: 1951 ms >> initialization done.
    Initializing USB MSC drive...1853 ms >> initialization done.
    test.txt:
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    For added info turned on UsbHost DEBUG - recompiled and it worked again!
    USB2 PLL running
     reset waited 6
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 10 02 09 00 01 40 09 21 13 28 01 90 01 02 00 01
        VendorID = 2109, ProductID = 2813, Version = 9001
        Class/Subclass/Protocol = 9(Hub) / 0 / 1(Single-TT)
    enumeration:
    enumeration:
    Manufacturer: VIA Labs, Inc.
    enumeration:
    Product: USB2.0 Hub
    enumeration:
    Config data length = 25
    enumeration:
      09 02 19 00 01 01 00 E0 00
        NumInterfaces = 1
      09 04 00 00 01 09 00 00 00
        Interface = 0
        Number of endpoints = 1
        Class/Subclass/Protocol = 9(Hub) / 0 / 0
      07 05 81 03 01 00 0C
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 1
        Polling Interval = 12
    enumeration:
    found possible interface, altsetting=0
    number of interfaces found = 1
    USBHub control callback
    09 29 04 E9 00 32 64 00 FF 00 00 00 00 00 00 00
    Hub ports = 4
    power turned on to all ports
    device addr = 1
    new_Pipe
    allocate_interrupt_pipe_bandwidth
      ep interval = 12
      interval = 256
     best_bandwidth = 2, at offset = 0
    pipe cap1 = F0012101
    HUB Callback (member)
    status = 6
    getstatus, port = 1
    deferred getstatus, port = 2
    01 01 01 00
    New Port Status
      status=10101  port=1
      state=0
      Device is present:
      Has Power
    Port Status Cleared, port=1
    getstatus, port = 2
    01 01 01 00
    New Port Status
      status=10101  port=2
      state=0
      Device is present:
      Has Power
    Port Status Cleared, port=2
    timer event (19998 us): Debounce Timer, this = 20009440, timer = 20009758
    ports in use bitmask = 6
    getstatus, port = 1
    01 01 00 00
    New Port Status
      status=101  port=1
      state=2
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=2
      Device is present:
      Has Power
    getstatus, port = 1
    01 01 00 00
    New Port Status
      status=101  port=1
      state=3
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=3
      Device is present:
      Has Power
    getstatus, port = 1
    01 01 00 00
    New Port Status
      status=101  port=1
      state=4
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=4
      Device is present:
      Has Power
    getstatus, port = 1
    01 01 00 00
    New Port Status
      status=101  port=1
      state=5
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=5
      Device is present:
      Has Power
    getstatus, port = 1
    01 01 00 00
    New Port Status
      status=101  port=1
      state=6
      Device is present:
      Has Power
    sending reset
    send_setreset
    unhandled setup, message = 40323
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=6
      Device is present:
      Has Power
    ports in use bitmask = 4
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=6
      Device is present:
      Has Power
    status = 2
    getstatus, port = 1
    03 05 10 00
    New Port Status
      status=100503  port=1
      state=7
      Device is present:
      Enabled, speed = 480 Mbit/sec
      Has Power
    unhandled setup, message = 140123
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=6
      Device is present:
      Has Power
    timer event (24998 us): Hello, I'm resettimer, this = 20009440, timer = 20009778
    port_doing_reset = 1
    PORT_RECOVERY
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 10 02 00 00 00 40 80 00 01 A0 03 02 01 02 03 01
        VendorID = 0080, ProductID = A001, Version = 0203
    enumeration:
    enumeration:
    Manufacturer: TOSHIBA
    enumeration:
    Product: External USB 3.0
    enumeration:
    Serial Number: 201503310007F
    enumeration:
    Config data length = 85
    enumeration:
      09 02 55 00 01 01 00 80 FA
        NumInterfaces = 1
        Interface = 0
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
      09 04 00 01 04 08 06 62 00
        Interface = 0
        Number of endpoints = 4
        Class/Subclass/Protocol = 8(Mass Storage) / 6(SCSI) / 98(UAS)
        Endpoint = 1 OUT
        Type = Bulk
        Max Size = 512
      04 24 01 00
        Endpoint = 2 IN
        Type = Bulk
        Max Size = 512
      04 24 02 00
      07 05 83 02 00 02 00
        Endpoint = 3 IN
        Type = Bulk
        Max Size = 512
      04 24 03 00
      07 05 04 02 00 02 00
        Endpoint = 4 OUT
        Type = Bulk
        Max Size = 512
      04 24 04 00
    enumeration:
    09 04 00 00 02 08 06 50 00 07 05 81 02 00 02 00 07 05 02 02 00 02 00 09 04 00 01 04 08 06 62 00 07 05 01 02 00 02 00 04 24 01 00 07 05 82 02 00 02 00 04 24 02 00 07 05 83 02 00 02 00 04 24 03 00 07 05 04 02 00 02 00 04 24 04 00
    numendpoint=2
    endpointIn=81
    endpointOut=2
    new_Pipe
    new_Pipe
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    00 00 06 12 5B 00 00 00 54 4F 20 45 78 74 65 72 6E 61 6C 20 55 53 42 20 33 2E 30 20 20 20 20 20
    0D F9 4B AF 00 00 02 00
    msReadBlocks()
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=6
      Device is present:
      Has Power
    sending reset
    send_setreset
    ports in use bitmask = 0
    status = 4
    getstatus, port = 2
    03 05 10 00
    New Port Status
      status=100503  port=2
      state=7
      Device is present:
      Has Power
    port_doing_reset = 2
    PORT_RECOVERY
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    enumeration:
    enumeration:
    Manufacturer: ADATA
    enumeration:
    enumeration:
    enumeration:
    enumeration:
        NumInterfaces = 1
        Interface = 0
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
    enumeration:
    numendpoint=2
    endpointIn=81
    endpointOut=2
    new_Pipe
    new_Pipe
    msReadBlocks()
    msReadBlocks()
    55 53 42 43 07 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 00 00 00 01 00 00 00 00 00 00 00
    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    msReadBlocks()
    55 53 42 43 08 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 32 00 00 00 01 00 00 00 00 00 00 00
    83 09 31 00 32 00 30 00 47 00 42 00 5F 00 45 00 78 00 74 00 00 00 00 00 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 09 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 32 01 00 00 01 00 00 00 00 00 00 00
    85 02 64 70 20 00 00 00 86 88 37 50 88 88 37 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 43 0A 00 00 00 00 02 00 00 80 00 0A 28 00 00 06 12 00 00 00 01 00 00 00 00 00 00 00
    55 53 42 43 0B 00 00 00 00 02 00 00 00 00 0A 2A 00 00 06 12 00 00 00 01 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 0C 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 32 01 00 00 01 00 00 00 00 00 00 00
    55 53 42 43 0D 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 32 01 00 00 01 00 00 00 00 00 00 00
    done.
    msReadBlocks()
    55 53 42 43 0E 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 32 00 00 00 01 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 0F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 32 01 00 00 01 00 00 00 00 00 00 00
    test.txt:
    msReadBlocks()
    55 53 42 43 10 00 00 00 00 02 00 00 80 00 0A 28 00 00 06 12 00 00 00 01 00 00 00 00 00 00 00
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    And running : ...\libraries\UsbMscFat\examples\SdInfoUSB\SdInfoU SB.ino
    MSC Fat version: 1.0.0
    type any character to start
    init time: 2703 ms
    Drive type: USB Drive.
    msc1 Partition Table
    part,boot,bgnCHS[3],type,endCHS[3],start,length
    1,0X0,0X20,0X21,0X0,0X7,0XFE,0XFF,0XFF,2048,234436608
    2,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0,0
    3,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0,0
    4,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0,0
    Scanning FAT, please wait.
    Volume is exFAT
    clusterCount:      915728
    freeClusterCount:  914221
    fatStartSector:    4096
    dataStartSector:   12288
  24. #574
    15,260
    Using the T_4.1 USB Host to External HDD enclosure with Powered Hub - and three USB 3 ports, where one has the 64GB Flash from above:
    Did a DUPE of code for msDrive1 to msDrive2
    >> Using file test2.txt, and put ' 2 ' then ' TWO ::' in the test write
    Both drives are online and usable - in GOOD TIME too!:
    Initializing USB MSC drive...2089 ms >> initialization done.
    test.txt:
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    testing 1, 2, 3.
    2156 ms >> initialization done.
    Writing to test2.txt...done.
    test2.txt:
    testing 2 1, 2, 3.
    testing TWO :: 1, 2, 3.
  25. #575
    Aug 2017
    574
    @defragster - Glad everything is working as it should be Something else that needs to be fixed in MassStorageDriver.cpp is a stray println("msReadBlocks()") at line #510. I guess I missed that one when I was cleaning it up. It can be deleted and that helps a little bit with the spew. I have used a non-powered 4 port Hub with 3 USB drives connected without issue. I was not brave enough to push it past that.
    I am hoping to finish up my current testing project today or tomorrow and post it on the forum for further testing as an example of unifying disk IO. I know this is something that was talked about here:
    https://forum.pjrc.com/threads/67588...-Beta-11/page3
    It will just be one example of doing this
