Page 24 of 25 FirstFirst ... 14 22 23 24 25 LastLast
Results 576 to 600 of 606
Thread: USBHost_t36 USB Mass Storage Driver Experiments
  1. #576
    15,279
    Yes, nice to see it work.
    Haven't looked ANY at the code or support functions (VOL label or other drive ID, or param info) - just running that sample. Interesting the Flash alone takes that long time first seen to come online - then the HDD in HUB online at 2089 ms and just a few ms later after running the short drive1 test the drive2 Flash is online at 2156 ms.
    And working reliably with rebuild, clean build, or Reset.
    After sitting since last post just hit TyComm Reset and HDD gave : 4109 ms >> initialization done.
    repeats after that went to 2 secs and under for a couple then back to 4 secs ... so 5 secs seems minimal safe WAIT
  2. #577
    Senior Member wwatson's Avatar
    Aug 2017
    599
    @defragster - I remember seeing a post, can't remember where, that I think explained the reason for the inconsistent initialization and access times and it made sense. Dealing with anything that involves flash memory has a bit of housekeeping involved. For that matter probably hard drives a little bit as well. The current state of the device is probably in an unpredictable state when powered down or up. Possibly syncing and unmounting the device before power down could help. Not sure
  3. #578
    15,279
    @wwatson - what I found in msc.h when I started was this:
    // These two defines are timeouts for detecting a connected drive
    // and waiting for it to be operational.
    #define MEDIA_READY_TIMEOUT	1000
    #define MSC_CONNECT_TIMEOUT 4000
    I just put that back - and when First try of MSC.begin() failed ... I added another try:
    Initializing USB MSC drive...initialization failed!
    Initializing USB MSC drive... Try #2 ...
    Initializing USB MSC drive...2175 ms >> initialization done.
    Writing to test.txt...done.
    That worked for Hub/HDD with Flash
    - but Flash only direct seems to have hung the T_4.1
    So that doesn't seem a viable path at this time?
    I put times back to 5K for both and only HDD with No Flash
    Works for HDD msDrive1 - when it tries msDrive2 fails as expected:
    No USB drive detected, plugged in?
    USB drive error: 0x28,0x0 --> Type: NO_SENSE Cause: NO ADDITIONAL SENSE INFORMATION
  4. #579
    Aug 2017
    599
    @defragster - Based on your testing and some of mine I think it would be best to set the timeouts to at least 30 seconds. I was checking some of the other Mass Storage drivers and they to were doing at least 30 seconds for there timeouts. It is actually waiting for the media to become internally ready to connect to USBHost_t36. (power up).
  5. #580
    Aug 2021
    6
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
     reset waited 5
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 1FFF4000
    periodictable = 1FFF4000
    Initializing USB MSC drive...port change: 10001803
        connect
      begin reset
    port change: 18001205
      port enabled
      end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 00 00 00 40 FF FF 78 56 00 02 01 02 03 01
        VendorID = FFFF, ProductID = 5678, Version = 0200
        Class/Subclass/Protocol = 0 / 0 / 0
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: USB
    enumeration:
    Product: Disk 2.0
    enumeration:
    Serial Number: 00001103230642337368
    enumeration:
    Config data length = 32
    enumeration:
    Configuration Descriptor:
      09 02 20 00 01 01 00 80 32
        NumInterfaces = 1
        ConfigurationValue = 1
      09 04 00 00 02 08 06 50 00
        Interface = 0
        Number of endpoints = 2
        Class/Subclass/Protocol = 8(Mass Storage) / 6(SCSI) / 80(Bulk Only)
      07 05 01 02 00 02 00
        Endpoint = 1 OUT
        Type = Bulk
        Max Size = 512
        Polling Interval = 0
      07 05 82 02 00 02 00
        Endpoint = 2 IN
        Type = Bulk
        Max Size = 512
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=1FFF2CE0
    USBHub claim_device this=1FFF30A0
    USBHub claim_device this=1FFF3460
    USBHub claim_device this=1FFF2920
    msController claim this=1FFF2020
    Descriptor 4 = INTERFACE
    09 04 00 00 02 08 06 50 00 07 05 01 02 00 02 00 07 05 82 02 00 02 00
    numendpoint=2
    endpointIn=82
    endpointOut=1
    packet size in (msController) = 512
    packet size out (msController) = 512
    polling intervalIn = 0
    polling intervalOut = 0
    new_Pipe
    new_Pipe
    Descriptor 5 = ENDPOINT
    control CallbackIn (msController)
    00 00 00 00 00 00 00 00
    msController CallbackOut (static)
    transfer->qtd.token = 1
    msController dataOut (static)31
    55 53 42 43 01 00 00 00 00 00 00 00 80 00 06 1B 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00
    msController CallbackIn (static)
    transfer->qtd.token = 0
    msController dataIn (static): 13
    55 53 42 53 01 00 00 00 00 00 00 00 00
    55 53 42 43 02 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 02 00 00 00 00 00 00 00 00
    55 53 42 43 03 00 00 00 24 00 00 00 80 00 06 12 00 00 00 24 00 00 00 00 00 00 00 00 00 00 00
    msController dataIn (static): 36
    00 80 04 02 1F 00 00 00 56 65 6E 64 6F 72 43 6F 50 72 6F 64 75 63 74 43 6F 64 65 20 20 20 20 20
    55 53 42 53 03 00 00 00 00 00 00 00 00
    55 53 42 43 04 00 00 00 08 00 00 00 80 00 0A 25 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    msController dataIn (static): 8
    01 D4 BF FF 00 00 02 00
    55 53 42 53 04 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 05 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
    msController dataIn (static): 512
    FA 33 C0 8E D0 BC 00 7C 8B F4 50 07 50 1F FB FC BF 00 06 B9 00 01 F2 A5 EA 1D 06 00 00 BE BE 07
    55 53 42 53 05 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 06 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 40 00 00 01 00 00 00 00 00 00 00
    EB 5A 90 2B 6A 30 7C 38 49 48 43 00 02 10 F0 0A 02 00 00 00 00 F8 00 00 20 00 40 00 40 00 00 00
    55 53 42 53 06 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 07 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 07 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 08 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 40 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 08 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 09 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 80 40 00 00 01 00 00 00 00 00 00 00
    52 45 43 59 43 4C 45 52 20 20 20 12 00 96 D4 88 3A 51 3A 51 00 00 D5 88 3A 51 03 00 00 00 00 00
    55 53 42 53 09 00 00 00 00 00 00 00 00
    55 53 42 43 0A 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 80 40 00 00 01 00 00 00 00 00 00 00
    msController dataOut (static)512
    55 53 42 53 0A 00 00 00 00 00 00 00 00
    Writing to test.txt...msReadBlocks()
    55 53 42 43 0B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 0B 30 00 00 01 00 00 00 00 00 00 00
    F8 FF FF 0F FF FF FF FF FF FF FF 0F FF FF FF 0F FF FF FF 0F FF FF FF 0F FF FF FF 0F 08 00 00 00
    55 53 42 53 0B 00 00 00 00 00 00 00 00
    55 53 42 43 0C 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 85 D0 00 00 01 00 00 00 00 00 00 00
    74 65 73 74 69 6E 67 20 31 2C 20 32 2C 20 33 2E 0D 0A 3A 51 00 00 D5 88 3A 51 03 00 00 00 00 00
    55 53 42 53 0C 00 00 00 00 00 00 00 00
    msReadBlocks()
    55 53 42 43 0D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 80 40 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 0D 00 00 00 00 00 00 00 00
    55 53 42 43 0E 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 80 40 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 0E 00 00 00 00 00 00 00 00
    55 53 42 43 0F 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 0B 30 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 0F 00 00 00 00 00 00 00 00
    55 53 42 43 10 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 45 B8 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 10 00 00 00 00 00 00 00 00
    done.
    test.txt:
    msReadBlocks()
    55 53 42 43 11 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 85 D0 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 11 00 00 00 00 00 00 00 00
    testing 1, 2, 3.
    I tried 3 USB sticks. One worked. Above the log for the USB stick that worked.
  6. #581
    15,279
    @sharafat
    From this post : pjrc.com/threads/55821-USBHost_t36-USB-Mass-Storage-Driver-Experiments
    #define MEDIA_READY_TIMEOUT	5000
    #define MSC_CONNECT_TIMEOUT       5000
    Set those to 5000 or 30000 and try your flash drives again.
    Also editing these two BOLD lines in for the success case might show how long it takes the drives there to work when it hits the "initialization done":
      if (!MSC.begin(&msDrive1)) {
        Serial.println("initialization failed!");
        // Check Sense Codes
        MSC.mscfs.printMscError(&Serial);
        return;
      Serial.print( millis() );
      Serial.println(" ms >> initialization done.");
      // open the file.
      myFile = MSC.open("test.txt", FILE_WRITE);
    @wwatson : Seems large single timeout effort would be best - even 30 seconds - when the drives are known to be there and needed ... just have to wait for them to appear.
    Was hoping the try twice might work - but unless the USB system is meant for handling that - I can see it might trip over itself.
  7. #582
    Aug 2017
    599
    Quote Originally Posted by sharafat View Post
    sizeof Device = 36
    sizeof Pipe = 96
    power up USBHS PHY
     reset waited 5
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    enumeration:
    enumeration:
    Manufacturer: USB
    enumeration:
    Product: Disk 2.0
    enumeration:
    enumeration:
    enumeration:
        NumInterfaces = 1
        Interface = 0
        Endpoint = 1 OUT
        Type = Bulk
        Max Size = 512
        Endpoint = 2 IN
        Type = Bulk
        Max Size = 512
    enumeration:
    numendpoint=2
    endpointIn=82
    endpointOut=1
    new_Pipe
    new_Pipe
    msReadBlocks()
    msReadBlocks()
    msReadBlocks()
    msReadBlocks()
    msReadBlocks()
    msReadBlocks()
    done.
    test.txt:
    msReadBlocks()
    testing 1, 2, 3.
    What are the name brands of the 3 USB sticks you are using? I see this for the one that works:
    Manufacturer: USB
    enumeration:
    Product: Disk 2.0
    enumeration:
    Not sure who manufactures it.
    I am glad to see you have one device working
  8. #583
    Aug 2017
    599
    @defragster @sdharafat - I guess what I am trying to say is that there is no real way to speed up the internal processes in any particular Mass Storage device. At least as far as my understanding of this goes. I do know that all of the Mass Storage devices are NOT created equal. There are some devices that require a delay after a reset command and some that do not. There are some devices that do not follow standards as far as following USB and SCSI standards. To make MSC work with everything would probably require having a database of PID's and VID's with known parameters for initialization and usage. So what we are left with is experimentation for every device we trying to use. Eventually This could happen. But for right now it is matter of testing each device and finding where within MSC we can make it work. Functionality now speed later
    Cannot afford to purchase every device available for testing so info on the type of device that does not work is needed.
    For research
  9. #584
    15,279
    @wwatson - understood as inarguably reasonable - 30 sec wait should assure max connectivity for devices to start, and if they work and connect early that is no problem.
    Having a device not respond properly in time and not get mounted is not useful at all especially if another couple of seconds could make it work as happens with a timeout that is too short.
    The 'Eventuality' of refinement is always promising. If having a known VID_PID helps maybe it could print out a parameter set for use embedded in the code for future use.
  10. #585
    Senior Member xxxajk's Avatar
    Nov 2013
    Buffalo, NY USA
    591
    FWIW, UHS 3.0 is in a basically usable state now for EHCI on teensy 3.6.
    What's tested so far:
    HUB, bulk storage (UHS_FS, which contains FAT32, and a driver for the SDcard, although a small modification is required for that), HID (RAW/BOOT-MOUSE/BOOT-KEYBOARD), various USB-serial and USB printers, and MIDI.
    Yes, the programming model is a little bit different, however it's all extendable in your own sketch without having to modify the library. You can take the base driver classes, and simply use them as a sub-class. This means you can write drivers for an interface directly in the sketch if something does not exist, and attach it to the USB core.
    Currently, I am working on a few filesystem improvements. RAM size of Teensy 3.[01256](low speed USB OTG) and 3.6 (EHCI) (4.x is next...) will be able to cache reads and writes, which increases the speeds for thumb drives. Physical hard drives already can read and write 10Mbytes in 8 to 9 seconds, but should get an enormous boost, I have to finish that part yet.
    More devices are going to be supported in the coming weeks.
  11. #586
    Aug 2017
    599
    Quote Originally Posted by xxxajk View Post
    I need to pull out one of my T3.6's and check this out. I played around with UHS 3.0 when you first came out with it but have not had time to keep up. Trying to keep up with MSC, SdFat, UsbFat and LittleFS has kept me busy. Will check it out
    Edit: Could you give me a link to the latest version?
  12. #587
    Nov 2013
    Buffalo, NY USA
    591
    @wwatson
    Certainly!
    Now note that it will have some issues depending on the SCSI version on the USB (same is true with any Mass storage/bulk storage) in particular, thumbdrives and external drives that are using UAS with scsi version 6 (USB 3.x), but most others do end up working just fine.
    Here's the URL:
    https://github.com/felis/UHS30
    and the URL to all of the rest of my stuff:
    https://github.com/xxxajk
  13. #588
    Nov 2013
    Buffalo, NY USA
    591
    Oh one other thing, You should be able to extend UHS_FS to accommodate littleFS, and even ISO9660 if you want to use it for CD/DVD. :-)
  14. #589
    Aug 2017
    599
    @xxajk -Thanks.
  15. #590
    Aug 2017
    599
    @xxxajk - Having troubles with RTCLib.h no such file or directory trying to compile UHS_FS_NEW_DEMO.ino. Can you refresh my memory as to which library this is? Been a long time
  16. #591
    Nov 2013
    Buffalo, NY USA
    591
    @wwatson
    You forgot to recursively clone, see the readme and optionally the wiki
  17. #592
    Aug 2017
    599
    @xxxajk - Kept doing the clone without recursively cloning. Did it the exactly the way you said and was albe to get things to compile. The only example I was able to use was in UHS_FS/examples/UHS_KINETIS_EHCI/UHS_FS_NEW_DEMO.ino. This gave me this:
    Configuring: parent = 0, port = 1, speed = 2
    dispatchPkt status code 01
    *** Configuring error: 0x11 Can't get USB_DEVICE_DESCRIPTOR
    Anything other examples would lock up the Teensy 3.6.
    Obviously I am doing something else wrong
    I have tried several thumb drives, a USB SD car reader, and HardDrives with a StarTech USB adapter. What else am I missing?
  18. #593
    Nov 2013
    Buffalo, NY USA
    591
    Status code 0x01 and error 0x11 shouldn't be possible...
  19. #594
    Nov 2013
    Buffalo, NY USA
    591
    @wwatson More improvements have been pushed, pull and try again.
    More information can be gathered by turning on the host debugging in the sketch
  20. #595
    Aug 2021
    6
    Hi all,
    I am having some issue in removing a file. I am using a SD card reader as storage. tried the example "FilesUSB.ino".
    When I run it 1st time it works fine. Creates the file then removes it. But when I have used a different file for it remove, it cannot remove it.
    Attached is the file I tried to remove.
    Initializing USB MSC drive...initialization done.
    example.txt exists.
    Creating example.txt...
    example.txt exists.
    Removing example.txt...
    example.txt exists.
    Attached Files Attached Files
  21. #596
    Aug 2017
    599
    I will. Probably tomorrow before I can try it. I had some of the debug turned on but not all.
  22. #597
    Aug 2017
    599
    Hi all,
    example.txt exists.
    example.txt exists.
    example.txt exists.
    I actually need to see the modified "FilesUSB.ino". Not This:
    -1.25,0.00,0.00,-1.87,-2.49,19200.02,19200.02,19200.02,19200.02,19200.02,19200.02,19200.02,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,
    -1.87,-2.49,-0.62,19200.02,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,
    -1.25,-0.62,-0.62,-2.49,-3.11,19200.02,1.88,5.04,-3.11,0.63,19200.02,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,999.00,
  23. #598
    Aug 2021
    6
    I actually didn't modify the FilesUSB.ino that is in the example. Here is the code I used:
      MSC USB Drive basic file example
     This example shows how to create and destroy an MSC USB drive file
     The circuit:
     created   Nov 2010
     by David A. Mellis
     modified 9 Apr 2012
     by Tom Igoe
     modified 17 Nov 2020
     by Warren Watson
    #include <mscFS.h>
    // Setup USBHost_t36 and as many HUB ports as needed.
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    USBHub hub3(myusb);
    USBHub hub4(myusb);
    // Setup MSC for the number of USB Drives you are using. (Two for this example)
    // Mutiple  USB drives can be used. Hot plugging is supported. There is a slight
    // delay after a USB MSC device is plugged in. This is waiting for initialization
    // but after it is initialized ther should be no delay.
    msController msDrive1(myusb);
    msController msDrive2(myusb);
    File myFile;
       while (!Serial) {
        ; // wait for serial port to connect.
      // Start USBHost_t36, HUB(s) and USB devices.
      myusb.begin();
      Serial.print("\nInitializing USB MSC drive...");
        return;
      Serial.println("initialization done.");
      if (MSC.exists("example.txt")) {
        Serial.println("example.txt exists.");
      else {
        Serial.println("example.txt doesn't exist.");
      // open a new file and immediately close it:
      Serial.println("Creating example.txt...");
      myFile = MSC.open("example.txt", FILE_WRITE);
      myFile.close();
      // Check to see if the file exists:
      else {
      // delete the file:
      Serial.println("Removing example.txt...");
      MSC.remove("example.txt");
      if (MSC.exists("example.txt")){
      else {
      // nothing happens after setup finishes.
  24. #599
    Aug 2017
    599
     The circuit:
     created   Nov 2010
     by David A. Mellis
     modified 9 Apr 2012
     by Tom Igoe
     by Warren Watson
    #include <mscFS.h>
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    USBHub hub3(myusb);
    USBHub hub4(myusb);
    File myFile;
       while (!Serial) {
      myusb.begin();
        return;
      else {
      myFile.close();
      else {
      // delete the file:
      else {
    I see this in your first post:
    example.txt exists.
    example.txt exists.
    example.txt exists.
    Should be:
    I tried several times with your "example.txt" and it worked correctly. Not sure why it's not working on your end. Did you check to see if the file was actually deleted or not on the SD card?
    Things you can do:
    - Maybe try reformatting the SD card and try it again.
    - If using a HUB try without using the HUB. We have had issues with some HUBs.
    - Try another SDcard.
    - Or if you have one try a USB Thumb stick.
    I know I have asked you this before, but which version of Arduino and Teensyduino are you using and which Teensy product are you using?
  25. #600
    Aug 2017
    599
    OK, did the pull and reset for it. Here is what I am seeing now (getting closer). With these debug settings:
    // enable testing output
    #define EHCI_TEST_DEV
    //#define LED_STATUS 1
    #define DEBUG_PRINTF_EXTRA_HUGE 1
    //#define DEBUG_PRINTF_EXTRA_HUGE_UHS_HOST 1
    #define DEBUG_PRINTF_EXTRA_HUGE_UHS_BULK_STORAGE 1
    Without the HUB:
    Start.
    SWI_IRQ_NUM 30
    USB HOST READY.
    No media. Waiting to mount /
    $$$$$$$$$$$$$$$$$$$$$$$$$ ADDRESS 1: 0 retries.
    USBHub: checking numep 1, klass 09, interface.klass 09, protocol 00/01-00?01
    USBHub: checking numep 1, klass 09, interface.klass 09, protocol 00/01-01?01
    USBHub Accepting address assignment 01
    USBHub: checking numep 2, klass 00, interface.klass 08, protocol 50/00-00?01
    BulkOnly: checking numep 2, klass 00, subklass 00
    BulkOnly: checking protocol 00, interface.klass 08, interface.subklass 06
    BulkOnly: checking interface.protocol 50
    USBHub: checking numep 2, klass 00, interface.klass 08, protocol 50/00-01?01
    BS SetInterface
    ep: 0x00 bmAttributes: 0x02 index: 1
    ep: 0x01 bmAttributes: 0x02 index: 2
    BS Start, speed: 2
    BS Start
    GetMaxLUN 0x00
    MaxLUN 0
    Inquiry 0x24 0x00
    LUN 0 `KingstonDataTraveler 3.0(four vertical rectangles, seen this before????)'
    Qualifier 0 Device type 00 RMB 1 SSCS 0 SCSI version 06
    Device conforms to T10/1731-D (SPC-4) standards.
    CheckLUN...
    9142
    >>>>>>>>>>>>>>>>CAPACITY OK ON LUN 0
    039a33f300000200
    9142
    Checked LUN...
    Onstart begin
    BS configured
    With the HUB:
    Start.
    SWI_IRQ_NUM 30
    USB HOST READY.
    Now with this debug setting I get:
    No Hub:
    Start.
    SWI_IRQ_NUM 30
    power up EHCI PHY
    init EHCI PHY & PLL
    PLL locked, waited 2809
    begin ehci reset
    reset waited 5
    USB HOST READY.
    PCI Vbus state changed to 0
    USB host speed now 1
    PCI Vbus state changed to 3
    USB host speed now f
    PCI Vbus state changed to 2
    USB host speed now 2
    ISRbottom, UHS_USB_HOST_STATE_CONFIGURING
    Configuring PktSize 0x40,  rcode: 0x00, retries 0
    SetAddress, addr=0, ep=0
    ********* Got UsbDevicePtr for 0x00, scanning 1 endpoints...
    PEP @ 0x1fff1384
    ep entry for interface 0 ep 0 max packet size = 64
    ctrlReq2: left: 64, read:64, nbytes 64
    *&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*& ctrlReqRead left: 64, nbytes: 64, dataptr: 2002fe4c
    InTransfer 64 NAKS: 0
    USBHS_USBSTS_UI
    InTransfer Got 18 Bytes
    InTransfer done.
    ctrlReqRead left: 46, read 18
    RESULT: 0x00 0x00 0x12 0x0040000001000680
    ctrlReq3: acceptBuffer sz 18 nbytes 64 left 46
    PEP @ 0x1fff1384
    USBHS_USBSTS_UI
    DevDescr 2nd poll, bMaxPacketSize0:64
    SetAddress, addr=1, ep=0
    ********* Got UsbDevicePtr for 0x01, scanning 1 endpoints...
    PEP @ 0x2002fe44
    ep entry for interface 9 ep 0 max packet size = 64
    ctrlReq2: left: 18, read:18, nbytes 18
    *&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*& ctrlReqRead left: 18, nbytes: 18, dataptr: 2002fe4c
    InTransfer 18 NAKS: 0
    USBHS_USBSTS_UI
    InTransfer done.
    ctrlReqRead left: 0, read 18
    RESULT: 0x00 0x01 0x12 0x0012000001000680
    ((((((((((((((((((address 1 parent 0
    PEP @ 0x1fff1384
    USBHS_USBSTS_UI
    configs: 1
    PEP @ 0x1fff1384
    ctrlReq2: left: 9, read:9, nbytes 9
    *&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*& ctrlReqRead left: 9, nbytes: 9, dataptr: 2002fe4c
    InTransfer 9 NAKS: 0
    USBHS_USBSTS_UI
    InTransfer Got 9 Bytes
    InTransfer done.
    ctrlReqRead left: 0, read 9
    RESULT: 0x00 0x01 0x09 0x0009000002000680
    CONFIGURATION: 0, bNumInterfaces 1, wTotalLength 32
    PEP @ 0x1fff1384
    *&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*& ctrlReqRead left: 32, nbytes: 32, dataptr: 2002fdc8
    InTransfer 32 NAKS: 0
    USBHS_USBSTS_UI
    InTransfer Got 32 Bytes
    InTransfer done.
    ctrlReqRead left: 0, read 32
    bLength: 9 bDescriptorType: 02
    eating 8
    bLength: 9 bDescriptorType: 04
    INTERFACE DESCRIPTOR FOUND
    Getting 2 endpoints
    bLength: 7 bDescriptorType: 05
    ENDPOINT DESCRIPTOR: 0
    ENDPOINT DESCRIPTOR OK
    eating 0
    ENDPOINT DESCRIPTOR: 1
    eating 0
    eating 1
    ENDPOINT DESCRIPTORS FILLED
    TestInterface VID:0951 PID:1666 Class:00 Subclass:00 Protocol 00
    Interface data: Class:08 Subclass:06 Protocol 06, number of endpoints 2
    Parent: 00, bAddress: 01
    Driver 1 supports this interface
    Driver 1 can be used for this interface
    USB_INTERFACE END OF STREAM
    PEP @ 0x1fff1384
    USBHS_USBSTS_UI
    InTransfer done.
    CONFIGURATION: 1, bNumInterfaces 1, wTotalLength 32
    Best configuration is 1, enumerating interfaces.
    PEP @ 0x1fff1384
    USBHS_USBSTS_UI
    InTransfer done.
    eating 8
    Getting 2 endpoints
    eating 0
    eating 0
    eating 1
    AttemptConfig: parent = 0, port = 1
    BS SetInterface
    Interface Configured
    PEP @ 0x1fff1384
    USBHS_USBSTS_UI
    Driver 0 @ 00 Skipped
    Driver 1 @ 01 Initialize
    BS Start, speed: 2
    BS Start
    ********* Got UsbDevicePtr for 0x01, scanning 3 endpoints...
    PEP @ 0x1fff6598
    ep entry for interface 2 ep 0 max packet size = 64
    ctrlReq2: left: 1, read:1, nbytes 1
    *&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*& ctrlReqRead left: 1, nbytes: 1, dataptr: 1fff653c
    InTransfer 1 NAKS: 0
    USBHS_USBSTS_UI
    InTransfer Got 1 Bytes
    InTransfer done.
    RESULT: 0x00 0x01 0x01 0x000100000000fea1
    GetMaxLUN 0x00
    MaxLUN 0
    outTransfer: addr: 0x01 ep: 0x02 nbytes: 0x001f data: 0x0x2002fd48
    SetAddress, addr=1, ep=2
    PEP @ 0x1fff6598
    ep entry not 0x00...
    ep entry not 0x01...
    ep entry for interface 0 ep 2 max packet size = 512
    outTransfer: SetAddress 0x00
    OutTransfer 31, NAKS:14 toggle 0
    OutTransfer done.
    SetAddress, addr=1, ep=1
    PEP @ 0x1fff6598
    ep entry for interface 0 ep 1 max packet size = 512
    InTransfer 36 NAKS: 14
    USBHS_USBSTS_UI
    InTransfer Got 36 Bytes
    InTransfer done.
    PEP @ 0x1fff6598
    InTransfer 13 NAKS: 14
    USBHS_USBSTS_UI
    InTransfer Got 13 Bytes
    InTransfer done.
    Inquiry 0x24 0x00
    And the spew continues....
    With the HUB I get:
    Start.
    SWI_IRQ_NUM 30
    power up EHCI PHY
    init EHCI PHY & PLL
    PLL locked, waited 2817
    begin ehci reset
    reset waited 5
    USB HOST READY.
    PEP @ 0x1fff1384
    *&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*& ctrlReqRead left: 64, nbytes: 64, dataptr: 2002fe7c
    USBHS_USBSTS_UI
    InTransfer done.
    PEP @ 0x1fff1384
    USBHS_USBSTS_UI
    PEP @ 0x2002fe74
    *&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*& ctrlReqRead left: 18, nbytes: 18, dataptr: 2002fe7c
    USBHS_USBSTS_UI
    InTransfer done.
    PEP @ 0x1fff1384
    USBHS_USBSTS_UI
    configs: 1
    PEP @ 0x1fff1384
    *&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*& ctrlReqRead left: 9, nbytes: 9, dataptr: 2002fe7c
    USBHS_USBSTS_UI
    InTransfer done.
    CONFIGURATION: 0, bNumInterfaces 1, wTotalLength 25
    PEP @ 0x1fff1384
    *&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*& ctrlReqRead left: 25, nbytes: 25, dataptr: 2002fdf8
    InTransfer 25 NAKS: 0
    USBHS_USBSTS_UI
    InTransfer Got 25 Bytes
    InTransfer done.
    ctrlReqRead left: 0, read 25
    eating 8
    Getting 1 endpoints
    eating 0
    eating 1
    TestInterface VID:05e3 PID:0608 Class:09 Subclass:00 Protocol 01
    Interface data: Class:09 Subclass:00 Protocol 00, number of endpoints 1
    Driver 0 supports this interface
    Driver 0 can be used for this interface
    PEP @ 0x1fff1384
    USBHS_USBSTS_UI
    InTransfer done.
    CONFIGURATION: 1, bNumInterfaces 1, wTotalLength 25
    PEP @ 0x1fff1384
    USBHS_USBSTS_UI
    InTransfer done.
    eating 8
    Getting 1 endpoints
    eating 0
    eating 1
    PEP @ 0x1fff1384
    USBHS_USBSTS_UI
    Driver 0 @ 01 Initialize
    PEP @ 0x1fff1384
    ctrlReq2: left: 3, read:3, nbytes 3
    *&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*& ctrlReqRead left: 3, nbytes: 3, dataptr: 2002fdfc
    InTransfer 3 NAKS: 0
    USBHS_USBSTS_UI
    InTransfer Got 3 Bytes
    InTransfer done.
    RESULT: 0x00 0x01 0x03 0x00030000290006a0
    PEP @ 0x1fff1384
    *&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*& ctrlReqRead left: 9, nbytes: 9, dataptr: 2002fde8
    USBHS_USBSTS_UI
    InTransfer done.
    RESULT: 0x00 0x01 0x09 0x00090000290006a0
    PEP @ 0x1fff1384
    USBHS_USBSTS_UI
    PEP @ 0x1fff1384
    ctrlReq2: left: 2, read:2, nbytes 2
    *&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*&*& ctrlReqRead left: 2, nbytes: 2, dataptr: 2002fde8
    InTransfer 2 NAKS: 0
    USBHS_USBSTS_UI
    InTransfer Got 2 Bytes
    InTransfer done.
    RESULT: 0x00 0x01 0x02 0x0002000000000080
    ********* Got UsbDevicePtr for 0x01, scanning 2 endpoints...
    PEP @ 0x1fff59bb
    USBHS_USBSTS_UI
    PEP @ 0x1fff59bb
    USBHS_USBSTS_UI
    PEP @ 0x1fff59bb
    USBHS_USBSTS_UI
    PEP @ 0x1fff59bb
    USBHS_USBSTS_UI
    And again it continues but does not seem to get past the inquiry phase.
    The inquiry phase is seeing the thumb drive.
