Page 27 of 32 FirstFirst ... 17 25 26 27 28 29 ... LastLast
Results 651 to 675 of 782
Thread: USBHost_t36 USB Mass Storage Driver Experiments
  1. #651
    Senior Member wwatson's Avatar
    Aug 2017
    870
    Quote Originally Posted by jesusangel View Post
    Hi, appart of this old Kingston Datatraveler G2 that doesn't even initialiaces, I have 2 Sandisk 32 GB that I get CSW Tag Error: 253, one is this SDCZ48-032G and the other is SDDD2-032G-GAM46
    Regards
    I have ordered up SDDD2-032G-GAM46 from Amazon. Should be here this coming Wednesday. I'll check it out then...
  2. #652
    New York
    8,668
    Quote Originally Posted by wwatson View Post
    for the heck of it I ordered on as well - time frame is about the same - Tuesday or Wednesday.. I did notice that they spec it as a USB3.0 device. A lot of times I find if I hook it up to a usb2 compatible hub it will work where as if I hook it up directly it may not.
  3. #653
    Aug 2017
    870
    Yeah, I think I mentioned that in an earlier post. My curiosity gets the better of me as well
  4. #654
    New York
    8,668
    Mine usually gets me in trouble. Sorry - came late to the party - missed your earlier post with that comment.
  5. #655
    11,656
    I ordered the other one…
  6. #656
    New York
    8,668
    I received the UAM6 version (older usb3) and hooked it up and tried a few things.
    1. Ran the USHost drive info sketch and that seemed to work. Here is what I mean:
    Device Info:
           connected: 1
         initialized: 0
       USB Vendor ID: 0000
      USB Product ID: 0000
          HUB Number: 0
            HUB Port: 0
      Device Address: 0
    Removable Device: NO
            VendorID:
           ProductID:
          RevisionID:
             Version: 0
        Sector Count: 0
         Sector size: 0
       Disk Capacity: 0 Bytes
    Volume name:
    Volume type: FAT32
    Cluster Size: 16384 bytes
    Volume size: 30769037312 bytes
     Space used: 1654784 bytes  (917 ms to compute)
    Files:
    2021-09-23 13:01     552605 Install SanDisk Software.dmg
    2021-09-23 13:02     707152 Install SanDisk Software.exe
    2021-09-23 13:01     300509 SanDisk Software.pdf
    It always prints the directory but the drive info did not show up - add a delay(5) before printing and it got a bit better:
    Partition Table
    	part,boot,bgnCHS[3],type,endCHS[3],start,length
    FAT32:	1,0,0x82,0x3,0x0,0xC,0xFE,0xFF,0xFF,8192,60116992
    pt_#0:	2,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
    pt_#0:	3,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
    pt_#0:	4,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
    Device Info:
           connected: 1
         initialized: 1
       USB Vendor ID: 0781
      USB Product ID: 5581
          HUB Number: 0
            HUB Port: 0
      Device Address: 1
    Removable Device: YES
            VendorID:      USB
           ProductID:  SanDisk 3.2Gen1
          RevisionID: 1.00
             Version: 6
        Sector Count: 60125183
         Sector size: 512
       Disk Capacity: 30784093696 Bytes
    but its hit or miss if it picks up the drive info.
    2. Tried with a MTP Test sketch that we have
    • Attached the drive no issue
    • Displayed the directory no issue
    • Opened a file from the drive no issue
    • NOT ABLE TO COPY FILE TO DISK
    • NOT ABLE to WRITE a TEST FILE TO THE DISK
    3. Tried the following sketch (Note not sure its right):
    #include <USBHost_t36.h>
    // Setup USBHost_t36 and as many HUB ports as needed.
    USBHost myusb;
    USBHub hub1(myusb);
    // Instances for one drive
    USBDrive myDrive(myusb);
    // Instances for accessing the files on the drive
    USBFilesystem myFiles(myusb);
    // Show USB drive information for the selected USB drive.
    void printDriveInfo(USBDrive &drive) {
      // Print USB drive information.
      delay(5);
      Serial.printf(F("       connected: %d\n"), drive.msDriveInfo.connected);
      Serial.printf(F("     initialized: %d\n"), drive.msDriveInfo.initialized);
      Serial.printf(F("   USB Vendor ID: %4.4x\n"), drive.msDriveInfo.idVendor);
      Serial.printf(F("  USB Product ID: %4.4x\n"), drive.msDriveInfo.idProduct);
      Serial.printf(F("      HUB Number: %d\n"), drive.msDriveInfo.hubNumber);
      Serial.printf(F("        HUB Port: %d\n"), drive.msDriveInfo.hubPort);
      Serial.printf(F("  Device Address: %d\n"), drive.msDriveInfo.deviceAddress);
      Serial.printf(F("Removable Device: "));
      if(drive.msDriveInfo.inquiry.Removable == 1) {
        Serial.printf(F("YES\n"));
        Serial.printf(F("NO\n"));
      Serial.printf(F("        VendorID: %8.8s\n"), drive.msDriveInfo.inquiry.VendorID);
      Serial.printf(F("       ProductID: %16.16s\n"), drive.msDriveInfo.inquiry.ProductID);
      Serial.printf(F("      RevisionID: %4.4s\n"), drive.msDriveInfo.inquiry.RevisionID);
      Serial.printf(F("         Version: %d\n"), drive.msDriveInfo.inquiry.Version);
      Serial.printf(F("    Sector Count: %ld\n"), drive.msDriveInfo.capacity.Blocks);
      Serial.printf(F("     Sector size: %ld\n"), drive.msDriveInfo.capacity.BlockSize);
      uint64_t drivesize = drive.msDriveInfo.capacity.Blocks;
      drivesize *= drive.msDriveInfo.capacity.BlockSize;
      Serial.print(F("   Disk Capacity: "));
      Serial.print(drivesize);
      Serial.println(" Bytes");
      drive.printPartionTable(Serial);
    // Show USB filesystem information
    void printFilesystemInfo(USBFilesystem &fs) {
      // print the type and size of the first FAT-type volume
      char volname[32];
      fs.mscfs.getVolumeLabel(volname, sizeof(volname));
      Serial.print("Volume name: ");
      Serial.println(volname);
      Serial.print("Volume type: FAT");
      Serial.println(fs.mscfs.fatType(), DEC);
      Serial.print("Cluster Size: ");
      Serial.print(fs.mscfs.bytesPerCluster());
      Serial.println(" bytes");
      Serial.print("Volume size: ");
      Serial.print(fs.totalSize());
      Serial.print(" Space used: ");
      elapsedMillis ms = 0;
      Serial.print(fs.usedSize());
      Serial.print(" bytes  (");
      Serial.print(ms);
      Serial.println(" ms to compute)");
      Serial.println("Files:");
      fs.mscfs.ls(LS_R | LS_DATE | LS_SIZE);
      while (!Serial) {
        ; // wait for Arduino Serial Monitor to connect.
      myusb.begin();
      Serial.println("\nWaiting for Drive to initialize...");
      // Wait for the drive to start.
      while (!myDrive) {
        myusb.Task();
      Serial.printf("Device Info:\n");
      printDriveInfo(myDrive);
      elapsedMillis em;
      while (!myFiles && (em < 1000)) {
        myusb.Task();
      if (myFiles) {
        printFilesystemInfo(myFiles);
        Serial.println("\n*** No Fat Filesystem Partitions found on drive **");
      File myFile = myFiles.open("test.txt", FILE_WRITE);
      // if the file opened okay, write to it:
      if (myFile) {
        Serial.print("Writing to test.txt...");
        myFile.println("testing 1, 2, 3.");
      // close the file:
        myFile.close();
        Serial.println("done.");
        // if the file didn't open, print an error:
        Serial.println("error opening test.txt");
      // re-open the file for reading:
      myFile = myFiles.open("test.txt");
      if (myFile) {
        Serial.println("test.txt:");
        // read from the file until there's nothing else in it:
        while (myFile.available()) {
          Serial.write(myFile.read());
        // close the file:
        myFile.close();
    void loop(void) {
    but hangs on writing to the disk.
  7. #657
    New York
    8,668
    After the hang and restart it does create a 0 byte file
    Volume name:
    Volume type: FAT32
    Cluster Size: 32768 bytes
    Volume size: 30771511296 bytes
     Space used: 131072 bytes  (459 ms to compute)
    Files:
                              0 USBC
    but if there is problems with this file - if you try and erase it in windows it gives an error message
    Note:
    Tried it with 2 different hubs as well. One of which was a powered hub
  8. #658
    New York
    8,668
    with the write files test sketch I am seeing the following:
      CSWResult: 0 CD:28
    msProcessError()
    65536 bytes  (1027 ms to compute)
    Files:
    checkConnectedInitialized()msReadBlocks()
    msDoCommand()
    USBDrive CallbackOut (static)
    transfer->qtd.token = 0
    USBDrive dataOut (static)31
    55 53 42 43 0E 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 88 40 00 00 01 00 00 00 00 00 00 00
    USBDrive CallbackIn (static)
    USBDrive dataIn (static): 512
    42 20 00 49 00 6E 00 66 00 6F 00 0F 00 72 72 00 6D 00 61 00 74 00 69 00 6F 00 00 00 6E 00 00 00
    msGetCSW()
    USBDrive dataIn (static): 13
    55 53 42 53 0E 00 00 00 00 00 00 00 00
    msProcessError()
    checkConnectedInitialized()msWriteBlocks()
    msDoCommand()
    55 53 42 43 0F 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 88 40 00 00 01 00 00 00 00 00 00 00
    USBDrive dataOut (static)512
    msGetCSW()
    transfer->qtd.token = 64
    USBDrive dataIn (static): 0
    ERROR Followup
    msProcessError()
    CSW Tag Error: 253
    msProcessError()
    CSW Tag Error: 253
    Writing to test.txt...checkConnectedInitialized()msReadBlocks()
    msDoCommand()
    55 53 42 43 10 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 15 A2 00 00 01 00 00 00 00 00 00 00
    CSW TAG Errors???
    It looks like it sent the bytes but then no response from usb stick.
  9. #659
    Aug 2017
    870
      CSWResult: 0 CD:28
    msProcessError()
    Files:
    msDoCommand()
    msGetCSW()
    msProcessError()
    msDoCommand()
    msGetCSW()
    ERROR Followup
    msProcessError()
    CSW Tag Error: 253
    msProcessError()
    CSW Tag Error: 253
    msDoCommand()
    CSW TAG Errors???
    It does look like there is no response but this:
    does not make sense. CSW size should be 13 bytes if I remember correctly. not sure where the 64 bytes are coming from. I should be getting my device tommorow. I need to read up on this again. Been a while
    Edit: found this:
    Host/Device Packet Transfer Order
    The host shall send the CBW before the associated Data-Out, and the device shall send Data-In after the
    associated CBW and before the associated CSW. The host may request Data-In or CSW before sending the
    associated CBW.
    If the dCBWDataTransferLength is zero, the device and the host shall transfer no data between the CBW and the
    associated CSW.
    3.4
    Command Queuing
    The host shall not transfer a CBW to the device until the host has received the CSW for any outstanding CBW.
    If the host issues two consecutive CBWs without an intervening CSW or reset, the device response to the second
    CBW is indeterminate.
    Hopefully something to go on...
  10. #660
    Aug 2017
    870
    @mjs513 - Just tried using Windows to compile "DriveInfo.ino". This is with a Kingston 128G USB stick.
    Fist time:
     === Task() Drive 0x200035e0 connected ===
    >> USBDrive::startFilesystems called 0x200035e0
    mscInit()
    >>msReset()
            >>Partition 1 VT:1 T:7 2048 241657856
            >>USBFilesystem::claimPartition 0x1 called >>USBFilesystem::check_voltype_guid(1, 0x20067f88)
    + Claimed
    Try Partition list>>USBDrive::printPartionTable
    Partition Table
    exFAT:  1,0,0x4,0x1,0x4,0x7,0xFE,0xC2,0xFF,2048,241657856
             < unused area starting at: 241659904 length 1011 >
    Device Info:
           connected: 1
         initialized: 1
       USB Vendor ID: 0951
      USB Product ID: 1666
          HUB Number: 0
            HUB Port: 0
      Device Address: 1
            VendorID: Kingston
           ProductID: DataTraveler 3.0
          RevisionID:
             Version: 6
        Sector Count: 241660915
         Sector size: 512
       Disk Capacity: 123730388480 Bytes
    Partition Table
    Volume name: 128GEXFAT
    Volume type: FAT64
    Cluster Size: 131072 bytes
    Volume size: 123723579392 bytes
     Space used: 33292288 bytes  (90 ms to compute)
    Files:
    2019-01-01 08:15     32767488 32MEGfile.dat
    2023-01-01 00:00           36 test.txt
    Second Time:
    Device Info:
           connected: 1
         initialized: 0
       USB Vendor ID: 0000
          HUB Number: 0
            HUB Port: 0
      Device Address: 0
            VendorID:
           ProductID:
          RevisionID:
             Version: 0
        Sector Count: 0
         Sector size: 0
    Volume type: FAT64
     Space used: 33292288 bytes  (91 ms to compute)
    Files:
    The drive is formatted to EXFAT. Arduino 1.8.19, TD1.58B3. I think there is another problem here. Going back to Linux to see if I can duplicate the problem there.
    Time for bed...
  11. #661
    11,656
    Quick note, I picked up my delivery of 4 of the Sanddisk ulta Flair 32gbs...
    Looks more or less identical to what @mjs513 showed yesterday...
    I did also try reformatting it on PC to FAT32 and no differences. MTP does not want to write a new file to it.
    14204 RESP:2001(RSP:OK)l: 12 T:2b
    loop:14204 CMD: 9803(GET_OBJECT_PROP_VALUE)l: 20 T:2c : 10 dc44 (NAME)
    14204 RESP:2001(RSP:OK)l: 12 T:2c
    loop:26649 CMD: 100c(SEND_OBJECT_INFO)l: 20 T:2d : 20001 ffffffff
    SendObjectInfo: 20001 ffffffff Dataset len=162
    File "annie1.bmp" size:230454 Created:641aea58 Modified:61e3a02e
     read consumed all data (TODO: how to check ZLP)
    msDoCommand()
    55 53 42 43 0E 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 80 20 00 00 01 00 00 00 00 00 00 00
    55 53 42 43 0F 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 80 20 00 00 01 00 00 00 00 00 00 00 00
    msGetCSW()
    ERROR Followup
    msProcessError()
    CSW Tag Error: 253
    msProcessError()
    CSW Tag Error: 253
    msDoCommand()
    transfer->qtd.token = 65
    USBDrive dataOut (static)0
    ERROR Followup
    msGetCSW()
    Note: I am running the simplified MTP with USB... sketch
    EDIT: the error code: CSW Tag Error: 253
    // Start/Stop unit on hold for now. Not all devices respond to it
    // the same way. Is it really needed for most devices? Not understanding
    // it's use. Am able to to plug in a CDROM and load or eject the media.
    // But that's all that works consistently with drives:(
    //	msResult = msStartStopUnit(1);	// 0 = transition to stopped power contition
    									// 1 = transition to active power contition
    									// 2 = load media, tested on SATA CDROM
    									// 3 = eject media, Tested on SATA CDROM
    	msDriveInfo[device].connected = true;  // Device connected.
    	msDriveInfo[device].initialized = true;
    	msDriveInfo[device].hubNumber = mscDrives[device]->getHubNumber();  // Which HUB.
    	msDriveInfo[device].hubPort = mscDrives[device]->getHubPort();  // Which HUB port.
    	msDriveInfo[device].deviceAddress = mscDrives[device]->getDeviceAddress();  // Which HUB.
    	msDriveInfo[device].idVendor = mscDrives[device]->getIDVendor();  // USB Vendor ID.
    	msDriveInfo[device].idProduct = mscDrives[device]->getIDProduct();  // USB Product ID.
    	msResult = getDriveInquiry(device);
    	msResult = getDriveCapacity(device);
    	// if device is not like hard disk, probably won't work! example CDROM...
    	if (msDriveInfo[device].inquiry.DeviceType != 0)
    		return MS_CSW_TAG_ERROR;
  12. #662
    New York
    8,668
    @kurtE - @wwatson
    Interesting - wondering what version I am running since I am seeing this:
    	msReset();
    	// delay(500); // Not needed any more.
    	maxLUN = msGetMaxLun();
    //	msResult = msReportLUNs(&maxLUN);
    //println("maxLUN = ");
    //println(maxLUN);
    //	delay(150);
    	msResult = WaitMediaReady();
    	if(msResult)
    		return msResult;
    	// Retrieve drive information.
    	msDriveInfo.initialized = true;
    	msDriveInfo.hubNumber = getHubNumber();			// Which HUB.
    	msDriveInfo.hubPort = getHubPort();				// Which HUB port.
    	msDriveInfo.deviceAddress = getDeviceAddress();	// Device addreess.
    	msDriveInfo.idVendor = getIDVendor();  			// USB Vendor ID.
    	msDriveInfo.idProduct = getIDProduct();  		// USB Product ID.
    	msResult = msDeviceInquiry(&msInquiry);			// Config Info.
    	if(msResult)
    		return msResult;
    	msResult = msReadDeviceCapacity(&msCapacity);	// Size Info.
    	if(msResult)
    		return msResult;
    	memcpy(&msDriveInfo.inquiry, &msInquiry, sizeof(msInquiryResponse_t));
    	memcpy(&msDriveInfo.capacity, &msCapacity, sizeof(msSCSICapacity_t));
    	return msResult;
    which is totally different than what you have.
  13. #663
    Aug 2017
    870
    @mjs513 @KurtE - Just got my drive and tested. Same results as you guys. Going to start walking back through the different versions of TD to see if anything changes. Beings how this only seems to happen with these drives I am really curious as to why I am seeing this:
    msGetCSW()
    ERROR Followup
    msProcessError()
    CSW Tag Error: 253
    msProcessError()
    CSW Tag Error: 253
    msReadBlocks()
    msDoCommand()
    55 53 42 43 0F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 3E 00 00 01 00 00 00 00 00 00 00
    Normally the qtd.token = 0 and datain should = 13. Stumped at this point
    More testing needed...
  14. #664
    Aug 2017
    870
    Ok, have narrowed it down to a failed command error. Bit 0 is set in the CSW status byte. Possibly a command not recognized by the USB stick. See below:
    msWriteBlocks()
    msDoCommand()
    55 53 42 43 0F 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 72 C0 00 00 01 00 00 00 00 00 00 00
    41 33 00 32 00 4D 00 45 00 47 00 0F 00 0F 66 00 69 00 6C 00 65 00 2E 00 64 00 00 00 61 00 74 00
    msGetCSW()
    ERROR Followup
    StatusBlockWrapper.DataResidue = 0
    msProcessError()
    CSW Tag Error: 253
      CSWResult: fd CD:2a
    msProcessError()
    CSW Tag Error: 253
    Done for tonight...
    Edit:
    bCSWStatus:
    bCSWStatus indicates the success or failure of the command. The device shall set this byte to zero if
    the command completed successfully. A non-zero value shall indicate a failure during command
    execution according to the following table
  15. #665
    11,656
    Any luck on this yet?
    I will try to take another look soon. Right now doing fun things like: cutting Himalayan Berry vines out and chipping them.
  16. #666
    Aug 2017
    870
    Not yet Just got home from work. Will play a little more tonight. Looks like I am going to have to got into the lowest levels. Try a single sector write and see what happens. It's complaining about an unrecognized CBW command, I just don't know what it is yet...
    Hopefully those vines are not like blackberry vines that cut you to shreds
  17. #667
    Aug 2017
    870
    Not yet Just got home from work. Will play a little more tonight. Looks like I am going to have to go into the lowest levels. Try a single sector write and see what happens. It's complaining about an unrecognized CBW command, I just don't know what it is yet...
  18. #668
    New York
    8,668
    Pulled out my old Sansdisk Cruzer 2gb and that didn't work either. Didn't even print the directory
  19. #669
    Aug 2017
    870
    @KurtE and @mjs513 - Referring to post #664, the command code is indeed the SCSI write(10) command, Instead of showing the tag error first I need to check the CSW status byte bit 0 first and if not 0 do a request for additional sense code(s). These gives more detail about what went wrong.
    If you look here you will see that there are quite a few different write commands. Maybe the device is using one of them. Not sure yet...
  20. #670
    11,656
    Yes those are the ones. The ones that grow maybe near an inch wide, and maybe 50' long, with long sharp thorns...
    These gloves help: https://www.amazon.com/Leather-Cowhi...dp/B08V5MFC9Q/
    Will play some today.
  21. #671
    New York
    8,668
    Good Morning All
    Was curious how the problematic drive behaved on windows vs one of my microcenter ones that work fine with USBHost.
    Test 1. Copied the same files from the PC to each drive.
    Image 1: UAM6 - start of copying files:
    Image2: Microcenter 64gb drive
    Looking at the Wireshark data I really didn't see a difference. But may help to debug whats going on with mass storage.
  22. #672
    New York
    8,668
    @wwatson - @KurtE
    loaded the wireshark files up on google will send you all the invitation
    ee1 - UAM when first inserted into PC - look for 1.20.x addresses
    ee2 - UAM copying files from PC to drive
    ff1 - micro center 64gb drive inserted into pc - look for 1.21.x addresses
    ff2 - copying files from pc to drive
  23. #673
    11,656
    Will have to take a look at those.
    But first I am curious about the failure:
    File "annie3 - Copy.bmp" size:230454 Created:641d6f21 Modified:61e3a02e
    msDoCommand()
    55 53 42 43 0F 00 00 00 FC 00 00 00 80 00 06 03 00 00 00 FC 00 00 00 00 00 00 00 00 00 00 00 00
    msGetCSW()
    	800D8140
    ERROR Followup
    msGetCSW TAG_ERROR: sig:53425355 Tag:0 DR:0 ST:0
    msProcessError()
    CSW Tag Error: 253
    msRequestSense()
    msDoCommand()
    The first data out of 31 bytes, came back on callback OUT with the QTD.token = 0
    Where the RED one was 512 bytes and callback was on the IN, with the last byte of QTD of 64.
    I also printed out the whole QTD in hex. So last byte is 0x40 or bit 6 set. Which means:
    Halted. Set to one by the Host Controller during status updates to indicate that a
    serious error has occurred at the device/endpoint addressed by this qTD. This
    can be caused by babble, the error counter counting down to zero, or reception
    of the STALL handshake from the device during a transaction. Any time that a
    transaction results in the Halted bit being set to a one, the Active bit is also set to
    zero.
    So I am assuming everything after this is garbage.
    EDIT: forgot to mention, that in the with the full QTX token: 800D8140
    bits 16-30 are how many bytes left to transfer
    So that is: D (13 bytes left)
    Bits: 8-9 are the PID Code which is: 01 (IN Token generates token (69H) )
    Bits 10-11 is the count down error count: 00
    12-14 is current page: 0
    15 is interrupt on completion: 1
  24. #674
    Aug 2017
    870
    @KurtE
    That makes sense. 13 bytes is the size of the CSW and probably why we are seeing:
    ERROR Followup
    I think. But why...
    Missing something. Working on that right now.
  25. #675
    Aug 2017
    870
    @KurtE @mjs513 - A little progress I have stooped to single sector reads and writes. Here is a sketch that appears to be working:
    #include <Arduino.h>
    #include "USBHost_t36.h"
    // For this sketch we need to define USE_EXTENAL_INIT in
    // MassStorage.h. Explained there.
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    USBHub hub3(myusb);
    USBHub hub4(myusb);
    USBDrive msDrive1(myusb);
    USBDrive msDrive2(myusb);
    // Instances for accessing the files on each drive
    USBFilesystem drv1(myusb);
    USBFilesystem drv2(myusb);
    USBDrive *drive_list[] = {&msDrive1, &msDrive2};
    char sbuff[256]; // readLine buffer.
    uint8_t cbuff[512];
    // Fill sector buffer with a uint8_t char.
    void fillBuff(uint8_t fillChar) {
    // A small hex dump function
    void hexDump(const void *ptr, uint32_t len) {
      uint32_t  i = 0, j = 0;
      uint8_t   c=0;
      const uint8_t *p = (const uint8_t *)ptr;
      Serial.printf("BYTE      00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F\n");
      Serial.printf("---------------------------------------------------------\n");
      for(i = 0; i <= (len-1); i+=16) {
       Serial.printf("%4.4lx      ",i);
       for(j = 0; j < 16; j++) {
          c = p[i+j];
          Serial.printf("%2.2x ",c);
        Serial.printf("  ");
          c = p[i+j];
          if(c > 31 && c < 127)
            Serial.printf("%c",c);
            Serial.printf(".");
        Serial.printf("\n");
    // A simple read line function.
    char *readLine(char *s) {
    	char *s1 = s;
    	int	c;
    	for(;;) {
    		while(!Serial.available());
    		switch(c = Serial.read()) {
    		case 0x08:
    			if(s == s1)
    			s1--;
    			Serial.printf("%c%c%c",c,0x20,c);
    		case '\n':
    		case '\r':
    			*s1 = 0;
    			return s;
    		default:
    			if(c <= 0x7E)
    			*s1++ = c;
    void setup(void) {
    	while(!Serial);
    	Serial.printf("%cSandisk ultra Dual USB drive 3.0 Testing\n",12);
    	// Init USBHost
    	myusb.begin();
    	myusb.Task();
    void loop(void) {
      uint8_t rslt = 0;
      Serial.printf("press enter to test...\n");
      readLine(sbuff);
      Serial.printf("\nWriting: 'this is a test.' to sector: 1000000\n");
      rslt = msDrive1.msWriteBlocks((uint32_t)1000000, (uint16_t)1, (uint16_t)512, (const char *)"this is a test.");
      Serial.printf("rslt = %d\n",rslt);
      Serial.printf("\nReading sector:10000000 to cbuff\n");
      rslt = msDrive1.msReadBlocks((uint32_t)1000000, (uint16_t)1, (uint16_t)512, cbuff);
      hexDump(cbuff,16);
      Serial.printf("\nClearing buffer\n");
      for(uint32_t i = 0; i < 512; i++) cbuff[i] = 0;
      rslt = msDrive1.msWriteBlocks((uint32_t)1000000, (uint16_t)1, (uint16_t)512, cbuff);
      hexDump(cbuff,16);
    This is writing "this is a test." to sector 1000000. Obviously will destroy any data in that sector. It started out by accidentally uploading this sketch without the drive plugged in. Noticed that and plugged in the SanDisk drive. It worked. It would continuously write to the sector with each key press without error. This was the first clue that it was a init problem. Something missing or something that should not be there for this drive. So I started eliminating delays and other initializations and wound up with the above test.
    Output:
    rslt = 0
    rslt = 0
    0000      74 68 69 73 20 69 73 20 61 20 74 65 73 74 2e 00   this is a test..
    Clearing buffer
    0000      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ................
    Just press enter key to repeat. It does a hex dump of the buffer and then clears the buffer and zeros the sector. I have not gone any further with testing. I think the problems might be initialization.
    Please test if you can.
