Page 4 of 15 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Results 76 to 100 of 351
Thread: USBHost_t36 USB Mass Storage Driver Experiments
  1. #76
    New York
    4,337
    @WMXZ
    Cool. Making good progress as Kurt said. Pretty much everything I have tested here is working. Only Kurt's 1gb cruzer isn't working. Only think I haven't tried is a HDD - have to find one of my old ones to see if it works
  2. #77
    Aug 2017
    150
    @WMXZ, @mjs513
    I do have a Github account but I have never used it. I think it is time I set it up and used it. The MSC.zip file that WMXZ does have all of the latest changes I have. Just need to eliminate the obsolete uSDFS directory in MSC.zip.
    @Kurte
    Thanks for pointing me in the right direction withe msGetmaxLun() issue. I knew I was not doing something right. A lot of information I read about this said that getting the max lun's can give strange results. I'll be gone for a week in Jesup Georgia (our sister plant) but will work on implementing the changes to MSC when I can while there. Kinda curious if the Targus Multi SD card reader will show more than 1 LUN.
  3. #78
    10,127
    On Github soon ...
    Here is today MSC.zip from mjs513 with the uSDFS_Files directory removed.
    I didn't build with it yet - but will link first post here … actually found I could remove old zip and link in this one to OP ..
    USBHost_t36 updates working with this : https://github.com/KurtE/USBHost_t36...WIP2-Bluetooth
    Attached Files Attached Files
  4. #79
    10,127
    Using Post #78 zip and github : ...\libraries\uSDFS\examples\uSDFS_test\uSDFS_test .ino
    Compiled and built for T$ - using SD card as #1_SDHC the card works. Moving that card to #2_USB in a USB adapter - get TONS of spew that ends like this:
     Full debug output from T_3.6 noted below : uSDFS.txt
    msController CallbackIn (static)
    transfer->qtd.token = 0
    msController dataIn (static): 13
    55 53 42 53 4E 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
       <dir>  System Volume Information
    17173152  SDTEST4.WAV
           0  SomeFile.txt
     8894873  workshop.pdf
    16787550  SDTEST1.WAV
    16425698  SDTEST2.WAV
    13617358  SDTEST3.WAV
       <dir>  Ascii
       <dir>  Binary
    Test completed.
    USB2 PLL running
     reset waited 6
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 20004000
    periodictable = 20004000
    port change: 10001803
        connect
      begin reset
    port change: 18001205
      port enabled
      end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    So it see the files then goes into an odd state were the #1 interface ended with a blink, the #2 ends with LED ON?
    And the T$ is in an odd state - it won't take an upload without a button press - or placed into bootloader before?
    Using TyCommander from SublimeText editor:
    upload@5794870-Teensy Uploading to board '5794870-Teensy' (Teensy 4.0)
    upload@5794870-Teensy Triggering board reboot
    upload@5794870-Teensy SetCommState() failed on '\\.\COM25': The semaphore timeout period has expired.
    Putting this code and same card on a T_3.6 [ FrankB Teensy64 ] it is similar and asking for fresh upload turns off LED and the T_3.6 disappears >> Full text attached above:
    ** CSWSIGNATURE
           0  SomeFile.txt
       <dir>  Ascii
       <dir>  Binary
    Test completed.
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
     reset waited 5
    USBHS_PERIODICLISTBASE = 1FFF4000
    periodictable = 1FFF4000
           upload@2272100-Teensy  Uploading to board '2272100-Teensy' (Teensy 3.6)
           upload@2272100-Teensy  Triggering board reboot
           upload@2272100-Teensy  Reboot didn't work, press button manually
           upload@2272100-Teensy  Board '2272100-Teensy' has disappeared
    And like the T$ - on the T_3.6 same code on #1 SDHC leaves it running with LED blink on same card:
    Test uSDFS
    1:/
    Change drive
    Create a new subdirectories.
    Create a new file /Ascii/HELLO13.TXT.
    Write some text lines. (Hello world!)
    Close the file.
    Open same file /Ascii/HELLO13.TXT.
    Get the file content.
    Hello world!
    Second Line
    Third Line
    Fourth Line
    Habe keine Phantasie
    Close the file.
    open binary file
    write file
    close file
    Binary test done
    Open root directory.
    Directory listing...
           0  SomeFile.txt
       <dir>  Ascii
       <dir>  Binary
    Test completed.
  5. #80
    2,401
    Does it work or not?
    OK,
    I have following observation
    8 GB Transcend formatted exFAT (with Win10)
    use program logger_RAWWrite from uSDFS/examples
    case 1: BUFFSIZE 8*1024 -> program blocks
    case 2: BUFFSIZE 2*1024 -> program runs fine
    case 3: BUFFSIZE 4*1024 -> program blocks
    same with 128 GB Transcend (fresh out of box, never used before, Edit: was formatted FAT32)
    not sure where to look
    program did run fine with uSD USB adapter and BUFFSIZE 8*1024
    edit: BUFFSIZE 8*1024 equiv. 32 kB
  6. #81
    2,401
    Here is a typical hang
    Test logger_RawWrite
    2:/
    USB2 PLL running
     reset waited 6
    USBHS_PERIODICLISTBASE = 20014000
    periodictable = 20014000
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 10 02 00 00 00 40 64 85 00 10 00 11 01 02 03 01
        VendorID = 8564, ProductID = 1000, Version = 1100
        Class/Subclass/Protocol = 0 / 0 / 0
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: JetFlash
    enumeration:
    Product: Mass Storage Device
    enumeration:
    Serial Number: 17Q880DIDAVC35MP
    enumeration:
    Config data length = 32
    enumeration:
    Configuration Descriptor:
      09 02 20 00 01 01 00 80 96
        NumInterfaces = 1
        ConfigurationValue = 1
      09 04 00 00 02 08 06 50 00
        Interface = 0
        Number of endpoints = 2
        Class/Subclass/Protocol = 8(Mass Storage) / 6(SCSI) / 80(Bulk Only)
      07 05 01 02 00 02 00
        Endpoint = 1 OUT
        Type = Bulk
        Max Size = 512
        Polling Interval = 0
      07 05 82 02 00 02 00
        Endpoint = 2 IN
        Type = Bulk
        Max Size = 512
    enumeration:
    msController claim this=20013780
    Descriptor 4 = INTERFACE
    09 04 00 00 02 08 06 50 00 07 05 01 02 00 02 00 07 05 82 02 00 02 00
    numendpoint=2
    endpointIn=82
    endpointOut=1
    packet size in (msController) = 512
    packet size out (msController) = 512
    polling intervalIn = 0
    polling intervalOut = 0
    new_Pipe
    new_Pipe
    Descriptor 5 = ENDPOINT
    control CallbackIn (msController)
    msController CallbackOut (static)
    msController dataOut (static)31
    55 53 42 43 02 00 00 00 00 00 00 00 80 00 06 1B 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 02 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 03 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 03 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 04 00 00 00 24 00 00 00 80 00 06 12 00 00 00 24 00 00 00 00 00 00 00 00 00 00 00
    msController dataIn (static): 36
    00 80 06 02 1F 73 6D 69 4A 65 74 46 6C 61 73 68 54 72 61 6E 73 63 65 6E 64 20 38 47 42 20 20 20
    55 53 42 53 04 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 05 00 00 00 08 00 00 00 80 00 0A 25 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    msController dataIn (static): 8
    00 E1 3F FF 00 00 02 00
    55 53 42 53 05 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 06 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 06 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 07 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
    msController dataIn (static): 512
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 07 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 08 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 08 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 09 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 20 00 00 00 01 00 00 00 00 00 00 00
    EB 76 90 45 58 46 41 54 20 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 09 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 0A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 0A 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 0B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 80 00 00 01 00 00 00 00 00 00 00
    83 09 54 00 52 00 41 00 4E 00 53 00 43 00 45 00 4E 00 44 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 0B 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 0C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 0C 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 0D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 28 00 00 00 01 00 00 00 00 00 00 00
    F8 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 0D 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    Free Disk Size -1 clusters
    Cluster Size 64 sectors
    Sector Size 512 bytes
    Change drive
    X_00001.dat
    55 53 42 43 0E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 0E 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 0F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 80 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 0F 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 10 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 10 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 11 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 81 00 00 01 00 00 00 00 00 00 00
    85 02 DA E7 20 00 00 00 00 00 21 50 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 11 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 12 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 12 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 13 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 82 00 00 01 00 00 00 00 00 00 00
    C0 01 00 0B BB 70 00 00 00 00 7D 00 00 00 00 00 00 00 00 00 F0 03 00 00 00 00 7D 00 00 00 00 00
    55 53 42 53 13 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 14 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 14 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 15 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 83 00 00 01 00 00 00 00 00 00 00
    C1 00 5A 00 5F 00 30 00 30 00 30 00 31 00 34 00 2E 00 64 00 61 00 74 00 00 00 00 00 00 00 00 00
    55 53 42 53 15 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 16 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 16 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 17 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 84 00 00 01 00 00 00 00 00 00 00
    85 02 59 2B 20 00 00 00 00 00 21 50 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 17 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 18 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 18 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 19 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 85 00 00 01 00 00 00 00 00 00 00
    C0 01 00 0B FB 6E 00 00 00 00 7D 00 00 00 00 00 00 00 00 00 C0 0B 00 00 00 00 7D 00 00 00 00 00
    55 53 42 53 19 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 1A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 1A 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 1B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 86 00 00 01 00 00 00 00 00 00 00
    C1 00 5A 00 5F 00 30 00 30 00 30 00 33 00 30 00 2E 00 64 00 61 00 74 00 00 00 00 00 00 00 00 00
    55 53 42 53 1B 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 1C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 1C 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 1D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 87 00 00 01 00 00 00 00 00 00 00
    85 02 44 52 20 00 00 00 00 00 21 50 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 1D 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 1E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 1E 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 1F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 88 00 00 01 00 00 00 00 00 00 00
    C0 03 00 0B 3B 6D 00 00 00 00 7D 00 00 00 00 00 00 00 00 00 0C 29 00 00 00 00 7D 00 00 00 00 00
    55 53 42 53 1F 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 20 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 20 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 21 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 89 00 00 01 00 00 00 00 00 00 00
    C1 00 5A 00 5F 00 30 00 30 00 30 00 34 00 36 00 2E 00 64 00 61 00 74 00 00 00 00 00 00 00 00 00
    55 53 42 53 21 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 22 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 22 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 23 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8A 00 00 01 00 00 00 00 00 00 00
    85 02 82 B1 20 00 00 00 00 00 21 50 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 23 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 24 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 24 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 25 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8B 00 00 01 00 00 00 00 00 00 00
    C0 03 00 0B 5B 70 00 00 00 00 7D 00 00 00 00 00 00 00 00 00 AC 38 00 00 00 00 7D 00 00 00 00 00
    55 53 42 53 25 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 26 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 26 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 27 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8C 00 00 01 00 00 00 00 00 00 00
    C1 00 5A 00 5F 00 30 00 30 00 30 00 36 00 32 00 2E 00 64 00 61 00 74 00 00 00 00 00 00 00 00 00
    55 53 42 53 27 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 28 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 28 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 29 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8D 00 00 01 00 00 00 00 00 00 00
    85 02 45 CE 20 00 00 00 00 00 21 50 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 29 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 2A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 2A 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 2B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8E 00 00 01 00 00 00 00 00 00 00
    C0 03 00 0B 9B 6E 00 00 00 00 7D 00 00 00 00 00 00 00 00 00 4C 48 00 00 00 00 7D 00 00 00 00 00
    55 53 42 53 2B 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 2C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 2C 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 2D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8F 00 00 01 00 00 00 00 00 00 00
    C1 00 5A 00 5F 00 30 00 30 00 30 00 37 00 38 00 2E 00 64 00 61 00 74 00 00 00 00 00 00 00 00 00
    55 53 42 53 2D 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 2E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 2E 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 2F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 90 00 00 01 00 00 00 00 00 00 00
    85 02 03 EE 20 00 00 00 00 00 21 50 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 2F 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 30 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 30 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 31 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 91 00 00 01 00 00 00 00 00 00 00
    C0 03 00 0B BB 71 00 00 00 00 7D 00 00 00 00 00 00 00 00 00 EC 57 00 00 00 00 7D 00 00 00 00 00
    55 53 42 53 31 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 32 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 32 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 33 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 92 00 00 01 00 00 00 00 00 00 00
    C1 00 5A 00 5F 00 30 00 30 00 30 00 39 00 34 00 2E 00 64 00 61 00 74 00 00 00 00 00 00 00 00 00
    55 53 42 53 33 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 34 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 34 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 35 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 93 00 00 01 00 00 00 00 00 00 00
    85 02 D0 8F 20 00 00 00 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 35 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    stat FR_OK 0
    55 53 42 43 36 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 36 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 37 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 80 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 37 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 38 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 38 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 39 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 81 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 39 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 3A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 3A 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 3B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 82 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 3B 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 3C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 3C 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 3D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 83 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 3D 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 3E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 3E 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 3F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 84 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 3F 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 40 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 40 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 41 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 85 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 41 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 42 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 42 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 43 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 86 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 43 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 44 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 44 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 45 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 87 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 45 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 46 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 46 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 47 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 88 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 47 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 48 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 48 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 49 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 89 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 49 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 4A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 4A 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 4B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8A 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 4B 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 4C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 4C 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 4D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8B 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 4D 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 4E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 4F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8C 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 4F 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 50 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 50 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 51 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8D 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 51 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 52 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 52 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 53 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8E 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 53 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 54 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 54 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 55 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8F 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 55 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 56 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 56 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 57 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 90 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 57 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 58 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 58 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 59 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 91 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 59 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 5A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 5A 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 5B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 92 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 5B 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 5C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 5C 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 5D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 93 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 5D 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
     opened FR_OK 0
    55 53 42 43 5E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 5E 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 5F 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 30 93 00 00 01 00 00 00 00 00 00 00
    msController dataOut (static)512
    55 53 42 53 5F 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 60 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 60 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 61 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 00 00 00 01 00 00 00 00 00 00 00
    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    55 53 42 53 61 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 62 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 62 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 63 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 01 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 63 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 64 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 64 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 65 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 02 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 65 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 66 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 66 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 67 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 03 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 67 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 68 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 68 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 69 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 04 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 69 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 6A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 6A 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 6B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 05 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 6B 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 6C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 6C 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 6D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 06 00 00 01 00 00 00 00 00 00 00
    55 53 42 53 6D 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 6E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 6E 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 6F 00 00 00 00 80 00 00 00 00 0A 2A 00 00 19 18 80 00 00 40 00 00 00 00 00 00 00
    It is not always with the same "sequence number" (here 6F) in other occasion it was 97
  7. #82
    10,127
    @WMXZ - Are you testing T_3.6 or T$? In my post 79 both seem the same (generally) - which was generally the case when we … KurtE and msj513 … did UsbHost_Bt and ili9488.
    This card in USB adapter is SanDisk Ultra 32GB.
    I just started 'default' logger_RW sketch on SDHC #1 w/T_3.6 - started with PC Quick fat32 SDFormat and that is working - up to the point of new upload:
    *I've just started pushing button after starting compile in SublimeTest so TyCommander completes the upload with Compile.cmd and defragster/Tset.
    I see the same in 2k {works} .vs. 8k (or 4k or larger) log fails on T_3.6:
    8192<< BUFFSIZE _ Dev Type >>2:/
    Change drive
    Z_00001.dat
    stat FR_OK 0
     opened 0 0
    // THEN NOTHING
    2048<< BUFFSIZE _ Dev Type >>2:/
    Change drive
    Z_00001.dat
    stat FR_OK 0
     opened 0 0
    .................................... (7111926 - 1.151868 MB/s)
     (open: 5064 us; close: 25000 us; write: min,max: 4945 191951 us)
    I put his mod in setup to track the buffer size:
      while(!Serial);
      Serial.println("Test logger_RawWrite");
      Serial.print(BUFFSIZE);
      Serial.print("<< BUFFSIZE _ Dev Type >>");
      Serial.println(Dev);
    Wow - only formatted before first test - T_3.6 with 2K buffer get really bogged down … and never over 1.27 MB/s::
    Z_00008.dat
    stat FR_OK 1586
     opened 0 0
    .................................... (7109975 - 1.152184 MB/s)
     (open: 238928 us; close: 24999 us; write: min,max: 4945 585951 us)
  8. #83
    2,401
    I have only T$ with USBHost possibility
    concerning my hang
    maybe it has something to do with USBHost::queue_Data_Transfer
    	// last qTD needs info for followup
    	data->qtd.next = 1;
    	data->pipe = pipe;
    	data->buffer = buffer;
    	data->length = len;
    	data->setup.word1 = 0;
    	data->setup.word2 = 0;
    	data->driver = driver;
    	// initialize all qTDs
    	data = transfer;
    	while (1) {
    		uint32_t count = len;
    		if (count > 16384) {
    			count = 16384;
    			last = true;
    		init_qTD(data, p, count, pipe->direction, 0, last);
    		if (last) break;
    		p += count;
    		len -= count;
    		data = (Transfer_t *)(data->qtd.next);
    as it hangs in msDoCommand
    else { // Data to device
    		queue_Data_Transfer(datapipeOut, CBW, sizeof(msCommandBlockWrapper_t), this);
    		if(CBW->CommandData[0]==CMDWR10) println("A");
    		while(!msOutCompleted);  // Wait for out transaction to complete.
    		if(CBW->CommandData[0]==CMDWR10) println("B");
    		msOutCompleted = false;
    		queue_Data_Transfer(datapipeOut, buffer, CBW->TransferLength, this);
    		if(CBW->CommandData[0]==CMDWR10) println("C");
    		while(!msOutCompleted);  // Wait for second out transaction to complete.
    		if(CBW->CommandData[0]==CMDWR10) println("D");
    		if((CSWResult = msGetCSW()) != 0)
    			return CSWResult;
    "D" is never printed as seen here
    Write 191880 64
    TransferLength 32768 CommandData  2A 0 0 19 18 80 0 0 40 0
    A
    B
    C
    but maybe not as it seems also not to work with exactly 16384
    But there it is a different hang position
    Write 191880 32
    TransferLength 16384 CommandData  2A 0 0 19 18 80 0 0 20 0
    A
    55 53 42 43 6F 00 00 00 00 40 00 00 00 00 0A 2A 00 00 19 18 80 00 00 20 00 00 00 00 00 00 00
    B
    C
    D
    55 53 42 53 6F 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 70 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Edit: the last CallbackOut, where it hangs, is a call to deviceAvailable()
    Which seems to never return.
    Another Edit:
    in a previous Write I have
    Write 103c6 1
    TransferLength 512 CommandData  2A 0 0 1 3 C6 0 0 1 0
    A
    55 53 42 43 29 00 00 00 00 02 00 00 00 00 0A 2A 00 00 01 03 C6 00 00 01 00 00 00 00 00 00 00
    B
    C
    5A 5F 30 30 30 39 36 20 44 41 54 20 10 00 00 00 21 50 00 00 00 00 00 00 21 50 62 5D 00 00 7D 00
    D
    ** CSWSIGNATURE
    EndWrite
    note the emmphasized length of dataOut
    which conflicts with
    D
    Write 199440 32
    TransferLength 16384 CommandData  2A 0 0 19 94 40 0 0 20 0
    A
    55 53 42 43 2D 00 00 00 00 40 00 00 00 00 0A 2A 00 00 19 94 40 00 00 20 00 00 00 00 00 00 00
    B
    C
    D
    ** CSWSIGNATURE
    EndWrite
  9. #84
    New York
    4,337
    @defragster
    Interesting - been using the T$ for al the tests I have done. Tried to repeat your test with a SD Card in the Audio Adapter (64GB SanDisk Ultra) and didn't have an issue with the T$ is a strange state. When it finished reading the card the LED stayed on for a sec and then started blinking. The only thing I notice is hot swapping doesn't work for me.
    EDIT: OK if I run the same test on USB I see the same issue with the T$ as you do
    Test uSDFS
    0:/
    Change drive
    Close the file.
    Hello world!
    Second Line
    Third Line
    Fourth Line
    Close the file.
    open binary file
    write file
    close file
    Binary test done
       29162  DATALOG.TXT
       <dir>  Ascii
      772140  operational.wav
       <dir>  2001
       <dir>  Flac
    30401785  Berlin - Take My Breathe Away theme from Top Gun with Lyrics.flac
     3177823  Christina Aguilera - Candyman (2009) 720p.aac
           0  mtpindex.dat
       21430  odd.mp3
       46888  odd1.mp3
      489461  zarathustra.mp3
      553004  odd1.wav
    16787550  SDTEST1.wav
      426300  calculations.wav
       <dir>  Binary
    131072000  Z_00001.dat
    131072000  Z_00002.dat
    131072000  Z_00003.dat
    131072000  Z_00004.dat
    131072000  Z_00005.dat
           0  Z_00006.dat
    Test completed.
  10. #85
    2,401
    Yes, All tests, where system hangs, are done with true USB memory sticks. uSD card with uSD-USB adapter worked without problems.
    USB memory sticks where also very slow (As you noticed)
    Conclusion: for high speed logging will stick with build-in SDIO (about 15 MB/s)
  11. #86
    New York
    4,337
    Is the extra while for "D" needed - seems to be there for A,B, and C
    [ERROR] Never mind my mistake
  12. #87
    5,756
    Good Morning... Sorry I may not be able to help here much... Other diversions....
    But in the code that queues the transfer, my version I put in stuff to detect if the calls fail...
    uint8_t msController::msDoCommand(msCommandBlockWrapper_t *CBW,	void *buffer)
    	if(CBWTag == 0xFFFFFFFF)
    		CBWTag = 1;
    	if((CBW->Flags == CMDDIRDATAIN)) { // Data from device
    		if (!queue_Data_Transfer(datapipeOut, CBW, sizeof(msCommandBlockWrapper_t), this)) {
    			println("msController::msDoCommand QDT failed CMDDIRDATAIN OUT");
    		if (!queue_Data_Transfer(datapipeIn, buffer, CBW->TransferLength, this)) {
    			println("msController::msDoCommand QDT failed CMDDIRDATAIN IN");
    		while(!msInCompleted);  // Wait for in transaction to complete.
    	} else { // Data to device
    			println("msController::msDoCommand QDT failed ELSE OUT");
    		if (!queue_Data_Transfer(datapipeOut, buffer, CBW->TransferLength, this)) {
    			println("msController::msDoCommand QDT failed ELSE OUT 2");
    	// Reset completion flags.
    	msInCompleted = false;
    	return msGetCSW();  // Get status of last transaction
    Again my version here may not be up to date with changes that @wwatson made on some of this...
    My guess is we are running out of transfer objects... Might add some USB Objects to get some more transfers allocated...
    Maybe start off the sketch something like:
    //Copyright 2019 by Walter Zimmer
    // Version 07-may-19
    #include "uSDFS.h"
    #include <USBHost_t36.h>
    extern USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    #define TEST_DRV 2
    #if TEST_DRV == 0
      const char *Dev = "0:/";  // SPI
    #elif TEST_DRV == 1
      const char *Dev = "1:/";  // SDHC
    #elif TEST_DRV == 2
      const char *Dev = "2:/";  // USB
    And see if that changes your run any. Good part is by adding these, you will be able to run with disk or the like plugged into USB HUB, which is probably a good thing.
  13. #88
    5,756
    for above the 8K transfer (2K * 4) I am thinking that some of the underlying stuff may need to debugged in usbhost_t36...
    In queue_Data_Transfer - Example this code:
    	for (count=(len >> 14); count; count--) {
    		next = allocate_Transfer();
    		if (!next) {
    			// free already-allocated qTDs
    			while (1) {
    				next = (Transfer_t *)transfer->qtd.next;
    				free_Transfer(transfer);
    				if (transfer == data) break;
    				transfer = next;
    			return false;
    		data->qtd.next = (uint32_t)next;
    		data = next;
    At 8K This for (count=(len >> 14); count; count--) { I believe sets count to 0 Using 8K which should then be 32K passed in here,
    count I think will be 2...
    And then how it works with the next loop:
    	while (1) {
    			count = 16384;
    			last = true;
    		if (last) break;
    		p += count;
    		len -= count;
    	return queue_Transfer(pipe, transfer);
    Example there may be issue with passing in 16384 as a length. As the first loop will say count=1 and allocate the a next unit... Then
    the next loop will only need the first one as 16384 will fit the first condition...
    So second one will not be init...
  14. #89
    2,401
    Got it
    IMO, the line must read
    	for (count=((len-1) >> 14); count; count--) {
    for 16k and smaller there should be no additional transaction
  15. #90
    5,756
    Got it
    I agree, other than I also put that test in a conditional if (count)...
    Not sure what it would do with 0 count, but...
  16. #91
    2,401
    I let you the mods and PR
  17. #92
    5,756
    Maybe someone will beat me to it, I did push up a change into my PS3_Motion.... branch, but have not tried to see if it fixes all of the issues yet.
    May be awhile before I will get a chance to try it out.
  18. #93
    New York
    4,337
    @WMXZ, @wwatson and @KurtE
    Just tried your change and seems to working. I first tried it with my very old Microcenter 1gb memory stick but it was taking so long to finish I swapped with a transcend card reader with the fast 64gb card I had:
    2:/
    Change drive
    Z_00001.dat
    stat FR_OK 0
     opened FR_OK 0
    .................................... (29888996 - 4.385293 MB/s)
     (open: 366048 us; close: 20000 us; write: min,max: 23889 247891 us)
    Z_00002.dat
    stat FR_OK 801
     opened FR_OK 0
    .................................... (30065996 - 4.359477 MB/s)
     (open: 361989 us; close: 20000 us; write: min,max: 23889 249891 us
    UPDATE:
    With the microcenter 1gb memory stick:
    Z_00001.dat
    stat FR_OK 0
     opened FR_OK 0
    .................................... (968335988 - 0.135358 MB/s)
     (open: 4051 us; close: 390000 us; write: min,max: 626891 1846877 us)
    With a 32Gb from SanDisk:
    2:/
    Change drive
    Z_00001.dat
    stat FR_NO_FILE 0
     opened FR_OK 0
    .................................... (62346995 - 2.102298 MB/s)
     (open: 76045 us; close: 25000 us; write: min,max: 39889 2925891 us)
  19. #94
    New York
    4,337
    For the heck of it I tried it with my SSD external drive but got an error:
    Change drive
    Z_00001.dat
    stat FR_OK 0
     opened FR_OK 0
     write FR_DISK_ERR
    It did write the file name though
  20. #95
    2,401
    Change drive
    Z_00001.dat
    stat FR_OK 0
     opened FR_OK 0
     write FR_DISK_ERR
    I may add a better write error (say how many records are already written)
    along the line
    Serial.printf(" write FR_DISK_ERR at count #%d\n",count);
  21. #96
    New York
    4,337
    @WMXZ
    Sounds like a good idea. I did look at the file contents but it was an empty file. Possibly because it didn't close correctly.
  22. #97
    10,127
    Update to this post above with USBHost_T36 link - will link it to here ...
    @mjs513 - you can edit ... it looks like @KurtE made some MSC edits?
    @WMXZ you can ping Robin if you'd like Sr+ as a T4_Beta and get 'old post edit' ability.
    @wwatson - if you get moved to github - or maybe @mjs513 could put 'current/evolving' WIP copy there for now?
    MSCv3.zip
    this MSCv3 did build ...
    Does this represent the known 'state of the art code'?
    Found an older 8GB Flash drive Windows Fat32 formatted and used to work with - just need to make sure code is complete. With old USBHost code it just starts and stalls … will get back with updated code ...
  23. #98
    New York
    4,337
    @defragster
    All I did was to download Kurt's USBHost_t36 ps3_Move_bluetooth branch and substitute it for what is installed with Teensyduino. Did not touch MSC.h at all as far as I know.
  24. #99
    10,127
    Using the latest @KurtE USBHost and turning on debug to Serial I got this on the 8GB Kingston Fat32 USB stick on T_3.6 - does it show anything helpful?::
    sizeof Device = 36
    sizeof Pipe = 96
    power up USBHS PHY
     reset waited 5
    USBHS_PERIODICLISTBASE = 1FFF5000
    periodictable = 1FFF5000
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 00 00 00 40 30 09 45 65 00 01 01 02 03 01
        VendorID = 0930, ProductID = 6545, Version = 0100
    enumeration:
    enumeration:
    Manufacturer: Kingston
    enumeration:
    Product: DataTraveler SE9
    enumeration:
    Serial Number: 001D0F1F90CAECB0472700A4
    enumeration:
    enumeration:
      09 02 20 00 01 01 00 80 64
        NumInterfaces = 1
        Interface = 0
      07 05 81 02 00 02 00
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
      07 05 02 02 00 02 00
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
    enumeration:
    new_Pipe
    new_Pipe
  25. #100
    10,127
    @defragster
    Okay wasn't sure if @KurtE post #87 or other resulted in changes.
    Here are the libs in use on my system:
    "T:\\TEMP\\arduino_build_logger_RawWrite.ino/logger_RawWrite.ino.elf"
    Multiple libraries were found for "USBHost_t36.h"
     Used: T:\tCode\libraries\USBHost_t36
     Not used: T:\Ard186t4b2\hardware\teensy\avr\libraries\USBHost_t36
    Using library uSDFS at version 1.1.0 in folder: T:\tCode\libraries\uSDFS :: 12 May WMXZ github
    Using library MSC at version 1.0.0 in folder: T:\tCode\libraries\MSC :: posted MSCV3 zip
    Using library USBHost_t36 at version 0.1 in folder: T:\tCode\libraries\USBHost_t36 :: linked KurtE github
