Page 3 of 14 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 51 to 75 of 338
Thread: USBHost_t36 USB Mass Storage Driver Experiments
  1. #51
    4,098
    @KurtE
    Can you? I managed to get CANFD have working - I can transmit a message from the T4 to the EVK now and I want to see whats going on with receive. I found the problem that was driving me crazy. Going to post that one on the T4 thread. Hoping to get it working today so I can go on to other distractions
  2. #52
    5,415
    (Here we ask for the media ready)
    msController CallbackOut (static)
    transfer->qtd.token = 1
    msController dataOut (static)31
    55 53 42 43 35 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    (Response - ends with 01 - fail)
    msController CallbackIn (static)
    transfer->qtd.token = 0
    msController dataIn (static): 13
    55 53 42 53 35 00 00 00 00 00 00 00 01
    ** CSWSIGNATURE
    (Now ask for request sense)
    55 53 42 43 36 00 00 00 12 00 00 00 80 00 06 03 00 00 00 12 00 00 00 00 00 00 00 00 00 00 00
    (response of sense)
    msController dataIn (static): 18
    70 00 02 00 00 00 00 0A 00 00 00 00 3A 00 00 00 00 00
    msDoCommand after msOutCompleted loop
    msDoCommand after msInCompleted loop
    55 53 42 53 36 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    (I had the waitMedia also dump out the response)...
    WaitMediaReady RSP:70 00 02 00 00 00 00 0A 00 00 00 00 3A 00
    .... Repeats for ever or until I unplug
    Now to look up what the response codes are...
    Follow on to this...
    Looking at the line: WaitMediaReady RSP:70 00 02 00 00 00 00 0A 00 00 00 00 3A 00
    Looking at the structure returned, the interesting info is the 0x3A
    Which from the site: http://www.t10.org/lists/asc-num.htm
    3A/00  DZT ROM  BK    MEDIUM NOT PRESENT
    3A/01  DZT ROM  BK    MEDIUM NOT PRESENT - TRAY CLOSED
    3A/02  DZT ROM  BK    MEDIUM NOT PRESENT - TRAY OPEN
    3A/03  DZT ROM  B     MEDIUM NOT PRESENT - LOADABLE
    3A/04  DZT RO   B     MEDIUM NOT PRESENT - MEDIUM AUXILIARY MEMORY ACCESSIBLE
    I believe the 0 after 3A is sub code here ... So simply "Medium not present"
    And never is... ???
    Wondering many of these commands have logical unit number and we always pass 0... Wonder if some of these devices have more than 1? and media on different one???
  3. #53
    5,415
    @KurtE
    Sounds good, I posted possible code for you try in previous posting (previous page)
  4. #54
    4,098
    @KurtE
    Looks like your modified claim code worked for my memory stick to make a long story short. This is what I am now seeing:
    Test Drive Inquiry with uSDFS
    Waiting For Device: 2:/
    USB2 PLL running
     reset waited 6
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 20004000
    periodictable = 20004000
    port change: 10001803
        connect
      begin reset
    port change: 18001205
      port enabled
      end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 00 00 00 40 07 13 63 01 00 01 01 02 03 01
        VendorID = 1307, ProductID = 0163, Version = 0100
        Class/Subclass/Protocol = 0 / 0 / 0
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: USB 2.0
    enumeration:
    Product: Flash Disk
    enumeration:
    Serial Number: 0ee644744fd53c
    enumeration:
    Config data length = 39
    enumeration:
    Configuration Descriptor:
      09 02 27 00 01 01 00 80 28
        NumInterfaces = 1
        ConfigurationValue = 1
      09 04 00 00 03 08 06 50 00
        Interface = 0
        Number of endpoints = 3
        Class/Subclass/Protocol = 8(Mass Storage) / 6(SCSI) / 80(Bulk Only)
      07 05 01 02 00 02 01
        Endpoint = 1 OUT
        Type = Bulk
        Max Size = 512
        Polling Interval = 1
      07 05 82 02 00 02 01
        Endpoint = 2 IN
        Type = Bulk
        Max Size = 512
      07 05 83 03 40 00 08
        Endpoint = 3 IN
        Type = Interrupt
        Max Size = 64
        Polling Interval = 8
    enumeration:
    msController claim this=20002F00
    Descriptor 4 = INTERFACE
    09 04 00 00 03 08 06 50 00 07 05 01 02 00 02 01 07 05 82 02 00 02 01 07 05 83 03 40 00 08
    numendpoint=3
    endpointIn=82
    endpointOut=1
    packet size in (msController) = 512
    packet size out (msController) = 512
    polling intervalIn = 1
    polling intervalOut = 1
    new_Pipe
    new_Pipe
    Descriptor 5 = ENDPOINT
    control CallbackIn (msController)
    55 53 42 43 02 00 00 00 00 00 00 00 80 00 06 1B 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 02 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 03 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 03 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 04 00 00 00 24 00 00 00 80 00 06 12 00 00 00 24 00 00 00 00 00 00 00 00 00 00 00
    msController dataIn (static): 36
    00 80 02 02 1F 00 00 00 55 53 42 20 32 2E 30 20 46 6C 61 73 68 20 44 69 73 6B 20 20 20 20 20 20
    55 53 42 53 04 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 05 00 00 00 08 00 00 00 80 00 0A 25 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    msController dataIn (static): 8
    00 1E 1F FE 00 00 02 00
    55 53 42 53 05 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 06 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 06 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 07 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
    msController dataIn (static): 512
    33 C0 8E D0 BC 00 7C FB 50 07 50 1F FC BE 1B 7C BF 1B 06 50 57 B9 E5 01 F3 A4 CB BD BE 07 B1 04
    55 53 42 53 07 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 08 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 08 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 09 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 3F 00 00 01 00 00 00 00 00 00 00
    EB 58 90 4D 53 44 4F 53 35 2E 30 00 02 08 00 11 02 00 00 00 00 F8 00 00 3F 00 FF 00 3F 00 00 00
    55 53 42 53 09 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 0A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 0A 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 0B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 40 00 00 01 00 00 00 00 00 00 00
    52 52 61 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 0B 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    Change drive
    Do Device Inquiry
    55 53 42 43 0C 00 00 00 24 00 00 00 80 00 06 12 00 00 00 24 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 0C 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    Removable Device: YES
            VendorID: USB 2.0
           ProductID: Flash Disk
          RevisionID: 0.00
    Get Device Capacity Specs
    55 53 42 43 0D 00 00 00 08 00 00 00 80 00 0A 25 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 0D 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
        Sector Count: 1974270
         Sector size: 512
       Disk Capacity: 1974270 * 512 Bytes
    Device Inquiry Test Finished.
  5. #55
    4,098
    @KurtE and others
    Tried the SSD drive again and now get a failed with RC=13, figured I would just give it a try:
    USB2 PLL running
     reset waited 6
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 10 02 00 00 00 40 2D 15 78 05 09 05 01 02 03 01
        VendorID = 152D, ProductID = 0578, Version = 0509
    enumeration:
    enumeration:
    Manufacturer: JMicron
    enumeration:
    Product: External USB 3.0
    enumeration:
    Serial Number: 0123456789CB
    enumeration:
    Config data length = 85
    enumeration:
      09 02 55 00 01 01 00 80 FA
        NumInterfaces = 1
      09 04 00 00 02 08 06 50 00
        Interface = 0
        Number of endpoints = 2
      07 05 81 02 00 02 00
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
        Polling Interval = 0
      07 05 02 02 00 02 00
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
      09 04 00 01 04 08 06 62 00
        Interface = 0
        Number of endpoints = 4
        Class/Subclass/Protocol = 8(Mass Storage) / 6(SCSI) / 98(UAS)
      07 05 01 02 00 02 00
        Endpoint = 1 OUT
        Type = Bulk
        Max Size = 512
      04 24 01 00
      07 05 82 02 00 02 00
        Endpoint = 2 IN
        Type = Bulk
        Max Size = 512
      04 24 02 00
      07 05 83 02 00 02 00
        Endpoint = 3 IN
        Type = Bulk
        Max Size = 512
      04 24 03 00
      07 05 04 02 00 02 00
        Endpoint = 4 OUT
        Type = Bulk
        Max Size = 512
      04 24 04 00
    enumeration:
    09 04 00 00 02 08 06 50 00 07 05 81 02 00 02 00 07 05 02 02 00 02 00 09 04 00 01 04 08 06 62 00 07 05 01 02 00 02 00 04 24 01 00 07 05 82 02 00 02 00 04 24 02 00 07 05 83 02 00 02 00 04 24 03 00 07 05 04 02 00 02 00 04 24 04 00
    numendpoint=2
    endpointIn=81
    endpointOut=2
    polling intervalIn = 0
    polling intervalOut = 0
    new_Pipe
    new_Pipe
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    55 53 42 53 02 00 00 00 00 00 00 00 01
    ** CSWSIGNATURE
    ** CSWSIGNATURE
    00 00 06 12 5B 00 00 00 48 50 20 53 53 44 20 53 36 30 30 20 31 32 30 47 42 20 20 20 20 20 20 20
    ** CSWSIGNATURE
    0D F9 4B AF 00 00 02 00
    ** CSWSIGNATURE
    ** CSWSIGNATURE
    33 C0 8E D0 BC 00 7C 8E C0 8E D8 BE 00 7C BF 00 06 B9 00 02 FC F3 A4 50 68 1C 06 CB FB B9 04 00
    ** CSWSIGNATURE
    ** CSWSIGNATURE
    55 53 42 43 09 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 08 00 00 00 01 00 00 00 00 00 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    Mount: Failed with rc=13.
    If you notice it has a descriptor that I don't think it knows about: Descriptor 36 = ???
  6. #56
    5,415
    @mjs513 and ...
    Neither did I know about descriptor 0x24...
    It is a class specific descriptor... Took me awhile to find: https://www.usb.org/sites/default/fi...2-19-2010.pdf]
    24h Pipe Usage Class Specific DescriptorAllocated by USB-IF for UAS. UAS is defined outside of USB
    As for your error code 13 - I believe that comes from ff.h
    FR_NO_FILESYSTEM, /* (13) There is no valid FAT volume */
    I have not dug in that far yet to know how that is determined...
  7. #57
    4,098
    @KurtE
    Interesting. I formatted to exFAT on the PC but it seems every time I run the example sketch using the drive it tells me I have to reformat when I hook it back up into the PC. Reformatting again as a double check will post update.
  8. #58
    2,330
    You may wanted to try this sketch
    #include "uSDFS.h"
    #include "diskio.h"
    * for APL see http://elm-chan.org/fsw/ff/00index_e.html
    #define TEST_DRV 2
    #if TEST_DRV == 0
      const char *Dev = "0:/";  // SPI
    #elif TEST_DRV == 1
      const char *Dev = "1:/";  // SDHC
    #elif TEST_DRV == 2
      const char *Dev = "2:/";  // USB
    struct partitionTable {
      uint8_t  boot;
      uint8_t  beginHead;
      unsigned beginSector : 6;
      unsigned beginCylinderHigh : 2;
      uint8_t  beginCylinderLow;
      uint8_t  type;
      uint8_t  endHead;
      unsigned endSector : 6;
      unsigned endCylinderHigh : 2;
      uint8_t  endCylinderLow;
      uint32_t firstSector;
      uint32_t totalSectors;
    } __attribute__((packed));
    typedef struct partitionTable part_t;
    struct masterBootRecord {
      uint8_t  codeArea[440];
      uint32_t diskSignature;
      uint16_t usuallyZero;
      part_t   part[4];
      uint8_t  mbrSig0;
      uint8_t  mbrSig1;
    typedef struct masterBootRecord mbr_t;
    uint32_t buffer[128];
      while(!Serial);
      BYTE pdrv = TEST_DRV;
      DSTATUS stat = disk_initialize(TEST_DRV);
      Serial.print("Disk initialize Status: "); Serial.println(stat);
      BYTE* buff = (BYTE *) buffer;
      DWORD sector = 0;
      UINT count = 1;
      DRESULT res = disk_read (pdrv, buff, sector, count);
      Serial.print("Disk read Result: "); Serial.println(res);
      for(int ii=0;ii<512; ii++)
      if((ii+1)%16) Serial.printf("%02x ",buff[ii]); else Serial.printf("%02x\n",buff[ii]);
      mbr_t *mbr = (mbr_t *) buffer;
      Serial.println("\nMaster Boot Record");
      for(int ii=0;ii<4;ii++)
        Serial.print("  Partition: "); Serial.print(ii);
        Serial.print(" first Sector: ");
        Serial.print(mbr->part[ii].firstSector);
        Serial.print(" total Sectors: ");
        Serial.println(mbr->part[ii].totalSectors);
      pinMode(13,OUTPUT);
      digitalWriteFast(13,!digitalReadFast(13));
    it should give something like this
    Disk initialize Status: 0
    Disk read Result: 0
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0a
    09 02 07 fe ff ff 00 80 00 00 00 78 f7 0e 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 aa
    Master Boot Record
      Partition: 0 first Sector: 32768 total Sectors: 251099136
      Partition: 1 first Sector: 0 total Sectors: 0
      Partition: 2 first Sector: 0 total Sectors: 0
      Partition: 3 first Sector: 0 total Sectors: 0
  9. #59
    2,330
    @KurtE
    It seems the Win10 Format does not anymore introduce MBR (which is used by ff.c)
    you need official SD Formatter (see also my reply to @KurtE)
  10. #60
    4,098
    @WMXZ, @KurtE and @wwatson
    Just ran the new test sketch (left the debugging stuff in) and do see the disk read and MBR:
    USB2 PLL running
     reset waited 6
    USBHS_PERIODICLISTBASE = 20003000
    periodictable = 20003000
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
        NumInterfaces = 1
        Interface = 0
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
        Interface = 0
        Endpoint = 1 OUT
        Type = Bulk
        Max Size = 512
      04 24 01 00
        Endpoint = 2 IN
        Type = Bulk
        Max Size = 512
      04 24 02 00
        Endpoint = 3 IN
        Type = Bulk
        Max Size = 512
      04 24 03 00
        Endpoint = 4 OUT
        Type = Bulk
        Max Size = 512
      04 24 04 00
    enumeration:
    msController claim this=20002900
    numendpoint=2
    endpointIn=81
    endpointOut=2
    new_Pipe
    new_Pipe
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    ** CSWSIGNATURE
    ** CSWSIGNATURE
    ** CSWSIGNATURE
    ** CSWSIGNATURE
    ** CSWSIGNATURE
    ** CSWSIGNATURE
    Disk read Result: 0
    33 c0 8e d0 bc 00 7c 8e c0 8e d8 be 00 7c bf 00
    06 b9 00 02 fc f3 a4 50 68 1c 06 cb fb b9 04 00
    bd be 07 80 7e 00 00 7c 0b 0f 85 0e 01 83 c5 10
    e2 f1 cd 18 88 56 00 55 c6 46 11 05 c6 46 10 00
    b4 41 bb aa 55 cd 13 5d 72 0f 81 fb 55 aa 75 09
    f7 c1 01 00 74 03 fe 46 10 66 60 80 7e 10 00 74
    26 66 68 00 00 00 00 66 ff 76 08 68 00 00 68 00
    7c 68 01 00 68 10 00 b4 42 8a 56 00 8b f4 cd 13
    9f 83 c4 10 9e eb 14 b8 01 02 bb 00 7c 8a 56 00
    8a 76 01 8a 4e 02 8a 6e 03 cd 13 66 61 73 1c fe
    4e 11 75 0c 80 7e 00 80 0f 84 8a 00 b2 80 eb 84
    55 32 e4 8a 56 00 cd 13 5d eb 9e 81 3e fe 7d 55
    aa 75 6e ff 76 00 e8 8d 00 75 17 fa b0 d1 e6 64
    e8 83 00 b0 df e6 60 e8 7c 00 b0 ff e6 64 e8 75
    00 fb b8 00 bb cd 1a 66 23 c0 75 3b 66 81 fb 54
    43 50 41 75 32 81 f9 02 01 72 2c 66 68 07 bb 00
    00 66 68 00 02 00 00 66 68 08 00 00 00 66 53 66
    53 66 55 66 68 00 00 00 00 66 68 00 7c 00 00 66
    61 68 00 00 07 cd 1a 5a 32 f6 ea 00 7c 00 00 cd
    18 a0 b7 07 eb 08 a0 b6 07 eb 03 a0 b5 07 32 e4
    05 00 07 8b f0 ac 3c 00 74 09 bb 07 00 b4 0e cd
    10 eb f2 f4 eb fd 2b c9 e4 64 eb 00 24 02 e0 f8
    24 02 c3 49 6e 76 61 6c 69 64 20 70 61 72 74 69
    74 69 6f 6e 20 74 61 62 6c 65 00 45 72 72 6f 72
    20 6c 6f 61 64 69 6e 67 20 6f 70 65 72 61 74 69
    6e 67 20 73 79 73 74 65 6d 00 4d 69 73 73 69 6e
    67 20 6f 70 65 72 61 74 69 6e 67 20 73 79 73 74
    65 6d 00 00 00 63 7b 9a 09 dc 4f 48 00 00 00 20
    21 00 07 fe ff ff 00 08 00 00 00 38 f9 0d 00 00
    Master Boot Record
      Partition: 0 first Sector: 2048 total Sectors: 234436608
    So at least looks like it working at the diskio level, I think
  11. #61
    Aug 2017
    125
    @Kurte
    Thanks for updating
    bool msController::claim(Device_t *dev, int type, const uint8_t *descriptors, uint32_t len)
    I have Targus Multi card reader which would not work with MSC. After applying your version I was able to read and write to various types of SD cards.
    Awesome work. I cannot believe how fast you can figure out program this stuff.
    Here is the output for the Multi card reader:
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
     reset waited 5
    USBHS_PERIODICLISTBASE = 1FFF3000
    periodictable = 1FFF3000
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 00 00 00 40 8F 05 66 63 00 01 01 02 03 01
        VendorID = 058F, ProductID = 6366, Version = 0100
    enumeration:
    enumeration:
    Manufacturer: Generic
    enumeration:
    Product: Mass Storage Device
    enumeration:
    Serial Number: 058F63666471
    enumeration:
    Config data length = 32
    enumeration:
      09 02 20 00 01 01 00 80 32
        NumInterfaces = 1
        Interface = 0
        Endpoint = 1 OUT
        Type = Bulk
        Max Size = 512
        Endpoint = 2 IN
        Type = Bulk
        Max Size = 512
    enumeration:
    msController claim this=1FFF2700
    09 04 00 00 02 08 06 50 00 07 05 01 02 00 02 00 07 05 82 02 00 02 00
    numendpoint=2
    endpointIn=82
    endpointOut=1
    new_Pipe
    new_Pipe
    ** CSWSIGNATURE
    55 53 42 53 03 00 00 00 00 00 00 00 01
    ** CSWSIGNATURE
    55 53 42 43 04 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    55 53 42 53 04 00 00 00 00 00 00 00 01
    ** CSWSIGNATURE
    55 53 42 43 05 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    55 53 42 43 06 00 00 00 24 00 00 00 80 00 06 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    00 80 00 00 1F 00 00 00 4D 75 6C 74 69 20 20 20 46 6C 61 73 68 20 52 65 61 64 65 72 20 20 20 20
    ** CSWSIGNATURE
    55 53 42 43 07 00 00 00 08 00 00 00 80 00 0A 25 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    00 EC DF FF 00 00 02 00
    ** CSWSIGNATURE
    55 53 42 43 08 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
    FA B8 00 10 8E D0 BC 00 B0 B8 00 00 8E D8 8E C0 FB BE 00 7C BF 00 06 B9 00 02 F3 A4 EA 21 06 00
    ** CSWSIGNATURE
    EB 58 90 6D 6B 66 73 2E 66 61 74 00 02 08 20 00 02 00 00 00 00 F8 00 00 3E 00 F5 00 00 08 00 00
    ** CSWSIGNATURE
    55 53 42 43 0A 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 08 01 00 00 01 00 00 00 00 00 00 00
    ** CSWSIGNATURE
    Change drive
    Do Device Inquiry
    55 53 42 43 0B 00 00 00 24 00 00 00 80 00 06 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
            VendorID: Multi
           ProductID: Flash Reader
          RevisionID: 1.00
    55 53 42 43 0C 00 00 00 08 00 00 00 80 00 0A 25 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ** CSWSIGNATURE
        Sector Count: 15523839
         Sector size: 512
       Disk Capacity: 15523839 * 512 Bytes
    Now I am going to work with reading and decode sense codes.
    I just tested Hot Plugging with the card reader and it works.
  12. #62
    5,415
    @wwatson @mjs513 @WMXZ - Glad we are making some progress here.. As we mentioned earlier on Bluetooth thread, it would be great to support some mass storage devices.
    I thought I would try with an Toshiba 1GB external hard disk I had sitting around.... Had Windows format it exFat... SDFormatter did not see it...
    Tried both test programs and both are dying...
    USB2 PLL running
     reset waited 6
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 00 00 00 40 39 09 13 0B 00 01 01 02 03 01
        VendorID = 0939, ProductID = 0B13, Version = 0100
    enumeration:
    enumeration:
    Manufacturer: TOSHIBA
    enumeration:
    Product: External HDD
    enumeration:
    Serial Number: 0010101A402E78AF0
    enumeration:
    enumeration:
      09 02 20 00 01 01 00 C0 01
        NumInterfaces = 1
        Interface = 0
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=20002D40
    msController claim this=20003120
    numendpoint=2
    endpointIn=81
    endpointOut=2
    new_Pipe
    new_Pipe
    ** CSWSIGNATURE
    ** CSWSIGNATURE
    05 80 00 21 1F 00 00 00 54 4F 53 48 49 42 41 20 56 69 72 74 75 61 6C 20 43 64 72 6F 6D 20 20 20
    ** CSWSIGNATURE
    00 01 F3 FF 00 00 08 00
    ** CSWSIGNATURE
    ** CSWSIGNATURE
    transfer->qtd.token = 64
    msController dataIn (static): 0
    ERROR Followup
    But it could be some of my hacking that failed...
    Although I think this is probably after my hacking...
  13. #63
    Aug 2017
    125
    @Kurte
    ERROR Followup
    I see the qtd.token has bit 6 set. The Host controller sets this to 1 on a HALT due to an error.
    Check page 44 of the EHCI PDF manual which can be downloaded here. https://www.intel.com/content/www/us...n-for-usb.html
    If I remember right, the followup error is due to a incomplete pending transfer. Probably should check the ehci.cpp file (lines 344-362) for that.
  14. #64
    2,330
    To facilitate rc=xx understanding, I added error strings to uSDFS.h (latest gitgub version)
  15. #65
    Aug 2017
    125
    @Kurte and others
    I found SCSI reference manual while hunting around the Internet.
    https://www.seagate.com/staticfiles/...100293068a.pdf
    Has a lot of good information as a companion to https://www.seagate.com/files/static...100293068j.pdf
  16. #66
    5,415
    Thanks @...
    Not sure how much more I will be able to do here for awhile. Like it might be awhile before I look at the Toshiba hard disk issue.
    I have not debugged the last command that error-ed out. As you mentioned it implies a transfer did not complete...
    Thanks @WMXZ - Having textual outputs can help!
    @wwatson - the SCSI documents on seagate links do not work for me.
    Again looking like some good progress.
    It will be great to have all of this working.
    Now getting ready for other distractions.
  17. #67
    4,098
    Not sure what @WMXZ changed in the library but I just reran the uSDFS_test sketch in the uSDS library and the HP 120GB SSD I was using is now working:
    Test uSDFS
    2:/
    Change drive
    Create a new subdirectories.
    Create a new file /Ascii/HELLO12.TXT.
    Write some text lines. (Hello world!)
    Close the file.
    Open same file /Ascii/HELLO12.TXT.
    Get the file content.
    Hello world!
    Second Line
    Third Line
    Fourth Line
    Habe keine Phantasie
    Close the file.
    open binary file
    write file
    close file
    Binary test done
    Open root directory.
    Directory listing...
       <dir>  System Volume Information
       <dir>  Ascii
       <dir>  Binary
    Test completed.
    @KurtE you might update the uSDFS lib and give your HDD a try. Reran it just to see what text strings would give me.
    OH, @WMXZ - need to make one change to the uSDFS.h file:
    const char *STAT_ERROR_STRING = {
    needs to be changed to:
    const char *STAT_ERROR_STRING[] = {
  18. #68
    Aug 2017
    125
    @mjs513
    Actually there was two files that needed to be changed. Not diskio.h but uSDFS.h line 3 and uSDFS_test.ino line 31.
    In uSDFS.h add sqaure brackets
    and
    in uSDFS_test.ino change line 31:
    FR_ERROR_STRING(rc)
    to:
    FR_ERROR_STRING[rc]
    @WMXZ
    I like it, I do better with words than numbers.
  19. #69
    2,330
    @mjs513
    @WMXZ
    Was typical cut/paste error (jet-lag), corrected now
    @wwatson, is there a github or new zip file with latest MSC?
  20. #70
    2,330
    I further updated ff.c to include all ff.c patches by Elm Chan
  21. #71
    5,415
    @wwatson, @WMXZ, @mjs513...
    I may not have much time to play here today, so thought I would revisit why the 1GB CRUZER (SanDisk) is not working... Endless loop waiting for media available...
    And document what I have found, in case someone else can pick up where I leave off...
    So wondered if maybe it has multiple logical units... So thought about adding the code for it... Then saw it was already there...
    Changed the init code to print out the result, like:
    	msResult = msDrive1.msGetMaxLun();
    	Serial.printf("## mscInit after msgGetMaxLun: %d\n", msResult);
    	delay(150);
    And for working disk and this non-working disk they showed 0 printed...
    Then I looked a little closer at it. The code for getting max lun...
    uint8_t msController::msGetMaxLun() {
    	mk_setup(setup, 0xa1, 0xfe, 0, 0, 1);
    	queue_Control_Transfer(device, &setup, report, this);
    	return report[0];
    This won't work as you have only queued the request and then return the data before it ever has chance to be filled in...
    Now looking at output of my non-working drive:
    ## mscInit after msgGetMaxLun: 0
    You will see the Callback showing a value of 1...
    And going back to look at the other thumb drive that is returning data:
    It does show 0 as the last valid LUN...
    So thinking maybe in this case, (after fixing the code to wait for callback before returning, which I have not done yet),
    Maybe if media is not available on LUN=0, need to try others up to MAX and/or maybe always try the MAX one first?
    If this is the issue, will need to change several low level functions, to take in the LUN to pass as either parameter or some global setting....
    Kurt
  22. #72
    4,098
    @KurtE
    That's interesting on you 1GB SanDisk Cruzer. Reason I am saying this is that I tried a 2Gb SanDisk Cruzer and it worked. It does have 2 partitions on it - one for the U3 system and the second for the data. It read the data partition no problem. I did reformat it though - I think for exFat or FAT32 - don't remember now will have to recheck and retest.
    Mike
  23. #73
    2,330
    So I got me a Transcend 8GB stick (FAT32 formated)
    with debug on and program (#58) I get the following
    USB2 PLL running
     reset waited 6
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 10 02 00 00 00 40 64 85 00 10 00 11 01 02 03 01
        VendorID = 8564, ProductID = 1000, Version = 1100
    enumeration:
    enumeration:
    Manufacturer: JetFlash
    enumeration:
    enumeration:
    Serial Number: 17Q880DIDAVC35MP
    enumeration:
    enumeration:
      09 02 20 00 01 01 00 80 96
        NumInterfaces = 1
        Interface = 0
        Endpoint = 1 OUT
        Type = Bulk
        Max Size = 512
        Endpoint = 2 IN
        Type = Bulk
        Max Size = 512
    enumeration:
    msController claim this=20002AA0
    endpointType = 2
    and then nothing
    OK, I still using the program V2 from earlier zip
    Any possibility to get a new zip file with update MSC?
    If USBHost_t3 still the same?
  24. #74
    4,098
    @WMXZ
    This is what I have been using - pretty sure it has all the changes talked about.
    Attached Files Attached Files
  25. #75
    2,330
    @mjs513, thanks, now it is running through
    USB2 PLL running
     reset waited 6
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
        NumInterfaces = 1
        Interface = 0
        Endpoint = 1 OUT
        Type = Bulk
        Max Size = 512
        Endpoint = 2 IN
        Type = Bulk
        Max Size = 512
    enumeration:
    msController claim this=20002AC0
    numendpoint=2
    endpointIn=82
    endpointOut=1
    new_Pipe
    new_Pipe
    ** CSWSIGNATURE
    ** CSWSIGNATURE
    00 80 06 02 1F 73 6D 69 4A 65 74 46 6C 61 73 68 54 72 61 6E 73 63 65 6E 64 20 38 47 42 20 20 20
    ** CSWSIGNATURE
    00 E1 3F FF 00 00 02 00
    ** CSWSIGNATURE
    Disk initialize Status: STA_OK
    ** CSWSIGNATURE
    ** CSWSIGNATURE
    Disk read Result: FR_OK
    33 c0 8e d0 bc 00 7c fb 50 07 50 1f fc be 1b 7c
    bf 1b 06 50 57 b9 e5 01 f3 a4 cb bd be 07 b1 04
    38 6e 00 7c 09 75 13 83 c5 10 e2 f4 cd 18 8b f5
    83 c6 10 49 74 19 38 2c 74 f6 a0 b5 07 b4 07 8b
    f0 ac 3c 00 74 fc bb 07 00 b4 0e cd 10 eb f2 88
    4e 10 e8 46 00 73 2a fe 46 10 80 7e 04 0b 74 0b
    80 7e 04 0c 74 05 a0 b6 07 75 d2 80 46 02 06 83
    46 08 06 83 56 0a 00 e8 21 00 73 05 a0 b6 07 eb
    bc 81 3e fe 7d 55 aa 74 0b 80 7e 10 00 74 c8 a0
    b7 07 eb a9 8b fc 1e 57 8b f5 cb bf 05 00 8a 56
    00 b4 08 cd 13 72 23 8a c1 24 3f 98 8a de 8a fc
    43 f7 e3 8b d1 86 d6 b1 06 d2 ee 42 f7 e2 39 56
    0a 77 23 72 05 39 46 08 73 1c b8 01 02 bb 00 7c
    8b 4e 02 8b 56 00 cd 13 73 51 4f 74 4e 32 e4 8a
    56 00 cd 13 eb e4 8a 56 00 60 bb aa 55 b4 41 cd
    13 72 36 81 fb 55 aa 75 30 f6 c1 01 74 2b 61 60
    6a 00 6a 00 ff 76 0a ff 76 08 6a 00 68 00 7c 6a
    01 6a 10 b4 42 8b f4 cd 13 61 61 73 0e 4f 74 0b
    32 e4 8a 56 00 cd 13 eb d6 61 f9 c3 49 6e 76 61
    6c 69 64 20 70 61 72 74 69 74 69 6f 6e 20 74 61
    62 6c 65 00 45 72 72 6f 72 20 6c 6f 61 64 69 6e
    65 6d 00 4d 69 73 73 69 6e 67 20 6f 70 65 72 61
    74 69 6e 67 20 73 79 73 74 65 6d 00 00 00 00 00
    00 00 00 00 00 2c 44 63 18 2e 07 c3 00 00 00 20
    21 00 0c fe ff 95 00 08 00 00 00 30 e1 00 00 00
    Master Boot Record
      Partition: 0 first Sector: 2048 total Sectors: 14757888
    BTW, it is Fat32 formatted by Win32
