I have sorted out a few issues that I was seeing with CSW tag errors. I wouldn't be surprised if you are running into the same issues I was seeing where the code wouldn't reload Command wrapper.tag, instead just using the value stored in a register.
I should also mention that some of these kinds of issues will disappear when printing debugging information as that often forces the code to reload the value, so make sure you also test without debugging enabled.
Gave your sketch a try using the UAM46 drive and as advertised it worked but I had to reformat the disk first.Originally Posted by wwatson
Also went back to the Wireshark Windows dump and looked at the startup for the drive on windows did notice a couple of scsi cmds setting the drive as direct access etc. 0xa2 and 0x23 but not sure that matters
Note: I have a lot of debug turned on. But it does appear to runCode:Writing: 'this is a test.' to sector: 1000000 msWriteBlocks() msDoCommand() USBDrive CallbackOut (static) transfer->qtd.token = 0 USBDrive dataOut (static)31 55 53 42 43 09 00 00 00 00 02 00 00 00 00 0A 2A 00 00 0F 42 40 00 00 01 00 00 00 00 00 00 00 USBDrive CallbackOut (static) transfer->qtd.token = 0 USBDrive dataOut (static)512 74 68 69 73 20 69 73 20 61 20 74 65 73 74 2E 00 72 73 6C 74 20 3D 20 25 64 0A 00 00 0A 52 65 61 msGetCSW() USBDrive CallbackIn (static) transfer->qtd.token = 0 USBDrive dataIn (static): 13 55 53 42 53 09 00 00 00 00 00 00 00 00 msProcessError() rslt = 0 Reading sector:10000000 to cbuff msReadBlocks() msDoCommand() USBDrive CallbackOut (static) transfer->qtd.token = 0 USBDrive dataOut (static)31 55 53 42 43 0A 00 00 00 00 02 00 00 80 00 0A 28 00 00 0F 42 40 00 00 01 00 00 00 00 00 00 00 USBDrive CallbackIn (static) transfer->qtd.token = 0 USBDrive dataIn (static): 512 74 68 69 73 20 69 73 20 61 20 74 65 73 74 2E 00 72 73 6C 74 20 3D 20 25 64 0A 00 00 0A 52 65 61 msGetCSW() USBDrive CallbackIn (static) transfer->qtd.token = 0 USBDrive dataIn (static): 13 55 53 42 53 0A 00 00 00 00 00 00 00 00 msProcessError() rslt = 0 BYTE 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F --------------------------------------------------------- 0000 74 68 69 73 20 69 73 20 61 20 74 65 73 74 2e 00 this is a test.. Clearing buffer msWriteBlocks() msDoCommand() USBDrive CallbackOut (static) transfer->qtd.token = 0 USBDrive dataOut (static)31 55 53 42 43 0B 00 00 00 00 02 00 00 00 00 0A 2A 00 00 0F 42 40 00 00 01 00 00 00 00 00 00 00 USBDrive CallbackOut (static) transfer->qtd.token = 0 USBDrive dataOut (static)512 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 msGetCSW() USBDrive CallbackIn (static) transfer->qtd.token = 0 USBDrive dataIn (static): 13 55 53 42 53 0B 00 00 00 00 00 00 00 00 msProcessError() msReadBlocks() msDoCommand() USBDrive CallbackOut (static) transfer->qtd.token = 0 USBDrive dataOut (static)31 55 53 42 43 0C 00 00 00 00 02 00 00 80 00 0A 28 00 00 0F 42 40 00 00 01 00 00 00 00 00 00 00 USBDrive CallbackIn (static) transfer->qtd.token = 0 USBDrive dataIn (static): 512 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 msGetCSW() USBDrive CallbackIn (static) transfer->qtd.token = 0 USBDrive dataIn (static): 13 55 53 42 53 0C 00 00 00 00 00 00 00 00 msProcessError() BYTE 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F --------------------------------------------------------- 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ press enter to test...
Edit: Sometimes when reading product information, it is hard to decipher what the mean.
That is, does it require a USB 3 port to get those speeds or period.
@mjs513 - I also noticed a couple of other things in those snapshots. Down a couple of lines you see "URB_FUNCTION_SYNC_RESET_PIPE_AND_CLEAR_STALL" twice. I think this is what we are seeing on the T4. For some reason the flash drive is stalling the pipe and that is why we are seeing the halted pipe and "ERROR followup". I know there is a way to rest and clear the stall. Just not sure how to do this with the T4.
Edit: There is also two "URB_BULK_IN" in a row after a "URB_BULK_OUT".
I have a magnifying lite and a magnifier for just such an occasionIt states that it is backward compatible with USB 2.0. I think it's time to do some online research...
Edit: Here is a link to the support page for the ultra dualdrive I am testing:
https://support-en.wd.com/app/produc...tailweb/p/8779
Think we had an issue with USB Pipe Stall before: https://forum.pjrc.com/threads/68139...l=1#post292596 but I remember similar issues - just can't find them now.
@mjs513 @wwatson
@PaullStoffregen (if you are watching) - thread shows last look about a week ago.
Some of this lower level USB stuff is above my pay grade (of $0)
Stalls - I have looked a little bit through the T3.6 and IMXRT manuals and trying to decipher some of the Jargons.
But my impression is that maybe to clear a stall there appears to be some Endpoint control registers
USB_nENDPOINTCTRLn on IMXRT and USBHS_EPCRn on T3.6 but I don't see anywhere in our code base that references these registers.
They are defined in imxrt.h...
Not sure if they would work or not. Might experiment later if we see the stall bit to try clearing it there/here and see if it does anything?
@KurtE @mjs513 - Here is a web article of interest with information on stalled USB 3.0 pipes and how to reset and clear them:
http://billauer.co.il/blog/2019/12/u...ow-halt-reset/
Would like to adapt this:
to our USBHost library and see if I can blowup somethingCode:if (rc == LIBUSB_ERROR_OVERFLOW) { rc = libusb_control_transfer(dev_handle, 0x02, // bmRequestType, endpoint 0x03, // bRequest = SET_FEATURE 0x00, // wValue = ENDPOINT_HALT (1 | LIBUSB_ENDPOINT_IN), // wIndex = ep NULL, // Data (no data) 0, // wLength = 0 100); // Timeout, ms if (rc) { print_usberr(rc, "Failed to halt endpoint"); break; } rc = libusb_control_transfer(dev_handle, 0x02, // bmRequestType, endpoint 0x01, // bRequest = CLEAR_FEATURE 0x00, // wValue = ENDPOINT_HALT (1 | LIBUSB_ENDPOINT_IN), // wIndex = ep NULL, // Data (no data) 0, // wLength = 0 100); // Timeout, ms if (rc) { print_usberr(rc, "Failed to unhalt endpoint"); break; } continue; }
It seems to be referencing Linux and xHCI. EHCI? Also here is the Linux lsusb output for the Sandisk Ultra 3.0 dualdrive:
The portion marked in red makes me wonder if there is configuration needed. This was list on a computer with USB 3.0 ports. The same listing on a computer with USB 2.0 ports shows max packets sizes of 512 instead of 1024...Code:Bus 002 Device 010: ID 0781:5590 SanDisk Corp. Ultra Dual Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 3.00 bDeviceClass 0 bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 9 idVendor 0x0781 SanDisk Corp. idProduct 0x5590 Ultra Dual bcdDevice 1.00 iManufacturer 1 SanDisk iProduct 2 Ultra iSerial 3 4C530001120612122373 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x002c bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0x80 (Bus Powered) MaxPower 896mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 8 Mass Storage bInterfaceSubClass 6 SCSI bInterfaceProtocol 80 Bulk-Only iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0400 1x 1024 bytes bInterval 0 bMaxBurst 15 Binary Object Store Descriptor: bLength 5 bDescriptorType 15 wTotalLength 0x0016 bNumDeviceCaps 2 USB 2.0 Extension Device Capability: bLength 7 bDescriptorType 16 bDevCapabilityType 2 bmAttributes 0x00000002 HIRD Link Power Management (LPM) Supported SuperSpeed USB Device Capability: bLength 10 bDescriptorType 16 bDevCapabilityType 3 bmAttributes 0x00 wSpeedsSupported 0x000e Device can operate at Full Speed (12Mbps) Device can operate at High Speed (480Mbps) Device can operate at SuperSpeed (5Gbps) bFunctionalitySupport 1 Lowest fully-functional device speed is Full Speed (12Mbps) bU1DevExitLat 10 micro seconds bU2DevExitLat 256 micro seconds Device Status: 0x0000 (Bus Powered)
Sounds like something to try. I have seen the clear feature like this somewhere else.
I opened an issue on github in regards to possible erroneous CommandBlockStatus.Tag errors here:
https://github.com/PaulStoffregen/US...t36/issues/113
Is my logic incorrect? Can we be sure that the compiler won't optimize away the reading of StatusBlockWrapper.Tag?
@ All - In mscInit() function, comment out call to msReset() function:
That took care of all issues with these SanDisk devices we were seeing. Other devices seem to still work but probably should be selective about which ones need to be reset (using vid and pid). I remembered seeing that some flash drives would fail if reset. The possibility exists the default power on configuration works and if msReset() is applied the device needs to be configured back to that same working configuration.Code:// Initialize Mass Storage Device uint8_t USBDrive::mscInit(void) { #ifdef DBGprint println("mscIint()"); #endif uint8_t msResult = MS_CBW_PASS; CBWTag = 0; uint32_t start = millis(); // Check if device is connected. do { if((millis() - start) >= MSC_CONNECT_TIMEOUT) { return MS_NO_MEDIA_ERR; // Not connected Error. } yield(); } while(!available()); // msReset(); // delay(500); // Not needed any more. maxLUN = msGetMaxLun(); // msResult = msReportLUNs(&maxLUN); //println("maxLUN = "); //println(maxLUN); // delay(150); //------------------------------------------------------- msResult = msStartStopUnit(1); msResult = WaitMediaReady(); if(msResult) return msResult; // Retrieve drive information. msDriveInfo.initialized = true; msDriveInfo.hubNumber = getHubNumber(); // Which HUB. msDriveInfo.hubPort = getHubPort(); // Which HUB port. msDriveInfo.deviceAddress = getDeviceAddress(); // Device addreess. msDriveInfo.idVendor = getIDVendor(); // USB Vendor ID. msDriveInfo.idProduct = getIDProduct(); // USB Product ID. msResult = msDeviceInquiry(&msInquiry); // Config Info. if(msResult) return msResult; msResult = msReadDeviceCapacity(&msCapacity); // Size Info. if(msResult) return msResult; memcpy(&msDriveInfo.inquiry, &msInquiry, sizeof(msInquiryResponse_t)); memcpy(&msDriveInfo.capacity, &msCapacity, sizeof(msSCSICapacity_t)); return msResult; }
What a lot of horsing around for that fix![]()
I hate issues like that.... Anyway just tried my read/write USB sketch on the GAM46 (the sansdisk ultra and the UAM46 old gen) and looks like no more hangs:Originally Posted by wwatson
on the UAM46 same thingCode:Initializing USB MSC drive...Waiting for USB Filesystem === Task() Drive 0x20004120 connected === >> USBDrive::startFilesystems called 0x20004120 >>Partition 1 VT:1 T:12 32 60062468 >>USBFilesystem::claimPartition 0x1 called >>USBFilesystem::check_voltype_guid(1, 0x20067f28) + Claimed Try Partition list>>USBDrive::printPartionTable Partition Table part,boot,bgnCHS[3],type,endCHS[3],start,length FAT32: 1,0,0x0,0x21,0x0,0xC,0xFE,0xFF,0xFF,32,60062468 pt_#0: 2,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0 pt_#0: 3,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0 pt_#0: 4,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0 Filesystem started SanDiskSecureAccess/ DownloadSanDiskSecureAccess_Mac.pdf 355233 SanDisk_SecureAccess_QSG.pdf 2676267 Back Up Your Files to the Cloud.pdf 403851 RunSanDiskSecureAccess_Win.exe 16024600 System Volume Information/ WPSettings.dat 12 IndexerVolumeGuid 76 LOST.DIR/ Writing to test.txt...done. SanDiskSecureAccess/ DownloadSanDiskSecureAccess_Mac.pdf 355233 SanDisk_SecureAccess_QSG.pdf 2676267 Back Up Your Files to the Cloud.pdf 403851 RunSanDiskSecureAccess_Win.exe 16024600 System Volume Information/ WPSettings.dat 12 IndexerVolumeGuid 76 LOST.DIR/ test.txt 18 test.txt: testing 1, 2, 3. SanDiskSecureAccess/ DownloadSanDiskSecureAccess_Mac.pdf 355233 SanDisk_SecureAccess_QSG.pdf 2676267 Back Up Your Files to the Cloud.pdf 403851 RunSanDiskSecureAccess_Win.exe 16024600 System Volume Information/ WPSettings.dat 12 IndexerVolumeGuid 76 LOST.DIR/ test.txt 18
Code:Initializing USB MSC drive...Waiting for USB Filesystem === Task() Drive 0x20004120 connected === >> USBDrive::startFilesystems called 0x20004120 >>Partition 1 VT:1 T:12 2112 60121088 >>USBFilesystem::claimPartition 0x1 called >>USBFilesystem::check_voltype_guid(1, 0x20067f28) + Claimed Try Partition list>>USBDrive::printPartionTable Partition Table part,boot,bgnCHS[3],type,endCHS[3],start,length FAT32: 1,0,0x21,0x22,0x0,0xC,0xFE,0xFF,0xFF,2112,60121088 pt_#0: 2,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0 pt_#0: 3,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0 pt_#0: 4,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0 < unused area starting at: 60123200 length 1983 > Filesystem started System Volume Information/ WPSettings.dat 12 IndexerVolumeGuid 76 Writing to test.txt...done. System Volume Information/ WPSettings.dat 12 IndexerVolumeGuid 76 test.txt 18 test.txt: testing 1, 2, 3. System Volume Information/ WPSettings.dat 12 IndexerVolumeGuid 76 test.txt 18
Looks like it even fixed the issue with my ancient sansdisk cruzr (2gb drive)
Code:Partition Table part,boot,bgnCHS[3],type,endCHS[3],start,length FAT32: 1,0,0x20,0x21,0x0,0xB,0xAA,0x28,0x82,2048,2097152 FAT16: 2,0,0xAA,0x29,0x82,0x6,0xFE,0x3F,0xF8,2099200,1912832 pt_#0: 3,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0 pt_#0: 4,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0 < unused area starting at: 4012032 length 1680 > Filesystem started System Volume Information/ IndexerVolumeGuid 76 WPSettings.dat 12 Writing to test.txt...done. System Volume Information/ IndexerVolumeGuid 76 WPSettings.dat 12 test.txt 18 test.txt: testing 1, 2, 3. System Volume Information/ IndexerVolumeGuid 76 WPSettings.dat 12 test.txt 18
That's my point. From the perspective of msGetCSW(), the value of .Tag doesn't change and when it gets to this point:
It seems to me that there's a chance that the real value of StatusBlockWrapper.Tag won't be used. It's possible that the code will just assume StatusBlockWrapper.Tag is still 0.Code:if(StatusBlockWrapper.Tag != CBWTag)
Think about it for a moment: if it were optimized out it would happen every time, not just on rare occasions.
The compiler simply isn't allowed to perform the optimization you're proposing because the address of the struct is being used in an intermediate function call.
@wwatson @mjs513 - I tried the change and as mentioned it appears to fix the issue with at least the problem child I picked up. I ran the MTP USB example and was able to both have it create the log file on the drive. It also allowed me to copy files to the disk.
This was after I fixed that sketch to build with the current stuff (I pushed up those changes).
Side question to myself and others who do stuff on the MTP_Teensy library. Wondering if I/We should create some github rules type stuff, that does not allow code to go in until github verifies that all of the examples compile. Was added recently to my ILI9341_t3n library...
@wwatson - wondering are you going to submit a PR to @PaulStoffregen on this? Default to just not call it? Or have list of drives to call it on or not call it on?
The logged info here looks really suspicious. First a CBW goes out for a WRITE_10 command of length one sector, then the 512 bytes of sector data go out, then trying to bring in the 13 byte CSW fails with a STALL. But have a look at the dumped sector data:
That doesn't look like random file data... it's a CBW for a REQUEST_SENSE command, with the next successive tag after the WRITE_10 command! How did it end up in the transfer buffer?Code:55 53 42 43 0F 00 00 00 FC 00 00 00 80 00 06 03 00 00 00 FC 00 00 00 00 00 00 00 00 00 00 00 00
Something very strange is going on here. The CBW/CSWs are all created as local variables (on the stack) so either there's major stack corruption happening or somehow the Transfer_t lists in ehci.cpp are getting corrupted...
With regards to clearing halted endpoints, this code that wwatson posted is spot on:
I.E. it's just a special control transfer, you don't need to do any magic hardware pokes of the host registers. Years ago I helped implement a homebrew usbstorage driver for the Nintendo Wii, we definitely had to add error handling (with resetting and clearing halts on the endpoints) to ensure most devices worked correctly. Another thing to watch out for is sector size - it's not safe to assume 1 dataIn/dataOut transfer = 1 sector because optical drives use 2048 bytes per sector (that would be why KurtE was getting errors earlier in the thread when trying to use one) and some HDDs use 4096 byte sectors. Other large (>2TB) HDDs still use 512b sectors but because they have over 2^32 LBAs, they require different READ/WRITE commands to be able to access the entire disk. I think there's a special inquiry page or code to check if that's needed but I don't remember exactly off the top of my head.Code:rc = libusb_control_transfer(dev_handle, 0x02, // bmRequestType, endpoint 0x01, // bRequest = CLEAR_FEATURE 0x00, // wValue = ENDPOINT_HALT (1 | LIBUSB_ENDPOINT_IN), // wIndex = ep NULL, // Data (no data) 0, // wLength = 0 100); // Timeout, ms
Ok did some testing with MTP (writing/reading files and transferring files) and all worked fine with that change.
Drives tested so far:
1. Crucial MX500 500GB 3D NAND SATA 2.5 Inch Internal SSD, up to 560MB/s - CT500MX500SSD1
2. INDMEM mSATA SSD 256GB Internal Mini SATA III SSD Micro-SATA TLC 3D NAND Flash 256 GB
3. HP SSD S 600 120GB
4. Silicon Power 2TB Rugged Portable External Hard Drive Armor A30:
This was a strange one:
notice the sector count?Code:connected: 1 initialized: 1 USB Vendor ID: 174c USB Product ID: 55aa HUB Number: 0 HUB Port: 0 Device Address: 1 Removable Device: NO VendorID: PHD 3.0 ProductID: Silicon-Power RevisionID: 0 Version: 6 Sector Count: -387938129 Sector size: 512 Disk Capacity: 2000398933504 Bytes
PS did find adding a delay(500) allowed the drive to come on line
Code:while (!myDrive) { myusb.Task(); } delay(500);
A little bit of an update
The Silicon Power 2TB HD does need a powered hub to be able to write/read using MTP.
Also just tried hooking up a very old Samsung HDD which definitely needs a powered hub
and still worked with the changeCode:VendorID: Initio ProductID: MP0603H RevisionID: 1.06 Version: 0 Sector Count: 117304991 Sector size: 512 Disk Capacity: 60060155392 Bytes
I have a few things I have to do this morning so after that I want to test more devices SD card readers, Hard Drives, etc. Just to make sure msReset() is not needed. For the most part I am convinced it's not needed. I will issue a PR once I done some more testing. I still have one PR in for the timeouts in "msc.h":
These timeouts were not long enough for detection of my SD card reader or SSD drive.Code:// These two defines are timeouts for detecting a connected drive // and waiting for it to be operational. #define MEDIA_READY_TIMEOUT 5000 // Was 1000 #define MSC_CONNECT_TIMEOUT 5000 // Was 4000
