OK - happy to provide, but didnot want to clog things up with rubbish if it was known problem.
Sketch - (examples) blink.ino
quote
#include <Arduino.h>
#include "TeensyThreads.h"
const int LED = 13;
volatile int blinkcode = 0;
void blinkthread() {
while(1) {
if (blinkcode) {
for (int i=0; i<blinkcode; i++) {
digitalWrite(LED, HIGH);
threads.delay(150);
digitalWrite(LED, LOW);
threads.delay(150);
blinkcode = 0;
threads.yield();
pinMode(LED, OUTPUT);
threads.addThread(blinkthread);
int count = 0;
count++;
blinkcode = count;
delay(5000);
unquote.
compiler output - Ist TLC 2nd T3.2(worked).
// Compiled for the LC and it failed.
Arduino: 1.8.8 (Windows 10), TD: 1.45, Board: "Teensy LC, Serial, 48 MHz, Smallest Code, US English"
C:\Program Files (x86)\Alibtemp\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Alibtemp\Arduino\hardware -hardware C:\Users\Michael\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Alibtemp\Arduino\tools-builder -tools C:\Program Files (x86)\Alibtemp\Arduino\hardware\tools\avr -tools C:\Users\Michael\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Alibtemp\Arduino\libraries -libraries C:\Users\Michael\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=osstd,keys=en-us -ide-version=10808 -build-path C:\Users\Michael\AppData\Local\Temp\arduino_build_324976 -warnings=default -verbose C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\examples\Blink\Blink.ino
C:\Program Files (x86)\Alibtemp\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Alibtemp\Arduino\hardware -hardware C:\Users\Michael\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Alibtemp\Arduino\tools-builder -tools C:\Program Files (x86)\Alibtemp\Arduino\hardware\tools\avr -tools C:\Users\Michael\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Alibtemp\Arduino\libraries -libraries C:\Users\Michael\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=osstd,keys=en-us -ide-version=10808 -build-path C:\Users\Michael\AppData\Local\Temp\arduino_build_324976 -warnings=default -verbose C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\examples\Blink\Blink.ino
Using board 'teensyLC' from platform in folder: C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\sketch\\Blink.ino.cpp" -o nul
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\libraries\\TeensyThreads" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\sketch\\Blink.ino.cpp" -o nul
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\libraries\\TeensyThreads" "C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\libraries\\TeensyThreads\\TeensyThreads-asm.S" -o nul
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\libraries\\TeensyThreads" "C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\libraries\\TeensyThreads\\TeensyThreads.cpp" -o nul
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\libraries\\TeensyThreads" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976" "C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/pch/Arduino.h" -o "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/pch/Arduino.h.gch"
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/pch" "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\libraries\\TeensyThreads" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling library "TeensyThreads"
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\libraries\\TeensyThreads" "C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\libraries\\TeensyThreads\\TeensyThreads-asm.S" -o "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\libraries\\TeensyThreads\\TeensyThreads-asm.S.o"
C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\TeensyThreads-asm.S: Assembler messages:
C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\TeensyThreads-asm.S:104: Error: cannot honor width suffix -- `cmp lr,#0xFFFFFFF1'
C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\TeensyThreads-asm.S:106: Error: cannot honor width suffix -- `cmp lr,#0xFFFFFFE1'
C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\TeensyThreads-asm.S:116: Error: lo register required -- `sub r1,#1'
C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\TeensyThreads-asm.S:136: Error: cannot honor width suffix -- `stmia r0!,{r4-r11,lr}'
C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\TeensyThreads-asm.S:161: Error: cannot honor width suffix -- `ldmia r0!,{r4-r11,lr}'
C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\TeensyThreads-asm.S:171: Error: cannot honor width suffix -- `and lr,lr,#0x10'
C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\TeensyThreads-asm.S:172: Error: cannot honor width suffix -- `orr lr,lr,#0xFFFFFFE9'
C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\TeensyThreads-asm.S:181: Error: cannot honor width suffix -- `orr lr,lr,#0b100'
Using library TeensyThreads at version 1.0 in folder: C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads
Error compiling for board Teensy LC.
// same file compiled for "3.2"
C:\Program Files (x86)\Alibtemp\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Alibtemp\Arduino\hardware -hardware C:\Users\Michael\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Alibtemp\Arduino\tools-builder -tools C:\Program Files (x86)\Alibtemp\Arduino\hardware\tools\avr -tools C:\Users\Michael\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Alibtemp\Arduino\libraries -libraries C:\Users\Michael\Documents\Arduino\libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=96,opt=o2std,keys=en-us -ide-version=10808 -build-path C:\Users\Michael\AppData\Local\Temp\arduino_build_324976 -warnings=default -verbose C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\examples\Blink\Blink.ino
C:\Program Files (x86)\Alibtemp\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Alibtemp\Arduino\hardware -hardware C:\Users\Michael\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Alibtemp\Arduino\tools-builder -tools C:\Program Files (x86)\Alibtemp\Arduino\hardware\tools\avr -tools C:\Users\Michael\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Alibtemp\Arduino\libraries -libraries C:\Users\Michael\Documents\Arduino\libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=96,opt=o2std,keys=en-us -ide-version=10808 -build-path C:\Users\Michael\AppData\Local\Temp\arduino_build_324976 -warnings=default -verbose C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\examples\Blink\Blink.ino
Using board 'teensy31' from platform in folder: C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\sketch\\Blink.ino.cpp" -o nul
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\libraries\\TeensyThreads" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\sketch\\Blink.ino.cpp" -o nul
Using cached library dependencies for file: C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\TeensyThreads-asm.S
Using cached library dependencies for file: C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy\avr\libraries\TeensyThreads\TeensyThreads.cpp
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\libraries\\TeensyThreads" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976" "C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/pch/Arduino.h" -o "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\pch\Arduino.h.gch
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=145 -DARDUINO=10808 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/pch" "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\libraries\\TeensyThreads" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\sketch\\Blink.ino.cpp.o"
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\libraries\TeensyThreads\TeensyThreads-asm.S.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\libraries\TeensyThreads\TeensyThreads.cpp.o
Compiling core...
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\memset.S.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\memcpy-armv7m.S.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\eeprom.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_desc.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\serial6.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\touch.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\serial1.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\serial6_lpuart.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\serial2.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\pins_teensy.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_serial.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_mtp.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\keylayouts.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\ser_print.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\analog.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\nonstd.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\mk20dx128.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_joystick.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\math_helper.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_midi.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_keyboard.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_mouse.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_mem.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_dev.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_touch.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_rawhid.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\serial4.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\serial3.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\serial5.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_seremu.c.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\Stream.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\WString.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\HardwareSerial5.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_flightsim.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\AudioStream.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\avr_emulation.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\new.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\DMAChannel.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\yield.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\main.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\EventResponder.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\Print.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_inst.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\HardwareSerial6.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\HardwareSerial4.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\IntervalTimer.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\usb_audio.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\Tone.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\WMath.cpp.o
Using previously compiled file: C:\Users\Michael\AppData\Local\Temp\arduino_build_324976\core\core.a
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1555663566 "-TC:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3/mk20dx256.ld" -lstdc++ -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/Blink.ino.elf" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\sketch\\Blink.ino.cpp.o" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\libraries\\TeensyThreads\\TeensyThreads-asm.S.o" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976\\libraries\\TeensyThreads\\TeensyThreads.cpp.o" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/core\\core.a" "-LC:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976" -larm_cortexM4l_math -lm
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/Blink.ino.elf" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/Blink.ino.eep"
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/Blink.ino.elf" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/Blink.ino.hex"
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/Blink.ino.lst" "C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/Blink.ino.elf"
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/Blink.ino.sym" "C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/Blink.ino.elf"
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/teensy_post_compile" -file=Blink.ino "-path=C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976" "-tools=C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/" -board=TEENSY31
Opening Teensy Loader...
"C:\\Program Files (x86)\\Alibtemp\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-size" -A "C:\\Users\\Michael\\AppData\\Local\\Temp\\arduino_build_324976/Blink.ino.elf"
Sketch uses 14196 bytes (5%) of program storage space. Maximum is 262144 bytes.
Global variables use 4672 bytes (7%) of dynamic memory, leaving 60864 bytes for local variables. Maximum is 65536 bytes.
C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy/../tools/teensy_post_compile -file=Blink.ino -path=C:\Users\Michael\AppData\Local\Temp\arduino_build_324976 -tools=C:\Program Files (x86)\Alibtemp\Arduino\hardware\teensy/../tools -board=TEENSY31 -reboot -port=COM6 -portlabel=(null) -portprotocol=(null)
TIA
