Results 1 to 3 of 3
Thread: [Teensy 3.2] Converting binary array to ascii for Hardware Serial Transmission?
    Oct 2017
    14
    Hi all,
    I am working on building an exploded 12-bit ADC for teaching purposes. I have the entire project working and am hitting a tiny brick wall due to my lack of CompSci knowledge.
    My (external) "system" clock is 1kHz. I am using 12 digital pins on my Teensy to parallel-read my 12 binary values into an array. I need to then send these binary values to my data processing unit/computer via Serial communication.
    The problem I am having is that my previous function used to convert my binary array to decimal seems to be too slow and does not fully convert my values before the next clockpulse. Though, this is only a theory, and could be just an error with my coding, because I should get 4095 unique (integer) values, but I am only getting up to 256 (integer). If I comment-out the Serial-Monitor "Write MasterCount" function of my code and instead merely read-out my binary array to the Serial monitor, I see that I am indeed reaching values well-over ~3000 (decimal).
    You will see below I tried to add a check state and only print one of every 1000 values (1 value per second) and I am still getting incorrect values topping-out somewhere around 230-250 (decimal).
    My full code:
    #define HWSERIAL Serial1
    const int numBits = 12;             //Number of bits in ADC (resolution)
    const int comparatorPin = 22;       //Pin number of comparator out
    const int clockPin = 23;            //Pin number of external clock (square wave) input; expecting clock with 50% duty-cycle
    const int enablePin = 19;
    const int upDownPin = 18;
    const int loadPin = 17;
    volatile bool clockState = 0;       //Is clock high or low?
    volatile bool isSameVal = false;    //Is the value of the master count the same value as last cycle?
    volatile bool upDown = 0;     //Init up/down count to up (being low state, or false)
    volatile byte loopCounter = 0;  //Keep track of number of clock pulses / loop iteration
    byte masterBinCountIn[12];     //Array to store binary value of the master count
    byte inputPins[12];         //Array to store the numbers associated with the output pin numbers
    short maxValue = 4096;           //Initialize max counter value to zero
    bool comparatorState = 0;   //Init comparator state
    short masterCount = 0;       //Init master Count
    bool inhibited = false;   //Define whether or not counters are told to hold the count for current iteration
      Serial.begin(115200);       //Begin Serial transmission (for troubleshooting)
      HWSERIAL.begin(115200, SERIAL_8N1);
      delay(3000);
      defineInPins();  //Assign pin numbers for output pins
      pinMode(comparatorPin, INPUT);   //Comparator Pin
      pinMode(clockPin, INPUT);     //Clock-in pin
      pinMode(enablePin, OUTPUT);     //Default to up-count (both low)
      pinMode(upDownPin, OUTPUT);
      digitalWrite(enablePin, LOW);
      digitalWrite(upDownPin, LOW);
      presetZero();
    /* THIS FUNCTION IS FOR TROUBLESHOOTING!!
       binaryToPins();
       for(int c = 0; c < 12; c++) {
          Serial.println(masterBinCountIn[c]);
      attachInterrupt(clockPin, doOnClock, RISING);   //When clock is on a positive-edge execute doOnClock function
     * THIS FUNCTION DEFINES THE DIGITAL INPUT PINS ON THE TEENSY 3.2
    void defineInPins() {   //Assign pin numbers to parallel binary out: Teensy 3.2 pin #2 --> #14
      for(byte i = 2; i < (numBits + 2); i++) {
        inputPins[(i-2)] = {i};      //Assign current pin this value
        pinMode(i, INPUT);          //Define pins as outputs
        //Serial.print(inputPins[(i-2)]);
     * THIS FUNCTION CONTROLS ACTIONS TAKEN ON RISING-EDGE CLOCK PULSE
    void doOnClock() {
      binaryToPins();                    //Get current binary count
      masterCount = convertBinToDec();   //Convert to decimal value
      comparatorState = digitalRead(comparatorPin);   //Check comparator state
      //Serial.println(masterCount);
      //HWSERIAL.println(masterCount);      //Send the decimal value to external Serial device (pins: #0, #1)
      if(comparatorState == 1) {                //Check if comparator is HIGH
          //if(masterCount == (maxValue - 1)) {   //Check if current count value is at "ceiling" (max)
          if(masterCount == 4095) {
            upDown = 1;
            toggleClk(upDown);           //Control counter IC
          else {                  //Else, increment count up
            upDown = 0;
      else if(comparatorState == 0) {       //Check if comparator is LOW
          if(masterCount == 0) {            //Check if current count value is at "floor"
            upDown = 0;
          else {
            upDown = 1;
      if(loopCounter < 1000)
        loopCounter++;
        loopCounter = 0;
     * THIS FUNCTION CONVERTS THE 12-BIT BINARY SEQUENCE STORED IN ARRAY TO DECIMAL VALUE
    byte convertBinToDec() {
      byte result = 0;
      for(int i = 0; i < numBits; i++) {
        result |= masterBinCountIn[(11-i)] << i;
      return result;
     * THIS FUNCTION READS THE 12-BIT BINARY VALUE FROM TEENSY 3.2 PINS #2 --> #13
    void binaryToPins() {
      for(int e = 0; e < numBits; e++) {
        masterBinCountIn[(11-e)] = digitalRead(inputPins[e]);   //Read our master binary value to output pins
        //Serial.print(masterBinCountIn[e]);
      //Serial.println();
     * THIS FUNCTION TOGGLES COUNTING UP/DOWN WITH THE 74LS191N COUNTER
    void toggleClk(bool hiOrLo) {
      if(hiOrLo == 1) {
        if(isSameVal == false) {
          //Count down from up
          digitalWrite(enablePin, HIGH);
          delayMicroseconds(10);
          digitalWrite(upDownPin, HIGH);
          delayMicroseconds(5);
          //Serial.println("down count");
          isSameVal = true;
        else {
          //Do nothing
      else if(hiOrLo == 0) {
        //Count up from down
        if(isSameVal == true) {
          //Serial.println("up count");
          isSameVal = false;
     * THIS FUNCTION PRESETS THE COUNTERS TO ZERO!
    void presetZero() {
       pinMode(loadPin, OUTPUT);
       digitalWrite(loadPin, HIGH);
       delay(1);
       digitalWrite(loadPin, LOW);
       delay(1);
    1,069
      byte result = 0;
      return result;
    numBits is defined to be 12. A byte can only hold 8 bits.
    Pete
    Oct 2017
    14
      byte result = 0;
      return result;
    Pete
    Thank you sir! I needed that second pair of eyes on my code. I've been working with this software for almost 2 months now and still did not notice that error. Seems to have fixed my issue!
