Results 1 to 2 of 2
Thread: Teensy 3.6 LED Pin
    Teensy 3.6 LED Pin
    Hi All,
    This might be already answered or available in forum.
    Quesitons;
    1. Can I use Pin 13 that's tied to LED for other digital functions? If so can I still use LED functionality?
    2. Otherwise can I reassign LED pin to another pin via PORT pin assignements and make use of Pin 13?
    The context here is I am working on PCB routing and its easier and I needed to access a digital PIN. The Pin 13 is pretty convinient, other digital pins on I have already used other digital pins on that side and will make my life easier if I don't have to go to other side of board.
    Thank you all.
    8,314
    Pin 13 has the LED hardwired on it so it cannot be moved or used independent of that pin on the processor - but that pin has normal digital function - the LED will just blink based on the state of the pin - with whatever minor electrical effects that may have on some signals.
