Results 1 to 4 of 4
Thread: How to set T3.6 clock speed higher than 240?
    152
    I am driving led panels with SmartMatrix and Teensy 3.6.
    I run at 240 MHz oversample.
    With 64 x 64 panels, it works flawlessly.
    With 128 by 64 I get crashes between 1 and 10 minutes.
    I suspect it may be the Clock/DMA rate needs to be boosted.
    I saw some discussion of overclocking even higher than 240 Mhz.
    Can anyone direct me specifically to the values I need to change to try this > 240 Hz overclocking?
    Thanks,
    Richard
    8,314
    In your TeensyDuino installed boards.txt there are two commented lines.
    Close the IDE - edit these two lines and open and there will be a new menu option for speed:
    teensy36.menu.speed.256=256 MHz (overclock)
    teensy36.menu.speed.256.build.fcpu=256000000
    152
    Brilliant. Thanks.
    8,314
    The Brilliance comes from FrankB ... I just remember how to enable it
