Results 1 to 4 of 4
Thread: Teesnsy Processor - who else uses it ?
    the Teensy 3.2 uses a MK20DX256VLH7 Cortex-M4, is this processor fitted to other boards ?
    does this mean another board using this processor can be programmed using using the Arduino IDE
    2,202
    Quote Originally Posted by Gadget999 View Post
    if you mean: can one use Teensyduino SW to program any MK20DX256VLH7 that is not a T3.2, the answer is most likely: it depends
    to use Teensyduino you need a board that comes with the PJRC provided bootloader chip.
    there are some custom Teensies (i.e. Teensy compatible) boards around
    ok - so i could buy a board that uses a similar chip and replace the processor with a PJRC chip instead
    I reckon PJRC could do well if they released a development board with built in connectors, audio, bluetooth etc
    20,086
    It means you need a board built with this chip, in addition to the MK20DX256VLH7.
    https://www.pjrc.com/store/ic_mkl02.html
