When trying to verify this code in Arduino, I am getting the following error messages:
In file included from C:\Users\Kaylen\AppData\Local\Temp\arduino_modified_sketch_411269\threeservos.ino:3:0:
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:80:0: warning: "MIN_PULSE_WIDTH" redefined
#define MIN_PULSE_WIDTH 544 // the shortest pulse sent to a servo
In file included from C:\Users\Kaylen\AppData\Local\Temp\arduino_modified_sketch_411269\threeservos.ino:1:0:
C:\Users\Kaylen\Documents\Arduino\libraries\ServoTimer2-master/ServoTimer2.h:79:0: note: this is the location of the previous definition
#define MIN_PULSE_WIDTH 750 // the shortest pulse sent to a servo
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:81:0: warning: "MAX_PULSE_WIDTH" redefined
#define MAX_PULSE_WIDTH 2400 // the longest pulse sent to a servo
C:\Users\Kaylen\Documents\Arduino\libraries\ServoTimer2-master/ServoTimer2.h:81:0: note: this is the location of the previous definition
#define MAX_PULSE_WIDTH 2250 // the longest pulse sent to a servo
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:95:3: error: conflicting declaration 'typedef struct ServoPin_t ServoPin_t'
} ServoPin_t ;
C:\Users\Kaylen\Documents\Arduino\libraries\ServoTimer2-master/ServoTimer2.h:95:6: note: previous declaration as 'typedef struct ServoPin_t ServoPin_t'
} ServoPin_t ;
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:100:3: error: conflicting declaration 'typedef struct servo_t servo_t'
} servo_t;
C:\Users\Kaylen\Documents\Arduino\libraries\ServoTimer2-master/ServoTimer2.h:107:4: note: previous declaration as 'typedef struct servo_t servo_t'
} servo_t;
exit status 1
Error compiling for board Arduino/Genuino Uno.
The code is shown below
#include <ServoTimer2.h> // the servo library
#include <VirtualWire.h>
#include <Servo.h>
// Declare Sevor Objects
ServoTimer2 finger1;
ServoTimer2 finger2;
ServoTimer2 finger3;
ServoTimer2 finger4;
ServoTimer2 finger5;
// Declare signal inputs
int flex_signal1;
int flex_signal2;
int flex_signal3;
int flex_signal4;
int flex_signal5;
#define MAX_PULSE_WIDTH 2050 // the longest pulse sent to a servo
// Callibrated MIN MAX valuse for the flex resistors
int F1MIN=545;
int F1MAX=635;
int F2MIN=600;
int F2MAX=775;
int F3MIN=750;
int F3MAX=875;
int F4MIN=825;
int F4MAX=945;
int F5MIN=915;
int F5MAX=1000;
//Setup
finger1.attach(9);
finger2.attach(10);
finger3.attach(11);
finger4.attach(12);
finger5.attach(13);
vw_set_ptt_inverted(true); // Required for RF Link module
vw_setup(400); // 400 Bits per sec
vw_set_tx_pin(12); // pin 12 is used as the transmit data out into the TX Link module
vw_set_rx_pin(11); // pin 11 is used as the transmit data out into the TX Link
vw_rx_start(); // Start the receiver
// Buffer that holds the data received
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
// check to see if anything has been received
if (vw_get_message(buf, &buflen)) {
// Data trimming
flex_signal1 = constrain(buf[0], F1MIN, F1MAX);
flex_signal2 = constrain(buf[2], F2MIN, F2MAX);
flex_signal3 = constrain(buf[4], F3MIN, F3MAX);
flex_signal4 = constrain(buf[6], F4MIN, F4MAX);
flex_signal5 = constrain(buf[8], F5MIN, F5MAX);
// Maps the values from the flex resistor to control signals of the motor
int controlFinger1 = map(flex_signal1, F1MIN, F1MAX, 180, 0);
int controlFinger2 = map(flex_signal2, F2MIN, F2MAX, 180, 0);
int controlFinger3 = map(flex_signal3, F3MIN, F3MAX, 180, 0);
int controlFinger4 = map(flex_signal4, F4MIN, F4MAX, 180, 0);
int controlFinger5 = map(flex_signal5, F5MIN, F5MAX, 180, 0);
finger1.write(controlFinger1);
finger2.write(controlFinger2);
finger3.write(controlFinger3);
finger4.write(controlFinger4);
finger5.write(controlFinger5);
//Monitor values through serial monitos
Serial.print("flex1: ");
Serial.print(flex_signal1);
Serial.print("flex2: ");
Serial.print(flex_signal2);
Serial.print("flex3: ");
Serial.print(flex_signal3);
Serial.print("flex4: ");
Serial.print(flex_signal4);
Serial.print("flex5: ");
Serial.print(flex_signal5);
Serial.print(" motor1: ");
Serial.print(controlFinger1);
Serial.print(" motor2: ");
Serial.print(controlFinger2);
Serial.print(" motor3: ");
Serial.print(controlFinger3);
Serial.print(" motor4: ");
Serial.print(controlFinger4);
Serial.print(" motor5: ");
Serial.print(controlFinger5);
} ServoPin_t ;
} ServoPin_t ;
} servo_t;
} servo_t;
exit status 1
#include <Servo.h>
int flex_signal1;
int flex_signal2;
int flex_signal3;
int flex_signal4;
int flex_signal5;
int F1MIN=545;
int F1MAX=635;
int F2MIN=600;
int F2MAX=775;
int F3MIN=750;
int F3MAX=875;
int F4MIN=825;
int F4MAX=945;
int F5MIN=915;
int F5MAX=1000;
//Setup
finger1.attach(9);
finger2.attach(10);
finger3.attach(11);
finger4.attach(12);
finger5.attach(13);
// Data trimming
