I just registered and received my first teensy (3.2)
I tested a few potentimeters and sliders which are working fine with the teensy but my project would require a 2 axis hall sensor that I took from a joystick thrustmaster T16000.
Here is the sensor in question : http://zupimages.net/viewer.php?id=19/18/sknj.jpg
I tried to understand how this component works and found this link : https://www.sensorsmag.com/components/angular-position-sensing-2-axis-hall-ics
I guess the figure 3.A from this link could match my component since there is 5 branches on that schematic and I have 5 wires but that's about where my knowledge of electronic ends...
I am really not sure how to connect to the teensy and if I could damage something ... Sensor<Teensy<usb Hub<Computer
From this picture, could you say what color is Ground, Sin,Ref volt(what is this??),Cos and common?
If not, is it possible to get those informations with a voltmeter and how?
The schematic is referring to +5V, is it sure the component I want to use will require 5V? Can this voltage be send by a teensy 3.2 I see 3.3V everywhere except for Vin (3.6 to 6.0 volts, not sure what that is)
The fact is that I have no idea how to connect this to the teensy neither do I know how to code it..
If someone can help me on this, it would be great...
FYI, I only need to receive 1 axis, the second won't be used but I guess I will still have to connect it.
Thanks a lot for your help.
Mike
Mike
