Results 1 to 4 of 4
Thread: Listening through headphones while recording
    I'm trying to listen to what I am recording while it's being recorded. Is this possible? If so, how do I do this? I attached my code
    #include <Bounce.h>
    #include <SerialFlash.h>
    #include <XPT2046_Touchscreen.h>
    #include <ILI9341_t3.h>
    AudioInputI2S            i2s2;
    AudioAnalyzePeak         peak1;
    AudioAnalyzePeak         peak2;
    AudioRecordQueue         queue1;
    AudioRecordQueue         queue2;
    AudioPlaySdRaw           playRaw1;
    // AudioPlaySdRaw           playRaw2;
    AudioOutputI2S           i2s1;
    AudioConnection          patchCord1(i2s2, 0, queue1, 0);
    AudioConnection          patchCord2(i2s2, 0, peak1, 0);
    AudioConnection          patchCord3(i2s2, 1, queue2, 0);
    AudioConnection          patchCord4(i2s2, 1, peak2, 0);
    AudioConnection          patchCord5(playRaw1, 0, i2s1, 0);
    AudioConnection          patchCord6(playRaw1, 1, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;
    #define TS_MINX 150
    #define TS_MINY 130
    #define TS_MAXX 3800
    #define TS_MAXY 4000
    // The STMPE610 uses hardware SPI on the shield, and #8
    #define STMPE_CS 8
    // The display also uses hardware SPI, plus #9 & #10
    #define TFT_RST 255
    #define TFT_MOSI 7
    #define TFT_SCLK 14
    #define TFT_MISO 12
    // For the Adafruit shield, these are the default.
    #define TFT_DC 20
    #define TFT_CS 21
    // which input on the audio shield will be used?
    //const int myInput = AUDIO_INPUT_MIC;
    #define SDCARD_CS_PIN    10
    #define SDCARD_MOSI_PIN  7
    #define SDCARD_SCK_PIN   14
    // PCB stuff
    #define PCB_POT_1_CS     26
    #define PCB_POT_2_CS     31
    #define SPICLOCK         30000000
    // Remember which mode we're doing
    int recording = 0;  // 0=stopped, 1=recording, 2=playing
    int playing = 0;
    int play_tracks[2];
    // The file where data is recorded
    File frec, frec2;
    int x;
    int y;
    int counter;
    char curr_menu = 'R';
    int was_touched_flag = 0;
    int can_scroll_down = 0;
    int can_scroll_up = 0;
    char* files[26];
    int pots[2];
    int num_files = 0, scroll_offset = 0;
    ILI9341_t3 tft(TFT_CS, TFT_DC, 255, TFT_MOSI, TFT_SCLK, TFT_MISO);
    XPT2046_Touchscreen ts(STMPE_CS);
    int tracks[4];
    int pot_vals[48] = {4099, 5895, 4360, 3080, 2312, 1, 4374, 6954, 2837, 1550, 2328, 8806, 3374, 1041, 2086, 2614, 2622, 3419, 2376, 266, 1066, 1339, 1616, 1626, 1092, 276, 1388, 1402, 1134, 861, 582, 296, 900, 1222, 935, 637, 327, 670, 689, 356, 736, 382, 398, 415, 434, 456, 480, 508};
      pinMode(32,OUTPUT);
      digitalWrite(32, HIGH);
      play_tracks[0] = 0;
      play_tracks[1] = 0;
      tracks[0] = 0;
      tracks[1] = 0;
      tracks[2] = 0;
      tracks[3] = 0;
      while(!Serial); // Wait for the serial to work
      tft.begin();
      if (!ts.begin()) {
        Serial.print("TS not connected.");
        while (1);
      display_top();
      display_record_menu();
      AudioMemory(60);
      sgtl5000_1.enable();
      // Initialize the SD card
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
        while (1) {
      pinMode(A17,INPUT);
      pinMode(A18,INPUT);
      pots[0] = analogRead(A17);
    //  pots[1] = analogRead(A18);
      sgtl5000_1.volume(pots[0] / 21);
    //  Serial.println(analogRead(A17));
    //  delay(2000);
      TS_Point p = ts.getPoint();
        if (!ts.bufferEmpty() && ts.touched()) {
            delay(150);
            //Serial.print(p.x); Serial.println(p.y);
            flag_resp(p.x,p.y);
      // If we're playing or recording, carry on...
      if (recording) {
        continueRecording();
      if (playing) {
        continuePlaying();
      int temp = 0; //abs(analogRead(A17) - pots[0]);
      if (temp > 15) {
        //Serial.println(temp); Serial.println(pots[0]);
      // when using a microphone, continuously adjust gain
      if (myInput == AUDIO_INPUT_MIC) adjustMicLevel();
    void startRecording() {
      Serial.println("startRecording");
      //check for flag if file 1 or file 2 has been pressed
      Serial.println(tracks[0]);
      Serial.println(tracks[1]);
      if (tracks[0]){
      if (SD.exists("RECORD.RAW")) {
        // The SD library writes new data to the end of the
        // file, so to start a new recording, the old file
        // must be deleted before new data is written.
        SD.remove("RECORD.RAW");
         frec = SD.open("RECORD.RAW", FILE_WRITE);
         if (frec) {
          queue1.begin();
          recording = 1;
           tft.fillRoundRect(105, 45, 120, 60, 5, ILI9341_RED);
            tft.setCursor(135, 65);
            tft.println("SD CARD ERR");
            delayMicroseconds(2000000);
            display_record_menu();  }
      if (tracks[1]){
      if (SD.exists("RECORD1.RAW")) {
        SD.remove("RECORD1.RAW");
         frec2 = SD.open("RECORD1.RAW", FILE_WRITE);
         if (frec2) {
          Serial.println("in Record1");
          queue2.begin();
          recording = 1;
          Serial.println("hey");
    void continueRecording() {
      //if first track is enabled
      if (tracks[0]){
        if (queue1.available() >= 2) {
          byte buffer[512];
          memcpy(buffer, queue1.readBuffer(), 256);
          queue1.freeBuffer();
          memcpy(buffer+256, queue1.readBuffer(), 256);
          // write all 512 bytes to the SD card
          elapsedMicros usec = 0;
          frec.write(buffer, 512);
      //If 2nd track is enabled
      if (tracks[1]){
        //Serial.println("ContinueRecording for track 2");
        if (queue2.available() >= 2) {
        byte buffer[512];
        memcpy(buffer, queue2.readBuffer(), 256);
        queue2.freeBuffer();
        memcpy(buffer+256, queue2.readBuffer(), 256);
        frec2.write(buffer, 512);
    void stopRecording() {
      Serial.println("stopRecording");
      queue1.end();
      queue2.end();
      if (recording) {
        Serial.println("Entered if");
        if (tracks[0]){
          frec.write((byte*)queue1.readBuffer(), 256);
        frec.close();
        if (tracks[1]){
         Serial.println("Ending recording");
        while (queue2.available() > 0) {
          frec.write((byte*)queue2.readBuffer(), 256);
        frec2.close();
      recording = 0;
    void startPlaying() {
      Serial.println("startPlaying");
      if (play_tracks[0])
        playRaw1.play("RECORD.RAW");
      if (play_tracks[1])
        playRaw1.play("RECORD1.RAW");
      playing = 1;
    void continuePlaying() {
      if (!playRaw1.isPlaying()) {
        playRaw1.stop();
        playing = 0;
    void stopPlaying() {
      Serial.println("stopPlaying");
      if (playing) playRaw1.stop();
      playing = 0;
    maybe just patch the i2s2 and the playRaw into an AudioMixer4 and then patch its outputs into the i2s1..?
    if that just works, you could could set the gain of the mixer channels that the i2s2 is patched into as "monitor levels"
    Quote Originally Posted by wXch0perator View Post
    Thanks! This does in fact let me listen to the input directly, but I am not able to record now. I didn't change any of my record code. Could there be some type of issue with using the i2s connection to redirect the signal to both the buffer queue, and then to audiooutputi2s.
    #include <Bounce.h>
    AudioInputI2S            i2s2;
    AudioMixer4              Channel1_mixer;
    AudioMixer4              Channel2_mixer;
    AudioMixer4              Channel12_mixer;
    AudioMixer4              Channel22_mixer;
    AudioConnection          patchCord1(i2s2, 0, Channel1_mixer, 0);
    AudioConnection          patchCord12(i2s2, 0, Channel12_mixer, 0);
    //AudioConnection          patchCord1(i2s2, 0, queue1, 0);
    AudioConnection          patchCord3(i2s2, 1, Channel2_mixer, 1);
    AudioConnection          patchCord32(i2s2, 1, Channel22_mixer, 1);
    //AudioConnection          patchCord3(i2s2, 1, queue2, 0);
    AudioConnection          patchCord7(Channel1_mixer, 0, queue1, 0);
    AudioConnection          patchCord8(Channel2_mixer, 1, queue2, 0);
    AudioConnection          patchCord9(Channel22_mixer, 1, i2s1, 1);
    AudioConnection          patchCord10(Channel12_mixer, 0, i2s1, 0);
    #define TS_MINX 150
    #define TS_MINY 130
    #define STMPE_CS 8
    #define TFT_RST 255
    #define TFT_MOSI 7
    #define TFT_SCLK 14
    #define TFT_MISO 12
    #define TFT_DC 20
    #define TFT_CS 21
    // PCB stuff
    int playing = 0;
    int play_tracks[2];
    File frec, frec2;
    int x;
    int y;
    int counter;
    char* files[26];
    int pots[2];
    int tracks[4];
      Channel12_mixer.gain(0,1);
      Channel22_mixer.gain(1,0);
      pinMode(32,OUTPUT);
      play_tracks[0] = 0;
      play_tracks[1] = 0;
      tracks[0] = 0;
      tracks[1] = 0;
      tracks[2] = 0;
      tracks[3] = 0;
      tft.begin();
      if (!ts.begin()) {
        while (1);
      display_top();
      AudioMemory(60);
        while (1) {
      pinMode(A17,INPUT);
      pinMode(A18,INPUT);
      pinMode(A17,INPUT);
      pinMode(A18,INPUT);
      Serial.println(pots[0] / 1000.0);
      Serial.println(pots[1] / 1000.0);
      Channel1_mixer.gain(0, pots[0]);
      Channel2_mixer.gain(1, pots[1]);
      Channel12_mixer.gain(0, pots[0]);
      Channel22_mixer.gain(1, pots[1]);
    //  delay(2000);
            delay(150);
            flag_resp(p.x,p.y);
      if (abs(analogRead(A17) - pots[0]) > 15 || abs(analogRead(A18) - pots[1]) > 15) {
        //pots[1] = analogRead(A18);
        Channel1_mixer.gain(0, pots[0] / 1000.0);
        Channel2_mixer.gain(1, pots[0] / 1000.0);
        Channel12_mixer.gain(0, pots[0] / 1000.0);
        Channel22_mixer.gain(1, pots[0] / 1000.0);
      if (recording) {
      if (playing) {
        continuePlaying();
      if (temp > 15) {
      Serial.println("startRecording");s
      if (tracks[0]){
         if (frec) {
          queue1.begin();
          recording = 1;
      if (tracks[1]){
         if (frec2) {
          queue2.begin();
          recording = 1;
      if (tracks[0]){
          byte buffer[512];
      if (tracks[1]){
        byte buffer[512];
      queue1.end();
      queue2.end();
      if (recording) {
        if (tracks[0]){
        frec.close();
        if (tracks[1]){
        frec2.close();
      recording = 0;
      if (play_tracks[0])
      if (play_tracks[1])
      playing = 1;
        playRaw1.stop();
        playing = 0;
      playing = 0;
    I don't have inputs set up on my teensy, so i can't run and debug your code. i would try making a simpler sketch that only streams one channel of audio from input to output via one mixer, set their gains to reasonable defaults, and if that works, then try routing the input to a queue and see if it still works. then if that works, add the recording memcopy / sd card code.
