Results 1 to 20 of 20
Thread: New Teensy user
    Apr 2019
    15
    New Teensy user
    howdy all!
    I'm new to the Teensy, but I've used a few flavors of Arduino for about 3.5 years now.
    I've noticed there are some differences. =)
    what would be really helpful (and I haven't found yet) is a web page or something that has code examples for how to do stuff on Teensy, esp things that are different from the Arduino.
    I'm using Teensyduino on the Arduino IDE. I have found the examples there, which are great, just looking for something to cover the basics, perhaps a comparison where there are differences, like Interrupts.
    Any suggestions? Anything I'm missing?
    Feb 2014
    Colmar, France
    2,535
    https://www.pjrc.com/teensy/teensyduino.html and then all the items in the Teensyduino submenu in the left sidebar...
    But most things are made to preserve a maximum of compatibility with Arduino out of the box. So, attachInterrupt(pin,MODE) will work on Teensy without problems, although the source code behind that function will be very different from the Arduino version, but the users don't have to care.
    Only a few Arduino things like addressing the AVR hardware (timer, gpio and interrupt) registers directly will naturally fail on the ARM processors which are completely different inside. For these, PJRC has published the reference manuals of the different Teensy CPUs on their website.
    20,591
    Here's a table with a hardware comparison of the 6 current Teensy models.
    https://www.pjrc.com/teensy/techspecs.html
    Some docs on the Teensy specific features are on this part of the site:
    https://www.pjrc.com/teensy/td_timing.html
    Usually we do much better on this forum if you have a more specific question? Or even if you can just talk about what sort of project you want to build, that context really helps inspire advice & conversation.
    Apr 2017
    187
    Welcome to the club. I too switched from Arduino to Teensy and have been wildly happy with that move
    1. better product
    2. better help from the Forum (and friendlier)
    I have found nearly 100% compatibility between Arduino and Teensy. Stuff like serial definition, PWM assignment and a few other code differences exist, but really not that hard to change. Even if your program had to be a total rewrite--which can't happen, it's well worth the change.
    There are some very helpful and talented people on this forum, so feel free to ask for help.
    Apr 2019
    15
    I've had generally good luck, but a couple libs here and there won't compile, like Pixy2 (pixy is ok), or PFC8574T I2C LCD interface.
    Qs:
    1. for INT, do I need to do this? seems to be working, but not needed for Arduino:
    //To use interrupts, you must include the AVR interrupt header
    #include <avr/io.h>
    #include <avr/interrupt.h>
    2. I2C, wd like to access the extra ports.
    it would appear I need to use this below, any other ways to do it?
    https://forum.pjrc.com/threads/21680...ry-for-Teensy3
    Apr 2019
    15
    Q: this ain't workin:
    #define shutDownPinRC 33 // for RC switch
    this always returns zero:
    digitalRead(shutDownPinRC);
    I can measure the pin voltage with a DMM, I can see it go high (3.3 V) or low (0 V).
    is there something special about pin 33?
    I'll triple check my code.
    Apr 2019
    15
    code below:
    // OpenLCD is an LCD with Serial/I2C/SPI interfaces fr SparkFun Electronics
    int lineNum, charNum;
    int lineNumMap[4] = {0,64,20,84}; // to map line numbers
    // LED pins
    #define LED_RED 24 // turn on if obstacle detected (OBS)
    #define LED_YEL 25 // turn on if at wp, turning to new course
    #define LED_GRN 26 // turn on if cone detected (cone)
    #define LED_BLU 27 // turn on if.... ?
    #define PN2222_PIN 28 // controlled by deadman, drive high to turn on PN2222, enable 555, siren
    int success = 0; // 1 = success/done
    // debug
    byte debug = 1; // 1 = turn on debug code. 2 = turn on timing code
    if (debug >= 1) {
    Serial.begin(115200); // no line ending in terminal
    delay(1000); // teensy needs time to get ready
    Serial1.begin(9600); // Begin communication with Serial1 for OpenLCD
    LCD_clear(); // forces the cursor to the beginning of the display
    // setup pins for various IO functions
    pinMode(LED_RED, OUTPUT); // pin 38
    pinMode(LED_YEL, OUTPUT); // pin 40
    pinMode(LED_GRN, OUTPUT); // pin 42
    pinMode(LED_BLU, OUTPUT); // pin 42
    // LED test
    digitalWrite(LED_RED, HIGH); // OBS det
    digitalWrite(LED_YEL, HIGH); // wp arrival, turning to new course
    digitalWrite(LED_GRN, HIGH); // Cone det
    digitalWrite(LED_BLU, HIGH); // Cone det
    delay(2000);
    digitalWrite(LED_RED, LOW); // OBS det
    digitalWrite(LED_YEL, LOW); // wp arrival, turning to new course
    digitalWrite(LED_GRN, LOW); // Cone det
    digitalWrite(LED_BLU, LOW); // Cone det
    // end LED test
    } // end setup
    LCD_setCursor(0,0);
    Serial1.print("shutDownPinRC: ");
    LCD_setCursor(1,0);
    Serial1.print(digitalRead(shutDownPinRC));
    LCD_setCursor(2,0);
    Serial1.print(shutDownPinRC);
    if (debug == 1) {
    Serial.print("shutDownPinRC: ");
    Serial.println(digitalRead(shutDownPinRC));
    delay(100); // debug only
    void LCD_clear() {
    // Send reset command - this forces the cursor to the beginning of the display
    // LCD_clear();
    Serial1.write('|'); // Send setting character
    Serial1.write('-'); // Send clear display character
    void LCD_setCursor(int lineNum, int charNum) {
    // Jump cursor to line, position
    // LCD_setCursor(3,19);
    Serial1.write(254); // Send command character
    Serial1.write(128 + lineNumMap[lineNum] + charNum); // 0, 64, 20, 84, 0-19
    LCD_clear();
    Apr 2019
    15
    pin 35 same, pin 6 same.
    hm...
    Apr 2019
    15
    for a sec I thot I'd found my answer....
    https://www.pjrc.com/teensy/td_digital.html
    but this errors out and won't compile. Doesn't like this at all:
    PIN_A5, etc.
    I can use outputs just like an Arduino, no prob, so what's up with inputs?
    9,767
    Until a Teensy digital pinMode() is set - it is not ready for use:
    This is needed in:
    setup() {
       pinMode ( shutDownPinRC, INPUT );
    Maybe not made clear enough on that linked page - but it is shown here:
    A Complete Example
    This simple example blinks the LED slowly when the pushbutton is not pressed, and blinks rapidly when it is pressed. The pushbutton is connected to the D7 pin and ground, and the pullup resistor is used to make the pin high when the button is not connecting it to ground.
      pinMode(PIN_D6, OUTPUT);       // LED
      pinMode(PIN_D7, INPUT_PULLUP); // Pushbutton
    Apr 2019
    15
    This is needed in:
    setup() {
    A Complete Example
    ok, I found what works is a slight variation of that:
    pinmode(shutDownPinRC, INPUT);
    the PIN_D7, etc., syntax errors out during compilation. I'm using tduino 1.46 and arduino 1.89, targeting T3.6.
    interestingly, if I attached shutDownPinRC to an INT it reads the pin fine without the pinmode declaration. I found I didn't want an INT on that, hence all the problems. =)
    Also I found that INPUT_PULLUP doesn't work, tried it on a couple of other pins reading switches that ground on closure. I hear the pullup is 25 ohms, but those pins always read zero even when switches were open. External 2.2 k pullups worked on those.
    so I've learned a couple of key diffs between Teensy and Arduino for GPIO. You MUST declare input mode (unless it's used as INT), and pullups don't work.
    Apr 2019
    15
    trying to use the updated i2c_t3 library instead of Arduino wire.h, so far not much luck:
    Arduino: 1.8.9 (Linux), TD: 1.46, Board: "Teensy 3.6, Serial, 180 MHz, Faster, US English"
    /tmp/arduino_build_957573/libraries/Wire/WireKinetis.cpp.o: In function `i2c0_isr':
    /home/ralph/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/WireKinetis.cpp:895: multiple definition of `i2c0_isr'
    /tmp/arduino_build_957573/libraries/i2c_t3/i2c_t3.cpp.o:/home/ralph/arduino-1.8.9/hardware/teensy/avr/libraries/i2c_t3/i2c_t3.cpp:1134: first defined here
    /home/ralph/arduino-1.8.9/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Disabling relaxation: it will not work with multiple definitions
    /tmp/arduino_build_957573/libraries/Wire/WireKinetis.cpp.o: In function `Print::availableForWrite()':
    /home/ralph/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/WireKinetis.h:132: multiple definition of `i2c1_isr'
    /tmp/arduino_build_957573/libraries/i2c_t3/i2c_t3.cpp.o:/home/ralph/arduino-1.8.9/hardware/teensy/avr/cores/teensy3/Print.h:61: first defined here
    /home/ralph/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/WireKinetis.h:132: multiple definition of `i2c2_isr'
    /home/ralph/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/WireKinetis.h:132: multiple definition of `Wire2'
    /home/ralph/arduino-1.8.9/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Warning: size of symbol `Wire2' changed from 20 in /tmp/arduino_build_957573/libraries/i2c_t3/i2c_t3.cpp.o to 108 in /tmp/arduino_build_957573/libraries/Wire/WireKinetis.cpp.o
    /home/ralph/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/WireKinetis.h:132: multiple definition of `Wire1'
    /home/ralph/arduino-1.8.9/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Warning: size of symbol `Wire1' changed from 20 in /tmp/arduino_build_957573/libraries/i2c_t3/i2c_t3.cpp.o to 108 in /tmp/arduino_build_957573/libraries/Wire/WireKinetis.cpp.o
    /home/ralph/arduino-1.8.9/hardware/teensy/avr/libraries/Wire/WireKinetis.h:132: multiple definition of `Wire'
    /home/ralph/arduino-1.8.9/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Warning: size of symbol `Wire' changed from 20 in /tmp/arduino_build_957573/libraries/i2c_t3/i2c_t3.cpp.o to 108 in /tmp/arduino_build_957573/libraries/Wire/WireKinetis.cpp.o
    collect2: error: ld returned 1 exit status
    Error compiling for board Teensy 3.6.
    verbose option showed:
    Using library i2c_t3 in folder: /home/ralph/arduino-1.8.9/hardware/teensy/avr/libraries/i2c_t3 (legacy)
    Using library VL53L1X at version 1.0.1 in folder: /home/ralph/code/libraries/VL53L1X
    Using library Wire at version 1.0 in folder: /home/ralph/arduino-1.8.9/hardware/teensy/avr/libraries/Wire
    not sure why Wire is being used, not in the code as far as I can tell:
    for Teensy 3.6
    This example takes range measurements with the VL53L1X and displays additional
    details (status and signal/ambient rates) for each measurement, which can help
    you determine whether the sensor is operating normally and the reported range is
    valid. The range is in units of mm, and the rates are in units of MCPS (mega
    counts per second).
    //#include <Wire.h> // Arduino Wire Library
    #include <i2c_t3.h> // Teensy I2C lib at https://github.com/nox771/i2c_t3
    //default pin setting SCL/SDA:
    //- Wire: 19/18
    //- Wire1: 37/38 (3.5/3.6)
    //- Wire2: 3/4 (3.5/3.6)
    //- Wire3: 57/56 (3.6)
    #include <VL53L1X.h>
    VL53L1X sensor;
    delay(250);
    Wire2.begin();
    Wire2.setClock(400000); // use 400 kHz I2C
    sensor.setTimeout(500);
    if (!sensor.init())
    Serial.println("Failed to detect and initialize sensor!");
    while (1);
    // Use long distance mode and allow up to 50000 us (50 ms) for a measurement.
    // You can change these settings to adjust the performance of the sensor, but
    // the minimum timing budget is 20 ms for short distance mode and 33 ms for
    // medium and long distance modes. See the VL53L1X datasheet for more
    // information on range and timing limits.
    sensor.setDistanceMode(VL53L1X::Long);
    sensor.setMeasurementTimingBudget(50000);
    // Start continuous readings at a rate of one measurement every 50 ms (the
    // inter-measurement period). This period should be at least as long as the
    // timing budget.
    sensor.startContinuous(50);
    sensor.read();
    Serial.print("range: ");
    Serial.print(sensor.ranging_data.range_mm);
    Serial.print("\tstatus: ");
    Serial.print(VL53L1X::rangeStatusToString(sensor.r anging_data.range_status));
    Serial.print("\tpeak signal: ");
    Serial.print(sensor.ranging_data.peak_signal_count _rate_MCPS);
    Serial.print("\tambient: ");
    Serial.print(sensor.ranging_data.ambient_count_rat e_MCPS);
    Apr 2019
    15
    the Basic Master example compiles fine, even when I change the port:
    Wire2.begin(I2C_MASTER, 0x00, I2C_PINS_3_4, I2C_PULLUP_EXT, 400000);
    must be something to do with the VL53L1X library, I guess, that causing the conflict.
    5,430
    Both the Wire library as well as i2c_t3 library define and use a bunch of the same resources. As such any one sketch can use one or the other but not both. This includes any libraries that is included in your sketch (or libraries that other libraries include).
    So if you are going to use i2c_t3, you need to go through all of the libraries you are using and change them to use i2c_t3 instead. You may want to then rename that library as to not conflict with use wire instead for other projects, that use that library.
    Also note, that i2c_t3 is not a direct replacement for Wire library. They are mostly compatible, but they both handle the ability to use alternate pins for SCL and SDA. And likewise probably some other differences as well.
    Kurt
    Apr 2019
    15
    Interrupts: near as I can tell this doesn't work, actually hangs the T3.6 when I call cli();
    "The simplest and most common approach is to simply disable the global interrupt setting with cli() and reenable with with sei()."
    cli();
    // setup pin for RC controller deadman switch
    pinMode(shutDownPinRC, INPUT);
    attachInterrupt(digitalPinToInterrupt(shutDownPinR C), readDeadman, FALLING);
    Apr 2019
    15
    Also anyone have any experience with the Teensy and the Adafruit TCA9548A 1-to-8 I2C Multiplexer Breakout?
    they don't seem to be compatible at all, but it works fine with Arduino.
    Feb 2014
    Colmar, France
    2,535
    Each I2C bus can communicate with more than 100 devices as per specifications. All Teensy 3.x have at least 2 I2C busses, so, one might connect up to 200+ devices. Where is the need for a multiplexer?
    Apr 2019
    15
    well, I have some VL53L1X Lidar rangefinders that all have the same I2C address. =)
    also the Teensy I2C library has been a bit problematic so far, but I haven't spent much time on it trying to work around the library issues with sensors, etc., so I only can get one I2C port up and running.
    I'll have more time to debug this maybe in a week or two, that should help.
    20,591
    Quote Originally Posted by ralphhipps View Post
    On this forum, we ask that you show a complete program. Complete means anyone can copy it into Arduino and upload it to the same board you're using, to recreate the problem.
    I know this is extra work for you. But it is worth your time to do this. We are very good at helping here when you show a complete program. Sometimes we figure out what's wrong without complete info, but even when we do, it takes a lot more time for everyone to guess the missing details.
    I can tell you, cli() and sei() do work on Teensy 3.6. However, using these in the wrong way can cause your program to stall. Teensy 3.6 is different hardware than Arduino Uno, so techniques that are correct for one aren't necessarily proper for the other. Details matter. That's why we have the "forum rule" at the top of every page. Please, do yourself a favor and save everyone's valuable time by showing a complete program. We can help you much better that way.
    Apr 2019
    15
    Understood, and I can see how it would be tough to debug without context. It's good to know they do work.
    I have removed the code for cli & sei from my project, but the above was basically the meat of it.
    to get things working again I just removed the cli & sei lines.
    based on debug serial statements the execution stopped at cli();
    I'll dig around further on the forum and see if I can figure out what I'm doing wrong.
