Hey,
I am using a T3.5. I am having an endstop which will pull the reset pin low to reset the teensy. Why? I use this as a last endstop for safety reasons. So in normal mode the endstop will never be reached. If for some reasons the endstop is reached and the system is reseted I am reading register RCM_SRS0 for reset reasons. After resetting the teensy with the resetpin the register shows that it has been reseted due to an external pin. So good so far.
But when I use the onboard pushbutton, the register show the same. In https://www.pjrc.com/teensy/troubleshoot.html it is written that the pushbutton will not reset the teensy rather reprogramming the teensy. Am I missing something?
