Results 1 to 3 of 3
Thread: how can i get the value from sine1 at any time?
    Oct 2017
    Ukraine
    33
    Hello! I know how to create an audio object, for example
    AudioSynthWaveformSine sine1;
    //AudioOutputAnalog dac1;
    //AudioConnection patchCord1(sine1, dac1);
    AudioMemory(10);
    sine1.frequency(100);
    sine1.phase(0);
    sine1.amplitude(1.0);
    I do not want to use the design
    I want to use
    analogWrite(A14,value);
    Feb 2014
    Colmar, France
    2,442
    The audio library is designed to always create 128 samples in one batch which are written into a buffer. The AudioAnalogOutput object is the DAC on A14 which gets fed a value from that buffer in regular intervals via DMA, triggered by the PDB to output 44117 samples per second.
    It makes absolutely no sense to use analogwrite instead, timing will not be precise (and you‘ll get a lot of phase jitter) and the sine object will not be aware of the amount of data consumed from the buffer, so it won‘t know when to start generating the next batch of 128 samples.
    Oct 2017
    Ukraine
    33
    @ Theremingenieur ! Thanks for your reply. He upset me.
